Topic: [Not my release] foo_uie_panel_splitter (Read 411922 times) previous topic - next topic
Reply #300
$if($isvisible_c(<CAPTION OF YOUR SIDEBAR>),
$movepanel_c(<CAPTION OF YOUR PLAYLIST>,new x,new y,new w,new h),
$movepanel_c(<CAPTION OF YOUR PLAYLIST>,normal x,normal y,normal w,normal h))
Reply #301
Sebas with  something like:
$if($isvisible_c(sidebar)
        $imagebutton
        $movepanel_c(sidebar)
        $movepanel_c(PLaylist)
        $imagebutton
Reply #302
@tedgo and @qwertz, thanks for your replies. Both methods work very well.
Do you have any suggestion on how I could switch images with a button? If this would be possible I could switch colors in my theme.
Reply #303
you can do that with a dummy panel.
$if($isvisible_c(dummy),
$imageabs(...[picture1]),
$imageabs(...[picture2])
instead of imageabs you can also draw a rectangle if you want colors only ($drawrect())
maybe you could also use variables, but i haven't tried this:
$puts(imagepath,[picture1])
$puts(imagepath,[picture2])
$imageabs(...$get(imagepath))
Reply #304
Is there a way for making rating buttons in PSS? I tried a lot but no success and I don´t want to use Track Info Mod because I want a transparent background, which is to my information not possible there. Better use a WSH panel?
any recommendations?
Reply #305
Apparently not, I use WSH Mod. There is an expample code in the WSH Mod thread.
Reply #306
ah, ok. Does it support transparency? I´m not used to JSchript, so I use most things with only slightly modified templates.
Edit: Never mind just saw the "pseudo transparent" checkbox
Reply #307
some strange thing I experienced: when playing radio streams %artist% and %title% shows up different things than in Trackinfo_mod
in TIM correct artist/title of the track playing whereas in PSS it shows up always the radio station´s name for title and nothing for artist...
can anybody confirm this?
Reply #308
Not that strange
Write your strings for %artist% and %title% on the PerSecond tab for updated info
Reply #309
Not that strange
that makes sense.
Hmm, doesn´t work for me in the PerSecond section. I used:
$font(Calibri Bold Caps,34,bold)
$drawstring($if(%artist%,%artist%,-)....
Reply #310
Entries on PerSecond tab are only available during playback of course.
Reply #311
yes, but it doesn´t show up.
Reply #312
I tried with:
$font(Segoe UI,8,)
$drawtextex([%artist% - ]%title%, 10,10,%ps_width%,20,0-0-0,hcenter top)
and it works perfectly here...
Maybe you made an issue in your drawstring string?
Reply #313
I used:
$font(Calibri Bold Caps,31,bold)
$drawstring($if(%artist%,%artist%,-),0,$sub(%_height%,250),%_width%,100,255-255-255-255,hcenter aa)
I also tried drawtext, drawtextex. All of them work fine in the PerTrack Tab.
Just also tried your code, but nothing...
Reply #314
That's strange...
What version number do you use? I used 0.3.6.3a and it works like it should.
It displays the current artist and title when a track is playing, and nothing when no track plays.
Tried your string now and it works here too...
Reply #315
PSS: also 0.3.6.3.alpha
Foobar: 0.9.6.3
(doesn´t work on both Vista and XP)
really strange...
Edit: just updated to Foobar 0.9.6.4. Didn´t fix it...
Reply #316
Found what was wrong! In the Behaviour-Tab of the PSS "enable per second" was unchecked!
Now it works! I should have seen that, sorry. Thanks for your patience
Reply #317
@SSENNA :
REQUEST for PSS:
i've just realized that variables setted with $puts() are resetted after a REFRESH; executed by a $imagebutton()
it's a really bad limitation, i have no way to save a value even after a REFRESH; it's really a pity, i have a new skin project that i must stop due to this limitation.
is it really no possibility to have permanent variables in PSS ?
thanx by advance for precisions about this big lack...
Reply #318
@SSENNA :
other request that often restrict me ...
there is a limitation of 65535 characters maximum in a PSS panel ... this limis is to small, is it possible to remove this limitation or at least increase it at the maximum possible value PLEASE !!
Thanx by advance for a feedback SSENNA.
Reply #319
PLEASE, HELP ! PSS CRASHED, i can't restart foobar, it crashes when it starts
PSS is the making crashed foobar (0.9.6.5)
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 01D1BB20h
Access violation, operation: read, address: 00000000h
Call path:
entry=>user_interface::init=>titleformat_object::run
Code bytes (01D1BB20h):
01D1BAE0h:  8B 0E 50 51 E8 3D 62 00 00 85 C0 74 04 89 46 04
01D1BAF0h:  C3 33 C0 C3 CC CC CC CC CC CC CC CC CC CC CC CC
