Topic: [crashware] foo_uie_lyrics2 (Read 484562 times) previous topic - next topic
Reply #75
Same here on Vista x86 SP2
Reply #76
Working fine here on Windows 7 64 bit.
Is there any chance to add the facility to display album art as background? I think this would make a nice looking display. IMHO
Reply #77
Dear component developer.
After a while of using foobar, I'm always getting this
Since this never happened before I started using foo_uie_lyrics2, it's most likely due to this component and I never had this problem with foo_uie_lyrics plugin.
I dunno if this is important, but I'm running windows 7 with the latest Versions of both Visual C++ Runtime 2005 and 2008 and Service Packs.
A crash report is not created, whyever.
It was happening here too recently. Wasn't sure if it was this plugins fault. But the fact thet it only happened when a new file was opened for playback and the lyrics were not shown for it makes it likely. Interestingly foobar continued working because I didn't click "ok" on the message, but I got another for every song thereafter.
Reply #78
Since this only happened to me when foobar was in the system tray, I had to press "OK", but foobar continues playing as well. But, well, this isn't very useful if you're unable to open foobar.
Reply #79
I cannot get this component to work for foobar2000.
I placed the dll in the components directory and restarted foobar, however no lyrics are displayed no matter what song I'm listening to. Also, I noted that the "Lyrics Show 2" is grayed out under the View menu.
Can anyone help? Thanks.
Reply #81
Same here, only with the latest versions (have never happen before with earlier versions). Win7 x64 en.
Reply #82
Seems like an unhandled exception in a worker thread or something.
Perhaps you could assist in tracking the bug down by providing similar info like I described [a href='index.php?act=findpost&pid=562464']here[/a].
Reply #83
I sent couple of crash reports, but here is also what Yirkha suggested:
Reply #84
When there is unsynced lyrics (or multiple lyrics) the lyric show panel hangs to first lyric, what i mean is when the next song starts the previous lyric is still there and i have to manually reload lyrics on the context menu. The old lyric show works fine. I'm using foobar2000 1.0 beta 5 and latest columns ui and foo_uie_lyrics2_0.4.5 on Windows 7 64bit.
Reply #85
One more minor problem with version 0.4.5. If I enable "Output verbose debugging information" option, the first line of plugin's output to the console becomes the last one, and not only for this plugin. No output from foobar2000 itself (like "Opening track for playback") or other plugins (like audioscrobbler) ever appears again until foobar2000 is restarted. If I uncheck this option, everything works fine. There were no such problem with the previous versions of the plugin.
Reply #86
Help please
I want a simplify way to use foo_uie_lyrics ("Lyric Show Panel"). I think my problem is very fundamental and this maybe a FAQ for other newbie like me in future as well.
1. how to make the component work??
- Prerequisite
> Foobar2000 (I used 0.9.6.1)
> download the plugin from the 1st post
> extract and place its in /components/ folder only the single dll file is enough
When I restart Foobar2000. Nothing change. no new lylic panel. I do not even know where I can turn it on or activate it. I check everything and found only the menu
View > Lyric Show 2 > [sub menu in disable color]
I can't do anything.
After I check the forum, somebody said I have to do something with Column UI.
2. Setup Column UI
Surprisingly, my Foobar2000 does not have Column UI in File > Preference section. Do I need to upgrade the latest version? please guide me some instruction.
I want the music player that can show me a Lyrics / dowmload a lyrics from internet automatically. Please help me T_T
Reply #89
Michael87, thanks for great plugin!
Can you add support for http://www.darklyrics.com/  in future? It's biggest metal lyrics archive.
On this site I have find lyrics scripts to interface with various lyrics sites. It's may be helpful.
