Topic: REACT 2 Released (Read 1289878 times) previous topic - next topic
0 Members and 9 Guests are viewing this topic.
REACT 2 Released
Reply #1450
1) Is there a list of which software can be safely updated without blowing up REACT2's capabilities? Or an updated tools download?
2) Is there an install document which covers XUI or ... do I really need to go through this 58 page forum topic <eeek!> to remind myself how to get XUI running?
1) Lame (edit: and flac & metaflac) can be updated safely AFAIK. Metamp3 is a different thing, updating that to a newer version (.92b5) breaks .cfg-files. Dunno about the rest. What tools would you like to update?
2) Just download the zip and extract that to the coverdownloader folder.. or install XUI and set the INI CoverDownloader setting to point to the installed directory. Also put the INI CoverDownloaderXUI setting to 1. That's all.
P.S. check out the mods Wiki page for an updated situation.
Ah! I hadn't realized that you had "taken over" the REACT2 mods. I somehow (and mistakenly) thought that your set of mods were parallel to those from SS. My bad, and my apologies.
I was most aware of the outdated LAME and WavPack programs since I use those encoders exclusively during EAC rips. I've updated them and haven't seen any issues. I did see some "command line help text" going by while I was ripping some oddly named tracks recently. I'll turn on debug to see what's up, then will update to your latest version to see if it continues, etc., etc.
McThanks,
McBill
REACT 2 Released
Reply #1451
Even with the latest version of your mods I'm seeing the help from the command line from metamp3. Here's an extract from the DOS window which may be helpful:
TITLE 02/02 mp3 "Dreams of India (CD1)" & C:\PROGRA~1\REACT2\tools\lame.exe -V5 --vbr-new --noreplay
gain --nohist  - "02 - Chapter Two - What you are you do not see, what you see is your shadow..mp3"
& C:\PROGRA~1\REACT2\tools\metamp3.exe --pict "{3}E:\Dreams of India (CD1).jpg"  --artist "ZBS Foun
dation" --album "Dreams of India (CD1)" --title "Chapter Two - What you are you do not see, what you
 see is your shadow." --track 02/02 --year "1992" --genre "Radio Drama" --comment "Created with EAC/
REACT v2.0.akku.b03, 2009-02-17" --frame TENC:"Bill Sherman" --frame TSSE:"LAME 3.98.2 -V5 --vbr-new
 --noreplaygain --nohist" "02 - Chapter Two - What you are you do not see, what you see is your shad
ow..mp3"
LAME 3.98.2 32bits (http://www.mp3dev.org/)
CPU features: MMX (ASM used), 3DNow! (ASM used), SSE (ASM used), SSE2
Using polyphase lowpass filter, transition band: 16538 Hz - 17071 Hz
Encoding <stdin>
      to 02 - Chapter Two - What you are you do not see, what you see is your shadow..mp3
Encoding as 44.1 kHz j-stereo MPEG-1 Layer III VBR(q=5)
metamp3 v0.91 - Copyright © 2006 by Tycho
Updating: 02 - Chapter Two - What you are you do not see, what you see is your shadow..mp3
C:\bill\Ripped CDs\MP3\ZBS Foundation\Dreams of India (CD1)>IF 1 == 1 C:\PROGRA~1\REACT2\tools\metam
p3.exe --replay-gain *.mp3
Usage: C:\PROGRA~1\REACT2\tools\metamp3.exe [options] [mp3files]
options:
  --artist <artist>              audio/song artist
  --album <album>                audio/song album
  --track <track>[/total]        audio/song track number
  --title <title>                audio/song title
  --year <year>                  audio/song year of issue (1 to 9999)
  --genre <genre>                audio/song genre name
  --comment [[desc]][{lng}]<text> add user-defined text
  --user-text [[desc]]<text>      add user text frame (TXXX)
  --user-url [[desc]]<URL>        add user URL frame (WXXX)
  --frame <frame:text>            set any T* or W* type frame
  --pict [[desc]][{type}]<file>  add picture artwork
  --save-pict <pict>              pict=[[desc]][{type}]<file>
  --list-pict-types              list possible picture type numbers
  --list-frames                  list Text and URL id3v2.3 frames
  --list-genres                  list standard id3v1.1 genres
  --1                            add id3v1 tag only (default both v1 and v2)
  --2                            add id3v2 tag only (--1 --2 will add both)
  --fit                          add id3v1 + id3v2 if tag does not fit id3v1
  --remove [[desc]]<frame>        remove frame(s). accepts wildcards *,?