01D1BB00h:  8B 0E 50 51 E8 05 62 00 00 85 C0 74 04 89 46 04
01D1BB10h:  C3 33 C0 C3 CC CC CC CC CC CC CC CC CC CC CC CC
01D1BB20h:  8B 0E 50 51 E8 3D 61 00 00 85 C0 74 04 89 46 04
01D1BB30h:  C3 33 C0 C3 CC CC CC CC CC CC CC CC CC CC CC CC
01D1BB40h:  50 8B 44 24 0C 51 8B 4C 24 0C 52 8B 11 50 8B 06
01D1BB50h:  52 50 E8 F7 60 00 00 85 C0 74 06 89 46 04 C2 08
Stack (0012EEB8h):
0012EE98h:  8972D920 BF82DE1C 806E6D43 B68B4340
0012EEA8h:  806E6427 BADB0D00 00000000 00000001
0012EEB8h:  01D3047C 7BF0FB5E 00130490 00130414
0012EEC8h:  001303EC 045A84D0 001303E0 00130414
0012EED8h:  01D748E0 00000004 01D70748 01D70000
0012EEE8h:  96000000 0012EEDC 00000000 00000064
0012EEF8h:  01D4EEB4 04D1FA28 00000000 7C920202
0012EF08h:  0092017B 01D4E7A0 00000000 00000000
0012EF18h:  00000000 00000009 00000000 0012EF5C
0012EF28h:  00000000 00000000 000000BE 00000001
0012EF38h:  0000000F 7BF0FBFA 00000005 0012EFFC
0012EF48h:  01D486F4 FFFFFFFF 0012EFA0 01D3A150
0012EF58h:  01D74818 001E0428 00000005 00000000
0012EF68h:  009E017D 0012EFDC 00000005 001E0428
0012EF78h:  008060B8 001E0428 00000005 00000000
0012EF88h:  009E017D 01D3A150 0012EFC4 01D70000
0012EF98h:  7C920202 00000004 01D70748 01D70000
0012EFA8h:  0012EFDC 003E0000 7C920202 00000004
0012EFB8h:  003E0748 003E0000 045A8EA8 0012EFB4
0012EFC8h:  7C92017B 0012F1F8 7C91E900 7C920208
Registers:
EAX: 00000000, EBX: 0012EF34, ECX: 04D1FB44, EDX: 00000000
ESI: 00000000, EDI: 0012EF30, EBP: 00130380, ESP: 0012EEB8
Crash location:
Module: foo_uie_panel_splitter
Offset: BB20h
Loaded modules:
foobar2000                      loaded at 00400000h - 00596000h
ntdll                            loaded at 7C910000h - 7C9C6000h
kernel32                        loaded at 7C800000h - 7C906000h
COMCTL32                        loaded at 77390000h - 77493000h
msvcrt                          loaded at 77BE0000h - 77C38000h
ADVAPI32                        loaded at 77DA0000h - 77E4C000h
RPCRT4                          loaded at 77E50000h - 77EE2000h
Secur32                          loaded at 77FC0000h - 77FD1000h
GDI32                            loaded at 77EF0000h - 77F39000h
USER32                          loaded at 7E390000h - 7E421000h
SHLWAPI                          loaded at 77F40000h - 77FB6000h
DSOUND                          loaded at 73E60000h - 73EBC000h
ole32                            loaded at 774A0000h - 775DD000h
VERSION                          loaded at 77BD0000h - 77BD8000h
WINMM                            loaded at 76AE0000h - 76B0F000h
SHELL32                          loaded at 7C9D0000h - 7D1F5000h
shared                          loaded at 10000000h - 1002B000h
imagehlp                        loaded at 76C40000h - 76C68000h
UxTheme                          loaded at 5B090000h - 5B0C8000h
dbghelp                          loaded at 5D3F0000h - 5D491000h
COMDLG32                        loaded at 76340000h - 7638A000h
IMM32                            loaded at 76320000h - 7633D000h
LPK                              loaded at 62DC0000h - 62DC9000h
USP10                            loaded at 753C0000h - 7542B000h
MSCTF                            loaded at 74690000h - 746DC000h
WINTRUST                        loaded at 76BE0000h - 76C0E000h
CRYPT32                          loaded at 779E0000h - 77A77000h
MSASN1                          loaded at 77A80000h - 77A92000h
wdmaud                          loaded at 72C70000h - 72C79000h
msacm32                          loaded at 72C60000h - 72C68000h
MSACM32                          loaded at 77BB0000h - 77BC5000h
midimap                          loaded at 77BA0000h - 77BA7000h
apphelp                          loaded at 77B50000h - 77B72000h
msctfime                        loaded at 75140000h - 7516E000h
foo_albumlist                    loaded at 01190000h - 011EA000h
foo_utils                        loaded at 01210000h - 01254000h
foo_abx                          loaded at 01280000h - 012B2000h
foo_uie_vis_channel_spectrum    loaded at 012E0000h - 0131D000h
MSIMG32                          loaded at 76310000h - 76315000h
foo_dsp_std                      loaded at 01340000h - 01388000h
foo_masstag                      loaded at 013B0000h - 01400000h
foo_converter                    loaded at 01420000h - 0148D000h
foo_input_std                    loaded at 014B0000h - 015F0000h
foo_ui_columns                  loaded at 01610000h - 0174B000h
gdiplus                          loaded at 4EB80000h - 4ED26000h
foo_unpack                      loaded at 01780000h - 017AE000h
foo_menu_addons                  loaded at 017D0000h - 0180C000h
