Topic: [crashware] foo_uie_lyrics2 (Read 484513 times) previous topic - next topic
Reply #325
I'm sorry that I can't give you more hints about the lyrics problem.
But no flickering anymore.
this one should fix the tag writing problem, make sure to enable "try to display synced lyrics first"
Many thanks for your efforts, Michael.
I have decided to use my brain (first time!) and download both kind of lyrics. With the different Tags there aren't the old problems of unsynced overwriting synced lyrics anymore - sorry that it took such a long time to understand this.
And it looks like the synced first option is working well.
Reply #326
Hi Michael! I noticed that you have gone through extra length to delete old downloads in Google Code downloads. I would humbly ask you to leave the old releases untouched because it would break links in other sites e.g.. http://code.google.com/p/foo-display-lyric...cs2_0.4.6.5.zip .
Anybody who goes to http://code.google.com/p/foo-display-lyrics/downloads/list would be able to access the latest release at the top of the list.
Thanks for keeping the program alive.
Reply #327
An update on a couple of issues I previously reported:
foobar2000 seems to be hanging quite a bit of late.  Not really sure whether this component is to blame.  No crash report, since it just hangs and as to be forcibly shut down.
I have a feeling this is something to do with foo_skip not playing well with foo_uie_lyrics2 on occasion.  At the moment I have foo_skip configured to skip any track which has something in either the LYRICS or the UNSYNCED LYRICS tags.  I happened to watch the behaviour a few times, and can see foobar2000 start to load up a track which already has a lyric (I have a column set to show a symbol if a lyric is present in the track), and quickly it skips to the next track.  This may happen a few times until it finds one without a lyric.  Occasionally, however, the playlist focus sticks on a track that DOES have a lyric, but the audio is playing a different track (perhaps the next track -- can't tell because I'm on Random).  At this point, foobar2000 has frozen up, and I have to restart it to get life back.
I wonder whether foo_uie_lyrics2 is attempting to load the track's lyric, and in the meantime foo_skip is trying to push on to the next track?  Or something?  Just a hunch.
Sometimes unsynced lyrics no longer save automatically to file; not sure why.  Sometimes they do, sometimes not.  I have "download and save" ticked, and save to tag, and fail: don't save.  If I right click and Save to Tag, it saves fine, so it's not a problem with actually writing to file.  And I don't have wave seekbar component active anymore.
This problem seems to have gone away after I ticked the option "Try to display synced lyrics first" -- is that a new option?  I don't recall seeing it before.  And, I don't really understand what it is for.  What do you mean by "display" here?  And "try"?  Why only "try"?
I can't really see why ticking this option should mean that unsynced lyrics are once again reliably written to tags.
Mike
Reply #328
It should be better:
If there's a song with no lyric, and the plugin download it automatically. The functions (open with External editor, open file location) should be enabled.
Reply #329
One more issue with version 0.4.6.7 - current line of synced lyrics is no longer highlighted with "highline color" that I've set in settings. Instead, placeholder text for tracks with no lyrics is displayed in highline color.
Update: Everything's OK. These were unsynced lyrics indeed that were not highlighted. The option "scroll unsynced lyrics" was unchecked previously, but it got checked again with the update to the new version, and I didn't notice that. Sorry for false bugreport.
Reply #330
THANK YOU FOR THE HARD WORK!
I have been testing this plug-in for several days and it runs well, there are several small issues to report:
1) It seems the online services——ailrc.com does not work;
2) Some lyrics can't match the songs;
3) The settings is somehow complex, it'll be nice if there is a guide.
Reply #331
well, any idea about disable the drag to change the offset, or scroll to change the offset?
Reply #332
I think I found a bug. If "Resume playback after restarting foobar2000" is enabled the and the file that was playing and the other files on the playlist are removed then after restarting the gui is unresponsive, cpu usage goes up to 100% and foobar tries to open the other files but not sequentially, often jumping back and forth between the playlist items. After a while foobar hangs completely, I have to kill its task.
First I thought it was a columnsUI problem, but then I disabled the external panels and the unresponsiveness and the freezing didn't happen. It came back when I enabled lyrics2.
Reply #333
thank you.  that was an excellent idea - i was not only able to fix this but using this method, but also to fix 3 big memory leaks
this settings requires a lot of work in the synced lyrics renderer, i will add it to the "sheduled" list, once i find the time i will add it
Reply #334
You're welcome. Althouugh it was more like an accident.  Deleted some files and fogot to update the playlist.
Reply #335
Another big step to stability.
No more memory leaks on track change.
More freeze-bug fixes.
Some requested upgrades.
