Topic: [Not My Release] ELPlaylist (Read 536800 times) previous topic - next topic
Reply #700
It's not possible, sorry man.
Reply #701
Hi!
I asked this in another thread but I think this is the right place to ask:
I want to make a EL playlist that looks like a the default library view! No Cover art, no fancy fonts etc. Just a line with the album title, then in brackets the album artist and then on double click the track number and the title of the song. But I want the look of the default library view with the "crosses" and the "lines" (the tree view I mean).Can anyone please make a script for this?
Thank you very much for your time!
Reply #702
Don't know if it's really what you're looking for, but I made one that looks exactly like the columns ui playlist:
I can hook you up of you want it.
Reply #703
unclean , it is very close to what I am looking for! Please upload the configuration file.
A 1000 thanks!!
Reply #704
I'm stucked on a subgroups configuration problem. I followed Falstaff's fine tutorial to create subgroups and managed to do what I couldn't do with NGPlaylist or ESPlaylist, but now my lack of coding skills is showing.
What I'm trying to achieve is displaying subgroups when an album has more than 1 disc and/or 1 side. Why the "side" thing? Because most of the music I listen to goes back to the vinyl time and I like to recreate virtual LPs/EPs/Singles. So I wish to display:
Multidisc CD
++Disc 1
--------track 01
--------track 02 etc.
++Disc 2
--------track 01
"Virtual" vinyl album
++A-side
--------track 01
++B-side
--------track 01
Multidisc "Virtual" vinyl album
++Disc 1 A-side
--------track 01
++Disc 1 B-side
--------track 01
++Disc 2 C-Side
--------track 01
++Disc 2 D-Side
--------track 01
Obviously, I don't want subgroups for single CDs or one-sided vinyls.
Subgrouping by discs or sides is easy: I just have to copy Falstaff's code and use either %totaldiscs% or %totalsides%:
%album artist% | $if(%album%,$ifgreater(%totaldiscs%,1,%album%|||%discnumber%,%album%),%album%)
But is it possible to have and/or subgroups?
Reply #705
Need some scripts
- to align item on left or right
- to show lenght like this --> "- time elapsed/lenght" (I already tried this "[%_time_elapsed% /] %_length%" but doesn't work)
thanks anyway
Reply #706
it doesn't work? what a surprise..... instead of making things up, why not read the help file?
Reply #707
Do you mean this? http://www.hydrogenaudio.org/forums/index....showtopic=62133
I've read it, but can't find it usefull for what i need...probably i've not so much foobar skills to understand that readme, and also the translation is so bad.
So if you want to help me, thanks...we aren't all foobar guru here.
Reply #708
forget ELplaylist for just a moment. i was talking about the playback time / length stuff which is standard foobar foobar title formatting. try looking under the help menu. don't even bother trying this component if you don't understand the basics....
Reply #709
I know time playback and length are standard in foobar configuration, but i've tried this
in ngplaylist and it works good, but doesn't work in elplaylist...don't know why
Reply #710
where in the help file is %_time_elapsed% ? you won't find it because it isn't there.
try again....
Reply #711
Boh can't find what i need in the help, thanks marc you have been very useful, next time if you don't want to help directly, just don't reply.
Reply #712
As you mentioned that you are aware that this is standard foobar config stuff:
Open Foobar
Click Help
Click TitleFormatting help
or for more extensive titleformat information there is the wiki.
terry
Reply #713
Just tried these from the help
%playback_time_seconds%
%playback_time%
%playback_time_remaining_seconds%
but no one work, i only got a "?"
only %length% works, but i need to add time left or time elapsed...
Reply #714
playback remaining works only in "per second" tab.
maybe that will help...
Reply #715
i'm not really sure how more direct i can be. everything you asked is covered in the help file. if you had read it, you wouldn't be asking such dumb **** questions.
Reply #716
relax and take it easy
as u can read in the post before, the syntax in the help doesn't work
Reply #717
Take a look at the code in the default elplaylist code that comes with the plug-in. This has an example of what you want or something close.
Reply #718
you're doing it wrong. of course it works.
as mentioned above, dynamic fields need to go in the "per second" tab. as well as being able to read, a little common sense goes a long way too.
Reply #719
Thanks, finally i got playback time remaining, but now i need to remove length time when a track is playing
http://www.pctunerup.com/up/results/_20100...717_Cattura.JPG
if this can help, im trying to edit this layout
http://www.hydrogenaudio.org/forums/index....showtopic=79947
Reply #720
oh gosh! you really expect us to learn you how to read helps?
no, no, marc please, be quit, ne laches pas les chiens, je m'en occupe!  (joke)
so nick, to put you on the right way try:
if el is playing = draw nothing, if not, draw length...
and for the start:
$if(%el_isplaying%,,$drawtext(.....))
Reply #721
and for the start:
this is arab for me
ok i give up, thanks anyway
Reply #722
this is arab for me
you are right, my bad
"oh my god!, do you really expect us to teach you how to read help?"
does that sound better for you?
joke apart, don't give up, you are near, just a little bit closed for doing it yourself. Open your eyes, in the few posts above, you have all the help you need.
in your config, in track display tab, find the syntax that display/draw %length%
then replace
$drawtext(%length%,x,y,etc,,)
with
$if(%el_isplaying%,,$drawtext(%length%,x,y,etc,,))
or with
$if($not(%el_isplaying%),$drawtext(%length%
,x,y,etc,,),)
if that doesn't help... I will give up
Reply #723
really thanks kabuki, it works really good now...thanks again
Reply #724
Thanks for this component! Would it be possible to add a "Browse Library" option like EsPlaylist has? Basically I want to use one ElPlaylist as the Library Filter from PanelsUI.