foo_freedb2                      loaded at 01830000h - 01871000h
foo_AdvancedControls            loaded at 018A0000h - 018E8000h
foo_uie_biography                loaded at 01900000h - 0197E000h
WS2_32                          loaded at 719F0000h - 71A07000h
WS2HELP                          loaded at 719E0000h - 719E8000h
foo_exvar                        loaded at 019E0000h - 01A08000h
foo_uie_wsh_panel_mod            loaded at 01B30000h - 01BAC000h
OLEAUT32                        loaded at 770E0000h - 7716B000h
foo_uie_panel_splitter          loaded at 01D10000h - 01D5F000h
foo_fileops                      loaded at 01D80000h - 01DC7000h
foo_uie_elplaylist              loaded at 01DF0000h - 01E59000h
foo_cdda                        loaded at 01E80000h - 01EC0000h
foo_rgscan                      loaded at 01EE0000h - 01F2E000h
foo_uie_lyrics                  loaded at 01F50000h - 01FAD000h
WININET                          loaded at 44080000h - 44150000h
Normaliz                        loaded at 01FC0000h - 01FC9000h
iertutil                        loaded at 43E00000h - 43E45000h
foo_vis_shpeck                  loaded at 021F0000h - 0222E000h
foo_ui_std                      loaded at 02250000h - 02359000h
Stack dump analysis:
Address: 01D3047Ch (foo_uie_panel_splitter+2047Ch)
Address: 01D4EEB4h (foo_uie_panel_splitter+3EEB4h)
Address: 7C920202h (ntdll+10202h), symbol: "RtlAllocateHeap" (+15Eh)
Address: 01D4E7A0h (foo_uie_panel_splitter+3E7A0h)
Address: 01D486F4h (foo_uie_panel_splitter+386F4h)
Address: 01D3A150h (foo_uie_panel_splitter+2A150h)
Address: 7C92017Bh (ntdll+1017Bh), symbol: "RtlAllocateHeap" (+D7h)
Address: 7C91E900h (ntdll+E900h), symbol: "strchr" (+113h)
Address: 7C920208h (ntdll+10208h), symbol: "RtlAllocateHeap" (+164h)
Address: 7C9201BBh (ntdll+101BBh), symbol: "RtlAllocateHeap" (+117h)
Address: 7C9200A4h (ntdll+100A4h), symbol: "RtlAllocateHeap" (+0h)
Address: 01D4E7C0h (foo_uie_panel_splitter+3E7C0h)
Address: 7C920098h (ntdll+10098h), symbol: "RtlFreeHeap" (+18Bh)
Address: 7C920021h (ntdll+10021h), symbol: "RtlFreeHeap" (+114h)
Address: 7C92003Dh (ntdll+1003Dh), symbol: "RtlFreeHeap" (+130h)
Address: 7C9201C0h (ntdll+101C0h), symbol: "RtlAllocateHeap" (+11Ch)
Address: 01D22340h (foo_uie_panel_splitter+12340h)
Address: 01D12084h (foo_uie_panel_splitter+2084h)
Address: 01D21F5Dh (foo_uie_panel_splitter+11F5Dh)
Address: 01D12D1Bh (foo_uie_panel_splitter+2D1Bh)
Address: 0050091Ch (foobar2000+10091Ch)
Address: 01D11A3Fh (foo_uie_panel_splitter+1A3Fh)
Address: 7C920040h (ntdll+10040h), symbol: "RtlFreeHeap" (+133h)
Address: 01D21F3Eh (foo_uie_panel_splitter+11F3Eh)
Address: 01D24510h (foo_uie_panel_splitter+14510h)
Address: 01D4216Dh (foo_uie_panel_splitter+3216Dh)
Address: 004B7AB4h (foobar2000+B7AB4h)
Address: 01D12093h (foo_uie_panel_splitter+2093h)
Address: 01D4BDC0h (foo_uie_panel_splitter+3BDC0h)
Address: 01D111D5h (foo_uie_panel_splitter+11D5h)
Address: 01D2D043h (foo_uie_panel_splitter+1D043h)
Address: 005578E8h (foobar2000+1578E8h)
Address: 0050710Fh (foobar2000+10710Fh)
Address: 005573B8h (foobar2000+1573B8h)
Address: 00406975h (foobar2000+6975h)
Address: 004FC80Fh (foobar2000+FC80Fh)
Address: 00516BE8h (foobar2000+116BE8h)
Address: 004B2A6Eh (foobar2000+B2A6Eh)
Address: 004B2907h (foobar2000+B2907h)
Address: 0055B568h (foobar2000+15B568h)
Address: 00500834h (foobar2000+100834h)
Address: 00500853h (foobar2000+100853h)
Address: 7E3A8DD9h (USER32+18DD9h), symbol: "DefWindowProcW" (+B9h)
Address: 7E398BD9h (USER32+8BD9h), symbol: "GetWindowThreadProcessId" (+159h)
Address: 7E3F1088h (USER32+61088h)
Address: 7E3A8DACh (USER32+18DACh), symbol: "DefWindowProcW" (+8Ch)
Address: 7E3A8D8Bh (USER32+18D8Bh), symbol: "DefWindowProcW" (+6Bh)
Address: 7E3C048Fh (USER32+3048Fh), symbol: "DeregisterShellHookWindow" (+1CFh)
Address: 7E3A8D90h (USER32+18D90h), symbol: "DefWindowProcW" (+70h)
Address: 01697721h (foo_ui_columns+87721h)
Address: 7E398B26h (USER32+8B26h), symbol: "GetWindowThreadProcessId" (+A6h)
Address: 016BABF0h (foo_ui_columns+AABF0h)
Address: 7E3988D1h (USER32+88D1h), symbol: "GetWindowLongW" (+2Bh)
Address: 7E3988DAh (USER32+88DAh), symbol: "GetWindowLongW" (+34h)
Address: 016BAD86h (foo_ui_columns+AAD86h)
Address: 77EF7002h (GDI32+7002h), symbol: "BitBlt" (+89h)
Address: 77EF6FEAh (GDI32+6FEAh), symbol: "BitBlt" (+71h)
Address: 7E398734h (USER32+8734h), symbol: "GetDC" (+6Dh)
Address: 7E39885Ah (USER32+885Ah), symbol: "GetDC" (+193h)
Address: 7E39882Ah (USER32+882Ah), symbol: "GetDC" (+163h)
Address: 0055A7C4h (foobar2000+15A7C4h)
