Topic: [crashware] foo_uie_lyrics2 (Read 484669 times) previous topic - next topic
Reply #250
@Michael87
When i click on the panel of lyrics2 and move the cursor up/down it makes the music lost him sync and i need to reload the lyric to get the sync back (move the mouse wheel make lyric lost him sync too)...i dont know if it's a bug or if you want it...but if you want it let an option to use it or not. You're doing a great work, really thx.
Reply #251
Hi Michael87,
My settings since T.P.Wang's previous component:
[a href="http://img521.imageshack.us/i/lyric2lrc.jpg/" target="_blank"]
okay, so this is what i have tried:
- set the same options as yours
1) played a file with no "LYRICS" or "UNSYNCED LYRICS" tag  -> synced lyrics was written to "LYRICS" tag
2) played a file with unsynced lyrics in "UNSYNCED LYRICS" tag -> synced lyrics was written to "LYRICS" tag, "UNSYNCED LYRICS" was not deleted/modified (this is current behaviour)
3) played a file with unsynced lyrics in "LYRICS" tag -> synced lyrics was written to "LYRICS" tag, replacing  unsynced lyrics
the song was  artist: "Avril Lavigne" title: "Nobody's Home" (maybe its related to that)
using version 0.4.6
so maybe its related to artist/title, could you give me an  example here please?
Reply #252
@Michael87
yes, that is how it is meant to be : mouse scrolling / draging adjusts the music sync offset.
if you dislike it, I'll add an option to disable it
Reply #253
Yeah. i love this plugin. and everything is working fine. thank you very much for this plugin!!!!!
Reply #254
thank you for your response Michael87.
im currently using br3tts Curacao 1.2 theme (which can be found at http://br3tt.online.fr/html/C/index.htm ) with a few minor mods & simply replaced the old lyrics panel with the new one, renaming the panel in the panel stack configuration so all the settings are the same.
i didnt have this problem in your previous versions, it only started in v0.4.5.9.
if i can provide anymore specific info please ask.
thank you for your time
Reply #255
Thx for your time.
I have tried it now with The Cure - Boys Don't Cry
Changing Tags by deleting and/or downloading them manually to test different  Tag situations in one session only take effect by restarting  foobar (fb2k 1.0 and lyrics2 0.4.6).
1) working.
2) not working. even with clicking next lyrics and/or changing "Try to load from this source first: Tag > Online Search"
3) not working - like 2)
I don't know why automatically download is not working with my config in case 2.
[a href="http://img515.imageshack.us/i/lyricsearch.jpg/" target="_blank"])
Reply #256
When I open the online search dialog it doesn't have focus. So I have to click with the mouse to "activate" the window and only after that the keyboard shortcuts are working. Can you change that?
Typo: Online search -> Save scheme and Fail to embed-> Save to the configruation folder.
Reply #257
After a track change, the lyrics panel shows only the album, artist, and title.  In order to get the lyrics to load, I have to right-click in the panel, click "Reload lyric" and "Next lyric" (in that order).  Once I do that, it works fine until the next track change.
Any ideas?
that's strange, I can't imagine the problem cause. could you please give me some example artist & title name, please? that would help me a lot
Thanks for the reply, Michael.
It happens throughout my library.  That's why I'm thinking it's a setting that I've missed somewhere along the line.
Here are two examples:
Also, the Pink Floyd file is an album image with an embedded cue sheet; the Anita Baker album is ripped to individual, tagged files - it seems to make no difference to the problem.
Reply #258
Can we have the best of both worlds: ability to drag up/down to see other parts of the lyric, but then an easy way to return the offset to normal (e.g. double click, or right-click option)?
Mike
Reply #259
1) working.
Btw. the panel is flickering when tags are updated by eg. Playback Statistics component
Edit: I have the same config as Jack (I still love it )
thanks for the perfect information
i think i see the problem now, after the first online search, the lyrics are stored in the local file cache (foobar config folder\lyrics).
because of that, the next time it tries to find lyrics it will treat them as "local file search" lyrics.
a temporary workaround would be setting "lyrics search " -> "local file search settings" from "do not save result" to "save to tag"
furthermore, after playing a track once, the result will also be stored in the RAM cache, causing it not to check wheter it should save the lyrics, until 50 different songs have been played (normally this should not be a big issue, as long as  one does not delete the lyrics right after it got saved )
Reply #260
- removed error message if tag writing fails
This is working well now, thanks -- even if there are conflicts, I don't get to know about them ;-)
Would be even better if there could be some logic to check for failure and to keep trying if so -- or a simple delay setting as you mentioned might be considered for a future version.