  --replay-gain                  calculate and set replay gain tags
  --apply-gain <gain>            change volume. gain=[album|radio]<+dB|-dB>
  --undo-gain                    undo previous apply-gain
  --info                          print detailed mp3/lametag info
  --version                      show version info
  --help                          show this help
p3.exe --apply-gain album+3.0 *.mp3
options:
Do you think this may be related to the period that is part of the track title? The resulting MP3 file name ends with "..mp3" because I'm including the period(s) that are part of the long track titles for this strange CD. Note: While EAC is ripping the CD to .WAV I go in and hand-edit the .cue file to include the full track titles in cases where EAC truncates them.
Bill
REACT 2 Released
Reply #1452
Ah. Nope. It's not the ..mp3 in the name. It seems to simply be the length of the track name. If I leave the .cue file untouched (with max track name length = 70) then there are no metamp3 issues. If I edit the .cue file by providing the full track names (which are longer than 70 bytes) then metamp3 has issues. I'm not sure if it's strictly an issue with metamp3 though. If it is, I wonder if a fix is possible using the back-level version that we are all using for the tweaked version of REACT 2?
Darn. I was hoping that editing the .cue file would be the fastest way to change all the names and tags for the image file and the track files. Will be a pain to have to edit them all manually to reflect the full track name.
Any ideas on how to get the track names right without having to edit them all 3 times (or so)? There are the file names of the MP3 tracks, the MP3 tags, the WavPack tags, and the .cue file. I like the idea of editing the cue file in the end but ... will that cause issues if I ever want to use EAC to burn a CD from the WavPack image?
Okay, I'll stop writing to myself and give y'all a break!
Bill
REACT 2 Released
Reply #1453
Last week I wrote this post, check it out.
Honestly, I'm a bit lost with your posts, maybe it's just me but what's "back-level version" (that whole sentence got me shaking my head.. I just don't understand it.. at all) and your cue file editing.
As for the EAC's 80 chars (first 77 chars of the title + 3 period chars) limitation in cuesheet titles, you should write to EAC forum wishlist topic and demand that this limitation should be fixed (if possible).
OT: darn I really hate this new "only 1 email notification per board visit to subscribed topics" setting.. missed 2 of your last posts.. it's stupid that I've to manually check topics (currently I've 7 tabs open with different topics.. I could put them to bookmarks but still..) because I don't (want to) login all the time. Advertisement: vote in this topic.
REACT 2 Released
Reply #1454
Sorry to scare you! Alas, I'm rather good at that.
Thank you very much for the link to the earlier post. That fix (using Glob) avoided both of the "metamp3 problems" I was having. Now, all files (long names and/or ones with ..) are processed, and files with .. in their names have their RG values scanned and updated appropriately. Perfect! Another satisfied customer!
Bill
REACT 2 Released
Reply #1455
I just tried out REACT 2 for the first time.
And I must say I'm very impressed by the functions and there ease of use. In less than half an hour my setup was ready and I was producing FLAC images with embedded cuesheet, albumgain, tags and embeded coverart. All automatically!
Thank you very much for this!
I have one question though:
Is it possible to also automatically add track gain to the embedded cuesheet in my FLAC images? This is now the only thing I do manually afterwards in foobar2000.
REACT 2 Released
Reply #1456
No if you are only ripping images. With tracks (in image mode) it's possible, but with "propeller-hat" amends to the .cfg file. I quickly checked the WaveGain.exe abilities to do this and I guess it's only possible when you have individual tracks. You'd have to delay the cuesheet embed and run WaveGain with all the individual tracks and get all the RG info that way. Next, before embedding cuesheet, you'd have to put all those track RG infos to the cuesheet file.. and in correct places between track informations (I don't actually know where f2k puts them). The current album RG info is very easy to prepend to the beginning of the file.
P.S. Do you absolutely need those in your cuesheets?
REACT 2 Released
Reply #1457
No not nessecarily. I thought it was the standard for images with embedded cuesheets. Only because foobar does it that way really.