Address: 7E398830h (USER32+8830h), symbol: "GetDC" (+169h)
Address: 7E3ABF15h (USER32+1BF15h), symbol: "UserLpkPSMTextOut" (+2F0h)
Address: 7E3A9313h (USER32+19313h), symbol: "IsWindow" (+0h)
Address: 5B091AF6h (UxTheme+1AF6h)
Address: 7E3A8DB2h (USER32+18DB2h), symbol: "DefWindowProcW" (+92h)
Address: 5B091B3Dh (UxTheme+1B3Dh)
Address: 7E3988E0h (USER32+88E0h), symbol: "GetWindowLongW" (+3Ah)
Address: 5B0934E5h (UxTheme+34E5h), symbol: "DrawThemeText" (+4EDh)
Address: 5B0934ADh (UxTheme+34ADh), symbol: "DrawThemeText" (+4B5h)
Address: 5B09348Eh (UxTheme+348Eh), symbol: "DrawThemeText" (+496h)
Address: 5B09350Ch (UxTheme+350Ch), symbol: "DrawThemeText" (+514h)
Address: 5B093357h (UxTheme+3357h), symbol: "DrawThemeText" (+35Fh)
Address: 7E3A3D3Ah (USER32+13D3Ah), symbol: "DefDlgProcW" (+0h)
Address: 7E3A3D5Ch (USER32+13D5Ch), symbol: "DefDlgProcW" (+22h)
Address: 7E3ABE0Ah (USER32+1BE0Ah), symbol: "UserLpkPSMTextOut" (+1E5h)
Address: 7E3A8EA0h (USER32+18EA0h), symbol: "DefWindowProcW" (+180h)
Address: 7E3A8EABh (USER32+18EABh), symbol: "DefWindowProcW" (+18Bh)
Address: 7E3A8EB0h (USER32+18EB0h), symbol: "DefWindowProcW" (+190h)
Address: 7E3ABE3Bh (USER32+1BE3Bh), symbol: "UserLpkPSMTextOut" (+216h)
Address: 7E3ABE4Bh (USER32+1BE4Bh), symbol: "UserLpkPSMTextOut" (+226h)
Address: 7C91E453h (ntdll+E453h), symbol: "KiUserCallbackDispatcher" (+13h)
Address: 7E3A8E53h (USER32+18E53h), symbol: "DefWindowProcW" (+133h)
Address: 7E3A99FFh (USER32+199FFh), symbol: "SetWindowPos" (+Ch)
Address: 01D3A866h (foo_uie_panel_splitter+2A866h)
Address: 01D3BCACh (foo_uie_panel_splitter+2BCACh)
Address: 01D3BD1Dh (foo_uie_panel_splitter+2BD1Dh)
Address: 0055B578h (foobar2000+15B578h)
Address: 77F34060h (GDI32+44060h)
Address: 01D13E8Bh (foo_uie_panel_splitter+3E8Bh)
Address: 7E3A8FE1h (USER32+18FE1h), symbol: "InvalidateRect" (+Ch)
Address: 012E165Ch (foo_uie_vis_channel_spectrum+165Ch)
Address: 01301DE5h (foo_uie_vis_channel_spectrum+21DE5h)
Address: 7E3A9D09h (USER32+19D09h), symbol: "SetRectEmpty" (+4Fh)
Address: 7E3A3C0Ah (USER32+13C0Ah), symbol: "EnumDisplaySettingsA" (+1A3h)
Environment:
App: foobar2000 v0.9.6.5
OS: Windows 5.1.2600 Service Pack 3 x86
CPU: Intel® Core™2 Duo CPU    E6850  @ 3.00GHz, features: MMX SSE SSE2 SSE3
Audio: SoundMAX HD Audio
UI: Columns UI 0.3.6.5
Components:
Core (2009-04-25 16:47:24)
    foobar2000 core 0.9.6.5
foo_abx.dll (2009-04-25 16:44:30)
    ABX Comparator 1.3.4
foo_AdvancedControls.dll (2008-11-20 16:09:40)
    FooBar2000 Advanced Controls 0.5.11.4
foo_albumlist.dll (2009-04-25 16:45:44)
    Album List 4.3.1
foo_cdda.dll (2009-04-25 16:45:30)
    CD Audio Decoder 2.1.4
foo_converter.dll (2009-04-25 16:45:38)
    Converter 1.2.1
foo_dsp_std.dll (2009-04-25 16:45:44)
    Standard DSP Array 1.0
foo_exvar.dll (2008-06-14 00:42:55)
    Extended Variables 0.3.1
foo_fileops.dll (2009-04-25 16:44:30)
    File Operations 2.1.2
foo_freedb2.dll (2009-04-25 16:44:48)
    freedb Tagger 0.6.1
foo_input_std.dll (2009-04-25 16:45:20)
    Standard Input Array 1.0
foo_masstag.dll (2007-10-13 16:17:26)
    Masstagger 1.6
foo_menu_addons.dll (2009-01-05 21:44:56)
    Menu Addons 0.4.1 (SSE)
foo_rgscan.dll (2009-04-25 16:45:16)
    ReplayGain Scanner 2.0.8
foo_ui_columns.dll (2009-02-08 18:58:33)
    Columns UI 0.3.6.5
foo_ui_std.dll (2009-04-25 16:45:54)
    Default User Interface 0.9.5
foo_uie_biography.dll (2009-04-24 00:21:36)
    Biography View 0.2.7
foo_uie_elplaylist.dll (2008-12-10 23:57:18)
    ELPlaylist 0.6.4(beta)
foo_uie_lyrics.dll (2008-12-12 11:39:20)
    Lyric Show Panel 0.3.3.9 [Dec 12 2008 - 17:39:01]
foo_uie_panel_splitter.dll (2009-03-07 00:05:06)
    Panel Stack Splitter 0.3.6.3(alpha)
foo_uie_vis_channel_spectrum.dll (2008-05-18 04:02:12)
    Channel Spectrum panel 0.17.2
foo_uie_wsh_panel_mod.dll (2009-04-05 15:20:28)
    WSH Panel Mod 1.1.4
foo_unpack.dll (2009-04-25 16:44:24)
    RAR reader 1.2
    ZIP/GZIP reader 1.0
foo_utils.dll (2008-02-08 23:26:58)
    Playlist Tools 0.6.2 beta 6
foo_vis_shpeck.dll (2008-12-01 13:49:43)
    Shpeck - Winamp vis plugins wrapper 0.3.0
Recent events:
Watching: Z:\MP3
can you give it a look Ssenna please, and maybe a fix ????
hope you'll read this!
*waiting for help*
for information, just before it crash, i've coded in the main PSS $movepanel_c(panel_caption,0,0,0,0) for 7 panels include in the main PSS, just before the $movepanel() of these 7 panels with real positions and size
==> this in order to refresh the main PSS background when i swap these poanels together ...
i hope that can help you to see why PSS crash ...