Reply #90
Mine log from crash:
ntoskrnl.exe!SeAccessCheckWithHint+0xb4a
ntoskrnl.exe!KeAcquireSpinLockAtDpcLevel+0x682
ntoskrnl.exe!KeWaitForSingleObject+0x19f
ntoskrnl.exe!PsIsSystemProcess+0x68
ntoskrnl.exe!KeStackAttachProcess+0x11b9
ntoskrnl.exe!KeAcquireSpinLockAtDpcLevel+0x88d
ntoskrnl.exe!KeWaitForMultipleObjects+0x26b
ntoskrnl.exe!MmCreateSection+0xe23
ntoskrnl.exe!NtOpenResourceManager+0x59d
ntoskrnl.exe!KeSynchronizeExecution+0x3a43
wow64cpu.dll!TurboDispatchJumpAddressEnd+0x690
wow64cpu.dll!TurboDispatchJumpAddressEnd+0xe3
wow64.dll!Wow64SystemServiceEx+0x1ce
wow64.dll!Wow64LdrpInitialize+0x429
ntdll.dll!LdrGetProcedureAddress+0x24db7
ntdll.dll!LdrInitializeThunk+0xe
ntdll.dll!NtWaitForMultipleObjects+0x15
kernel32.dll!WaitForMultipleObjectsEx+0x8e
kernel32.dll!WaitForMultipleObjects+0x18
kernel32.dll!CheckForReadOnlyResource+0x175
kernel32.dll!CheckForReadOnlyResource+0x212
kernel32.dll!UnhandledExceptionFilter+0x163
kernel32.dll!UnhandledExceptionFilter+0xe0
ntdll.dll!RtlFreeAnsiString+0x6c
ntdll.dll!RtlDetermineDosPathNameType_U+0x206
Hope this is it/will help.
Reply #91
Hmm OK, so the message is shown just because foo_uie_vis_channel_spectrum is not happy that the process is abruptly terminated. I guess. Nothing to see there.
Reply #92
I'm not using foo_uie_vis_channel_spcectrum yet have same error
Reply #93
Columns UI is a third party plugin, not part of foobar2000 core. See here.
HTH.
Alessandro
Thank you mobyduck.
I download and copy the ColumnUI in Foobar2000 folder. Anyway, it seems I can't activate foo_uie_lyric 2 anyway. Could you please tell me how do I show the lyric (and automatically download from internet) in Foobar2000 please? I have no clue for now. T_T
Reply #94
You mean you placed foo_uie_columns into the components folder, correct?
terry
Reply #95
@Developor:
Running windows 7 64bit.
Latest foobar stable.
After a while, foobar just crashes due to this plugin. (I've removed it and it hasn't happened since).
If you need me to post a crash log please tell me, i've got about 4 of them just becuase of this.
Hope you fix it, thanks.
Reply #96
Thank you mobyduck.
Welcome.
First off, as Terry pointed out, make sure you put foo_ui_columns.dll in the component folder, NOT in Foobar2000 folder. Then goto Preferences (Ctrl/P), select CUI in the Display page and restart foobar. Form there you can start configuring your CUI layout, see here for more details.
HTH.
Alessandro
Reply #97
glad to see development is back on again, this weekend i replaced foo_uie_lyrics 0.3.3.9 with the new lyrics2 0.4.5.
just had my first foobar crash in 6-8+ months. i'm on windows 7 x64 and foobar 1.0b5.  the windows crash log points to foo_dockable_panels.dll (but it is very likely the crash was something between it and lyrics2).
i read the above posts on the crashes, i'll grab the procexp stack info if it happens again.
anyways, the most exciting thing is the planned support for DUI!  i am very excited indeed... as i would really love to get rid of dockable panels altogether.
Reply #98
I have some songs which do not have Artist
Can I manual search lyric by title only?
Reply #99
Working fine at fb2k 1.0 beta 5, Win 7 x86.
A feature request:
Do not show or search lyrics under some user-defined condition, such as $if(%artist%,show_and_search,do_nothing)
Since some tracks(vocal removal versions, pc game OST, Yanni concert ...) do not have lyrics
