Topic: [Not my release] foo_uie_panel_splitter (Read 411787 times) previous topic - next topic
Reply #150
Is it possible to give portions of PSS TF mode "now playing" when "titleformat mode on startup: follow cursor" is selected?
How can i do it?
i don't think so, it only set for the full PSS panel area... but maybe i'm wrong
Reply #151
hi, I'm a new pss user and I want to ask how can I emulate tabs like in cui?
heres  my simple config and I want to replace the tab stack with something prettier...
http://img3.imagebanana.com/view/lti49rd0/fb2k.jpg
Make a button for each tab, and use the PANELSHOW command in order to show or hide panels. You need the function $isvisible_c() to set your context.
How can i do it?
Just use more PSS's to show what you need with pseudo transparency enabled.  You won't notice any difference.
<insert signature here>
Reply #152
I once again have a little problem:
I have hidden ng playlists vertical scrollbar by placing ng playlist in a child PSS and inserted it in the main PSS.
Now i wanted to show the scrollbar if needed with a button and inserted a blank tab stack (hidden on startup and called "Scrollbar") in the child PSS.
But something's wrong!
I see the buttons and they show/hide the scrollbar, but only partially and non-functional! And the buttons doesn't show the mousehover images (only when i move the mouse over a blank part of the child PSS. Then the mousehover image is shown durable).
Here is my code:
$puts(imagepath,C:\Programme\foobar2000\Appearance\)
$if($isvisible_c(Scrollbar),$imagebutton($sub(%_width%,10),0,10,10,$get(imagepath)Scroll2.png,$get(imagepath)Scroll2MH.png,PANELSHOW:Scrollbar:0;REFRESH,,)$movepanel_c(Playlist,0,10,%_width%,$sub(%_height%,10)),
$imagebutton($sub(%_width%,10),0,10,10,$get(imagepath)Scroll1.png,$get(imagepath)Scroll1MH.png,PANELSHOW:Scrollbar:1;REFRESH,,)$movepanel_c(Playlist,0,10,$add(%_width%20),$sub(%_height%,10)))
What have i done wrong?
Or does anyone know a better solution?
EDIT
I found a workaround.
I added the ng playlist twice in the child pss panel.
One with %_width% and one with $add(%_width%,20) (to hide the scrollbar) and switch with a button.
But it increases memory load and i wanted to keep my config as light as possible...
Any other ideas?
Reply #153
i did one text button to show on my El_Playlist other playlist, like an auto playlist named "Most Played" but what command need i use on this button to change playlist?
i saw the command File/Next Playlist
but i want one named playlist
sorry for a bad english =/
if you dont understand what i want i can try to ask again
thx anyway
bb
Reply #154
Hey, does somebody know how to set buttons in the splitter with commands providen by foo_run?
I'm using the latest panel_stack_splitter but no luck with that suff...
Reply #155
Unfortunately, I don't think there's a way to do this. At least I haven't been able to find one.
Reply #156
it seems that PSS do not support foo_run commands, really a shame. So, i use a trackinfo_mod panel çin the PSS just for these foo_run buttons
Reply #157
Oho, so you *can* use foo_run commands in trackinfo_mod? Now that I did not know. Awesome!
Reply #158
In trackinfo_mod there is SYSCOL-n to use system colours, but is there something similar in PSS?
I want to make a rectangle in the background that should automatically change colour when changing the visual style.
Is it possible?
Reply #159
Is it possible?
i don't think so ...
Reply #160
False!
@tedgo:
You can use $getsyscolour(n) instead SYSCOL-n. I use that a lot since it returns a color in the R-G-B format.
Cheers!
Reply #161
@xbullethammer
Ah, many thanks. I'll try it immediately
EDIT:
Yes, works perfect.
Many thanks again
Reply #162
thx anyway
bb
I second this question, is there any way to change the playlist to a particular playlist using a PSS button?
Reply #164
It is possible, using foo_scheduler, to add a menu command which switches to a specific playlist, which can then be tied to a button on the standard Columns UI toolbar.
I don't know if it can be made into a button in Panel Stack Splitter, though; it may run into the same issues that foo_run commands do. (Or it may not; I haven't actually tried doing this.)
Reply #165
Ok thanks.
Another question is, is there anyway for the pss to tell whether the current playback mode is random or shuffle(album) or whatever?
Reply #166
according to my knowledge level, it's not possible to use a button in order to activate a specific playlist.
I couldn't find anything regarding activation of a specific playlist, but there is the Context Commands of "Main Menu/File/Next Playlist" and "Main Menu/File/Previous Playlist".  You would need to add them into your current Context Commands in the Preferences though.  Then you could have buttons using those commands to cycle back-and-forth between the playlists.
Actually, it should already be in the splitter settings.  The Menu Commands are "File/Next Playlist" and "File/Previous Playlist".
Reply #167
is something like $glass() possible with PSS?
Reply #168
Is there something like "$fileexist()"?
I want to add an artist picture and want to write text on its place, only when there's no picture available (like "- Image not available. Please recheck the path to your image folder! -" or something similar).
I have some very very small pictures and when i just place the picture over the written words it looks like
- Im[PICTURE]er! -...
Reply #169
You can use "$findfile(path)"
Reply #170
@bulhakov
Tried it already but that displays nothing...
I tried
$if($findfile('D:\Artist Pics\%artist%.jpg'),$drawtext(...),)
and nothing happened.
Is there a logical flaw in my string?
Did i used $findfile() the wrong way?
Reply #171
for me $findfile doesn't work under PSS (it does in ELPlaylist)
Reply #172
So my string should work (if PSS would do it...)
Reply #173
It works for me in the latest version of PSS, but not earlier versions:
$if2($findfile($directory_path(%path%)/folder.jpg),images\nocover.png)
Reply #174
Sorry guys, i'm too dumb. I forgot a bracket...
It works excellent.