It is fairly easy for me to add them to the flac image in foobar2000 after its created by reakt2. But a step less in the process is allways better.
REACT 2 Released
Reply #1458
No not nessecarily.
Why bother at all with that step if you don't need those in your cuesheets? (This from a person who fights against his own perfectionism in everything. )
REACT 2 Released
Reply #1459
No not nessecarily.
Well... Its not that I dont need them at all. I just thought there was maybe an other method of storing them.
I use the trackgain values on those images for daily listening. When using random/shuffle play those values equal the volume on those tracks.
REACT 2 Released
Reply #1460
Oh ok. Unfortunately I don't have the time to concoct a solution for you. Sorry. I gave "raw" instructions how one could do it in my #1457 post. Also check out lines 125-140 from REACT-image.cfg for how the Album Gain info is "extracted" from Wavegain output and put to the cuesheet.
REACT 2 Released
Reply #1461
Thank you for the replies. I will look into asap!
REACT 2 Released
Reply #1462
I've got some older CDs in my collection. I was lucky to notice that a few of them use Pre-Emphasis. I have to perform special handling to get the MP3s generated correctly for those tracks (I use SoX).
Is there a way to make REACT2 stop dead in its tracks and/or notify me in a wonderfully blatant way that one or more track on a CD -- or that an entire CD -- uses Pre-Emphasis so that I don't miss it? (I'm easily distracted.)
Thanks still even more yet again,
Bill
REACT 2 Released
Reply #1463
No, sorry. Can't you remember to check the Pre-Emphasis column on the main EAC window before you start ripping? Since the information is so easily available, I'm not going to put this into my ToDo list. If you are familiar with programming, amend the program to your needs, the source code is free.
REACT 2 Released
Reply #1464
Ah HA! EAC nicely puts "FLAGS PRE" into a .cue file when a track is found to have Pre-Emphasis enabled. I can just grep all the .cue files. I did that this morning and found that I'd managed to miss two such CDs during my recent ripping efforts. One CD the flag set on all tracks while the other had just one track with the flag set. That was easy. Almost too easy.
REACT 2 Released
Reply #1465
I'm using Windows 7 and the ssb16 add-on to React 2. I've installed everything and eac starts up in react mode. I press F10 to start the rip and this works. The rip happens, but when it finishes a dialog box pops up with the following error:
Title of Dialog box is AutoIt Error
Line 0 (File "C:\Program Files (x86)\React2\React.exe"):
For $i = $g_userSettings[0][0] To 1 Step -1
For &i = $g_userSettings^ ERROR
Error: Subscript used with non-Array variable.
What is interesting is that I start react from c:\program files\exact audio copy as I forced it to install the 32 bit app here. The Tools line in my react settings file is as follows, so maybe react knows about the react2 directory because of this?
Tools=C:\Program Files (x86)\REACT2\tools
The error message states that it is trying to run the program from the react2 directory when I started from another directory.
Any ideas as to what the error message means and how to solve it?
Jim
REACT 2 Released
Reply #1466
Why did you install it there? Well, anyways, I'm not quite sure why you are getting this error; perhaps REACT fails to read your INI file correctly.. and I don't understand how the "encoder" part of REACT runs from "C:\Program Files (x86)\React2\" if you installed it to another folder.
Have you read this: REACT:Mods - Akkurat's Mod - Documentation - Notes - Windows_Vista?
And one has to remember that Win 7 is a beta.. I've seen very bizarre problems with computers/software so it's not so far fetched to think that it could be the problem.
P.S. There's a newer mod available if you didn't know. The above link is to my mod documentation (that note also applies to Synthetic Soul's mod.. and to Win 7 (AFAIK)).
REACT 2 Released
Reply #1467
Hmm -  don't know if I'm supposed to post this as a reply, and if my question is too stupid
Anyway: I to use REACT and think it's great, THANKS.
Now I want to rip Various Artist CDs as MP3s into "Various Artists\$album$\$artist$\$title$".
But when I edit the value "TrackName_VA=xxx" in REACT.ini , my MP3s go into Nirvana, without any trace in the logs...!?
Ideas?
REACT 2 Released
Reply #1468
Ideas?
Go into Nirvana? Nirvana folder?