Mike
Reply #261
Sorry to bother you with this, but I'm really desperate to figure it out: how do I set Lyric Show 2 to save the lyrics it downloads after a pre-defined pattern (e.g. %tracknumber%. %title%)? I remember I've done this in an earlier version of foobar and Lyric Show, but I can't get it to work with foobar2000 v1.0 and latest Lyric Show 2. I even wonder if this is controlled from within Lyric Show 2 or it is a foobar setting.
Lyrics are now saved under the Artist - Title pattern. I prefer to have them otherwise, and I'd rather have them as separate files (not embedded). I'd appreciate, if anyone could help. Thanks.
Michael87, you're doing a great job keeping this plugin running.
Reply #262
I would imagine you add your titleformat string to the Lyric File Name text box under lyric show settings.
Someone else may be able to confirm.
terry
Reply #263
So I've got something you could add, because I'm way too lazy to use CUI and split etc etc etc.
The background as the album cover, as defined in the settings of CUI/DUI, or whatever.
I'm just too lazy to use panel stack splitter and such.
Good work you've done so far! I look forward to what else you put out for it.
Reply #264
Did anybody noticed that this component would be perfect for viewing .log and .nfo files? It just needs to recognize those extensions, changing them to .txt is cumbersome.
What you think michael?
Reply #265
good finding, this setting seems to got lost. I'll re-add it to the "Misc" settings tab
edit: you  can set this option currently only in the only search dialog, it will be saved globally.
next version will also have it in the normal configuration
Reply #266
Thanx Michael, you are the man
Reply #267
what could be hapenning here, is a connection timeout for the online search:
a) the lyrics panel queries the online databases, but the connection times out -> no search result
b) "no search result" is saved in the cache
c) pressing "reload lyrics" queries the online databases again, this time no connection timeout
-> try setting the timeout in "online search" settings to about 4000 ms
Reply #268
if you send me some example files, i will take a look at it
Reply #269
Michael,
Thanks for your greate work, the word wrapping bug was fixed so fast.
Another question, ailrc.com database could not be accessed by your plug-in since a few weeks ago. Would you like to investigate what's wrong with it?
Reply #270
It seems that "Open File Location" doesn't do anything. It could be cause I'm running Litestep though... but the foobar2000 "Open Containing Folder" command does work. Open with external editor works fine too.
Reply #271
I know there's no problem for Latin characters, but not for CJK characters.
+ I haven't checked, but previous component (by T.P.Wang) has wrapping problems with Cyrillic also: http://www.hydrogenaudio.org/forums/index....st&p=660507
Thanks for your reply.
I don't use Cyrillic words, and I don't know if there's any problem for languages other than English, Chinese & Japanese.
Fortunately, Michael carries on the task of developing the great plug-in. I think he will make it better than before.
Reply #272
here it is....! the text jerking should be gone now & some more things...
biggest change is: the plugin supports now background images by itself... no more dockable panels /etc required
btw, there are still no crash reports for 0.4.5.9 & 0.4.6 !:D
foo_uie_lyrics2_0.4.6.1
~ Report bugs here ~
http://code.google.com/p/foo-display-lyrics/issues/list
~ Changelog ~
0.4.6.1
- fixed text sometimes jerking to the top
- possible fix for online lyrics sometimes not getting saved automatically
- changed "Open folder" to be available more often
- added "reset offset" option into context menu, a double-click will also trigger this
- fixed typo (configruation)
- added option to set lyrics save filename
- moved "online search" button in context menu up
- fixed online search not having focus after creation
- new option: "background image" - display either cover art or a user select image
Reply #273
Thanks for the tip, Michael.
It wasn't a timeout issue, however.  When I went to change the connection setting as you recommended, I saw that the download options (on the same page) were not configured at all.  So I checked the "Download and save automatically" option, and that did the trick - it works fine now.  (I also set the timeout to 2500ms, just in case.)
I'm not sure why there was no download option selected, but that was the problem.
Thanks again for you assistance, and many thanks for keeping this component alive!
~esa