Regards,
EDIT:
same crash with a previous foobar version 0.9.6.2 here is the old dump formt generated with this foobar version:
[code]
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 018FBB20h
Call path:
Code bytes (018FBB20h):
018FBAE0h:  8B 0E 50 51 E8 3D 62 00 00 85 C0 74 04 89 46 04
018FBAF0h:  C3 33 C0 C3 CC CC CC CC CC CC CC CC CC CC CC CC
018FBB00h:  8B 0E 50 51 E8 05 62 00 00 85 C0 74 04 89 46 04
018FBB10h:  C3 33 C0 C3 CC CC CC CC CC CC CC CC CC CC CC CC
018FBB20h:  8B 0E 50 51 E8 3D 61 00 00 85 C0 74 04 89 46 04
018FBB30h:  C3 33 C0 C3 CC CC CC CC CC CC CC CC CC CC CC CC
018FBB40h:  50 8B 44 24 0C 51 8B 4C 24 0C 52 8B 11 50 8B 06
018FBB50h:  52 50 E8 F7 60 00 00 85 C0 74 06 89 46 04 C2 08
Stack (0012EF30h):
0012EF10h:  8944AB80 BF82DE1C BC6DEFA8 00000083
0012EF20h:  00000083 0078EFA8 00000083 00000001
0012EF30h:  0191047C 3FAB4DA7 001304F0 0013048F
0012EF40h:  00130448 03AE7070 0013045C 0013048F
0012EF50h:  019546F8 00AE8270 00000000 00000000
0012EF60h:  96000000 0078EE80 00000000 00000064
0012EF70h:  0192EEB4 0467FA28 00000000 00000000
0012EF80h:  00000000 0192E7A0 00000000 00000000
0012EF90h:  00000000 00000009 00000000 3FAB4C5B
0012EFA0h:  00000000 00000000 000000BE 00000001
0012EFB0h:  0000000F 0191A150 01954630 00280500
0012EFC0h:  00000005 00000000 009E017D 0012F03C
0012EFD0h:  00000005 00280500 0078EE80 00280500
0012EFE0h:  00000005 00000000 009E017D 0191A150
0012EFF0h:  DCBAABCD 00000000 0012F03C 0012F018
0012F000h:  7E3A8DD9 00280500 00000005 00000000
0012F010h:  0192E7A0 00000000 00000000 00000000
0012F020h:  0000000F 0012F060 7E3A8DAC 7E3A8D8B
0012F030h:  00000005 00280500 0078EE80 0012F070
0012F040h:  01950000 7C920202 0012F07C 01950000
Registers:
EAX: 00000000, EBX: 0012EFAC, ECX: 0467FB44, EDX: 00000000
ESI: 00000000, EDI: 0012EFA8, EBP: 001303F8, ESP: 0012EF30
Crash location: "foo_uie_panel_splitter", loaded at 018F0000h - 0193F000h
Loaded modules:
foobar2000                      loaded at 00400000h - 0053B000h
shared                          loaded at 10000000h - 1002A000h
foo_dsp_std                      loaded at 00D50000h - 00D98000h
foo_ui_std                      loaded at 00DC0000h - 00EC9000h
foo_rgscan                      loaded at 00F00000h - 00F4E000h
foo_exvar                        loaded at 00F70000h - 00F98000h
foo_cdda                        loaded at 010C0000h - 01100000h
foo_uie_biography                loaded at 01120000h - 0119E000h
foo_uie_elplaylist              loaded at 01200000h - 01269000h
foo_uie_vis_channel_spectrum    loaded at 01290000h - 012CD000h
foo_uie_wsh_panel_mod            loaded at 01370000h - 013EC000h
foo_converter                    loaded at 01550000h - 015BD000h
foo_abx                          loaded at 015E0000h - 01612000h
foo_ui_columns                  loaded at 01640000h - 0177B000h
foo_fileops                      loaded at 017A0000h - 017E7000h
foo_albumlist                    loaded at 01810000h - 0186A000h
foo_AdvancedControls            loaded at 01890000h - 018D8000h
foo_uie_panel_splitter          loaded at 018F0000h - 0193F000h
foo_menu_addons                  loaded at 01960000h - 0199C000h
foo_masstag                      loaded at 019C0000h - 01A10000h
foo_input_std                    loaded at 01A30000h - 01B70000h
foo_utils                        loaded at 01B90000h - 01BD4000h
foo_uie_lyrics                  loaded at 01C00000h - 01C5D000h
Normaliz                        loaded at 01C70000h - 01C79000h
foo_unpack                      loaded at 01EA0000h - 01ECE000h
foo_freedb2                      loaded at 01EF0000h - 01F31000h
foo_vis_shpeck                  loaded at 01F60000h - 01F9E000h
DBGHELP                          loaded at 5D3F0000h - 5D491000h
Address: 0191047Ch, location: "foo_uie_panel_splitter", loaded at 018F0000h - 0193F000h
Address: 0192EEB4h, location: "foo_uie_panel_splitter", loaded at 018F0000h - 0193F000h
Address: 0192E7A0h, location: "foo_uie_panel_splitter", loaded at 018F0000h - 0193F000h
Address: 0191A150h, location: "foo_uie_panel_splitter", loaded at 018F0000h - 0193F000h
Address: 7E3A8DD9h, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "DefWindowProcW" (+000000B9h)
Address: 7E3A8DACh, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "DefWindowProcW" (+0000008Ch)
Address: 7E3A8D8Bh, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "DefWindowProcW" (+0000006Bh)
Address: 7C920202h, location: "ntdll", loaded at 7C910000h - 7C9C6000h
Symbol: "RtlAllocateHeap" (+0000015Eh)
Address: 7C920208h, location: "ntdll", loaded at 7C910000h - 7C9C6000h
Symbol: "RtlAllocateHeap" (+00000164h)
Address: 7C91E900h, location: "ntdll", loaded at 7C910000h - 7C9C6000h
Symbol: "strchr" (+00000113h)
Address: 7C92017Bh, location: "ntdll", loaded at 7C910000h - 7C9C6000h
Symbol: "RtlAllocateHeap" (+000000D7h)
Address: 7C9201BBh, location: "ntdll", loaded at 7C910000h - 7C9C6000h
Address: 7C9200A4h, location: "ntdll", loaded at 7C910000h - 7C9C6000h
Symbol: "RtlAllocateHeap" (+00000000h)
Address: 7E3A3D3Ah, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "DefDlgProcW" (+00000000h)