Check the TrackDir_MP3 setting. There you can set your directory structure. Use the TrackName_VA setting only for the filename.
REACT 2 Released
Reply #1469
Additional Meta Data Question...
I'm attempting to rip a multi disc set (Tom Petty - Playback)...  Each disc has its own disc name...  I'd like to use the additional meta data to set the disc name, disc number, total discs...  It seems that by design these are mutually exclusive.  When setting the disc name the disc number and total discs section is skipped cause of the following line.
GOTO :end_discnumber
  If I REM this out the disc name variables are overwritten...  Any ideas how I can use both the disc name, disc number and total discs?  Thanks in advance.
REM ** Create Disc-related tags if we have a set
REM If a disc name has been provided
IF "@discname@" EQU "" GOTO end_discname
SET discName=discname
SET discName=@%discname%@
IF "@discname@" EQU "%discName%" GOTO end_discname
    REM Set tagging switches
    SET Disc_Flac=-T "discname=@discname@"
    SET Disc_Wavpack=-w "discname=@discname@"
    REM SET Disc_MP3=--frame TSST:"@discname@"
    SET Disc_MP3=--frame "TXXX[setsubtitle]:@discname@"
    SET Disc_OggEnc2=-c "discname=@discname@"
    SET Disc_Tak=-t "discname=@discname@"
    SET Disc_Flac_acdir=-T $qdiscname=@discname@$q
    SET Disc_Wavpack_acdir=-w $qdiscname=@discname@$q
    REM SET Disc_MP3_acdir=--frame TSST:$q@discname@$q
    SET Disc_MP3_acdir=--frame $qTXXX[setsubtitle]:@discname@$q
    SET Disc_OggEnc2_acdir=-c $qdiscname=@discname@$q
    SET Disc_Tak_acdir=-t $qdiscname=@discname@$q
    REM Add disc name to image and track folder paths
    SET imageDir=%imageDir%\$discname$
    SET trackDir=%trackDir%\$discname$
:end_discname
REM Ensure that we have numeric values
SET /A discNumber = @discnumber@ + 0
SET /A totalDiscs = @totaldiscs@ + 0
REM IF a valid disc number and total number of discs has been provided
IF %totalDiscs% LEQ 1 GOTO :end_discnumber
IF %discNumber% LEQ 0 GOTO :end_discnumber
    SET Disc_Flac=-T "discnumber=@discnumber@" -T "totaldiscs=@totaldiscs@"
    SET Disc_Wavpack=-w "discnumber=@discnumber@" -w "totaldiscs=@totaldiscs@"
    SET Disc_MP3=--frame TPOS:"@discnumber@/@totaldiscs@"
    SET Disc_NeroAac=--disk "@discnumber@/@totaldiscs@"
    SET Disc_OggEnc2=-c "discnumber=@discnumber@" -c "totaldiscs=@totaldiscs@"
    SET Disc_Tak=-t "discnumber=@discnumber@" -t "totaldiscs=@totaldiscs@"
    SET Disc_Flac_acdir=-T $qdiscnumber=@discnumber@$q -T $qtotaldiscs=@totaldiscs@$q
    SET Disc_Wavpack_acdir=-w $qdiscnumber=@discnumber@$q -w $qtotaldiscs=@totaldiscs@$q
    SET Disc_MP3_acdir=--frame TPOS:$q@discnumber@/@totaldiscs@$q
    SET Disc_NeroAac_acdir=--disk $q@discnumber@/@totaldiscs@$q
    SET Disc_OggEnc2_acdir=-c $qdiscnumber=@discnumber@$q -c $qtotaldiscs=@totaldiscs@$q
    SET Disc_Tak_acdir=-t $qdiscnumber=@discnumber@$q -t $qtotaldiscs=@totaldiscs@$q
    REM Add disc number to image and track folder paths
    SET imageDir=%imageDir%\Disc @discnumber@
    SET trackDir=%trackDir%\Disc @discnumber@
:end_discnumber
REACT 2 Released
Reply #1470
It may be as easy as amending the code in the second part to append, not reset.  E.g.:
SET Disc_Flac=%Disc_Flac% -T "discnumber=@discnumber@" -T "totaldiscs=@totaldiscs@"
I.e.: just add "%<variable name>% " after each "=".
