Topic: [crashware] foo_uie_lyrics2 (Read 484668 times) previous topic - next topic
Reply #125
Enter "%_filename%" into "save format:" field in "Online Search".
Reply #126
Titleformatting for lyric search (Internet-Tab) does not work.
For example:
%artist% = "Paola E Chiara" finds lots of lyrics, "Paola & Chiara" not.
If %artist% = "Paola & Chiara" and I use titleformatting:
$if($strcmp(%artist%,Paola & Chiara),Paola E Chiara,$if2(%artist%,))
nothing happens.
Edit: Sorry, it does work! Had to restart foobar.
Reply #127
Thanks for your quick replay! It works perfect.
Reply #128
How do i go about adding lyricsshow2 to a columnsui panel or column of some sort?
Reply #129
Looking forward to "support for DUI" !
Mike
Reply #130
Basically...
1. Enable "Main menu > View > Layout > ? Live editing".
2. Click using the right mouse button on some part of your window - notice there is one or more sections, with a grey-ish heading saying something like "Vertical splitter", then some commands below.
3. Choose "Add panel > Panels > Lyric Show 2", the Lyrics panel it will be added to the layout.
4. Experiment with other options in the context menu when clicking elsewhere (...).
5. Disable "Main menu > View > Layout > Live editing" again.
This kind of changes can be also done in Preferences under the Display > Columns UI section.
Reply #131
Go to "File>Preferences>Columns UI", click the "Layout" tab. Right click on that separator where you want the lyric panel, and select "Insert panel>Panels>Lyric Show 2". Thats it.
Maybe this helps: my config
Reply #132
There are problem with foo_uie_lyrics2 0.4.5 and foobar 1.0: didn`t changes lyrics if playing ape\flac+cue file on next song, only with "Reload lyrics"
Reply #133
c++ errors here too...
please fix this annoying bug because i can't use this component
if it crashes every 20 to 60 minutes!
thank you
Reply #134
Thanks a ton Yirkha and yossirian
First time ever actually playing with the columns ui layout but im on my way now heh
Moderation: Merged two posts with fixed image.
Reply #135
I use the curacao interface, and I have reported the overlapping before, recently I have found it is the setting of the column cause the lyric-overlapping(I don't know if all the overlapping caused by this reason). I checked the column setting dialog-box, found there is "use transparency,opacity" in "miscellaneous" options of the "main" sub-dialog-box, the overlapping will be solved if we disable this option. I'm quite wondering why there is nobody point it out. And the lyric-show plug-in should be modified to avoid this error.
The image shows below:
1)Lyric overlapping
2)The setting dialog-box of column
Reply #136
C++ errors also, I'm afraid. Reverting back to using %lyrics% in item details, for the moment.
One thing I couldn't find was a way to disable skipping forward or back one track when pressing the '◄' or '►' on keyboard. For someone who uses those buttons for other things, it's annoying to keep ending a song halfway through. But it is a really good component, when working it is the best lyric display.
Reply #137
I like the original foo_uie_lyrics much more. I don't know what the author intends to do with the plugin, but I don't like what had already been done. "highline" doesn't work, saving lyrics file doesn't work, in addition to that when you manually search it downloads all the results even before you ask it (traffic) and keeps it somewhere (where?), most of the results are the same, what does L. M Y B. means??? sometimes the lyrics stops scrolling... I dont like, I want everything back, just more stable!
Suggestions:
1) Rollback all the changes and make the plugin F2000 1.0 compatible
2) Make something like simple editor, it's not necessary to say what for, I think every user of this plugin want it.
3) We shall make our own lyrics server, like wiki but with the ability to edit lyrics from foobar2000 and save it!
4) Only save UNsynced lyrics option is necessary
Reply #138
Why would I want to keep the unsynced lyrics. I like many others prefer the synced lyrics. If you don't like the changes don't use. BTW most of the changes were additions. And more sites are better in my opinion.
Moderation: Removed unnecessary full quote of the preceding post.
Reply #139
Why have highlined text in synced lyrics is scrolling, when I am draging text by mouse or scroll button? where can I turn off this?
Reply #140
One more thing. Foobar2000 without this plugin (=with the current foo_uie_lyrics2) is not Foobar2000. So, either Peter Pawlowski should stop making plugins incompatible or someone should make this plugin to work as it used to work (and even better)! =:{
Reply #141
foo_uie_lyrics ("Lyric Show Panel") by bluenet & T.P Wang is my favorite lyrics plugin for foobar.
Sadly it is marked "heavy crashware"  by the Online Trobleshooter, and is no longer under development.
I've decided to change that & pick up development.
Note that this component is the leading cause of crashes (among components with development presence in the forums) in foobar2000 v1.0 at the moment. I strongly suggest that the developer work on fixing bugs instead of adding features if he wishes to continue development of this component.
Reply #142
Michael87 haven't been here for a long time, and couldn't get up with the schedule. And I agree with Canar's idea too.
Reply #143
What's up with development of this component?  The download links in the original post appear to be broken.  Where to download?
Mike
Reply #144
Try again, I have fixed the links in the first post.
Reply #145
Is there any way to use the lyrics on upnp source? When I us the normal playback the the lyrics are displayed indicating that my setup is working. But when i use the upnp playback (with the upnp plugin) and the upnp controller then the lyrics are not displayed. when using UPNP then another playlist is used.
The artist info plugin is working with the upnp playback and the normal playback.
Reply #146
using this Plugin, my foobar2000 gets to a CPU-Usage of ~5%. Without this Plugin, foobar is constantly at ~0-1%.
Is there a way to minimize the CPU-Usage for this Plugin?
Or did an option exists to disable this plugin in a tab stack or similiar until i enable it?
I like this plugin very much, but the cost of ~5% CPU-Usage is too much for me.
Thanks in advance!
Reply #147
Very good component!  I have to say that it's pretty stable on my setup.  I have seen a crash once, but only once.
Would it be possible to have an option to suppress the dialog which pops up when the component attempts to write to the music file, but cannot?  I share my music folder with other users on my computer, giving them read-only access.  So when they play tracks from my collection with this component active (and set to write to music file), they get lots of popups saying the write attempt has failed (access denied).  Would be nice if you could have an option to suppress these warnings.
Hopefully development of this component will continue apace; seems a bit quiet recently though.
Mike
[Edit: to correct typo]
Reply #148
I went back to foo_uie_lyrics... it supposed to be "crashware", but never, not once crashed on me, quite the contrary to this one... o_x
Reply #149
I went back to foo_uie_lyrics from T.P Wang, too.
It only crashed for me, when i edited title formatting string during playback or enabled "transparent background".
foo_uie_lyrics2 crashes much more often simply on track change, without crash log.
But since i deleted it and went back to foo_uie_lyrics i never got these crashes again, so i'm sure it was the cause.
I strongly suggest the same as Canar: at first all present bugs should be fixed before adding new features.