Enjoy!
~ Download lastest version ~
foo_uie_lyrics2_0.4.6.8
~ Report bugs here ~
http://code.google.com/p/foo-display-lyrics/issues/list
~ Changelog ~
0.4.6.8
- fixed displaying lyrics on playback stop
- fixed download button stays disabled after online search
- reduced cpu-time for playback callback
- fixed crashbug on track change
- fixed 3 memory leaks related to track change
- fixed ailrc support
- added tag editing support for "Open with external editor" (will open foobar2000 file properties)
- codepage dialog now applies selected codepage to preview text when opened
- disabled lrcdb because webpage is down
- updated database implementations to support title-only searches
Reply #336
Is it not possible to go one step further, and actually open the lyric tag in the internal editor -- otherwise I might as well just do right-click > Properties on the track itself (which has the benefit of not requiring the track to be playing).
Mike
Edit: also this menu option does not work when after the lyric is first downloaded to the tag -- only works when you reload the track, or play a track with the lyric already pre-written.
Reply #337
Great component!
I'm surprised that many of my chinese and japanese songs are in the database~
Reply #338
question about the new feature:
- added option "use dui font/colors" to override font&color with dui settings
would it be feasible to split the two items such as the DUI settings, like:
- "use dui fonts"
- "use dui colors"
This would be useful for the case when you might want to have one lyrics2 element set set for normal viewing and another for large distance viewing (different size fonts), but you would still want your colors to match the rest of the foobar elements.
Anyways, just a thought.  I don't change my colors that much, so it's not too big of a deal to manually do it.
Reply #339
I'm getting an error where it finds the song, says "download successful" but the lyrics never show up.  Anyone else seeing this?
(I should note, this is doing it manually since I normally have auto-download turned off.  If auto-download is on it will auto-download and display something, but this obviously doesn't give me a choice to browse)
Reply #340
I find some online steam enable dynamic track title, is it possible to search the lyrics of the songs? It'll be amazing!
There is an example of the online stream:http://scfire-ntc-aa02.stream.aol.com/stream/1074
Reply #341
maybe this helps:
when clicking "download lyrics" the lyrics are saved to your configured download lyrics save location and then the lyrics are reloaded.
so if you have set "save to profile directory" but the music file also contains tag lyrics, it will still display the tag lyrics first (if you have set to load tag lyrics first).
however if your music files do not contain tag lyrics, this should not be the case, i will investigate.
a tip:
if you enable auto download, you can browse through the lyrics with right click -> "next lyrics", it loops through all found lyrics, including online search.
Reply #342
the latest version appears to be very stable, no more freezes on track change so thank you very much for that.
i do seem to be having an issue disabling lyric association when downloaing lyrics, the lyrics continue to be shown despite me selecting this.
if i can provide anymore info please ask, i should be able to string more of a sentence together once iv woke up a little
thanks again
Reply #343
I'm loving this plugin more and more. Your work is very much appreciated Michael.
Having read the above post, it would be useful to display, at the start of each song, the source of the lyrics ie. local, tag, cache or the online database name. It may make our understanding a little better and we could provide better feedback to you for debugging.
Reply #344
will be included next release (today!  )
Reply #346
Michael,
I'm using the latest release (0.4.6.8) but foobar keeps crashing randomly on track change. Probably some of the users refer to theses crashes as "freezes", but since you can't use foobar once it freezes (so you have to shut it down and restart it), I tend to think this is a crash. After I restart foobar it offers me to use the online troubleshooter and sometimes it makes a crash report and offers me to send it (which I do).
Somewhere in the crash report it says:
"Crash location:
Module: foo_uie_lyrics2
Offset: 76B4Ah
Symbol: "foobar2000_get_interface" (+7222Ah)"
I don't know why it sometimes offers the online troubleshooter, and sometimes makes a crash report.
I hope you can figure this out. Thanks
BR
Reply #347
thanks, the crashdumps are not yet available for me, but i'll wait for them & include the fix in the next release sheduled for today
Reply #348
Foobar still crashes for me somethimes on track change. Everything else is finde, but this is just annoying.
And again, no crash reports were created.
Reply #349
dont know if its my own problem..
in lyrics search tab, press new button in lyrics search filter or search patterns, enter name and value then click ok, the result will like pic2 below...
I cant add any new search filter or pattern, even modify default items, really cant figure out what is going on.
what I can do is reset or remove them.
another issue is, the lyric2 setting window cant appear when swith window from others to foobar2000, it's always be the bottom.
my os : windows xp sp3 traditional chinese big5
foobar2000 version: 1.0