I assume, looking at that code, that the file structure is as expected (/<discname>/Disc <discnumber>/)?
I'm on a horse.
REACT 2 Released
Reply #1471
This does exactly what I'm looking for...  Thanks!  The directory structure is fine, I'm really not worried about the directory structure as long as metadata is correct is correct and things display correct in Foobar, SqueezeCenter , and my iPod.  Thanks again!
REACT 2 Released
Reply #1472
Just ripped by first Various Artists CD using Akkurat's latest Mod. I am ripping to FLAC image, FLAC tracks and MP3 tracks. The image and flac tracks look fine, but my MP3 files are not getting any id3 tags populated apart from the RG tags. The MP3 tracks section in my REACT_image.cfg is as follows:
IF NOT @LameMP3@==1 GOTO end_lame_tracks
    SET dest="@TrackDir_MP3@%trackDir%"
    IF NOT EXIST %dest% MKDIR %dest%
    PUSHD %dest%
        IF @various@==1 SET VA_tag=--user-text $q[album artist]@VA@$q --frame $qTPE2:@VA@$q
IF %embed_cover%==1 SET Cover_tag=--frame $#x
@tools@\acdir.exe --overwrite --output "%TrackName%.mp3" --extra-opt "APIC{3}:%
cover%" --pipe "TITLE $n/$N mp3 $#T & @tools@\lame.exe @Opt_LameMP3@ %ApplyAG_Lame% -
 $#o & @tools@\metamp3.exe --2 %Cover_tag% %VA_tag% %Disc_MP3_acdir% --artist $#a --
album $q@year@: $T$q --title $#t --track $n --year $q@year@$q --genre $q@genre@$q --comment
 $q%Comment_tag%$q --frame $qTXXX[Listened to]:No$q --frame TENC:$q%USERNAME%$q --
frame TSSE:$qLAME @Ver_LameMP3@ @Opt_LameMP3_tag@$q $#o" "@sourcecuesheet@"
IF %add_rg%==1 @tools@\Glob.exe -v -c @tools@\metamp3.exe --2 %RG_MetaMP3% *.mp3
IF @ApplyAlbumGain@==1 @tools@\Glob.exe -v -c @tools@\metamp3.exe --2 %ApplyAG_MetaMP3% *.mp3
REM    COPY /Y "@eaclog@" "EAClog.log"
        IF %have_cover%==1 COPY /Y "%cover%" "Folder.jpg"
IF %have_cover%==1 COPY /Y "%cover_small%" "AlbumArtSmall.jpg"
REM    IF @CreatePlaylist@==1 @tools@\tag.exe --playlist --onlyfiles --sort track --plname "$artist$ - $album$.m3u" *.mp3
        IF @CreatePlaylist@==1 @tools@\tag.exe --playlist --sort track --plname "$artist$ - $album$.m3u" *.mp3
    POPD
:end_lame_tracks
Any ideas?
REACT 2 Released
Reply #1473
Sorry again for the late answer, as I told you in my email, HA forum seems to bug out, I got no email notification of your post (I've been logging in/out after every new notification so that I'd get a notification also for the next post.. so it's not the new behavior of the notification setting).
You have updated metamp3? It seems that you forgot to change the
line into
IF @various@==1 SET VA_tag=--frame $qTXXX[album artist]:@VA@$q --frame $qTPE2:@VA@$q
The "--user-text" is no longer supported in the newest version of metamp3.
REACT 2 Released
Reply #1474
In latest beta(2.0.akku.b03), then changing the ripping directory in EAC after doing CTRL+F2 dosen't have any effect, since EAC changes and uses the 'DirectorySpecification' regkey, while with REACT then the 'ActualPath' regkey is used instead for determining ripping directory.
Personally, then i would suggest to change it back as the way Neil had done it with the CTRL+F2  synching of ripping directories, as the new scheme IMHO dosen't make much sence even if it worked right, i mean, why ignoring the EAC defined ripping directory in favor of My Music???
I can fix this manually by changing the registry directly, but just wanted to report it(sorry if it's done allready).
Also, i understand that the syntax of the CFGs is done with the old metamp3 in mind, but then isn't e.g. this wrong in the image cfg(new metamp3 beta syntax):
Thanks for your work on REACT!