Address: 0192E7C0h, location: "foo_uie_panel_splitter", loaded at 018F0000h - 0193F000h
Address: 7C920098h, location: "ntdll", loaded at 7C910000h - 7C9C6000h
Symbol: "RtlFreeHeap" (+0000018Bh)
Address: 7C920021h, location: "ntdll", loaded at 7C910000h - 7C9C6000h
Symbol: "RtlFreeHeap" (+00000114h)
Address: 7C92003Dh, location: "ntdll", loaded at 7C910000h - 7C9C6000h
Symbol: "RtlFreeHeap" (+00000130h)
Address: 7C9201C0h, location: "ntdll", loaded at 7C910000h - 7C9C6000h
Symbol: "RtlAllocateHeap" (+0000011Ch)
Address: 01902340h, location: "foo_uie_panel_splitter", loaded at 018F0000h - 0193F000h
Address: 01901F3Eh, location: "foo_uie_panel_splitter", loaded at 018F0000h - 0193F000h
Address: 004AF041h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 018F2D1Bh, location: "foo_uie_panel_splitter", loaded at 018F0000h - 0193F000h
Address: 01904510h, location: "foo_uie_panel_splitter", loaded at 018F0000h - 0193F000h
Address: 01901F5Dh, location: "foo_uie_panel_splitter", loaded at 018F0000h - 0193F000h
Address: 0192216Dh, location: "foo_uie_panel_splitter", loaded at 018F0000h - 0193F000h
Address: 00478AF4h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 018F2093h, location: "foo_uie_panel_splitter", loaded at 018F0000h - 0193F000h
Address: 004738D0h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 0192BDC0h, location: "foo_uie_panel_splitter", loaded at 018F0000h - 0193F000h
Address: 018F1A3Fh, location: "foo_uie_panel_splitter", loaded at 018F0000h - 0193F000h
Address: 018F11D5h, location: "foo_uie_panel_splitter", loaded at 018F0000h - 0193F000h
Address: 0190D043h, location: "foo_uie_panel_splitter", loaded at 018F0000h - 0193F000h
Address: 00444069h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 004A9E7Fh, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 00405194h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 0040510Ch, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 004C9B71h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 00479219h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 004737C0h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 005050CCh, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 7C920040h, location: "ntdll", loaded at 7C910000h - 7C9C6000h
Symbol: "RtlFreeHeap" (+00000133h)
Address: 004AEF59h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 7E398BD9h, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "GetWindowThreadProcessId" (+00000159h)
Address: 7E3F1088h, location: "USER32", loaded at 7E390000h - 7E421000h
Address: 7E3C048Fh, location: "USER32", loaded at 7E390000h - 7E421000h
Address: 7E3A8D90h, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "DefWindowProcW" (+00000070h)
Address: 016C7721h, location: "foo_ui_columns", loaded at 01640000h - 0177B000h
Address: 7E398B26h, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "GetWindowThreadProcessId" (+000000A6h)
Address: 016EABF0h, location: "foo_ui_columns", loaded at 01640000h - 0177B000h
Address: 7E3988D1h, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "GetWindowLongW" (+0000002Bh)
Address: 7E3988DAh, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "GetWindowLongW" (+00000034h)
Address: 0171D310h, location: "foo_ui_columns", loaded at 01640000h - 0177B000h
Address: 016EAD86h, location: "foo_ui_columns", loaded at 01640000h - 0177B000h
Address: 77EF7002h, location: "GDI32", loaded at 77EF0000h - 77F39000h
Symbol: "BitBlt" (+00000089h)
Address: 77EF6FEAh, location: "GDI32", loaded at 77EF0000h - 77F39000h
Symbol: "BitBlt" (+00000071h)
Address: 7E398734h, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "GetDC" (+0000006Dh)
Address: 7E39885Ah, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "GetDC" (+00000193h)
Address: 7E39882Ah, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "GetDC" (+00000163h)
Address: 0050495Ch, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 7E398830h, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "GetDC" (+00000169h)
Address: 7E3ABF15h, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "UserLpkPSMTextOut" (+000002F0h)
Address: 7E3A9313h, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "IsWindow" (+00000000h)
Address: 5B091AF6h, location: "UxTheme", loaded at 5B090000h - 5B0C8000h
Address: 7E3A8DB2h, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "DefWindowProcW" (+00000092h)
Address: 5B091B3Dh, location: "UxTheme", loaded at 5B090000h - 5B0C8000h
Address: 7E3988E0h, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "GetWindowLongW" (+0000003Ah)
Address: 5B0934E5h, location: "UxTheme", loaded at 5B090000h - 5B0C8000h
Symbol: "DrawThemeText" (+000004EDh)
Address: 5B0934ADh, location: "UxTheme", loaded at 5B090000h - 5B0C8000h
Symbol: "DrawThemeText" (+000004B5h)
Address: 5B09348Eh, location: "UxTheme", loaded at 5B090000h - 5B0C8000h
Symbol: "DrawThemeText" (+00000496h)
Address: 5B09350Ch, location: "UxTheme", loaded at 5B090000h - 5B0C8000h
Symbol: "DrawThemeText" (+00000514h)
Address: 5B093357h, location: "UxTheme", loaded at 5B090000h - 5B0C8000h
Symbol: "DrawThemeText" (+0000035Fh)
