Topic: [crashware] foo_uie_lyrics2 (Read 484567 times) previous topic - next topic
Reply #350
dont know if its my own problem..
in lyrics search tab, press new button in lyrics search filter or search patterns, enter name and value then click ok, the result will like pic2 below...
I cant add any new search filter or pattern, even modify default items, really cant figure out what is going on.
what I can do is reset or remove them.
another issue is, the lyric2 setting window cant appear when swith window from others to foobar2000, it's always be the bottom.
my os : windows xp sp3 traditional chinese big5
foobar2000 version: 1.0
thanks for the detailed report, will be fixed next release
Reply #351
~ Download lastest version ~
foo_uie_lyrics2_0.4.6.9
~ Report bugs here ~
http://code.google.com/p/foo-display-lyrics/issues/list
~ Changelog ~
0.4.6.9
- added support for internet radios / streams
- manual downloaded lyrics are now loaded immediately
- added "about current lyrics" info dialog
- fixed memory leak on dui window destruction
- fixed RAM cache not always getting used
- fixed list settings not working
- fixed config dialog not being on top
- added possible freeze workaround
the latest version appears to be very stable, no more freezes on track change so thank you very much for that.
i do seem to be having an issue disabling lyric association when downloaing lyrics, the lyrics continue to be shown despite me selecting this.
if i can provide anymore info please ask, i should be able to string more of a sentence together once iv woke up a little
thanks again
the latest version comes with some changes related to the lyrics cache - i have tried to reproduce the problem with it, and it worked for me.
so let's give it a try.
if the problem persists, please give me an example lyrics & music file name, maybe it is related to unicode chars/etc
Reply #352
~ Changelog ~
0.4.6.9
wow...so fast.
the lastest version works fine for me, thx !!
Reply #353
Hi!
I'm very glad to have discovered this awesome and useful plugin!
My question: Is it possible to not only have the lyrics files saved into the directory containing the audio file, but rather in a subdirectory within? For example, I'd like to have lyrics files stored into a subdirectory called "Lyrics" within the album directory:
...\Artist\Album\Lyrics\Songtitle.txt
In the settings under "Misc -> Use this file name pattern to save lyrics to files:" I have tried simply entering a backslash, but it doesn't seem to work here.
Is there a way?
I am using version 0.4.6.9
Reply #354
will be included next release
Reply #357
foo_uie_lyrics2_0.4.6.10
~ Changelog ~
0.4.6.10
- online stream song start position is no longer lost on a lyrics change
- added posibility to use folders in file name save pattern
you can now use this setting as desired
Reply #358
@Michael87 - Uh, when I was writing "sometimes" I mean "with some mp3, but always with them". But, of course, Foobar2000/mp3tag shows them correct. Changing aspect ratio adds only few pixels to cover border (hard to spot any difference), but image size still is wrong.
http://img694.imageshack.us/img694/4079/rhfjdjejddi.png
Reply #359
are you using DUI or CUI, with or without together with a panel stack plugin?
the problem is here that it does not know the correct window size , i will investigate
Reply #360
Tested under CUI with PSS, DUI on my normal install and DUI on clean install - always same result.
Reply #361
I get same thing on art , using CUI no PSS (Don't really care tho)  Michael - amazing work you really have/are making this a superb reliable plug-in.
Reply #362
i have finally located the problem for the image resize issue - fix will be included next release
Reply #364
a new day, a new version ^^
foo_uie_lyrics2_0.4.6.12
~ Changelog ~
0.4.6.12
- fixed saved lyrics not getting displayed first when loaded from cache  (this one keeps coming back x.X)
edit: still will only work after saving a 2nd time, i will investigate this tommorrow
Reply #365
i want it to display a fixed lyric when playing mms:// radio
so i added following script to the top of the search pattern
$if($stricmp($left(%_path_raw%,$sub($strstr(%_path_raw%,':'),1)),'mms'),mms.txt)
it failed to display mms.txt but other lyrics instead, any ideas?
Reply #366
leave out the file extension , it detects .lrc / .txt automatically
$if($stricmp($left(%_path_raw%,$sub($strstr(%_path_raw%,':'),1)),'mms'),mms)
Reply #367
it works, thx for the fast response
Reply #368
Thank you for the amazing work, it works well searching the lyrics for the online stream. I believe It's a great improvement.
Reply #369
+1. Thank you very much for this wonderful plugin.
P.S. Waiting for final stable release
🇺🇦 Glory to Ukraine!
Reply #370
I'm having problems getting lyrics for artists with special characters such as Röyksopp, but i can find the lyrics when i search for Royksopp. So could you let it search for the artist -with- special characters first, and if it fails search for the artist without special characters?
Reply #371
i like that idea, wil come with one of the next releases
Reply #372
Sorry if this has already been asked, but will this plugin support lyrics from internet radio stations (shoutcast stations) or is there a way of doing this already?
Reply #373
if you mean displaying lyrics for the songs - thats supported since 0.4.6.9, so just get 0.4.6.12 and enjoy :=)
if you mean streamed lyrics ( is that possible?) it should work depending on wheter foobar2000 supports this
Reply #374
Hi!First of all i wont to thank you for the great plugin.
I have a little problem with automatic searching of the lyrics.My entire music collection is in this format
artist/year, album/tracknumber.artist - title.wav
the problem is that all is in .wav. In the online search options of lyrics the filename is in titlebox
The question is.How can i get the ARTIST and TITLE from filename in that kind of format - tracknumber.artist - title.wav
