@DiGiCharat: I use Segoe UI. This font comes with Vista or Office 2007 and maybe .NET 3.0 and 3.5 too AFAIK.
Well here's the updated version of my Graphical Browser config:
Popup now has album art in it.
Item code:
//cover sources, if you add more sources please add more $draw_image functions below
$puts(cpath1,$replace(%path%,%filename_ext%,*))
$puts(cpath2,$replace(%path%,%directory%\%filename_ext%,*))
//no cover source, remember to change this if needed
$puts(nocover,components\default.png)
//other image sources
$puts(glareImage,components\glareyo0.png)
$puts(playIcon,components\Play-icon256-by-nagaya.png)
//font settings
$puts(fontName,Segoe UI)
$puts(fontSize,9)
//dimensions and positions of objects
$puts(itemW,$eval(%gb_width%-1))
$puts(itemH,$eval(%gb_height%-1))
$puts(frameD,$eval(%gb_height%-8))
$puts(frameCu,$eval(%gb_height%/30))
$puts(coverD,$eval($get(frameD)-4))
$puts(textX,$eval($get(frameD)+7))
$puts(textW,$eval(%gb_width%-$get(textX)-4))
$puts(textH,$eval(%gb_height%-20))
$puts(subitem_countY,$eval($get(textH)+6))
//check whether item is playing
$puts(isplaying,$if($and($strcmp(%cwb_activelist%,%cwb_playinglist%),
$greater($add(%gb_playlist_number%,%gb_subitem_count%,1),%cwb_playing_index%),
$greater(%cwb_playing_index%,%gb_playlist_number%)),
1,))
$if(%gb_focused%,
$set_pen(44-98-139)
$draw_rect(0,0,$get(itemW),$get(itemH))
$gp_set_brush(255-109-182-221,0,%gb_height%,0-255-255-255,0,0)
$gp_fill_rectangle(1,1,$eval(%gb_width%-2),$eval(%gb_height%-2)),
$set_brush(240-240-240,cross)
$fill_rect(0,0,%gb_width%,%gb_height%)
$select($add($mod(%gb_item_index%,2),1),
$gp_set_brush(100-200-200-200),
$gp_set_brush(100-240-240-240)
$gp_fill_rectangle(0,0,%gb_width%,%gb_height%)
$set_pen(0-0-0)
$set_brush(0-0-0)
$round_rect(5,4,$get(frameD),$get(frameD),$get(frameCu),$get(frameCu))
//add more cover sources here
$if3(
$draw_image(7,6,$get(coverD),$get(coverD),$get(cpath1),255,nokeepaspect),
$draw_image(7,6,$get(coverD),$get(coverD),$get(cpath2),255,nokeepaspect),
$draw_image(7,6,$get(coverD),$get(coverD),$get(nocover),255,nokeepaspect)
$draw_image(7,6,$get(coverD),$get(coverD),$get(glareImage),50,nokeepaspect)
$if($get(isplaying),
$draw_image(7,6,$get(coverD),$get(coverD),$get(playIcon),128)
$set_font($get(fontName),$get(fontSize))
$draw_text($get(font) %gb_group% $get(font),$get(textX),6,$get(textW),$get(textH),right,wordbreak,word_ellipsis)
$set_font($get(fontName),$get(fontSize),i)
$draw_text(%gb_item_index%/%gb_item_count% %gb_subitem_count%
$ifgreater(%gb_subitem_count%,1, tracks, track),
$get(textX),$get(subitem_countY),$get(textW),12,right,singleline,bottom)
$if(%gb_mouse_over%,
$gp_set_brush(128-255-255-255,0,0,0-255-255-255,%gb_width%,%gb_height%)
Popup code:
//Dimensions
$puts(coverD,$eval(%gb_width%-8))
$puts(textY,$eval($get(coverD)+6))
$puts(textH,$eval(%gb_height%-$get(textY)-2))
//Font setting for artist display
$gp_set_font(Segoe Print,9)
$gp_set_brush(255-128-128-128)
$gp_set_pen(255-0-0-0,1)
$gp_draw_rectangle(0,0,$eval(%gb_width%-1),$eval(%gb_height%-1))
$if3(
$draw_image(4,4,$get(coverD),$get(coverD),$get(cpath1),255),
$draw_image(4,4,$get(coverD),$get(coverD),$get(cpath2),255),
$draw_image(4,4,$get(coverD),$get(coverD),$get(nocover),255)
$gp_set_brush(255-218-218-218)
$gp_set_text_rendering_hint(ct)
$gp_set_string_format(center,center)
$if(%album artist%,
$gp_draw_string(by %album artist%,0,$get(textY),%gb_width%,$get(textH)),
Unknown Artist
Popup size: height should be bigger than width. I use 200x240.
Other settings and requirements are the same as [a href=\"http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=61412&view=findpost&p=551336\" target=\"_blank\"]my previous post[/url].
EDIT: Small change: make it easier to change font for item display.