Address: 7E3A3D5Ch, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "DefDlgProcW" (+00000022h)
Address: 7E3ABE0Ah, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "UserLpkPSMTextOut" (+000001E5h)
Address: 7E3A8EA0h, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "DefWindowProcW" (+00000180h)
Address: 7E3A8EABh, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "DefWindowProcW" (+0000018Bh)
Address: 7E3A8EB0h, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "DefWindowProcW" (+00000190h)
Address: 7E3ABE3Bh, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "UserLpkPSMTextOut" (+00000216h)
Address: 7E3ABE4Bh, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "UserLpkPSMTextOut" (+00000226h)
Address: 7C91E453h, location: "ntdll", loaded at 7C910000h - 7C9C6000h
Symbol: "KiUserCallbackDispatcher" (+00000013h)
Address: 7E3A8E53h, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "DefWindowProcW" (+00000133h)
Address: 7E3A99FFh, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "SetWindowPos" (+0000000Ch)
Address: 0191A866h, location: "foo_uie_panel_splitter", loaded at 018F0000h - 0193F000h
Address: 0191BCACh, location: "foo_uie_panel_splitter", loaded at 018F0000h - 0193F000h
Address: 0191BD1Dh, location: "foo_uie_panel_splitter", loaded at 018F0000h - 0193F000h
Address: 005050DCh, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 77F34060h, location: "GDI32", loaded at 77EF0000h - 77F39000h
Address: 018F3E8Bh, location: "foo_uie_panel_splitter", loaded at 018F0000h - 0193F000h
Address: 7E3A8FE1h, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "InvalidateRect" (+0000000Ch)
Address: 018F4A07h, location: "foo_uie_panel_splitter", loaded at 018F0000h - 0193F000h
Address: 0129165Ch, location: "foo_uie_vis_channel_spectrum", loaded at 01290000h - 012CD000h
Address: 012B1DE5h, location: "foo_uie_vis_channel_spectrum", loaded at 01290000h - 012CD000h
Address: 019286F4h, location: "foo_uie_panel_splitter", loaded at 018F0000h - 0193F000h
Address: 7E3A9D09h, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "SetRectEmpty" (+0000004Fh)
Address: 7E3A3C0Ah, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "EnumDisplaySettingsA" (+000001A3h)
Version info:
foobar2000 v0.9.6.2
UNICODE
Windows 5.1
Additional info:
Channel Spectrum panel 0.17.2  (foo_uie_vis_channel_spectrum)
ELPlaylist 0.6.4(beta)  (foo_uie_elplaylist)
Shpeck - Winamp vis plugins wrapper 0.3.0  (foo_vis_shpeck)
foobar2000 core 0.9.6.2  (Core)
Standard DSP Array 1.0  (foo_dsp_std)
Biography View 0.2.7  (foo_uie_biography)
Columns UI 0.3.6.5  (foo_ui_columns)
Menu Addons 0.4.1 (SSE)  (foo_menu_addons)
Album List 4.3.1  (foo_albumlist)
File Operations 2.1.2  (foo_fileops)
Lyric Show Panel 0.3.3.9 [Dec 12 2008 - 17:39:01]  (foo_uie_lyrics)
freedb Tagger 0.6.1  (foo_freedb2)
Playlist Tools 0.6.2 beta 6  (foo_utils)
Default User Interface 0.9.5  (foo_ui_std)
RAR reader 1.2  (foo_unpack)
ZIP/GZIP reader 1.0  (foo_unpack)
Masstagger 1.6  (foo_masstag)
WSH Panel Mod 1.1.4  (foo_uie_wsh
Reply #320
There was a new version released today, 0.3.6.4, maybe try that?
Reply #322
There's a new Biography and EL Playlist too
Reply #323
new version installed, it allows me to restart foo, but after adding a new $movepanel(p_caption,0,0,0,0), it crashes again :
Thanx a lot!!!!!!
here is the dump :
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 0119BB30h
Call path:
entry=>app_mainloop=>context=>titleformat_object::run
Code bytes (0119BB30h):
0119BAF0h:  8B 0E 50 51 E8 07 63 00 00 85 C0 74 04 89 46 04
0119BB00h:  C3 33 C0 C3 CC CC CC CC CC CC CC CC CC CC CC CC
0119BB10h:  8B 0E 50 51 E8 CF 62 00 00 85 C0 74 04 89 46 04
0119BB20h:  C3 33 C0 C3 CC CC CC CC CC CC CC CC CC CC CC CC
0119BB30h:  8B 0E 50 51 E8 51 63 00 00 85 C0 74 04 89 46 04
0119BB40h:  C3 33 C0 C3 CC CC CC CC CC CC CC CC CC CC CC CC
0119BB50h:  50 8B 44 24 0C 51 8B 4C 24 0C 52 8B 11 50 8B 06
0119BB60h:  52 50 E8 0B 63 00 00 85 C0 74 06 89 46 04 C2 08
Stack (001302C0h):
001302A0h:  893B1DA8 BF82DE1C BC71D9A8 00000083
001302B0h:  00000083 0082D9A8 00000083 00000001
001302C0h:  011B0605 BF93B9A3 00131844 00131964
001302D0h:  00000000 00131810 00131844 06884DB0
001302E0h:  00920202 00000004 01200748 96000000
001302F0h:  0689ACB0 00000000 00000064 011CEE90
00130300h:  07021C80 00000000 00FFFFFF 7C920202
00130310h:  7C92017B 011CE790 00000000 00000000
00130320h:  00000000 00000009 00000000 00000000
00130330h:  000000BE 00000001 00130564 7C91E900
00130340h:  7C920208 FFFFFFFF 00130400 00130418
00130350h:  06FD2230 0013181C 07059760 00130368
00130360h:  4EC1C840 440C147A 00130380 06FD1848
00130370h:  0165B3D0 00130488 06FD35F0 00000000
00130380h:  00000000 4EBE932A 00000000 00000000
00130390h:  00000000 00000000 001303CC 01200000
001303A0h:  7C920202 00000004 01200748 01200000
001303B0h:  001303E4 003E0000 7C920202 00000004
001303C0h:  003E0748 003E0000 04169568 001303BC
001303D0h:  7C92017B 00130600 7C91E900 7C920208
Registers:
EAX: 00000000, EBX: 00130334, ECX: 07021D9C, EDX: 00000000
ESI: 00000000, EDI: 00130330, EBP: 00131788, ESP: 001302C0
Crash location:
Offset: BB30h
