Topic: [Not My Release] ELPlaylist (Read 535602 times) previous topic - next topic
Reply #600
I'm not very familiar with EL Playlist, so I'm hoping someone can help me out. Is there any way to set up the grouping so that you can have subgroups for multiple discs that show up under a single group header? If that didn't make sense, here are some screenshots of what I want. The first one is my setup currently and the second one is something like what I want to do.
here is my tutorial, HTH
click to enlarge
Collapsed groups view :
Is possible to have this config? Is possible to upload it somewhere?
Reply #601
Is he maybe working on a DUI compatible version of ELPlaylist?  There's this new experimental component called EsPlaylist on his website now.
http://foo2k.chottu.net/
I tried it out and it is an alternative playlist view in DUI, but obviously no where near any form of usability.  But very exciting news for us DUI people perhaps!
Reply #602
interesting stuff. DUI screenshot:
and as it has column headers, it looks like it's going to be nice and easy to configure. i suppose it will be like NGPlaylist for DUI.
Reply #603
not supported on WindowsXP.... shoot no testing for me than but anxious to see other news
Reply #604
I hope it will use the internal foobar2000 artreader to display embedded album art as well (and doesn't have to be setup separately for displaying album art) once it leaves experimental state. At the moment it doesn't display any album art in my library (i only use embedded album art).
Reply #605
it must be using the internal artreader because it's showing my stub image for music without art.
Reply #606
Yup, same here .
Reply #607
Yes i know that its using the internal artreader. But embedded artwork - which is supported by the artreader - is currently ignored.
Reply #608
There's a new version of ElPlaylist too on the web site that says it supports foobar's core art reader - maybe you should try this.
Reply #609
Damned
The new ELPlaylist ignores embedded artwork, too!
Now its unusable for me...
Or is there any new setting hidden in this japanese readme to enable displaying embedded artwork?
Reply #610
edit: upon checking the readme, it seems this is new...
* NOTE *
      if you use artreader and artreader_*** options, you must pass %el_group_first_path% to "path".(since foobar2000 v1.0)
Reply #611
Its not new. I've already set it up since elplaylist 0.6.5...
Unfortunately elplaylist still ignores embedded artwork. That's bad (and i can't understand the reason, since the foobar2000 artreader still supports it).
I hope its only a bug that will be fixed soon or i can't update my configuration...
Reply #612
i've found a few more problems with this new release....
it doesn't use the stub image set in the display properties (even though ESPlaylist does)
it doesn't show album art for music that isn't in the library.
Reply #613
I'll stay with 0.6.6.4 for the moment and wait for the next release.
It looks that only artreader settings have changed (or better: messed up ) with the new release. Found no other changes so far.
Reply #614
Does anyone know the parameters for the $imageabs() function to display album art with the latest version? I'm guessing we don't need the path parameter anymore but no idea what to use to get it to work.
Reply #615
from the readme....
$imageabs(10,10,50,50,%el_group_first_path%,artreader_front)
just note the issues that have been mentioned above.
also, ESPlaylist 0.0.1 is up. looks a lot like graphical browser when albums are collapsed.
Reply #616
wow (!), might be some stroke of a genius. I think I like it... much
edit: available for EL_playlist sometime, too?
Reply #617
works for me on WinXp SP3
Reply #618
marc2003 - Thanks for the reply but I mean the latest version that uses the core API to read album art. I would have thought that we didn't need the path parameter since that would be dealt with in the core application.
Reply #619
@Senna : bug report
in this ELP config (see the screenshot below), a black horizontal line appear in a track area when i scroll down and if the height of the last track-line displayed is cut ... it seems that the cut of the bottom last track is not refresh on scrolling down, so, after the scrool, a black line is keeping displayed
Seven 64 bits
foobar 1.0
ELP 0.6.6.5b
PSS 0.3.8.2
can you check this and fix this bug please ? (i can send to you the .elp if you need it, PM me)
Thanx by advance
ignore, fixed ... it's because the wsh panel on bottom is overlaping the elp panel of 1 pixel, so, refresh is bad in this case in elp.
Reply #620
I REALLY hope the new EsPlaylist supports a "library mode" so that I can view my entire media library this way.  Album art in playlist is nice and all, but being able to browse through your albums in the library (as if it was a real music collection) would be amazing.
Reply #622
what are main differences from NG playlist ?
Reply #623
Just make an autoplaylist with everything in your library.
edit: In the new version you can right click in an empty area and select browse library
Anyway, shouldn't have ESplaylist have a new thread for itself? It's getting quite awesome now that you can edit the settings and everything. Quite useful for reporting problems as well, in the end this is the ELplaylist thread.
