Topic: [crashware] foo_uie_lyrics2 (Read 484519 times) previous topic - next topic
Reply #275
a temporary workaround would be setting "lyrics search " -> "local file search settings" from "do not save result" to "save to tag"
I installed 0.4.6.1 and synced lyrics are still not saved automatically to LYRICS, even not with this workaround.
Btw., with 0.4.6.1 text is permanently flickering.
Edit: I will try 0.4.6.2
Edit²: Still no downloading and permanently flickering
Reply #278
thanks for maintaining this component Michael87. I just have one question.
is there any way to set a higher priority for .lrc files over .txt files?
sometimes it downloads lyrics without timestamps, even though there are lyrics with timestamps available.
Reply #279
@Michael87
you did a great work with double click, nice solution
now i see another problem, with unsynced lyrics, when i click and move the cursor up/down the lyrics freeze and then get back moved (if scroll is turned on), when the scroll is turned off the lyrics simple don't move when i try to drag them.
one more time thx and good work!
Reply #281
I like the new ability to reset the offset.  I note that when you drag the lyric so that it is no longer "in time", it still highlights the lines, and the lyric still scrolls.  Though now of course the wrong lines are being highlighted.  I wonder whether it would be better if, when manually dragged from the current position in the track, lyric highlighting stops, and perhaps also lyric scrolling.  For me, if I drag the lyric manually, it's because I want to read/study the lyric somewhere else -- I don't want the lyric to continue scrolling (difficult to read), and I don't want any lines highlighted (cos they're the wrong lines!).  A quick double click would get you back to the correct position in the track, with highlighting and scrolling resumed.
Just an idea -- others may disagree with this behaviour !
Mike
Reply #282
I really like the ability to use album art as the background to this panel. Thank-you.
Does this use the new core album art handling functions? If so, could we have the ability to;
1) Select front, back, CD etc or
2) Sequence through these on some configurable timed basis
I've also noticed that sometimes, on change of track, the album art changes to a small picture in the top left corner. This is was during the same album so I know the folder.jpg file was the same size (600x600). (Would be nice if we could have the usual config. to allow image expansion with\without aspect ration preservation etc). The tracks do not contain any embedded images. I hope you can fix this because this panel is now almost perfect IMHO.
Thanks again.
Reply #283
I love the idea of using cover art as the background, but I would like it to be slightly more configurable as well... For example maybe the option to have it monochrome or a lighter or in a certain color, so that the lyrics show up clearly on top of it... I'd also like it to be able to set to "stretch to height" of the window, so it covers my whole lyrics panel!
I've also seen that one cover caused the background to turn black in some spots. I've uploaded the image, although I'm not sure what info it could contain...
http://imgur.com/vYPv3.jpg (it was called folder.jpg before imgur)
Here's a screenshot of how it looks:
Reply #284
Would be awesome to have Metal-Archives.com added to that source list since it has got lots of lyrics from metal bands (you can't find 'em anywhere else). Tho they don't have anything to support this, maybe you could contact them and see if there is a way to add it into your plug-in ?
Good work
Reply #285
Good work
darklyrics.com is even better IMHO, but good idea.
Disregard the constabulary.
Reply #286
I have a problem. While skipping quickly through the songs after a while the lyrics panel gets all white and after a second whole foobar2k windows becomes unresponsive.
Reply #287
i have changed something that could possibly fix this problem, it's included next release
Reply #288
Sionce a few versions, my foobar crashes randomly after a while. The song is still being played, but neither the window, nor the tray icon or the multimedia keys on my keyboard do anything.
Reply #289
@drfakeacc
if it crashes, please always send the crashdump to the online database.
so far there are none reported for the last 4 versions & i really do fix those
however, if your foobar does not crash but freeze, please report it here & write down the last clicks you did before it frooze
~ Download lastest version ~
foo_uie_lyrics2_0.4.6.4
~ Report bugs here ~
http://code.google.com/p/foo-display-lyrics/issues/list
~ Changelog ~
0.4.6.4
- fixed synced lyrics sometimes jumping back without reason
- optimized drawing of transparent background
- added IsRepaintNeeded() function concept by jano to optimize drawing
- fixed incorrect internal drawing (now only draws on system-invoked WM_PAINT messages) thanks goes to Yirkha and foosion
Reply #290
some more internal changes for even better performance and some upgrades for the cover art display.
i like the idea of swiching between cover art manual / by a timer, & will definitely include once i find the time.
also i like the proposed scrolling features and support for more databases, but that will need some time
my current plan is:
-> a stable 0.4.6.x version
-> a 0.4.7.x with the new database settings and support for around 5 more databases
-> a 0.4.8.x line with more features
foo_uie_lyrics2_0.4.6.5
~ Changelog ~
0.4.6.5
- added "keep aspect ratio" setting for cover art background image background
- cover art background image now alpha blends into background color
- fixed scrolling not possible if auto-scrolling is disabled
Reply #291
@drfakeacc
No crash report is created, and it doesn't seem to matter what I do. It crashed no matter what, if I'm playing games, browsing the internet, but it seems to occur on a track change, no matter if i switch the track by myself or just the next one is played. It does't occur to certain tracks, or if lyrics are displayed or not.
But I'll give 0.4.6.5 a try, maybe the problem solves itself.
Reply #292
~ Changelog ~
0.4.6.5
For my foobar 1.0, still it doesn't scroll the lyrics if auto-scrolling is disabled.
Anyway, thanks for keeping updating this plug-in.
Reply #293
are you using CUI or DUI?
be aware that DUI by default does not send the mousewheel info to the element, there is a setting in "General" called "Mouse wheel: scroll ..."
Reply #294
I'm sorry that I can't give you more hints about the lyrics problem.
But no flickering anymore.
good news, I'm pretty sure I have just fixed this problem, will be included in  0.4.6.6
Reply #295
Highline line in the synced lyrics are still scrolling by mouse independently of synced time.
Reply #296
Why does custom font not work in DUI?
🇺🇦 Glory to Ukraine!
Reply #297
umm, it does work xD  dui default fonts are currently not supported, but in the foo_uie_lyrics2 settings you can select any font you like
Reply #298
Sorry for confusing
resolved by restarting foobar2000
Reply #299
Thanks a lot, will try it
EDIT: Still there. Hitting "next" button and holding it and few seconds later a freeze of the UI (tho the music is playing). I'm aware that this might not be the most reasonable use-case but ...