Loaded modules:
foo_uie_panel_splitter          loaded at 01190000h - 011E0000h
foo_input_std                    loaded at 01210000h - 01350000h
foo_cdda                        loaded at 01370000h - 013B0000h
foo_ui_std                      loaded at 013D0000h - 014D9000h
foo_uie_elplaylist              loaded at 01500000h - 01569000h
foo_uie_wsh_panel_mod            loaded at 01590000h - 0160C000h
foo_uie_vis_channel_spectrum    loaded at 01770000h - 017AD000h
foo_AdvancedControls            loaded at 017D0000h - 01818000h
foo_uie_biography                loaded at 01830000h - 018AE000h
foo_albumlist                    loaded at 01910000h - 0196A000h
foo_unpack                      loaded at 01990000h - 019BE000h
foo_rgscan                      loaded at 019E0000h - 01A2E000h
foo_menu_addons                  loaded at 01A50000h - 01A8C000h
foo_ui_columns                  loaded at 01AB0000h - 01BEB000h
foo_masstag                      loaded at 01C10000h - 01C60000h
foo_freedb2                      loaded at 01C80000h - 01CC1000h
foo_fileops                      loaded at 01CF0000h - 01D37000h
foo_converter                    loaded at 01D60000h - 01DCD000h
foo_abx                          loaded at 01DF0000h - 01E22000h
foo_exvar                        loaded at 01E50000h - 01E78000h
foo_uie_lyrics                  loaded at 01FA0000h - 01FFD000h
Normaliz                        loaded at 02010000h - 02019000h
foo_utils                        loaded at 02240000h - 02284000h
foo_vis_shpeck                  loaded at 022B0000h - 022EE000h
foo_dsp_std                      loaded at 02310000h - 02358000h
CLBCATQ                          loaded at 76F80000h - 76FFF000h
COMRes                          loaded at 77000000h - 770D4000h
mlang                            loaded at 75D30000h - 75DC1000h
msdmo                            loaded at 73600000h - 73607000h
wmadmod                          loaded at 11820000h - 118DC000h
mfplat                          loaded at 0BF10000h - 0BF47000h
mswsock                          loaded at 71990000h - 719D0000h
DNSAPI                          loaded at 76ED0000h - 76EF7000h
mdnsNSP                          loaded at 16080000h - 160A5000h
Iphlpapi                        loaded at 76D10000h - 76D29000h
rasadhlp                        loaded at 76F70000h - 76F76000h
hnetcfg                          loaded at 62E40000h - 62E99000h
wshtcpip                        loaded at 719D0000h - 719D8000h
KsUser                          loaded at 73E30000h - 73E34000h
Address: 011B0605h (foo_uie_panel_splitter+20605h)
Address: 011CEE90h (foo_uie_panel_splitter+3EE90h)
Address: 011CE790h (foo_uie_panel_splitter+3E790h)
Address: 4EC1C840h (gdiplus+9C840h), symbol: "GdipDeletePathIter" (+33918h)
Address: 440C147Ah (WININET+4147Ah), symbol: "CreateUrlCacheContainerA" (+94h)
Address: 4EBE932Ah (gdiplus+6932Ah), symbol: "GdipDeletePathIter" (+402h)
Address: 011CE7ACh (foo_uie_panel_splitter+3E7ACh)
Address: 4EBEAD57h (gdiplus+6AD57h), symbol: "GdipDeletePathIter" (+1E2Fh)
Address: 4EBEAFD1h (gdiplus+6AFD1h), symbol: "GdipDeletePathIter" (+20A9h)
Address: 011A2474h (foo_uie_panel_splitter+12474h)
Address: 01191FF4h (foo_uie_panel_splitter+1FF4h)
Address: 011A2091h (foo_uie_panel_splitter+12091h)
Address: 01192CABh (foo_uie_panel_splitter+2CABh)
Address: 011919AFh (foo_uie_panel_splitter+19AFh)
Address: 011A2072h (foo_uie_panel_splitter+12072h)
Address: 011A5740h (foo_uie_panel_splitter+15740h)
Address: 011C238Dh (foo_uie_panel_splitter+3238Dh)
Address: 01192003h (foo_uie_panel_splitter+2003h)
Address: 011CBD18h (foo_uie_panel_splitter+3BD18h)
Address: 0119DC65h (foo_uie_panel_splitter+DC65h)
Address: 011AD1C3h (foo_uie_panel_splitter+1D1C3h)
Address: 0046B77Ch (foobar2000+6B77Ch)
Address: 00419B88h (foobar2000+19B88h)
Address: 01B37721h (foo_ui_columns+87721h)
Address: 01B5ABF0h (foo_ui_columns+AABF0h)
Address: 01B8D310h (foo_ui_columns+DD310h)
Address: 01B5AD86h (foo_ui_columns+AAD86h)
Address: 011BA9B6h (foo_uie_panel_splitter+2A9B6h)
Address: 011BBDFCh (foo_uie_panel_splitter+2BDFCh)
Address: 011BBE6Dh (foo_uie_panel_splitter+2BE6Dh)
Address: 77EF6E1Dh (GDI32+6E1Dh), symbol: "DeleteObject" (+223h)
Address: 77EF6E3Eh (GDI32+6E3Eh), symbol: "DeleteObject" (+244h)
Address: 77EF6BFAh (GDI32+6BFAh), symbol: "DeleteObject" (+0h)
Address: 01194987h (foo_uie_panel_splitter+4987h)
Address: 011BEE2Bh (foo_uie_panel_splitter+2EE2Bh)
Address: 011C0337h (foo_uie_panel_splitter+30337h)
Address: 01844300h (foo_uie_biography+14300h)
Address: 0188CE93h (foo_uie_biography+5CE93h)
Address: 011BA2A0h (foo_uie_panel_splitter+2A2A0h)
Environment:
Components:
    Album List 4.3.1
    Converter 1.2.1
    freedb Tagger 0.6.1
    Masstagger 1.6
    Columns UI 0.3.6.5
foo_uie_panel_splitter.dll (2009-04-26 23:58:12)
    Panel Stack Splitter 0.3.6.4(alpha)
    WSH Panel Mod 1.1.4
    RAR reader 1.2
    ZIP/GZIP reader 1.0
hope that will help!
Reply #324
Still unable to play selected track when hitting "ENTER" on keyboard.
Been this way for the last few versions. Anybody else facing same problem?
