Topic: [crashware] foo_uie_lyrics2 (Read 484619 times) previous topic - next topic
Reply #425
I cannot get this component to save to the <UNSYNCED LYRICS> field aka the USLT frame. I have configured the plugin to save unsynched lyrics to the "UNSYNCED LYRICS" field however it's always saved in the <UNSYNCEDLYRICS> field. As a result when I sync with foo_dop the lyrics don't appear on my ipod because they are in the wrong field. How do I fix this?
What file types are you using?  I can get it to work fine with FLAC and MP3, but if I recall correctly the MP4 (Apple) files ended up not showing up on my iPod because fb2k maps to a different frame....
I have this component setup to send unsynced to UNSYNCED LYRICS and it works fine for me all the way through to the iPod with foo_dop.  Double check your settings.
I am using only mp3 files. This is the problem I'm getting right now:
And these are the settings responsible:
I don't think there is anything wrong with my settings for the component, should I be looking elsewhere?
EDIT: It also seems that if I make the field to save the tags to save in "UNSYNCED  LYRICS" (two spaces) it saves it in the proper field, it seems that when there is one space it is just ignored.
Reply #426
Those settings are exactly what I have....but mine works correctly.  The only difference I can see is that I have UNSYNCED LYRICS setup as a standard field in "Advanced > Display > Properties Dialog > Standard Fields", but I can't imagine this would make any difference.  Strange....
Reply #427
I uninstalled the component and reinstalled it and that has seemed to fix the issue. Very strange indeed...
Also, since you use this component with foo_dop I was wondering if you have managed to find a way to make the plugin download unsynced lyrics even if the track has synched lyrics so there will always be something to see on my ipod?
Reply #428
In the "Online Search" window, there is a column called LRC.  If it says "Yes" it puts it in the synced field; if it says "No" it puts it in unsynced.  If I download one of each, it fills in both tag fields.....
Reply #429
But there is no way to automate the downloading of both right?
Reply #430
Not that I can see
Reply #431
Is there any way to display *.nfo files insteed of lyrics whit this plugin?
Reply #432
well, so much for that. just had a crash on 0.4.6.9.
longshot, but i'm thinking maybe the lyrics2 plugin was reacting badly to either the old 2.3.1.2 version of foo_audioscrobbler.dll (official from last.fm) or foo_popupplus.dll...so for now i've taken out those to plugins on both of my foobar configs.  for now I switched to florian's foo_audioscrobbler.dll v1.4.6 and will live without popupplus, i guess.
i also had two instances of the lyrics2 panel in my config, so i went back down to just 1.
hopefully that will get me by fairly crash free until the new version.
anyone else have updates on which version maybe the most crash free.
also, would be curious if others seeing the crashes might have the above plug-ins running.
I've had good luck with 0.4.6.8 so far.  (I also had crashes in x.12 and x.9 before trying x.8)
Reply #433
hello i'm new in foobar and this plugin is really great. but ihave a few problems...
some songs have wrong lyrics shown and i start an online search and find the suitable lyrics. But when i replay the song it shows the older lyrics (wrong one). I also tried hitting "save to tag" and "save" buttons but they didnot work. I'm using Windows 7 x64.
Do i have a chance to save the lyrics that i find with online search?
Reply #434
Completely rewritten version due March if Michael hasn't been busy elsewhere, which hopefully will be more stable since he's written it as opposed to stepping in working out how to fix bugs in someone else's code.  Maybe just be patient and see what new ver brings...
But my onine search has option to save , so check file . preferences , lyrics and make sure your saving to correct directory
Reply #435
I found a problem - when an artist's or song's name has special letters (like band Mötley Crüe) this plugin can't find the lyrics
Reply #436
In the "Online Search" tab, under "Titleformatting for online search", use $ascii(...) around your strings.
Reply #437
My sincere apology if this has been covered (I did a cursory search), but foo_uie_lyrics2 does not seem to successfully search when I have the artist tagged as "lastname, firstname."  Any previous post or recommendations on how to handle this?
Was that a 1 or a 0?
Reply #438
Manually change it to First Last.  You should only have "Last, First" in a Sort tag anyway (artistsort).
Reply #439
i also have an option to save. But when i listen the song any other time, same wrong lyrics appear. When i hit the "next lyrics" button the right one appear.
Reply #440
Check the incorrect lyrics file isn't saved on your  HDD
Reply #441
When will the new version of this plugin be released ?
Reply #442
Well he saild  ~4 weeks which is up next week , but he could have hit issues - so all we can do Is wait, personally I'd rather wait for a stable issue that Michael is happy with than a rushed release with known bugs  but I reverted from .12  to 4.6.10 and not getting crashes.
Reply #443
this component generates AppHang! foobar freeze and doesn't respond at all ... very annoying, but after emoving this component, all is fine, so ...
waiting for the new lyrics components, can't wait !
Reply #444
I try to write script that save lyrics in my define directory in this mode: directory same as file/lyrics (crate folder 'lyric' if not exist). It look like this: $replace(%path%,%filename_ext%,)\lyrics - but not work. Anyone can help my do this.
Sorry for my awful English.
Reply #445
try this:
$replace(%path%,%filename_ext%,'\lyrics')
Reply #448
Thanks for pointing that tag out.  My original tagging was done years ago - in process or creating Sort tags - very painful but of course its working.
Reply #449
Getting freezes here too, was hoping another plugin was causing them but it's not the case =/. Will wait for the new version and until try .10 if i can find it.
If all you want to do is to save the lyrics downloaded by the plugin to a folder like "\SONGS_FOLDER\Lyrics\lyric_file.lrc", all you have to do is add "\Lyrics\" in front of the filename pattern, and check the radio button to save the lyric files in the same folder as the songs
