Topic: [crashware] foo_uie_lyrics2 (Read 484539 times) previous topic - next topic
Reply #300
Still there. Hitting "next" button and holding it and few seconds later a freeze of the UI (tho the music is playing). I'm aware that this might not be the most reasonable use-case but ...
that is not good :/
i've tried clicking "next" very fast & holding it very long, but it did not freeze for me.
is there anything else that triggers  it? this bug must be fixed asap
Reply #301
I don't think so. Any tip what to send you when it occur again? Some info copied from Process Explorer?
Reply #302
let's try the next version 0.4.6.6. it contains many internal changes to fix this problem
Reply #303
here it is, this is a major update, big internal changes
~ Download lastest version ~
foo_uie_lyrics2_0.4.6.6
~ Report bugs here ~
http://code.google.com/p/foo-display-lyrics/issues/list
~ Changelog ~
0.4.6.6
- added new setting "try to display synced lyrics first"
- fix for online lyrics sometimes not getting saved automatically
- possible fix for freezes on track change
- added option "use dui font/colors" to override font&color with dui settings
- now every instance has its own configuration and configuration is saved in dui/cui theme settings
**** WARNING: you will loose your configuration when upgrading to this version, due to new configuration system *******
I'm sorry that I can't give you more hints about the lyrics problem.
But no flickering anymore.
this one should fix the tag writing problem, make sure to enable "try to display synced lyrics first"
Please check for callback->is_edit_mode_enabled() in your WM_CONTEXTMENU handler, the LEM context menu is currently unavailable.
Also I hope the configuration (the part related to presentation) will be handled per-instance instead of the global configuration in Preferences, allowing it to be serialized into the monolith theme file for distribution, and that the defaults will be based on the current global color scheme (maybe access them using some new custom formatting function like $color(text)?).
  • all done  ;D
Reply #304
- Line padding config doesn't update "live" when setting is saved. It only takes effect on the next song.
- Online search causes fb2k to not respond when used
- When a file is loaded, the "assume encoding" setting doesn't take effect. If my settings were on "associate when found", the first time the song is loaded the "assume encoding" setting doesn't take effect, however from the second time onwards, it does.
Reply #306
No crashes for me in last few versions, everything runs smoothly.
Thanks for your effort, outstanding component.
Disregard the constabulary.
Reply #308
great idea, once it's fixed it will be very cool.
i've been messing with it on my test install and it def saves time rather than having to manually match all the colors.
Reply #309
I just installed the latest version 0.4.6.6 and have encountered problems with the proxy connections, so it seems. I am unable to connect to various lyrics databases. There are times when I can connect, but then I seem to lose the connection and I'm not sure if the problem is within the internal network on my end - or whether the proxy capabilities are unstable. I also can't manually search for lyrics. It would be useful if - in addition to "searching for lyric" message we have, it would also be useful if errors in connecting were reporting - instead of just "search failed" so that we can tweak our settings or report the problem more accurately.
Also - I tried using the "Use IE settings" feature - but still couldn't get a connection although IE works for me using the proxy settings in the browser settings. I also tried manually configuring - still no connection.
Is this problem common to others who use proxies? I'm trying to isolate the problem - any thoughts would be great!
And many thanks for developing this component. I think its great. I used to use lyrics grabber, but like the control we get here in terms of databases and better options for synced lyrics. Although I do miss the batch lyrics grabber feature (selecting lots of albums and run the finder for mass-tagging the lyrics fields, etc).
Reply #310
thanks for the error reports, due to huge changes, the 0.4.6.6 has some cirtical errors, sadly
however,
0.4.6.7
- fixed incorrect usage of dui font
- fixed freezing when using online search
- fixed padding changes not taking effect immediately
- changed codepage assumption for assicated lyrics files
will be released shortly
@osodeh:
did you already try increasing the timeout value?
if using a proxy i recommend a value of about 3000ms
Reply #311
Here it comes!!
Hopefully fixes all your reported bugs *crosses his fingers*.
With a bit luck we have now a rather stable version.
foo_uie_lyrics2_0.4.6.7
~ Changelog ~
0.4.6.7
Reply #312
New version seems to fix that error (fast switching to the next track) but hung for me while I was customizing the panel o_x
A suggestion - a "stop search" button in the Online Search dialogue would be great!
Reply #313
do you remember what setting you did customize? i will try to track it down.
yeah I agree, the Online Search needs an upgrade, I will add that together with the progess bar and the database upgrades in 0.4.7.x
edit:
ok, I've found something, will be included next version
Reply #314
Probably most of the settings?
But after fist customization I closed the dialog and then, after a while, opened it again and it just sit there for a while (foobar lost focus) and when I wanted to go back to foo2k I was unresponsive.
Reply #315
-When no song is being played, if you minimized foobar and open it again, the background of lyric panel changes.
-(I dont know if it's supposed to be this way) configuration is lost when you remove then add lyric panel back in dui mode.
-(I dont know if it's supposed to be this way) when you stop a song, the lyric remains.
-Can you make it possible to do online search without artist's name? This was possible in the old lyric panel but is changed in some version.
Reply #316
foobar2000 seems to be hanging quite a bit of late.  Not really sure whether this component is to blame.  No crash report, since it just hangs and as to be forcibly shut down.  I'll try removing this component for a bit and see if things improve.
Mike
Reply #317
a) -When no song is being played, if you minimized foobar and open it again, the background of lyric panel changes.
b) -(I dont know if it's supposed to be this way) when you stop a song, the lyric remains.
a) should be fine
b) will be fixed next release
as DUI is now handling the configuration that should be standard DUI behaviour
Mike
the latest version (0.4.6.7) should take care of most freeze reasons, the next release will cover some more & hopefully end them
thank you for your feedback
Reply #318
I've just finally tried this plugin and gotta say, it's pretty awesome!
I was wondering, any chance you could add this site to list of providers:
goo.ne.jp
http://music.goo.ne.jp/lyric/db.php
It's fantastic for Japanese lyrics
Here's what the search fields mean:
アーティスト名 - Artist
曲名 - Song name
The others are maybe not as useful, they stand for excerpt from lyrics, and songwriters
Thanks in advance!
Reply #319
I thought I was up to date.  Just installed latest version and seem to have lost at least some of my settings -- don't mind too much though ;-)  Will see how stability is now.
Mike
Reply #320
Just tested latest version 0.4.6.7. Tried to download a lyric but the download button is disabled.
- Right clicked on lyrics window.
- Online search
Search windows opens
- click search
- click on the lyric
The download button stays disabled
I can however download the chosen lyric by double clicking on the lyric. After downloading  the download button is suddenly enabled.
Just a small bug.
love this plugin!!
Reply #321
I save lyrics to the file, but I notice in the latest version the "Open File Location" context menu item is now active -- doesn't really make sense for this to be active.  Doesn't do anything when selected anyway.
Would be great for Open With External Editor to work on tag lyrics -- I know you've said you might be able to link this to the foobar2000 in-built tag editor.
Mike
Reply #322
Sometimes unsynced lyrics no longer save automatically to file; not sure why.  Sometimes they do, sometimes not.  I have "download and save" ticked, and save to tag, and fail: don't save.  If I right click and Save to Tag, it saves fine, so it's not a problem with actually writing to file.  And I don't have wave seekbar component active anymore.
Mike
Reply #323
-When you stop a song, the lyric remains visible.
-Download button stays disabled after online search.
-Vertical padding effects fading instead of font.
Reply #324
I found this component always find lyrics of janpanese songs in romaji instead of japanese characters, Obvious we prefer the latter
