Topic: foo_uie_graphical_browser (Read 245184 times) previous topic - next topic
Reply #100
Kiteroa
thx,
$replace(%path%,%filename_ext%,)../cover.jpg
works fine
Reply #101
hmmm.... im using $rand(10) to display no cover art pics..
i noticed that when i mouse over the pic it changes.. not a problem
my problem is im on a pos computer and its using alot of memory.
so i was thinking is there a way to load images according to First Letter of album or something similar?
exp: $if(%artist%, First Letter T, NoCover2.jpeg,First Letter M, NoCover5.jpeg)
Edit: I Figgered a work around... I have the $rand() Looking inside the code instead of looking tho my computer.
$puts(nocover0,C:\Program Files\Foobar\images\NoCover2\nocover0.jpeg)
$puts(nocover1,C:\Program Files\Foobar\images\NoCover2\nocover1.jpeg)
$puts(nocover2,C:\Program Files\Foobar\images\NoCover2\nocover2.jpeg)
$puts(nocover3,C:\Program Files\Foobar\images\NoCover2\nocover3.jpeg)
$puts(nocover4,C:\Program Files\Foobar\images\NoCover2\nocover4.jpeg)
$puts(nocover5,C:\Program Files\Foobar\images\NoCover2\nocover5.jpeg)
$puts(nocover6,C:\Program Files\Foobar\images\NoCover2\nocover6.jpeg)
$puts(nocover7,C:\Program Files\Foobar\images\NoCover2\nocover7.jpeg)
$puts(nocover8,C:\Program Files\Foobar\images\NoCover2\nocover8.jpeg)
$puts(nocover9,C:\Program Files\Foobar\images\NoCover2\nocover9.jpeg)
$puts(nocover10,C:\Program Files\Foobar\images\NoCover2\nocover10.jpeg)
$puts(nocover11,C:\Program Files\Foobar\images\NoCover2\nocover11.jpeg)
$puts(nocover12,C:\Program Files\Foobar\images\NoCover2\nocover12.jpeg)
$draw_image(0,0,$eval(%gb_width%),$eval(%gb_width%),
$if($cwb_fileexists($replace(%path%,%filename_ext%,)folder.jpeg),
$replace(%path%,%filename_ext%,)folder.jpeg,
$if($cwb_fileexists($replace(%path%,%filename_ext%,)folder.jpg),
$replace(%path%,%filename_ext%,)folder.jpg,
$get(nocover$rand(12))
255,nokeepaspect)
If any1 has a better way plz let me know but with my basic skillz thats what i got
Reply #102
Whenever I need "sufficiently random" numbers, I use a combination of the mod/length functions, as in
$mod($len(%album artist%%album%),###)
I know others have used the $crc32 function to similar effect.
Reply #103
ok Ty  i havnt played with the $mod or $len yet and never heard of $crc32, ill tinker around and see what i can get
Reply #104
@BuM: in your code, you should use $select instead of using a bunch of custom variables. It's faster and has less overhead. The mod len combi is a little faster but the variation is worse than crc32. I don't know how $rand is implemented in foobar but anyway crc32 calculation time is proportion to length of strings so more often than not I think $rand is faster especially in case the pool is small like yours.
Reply #105
New version is out.
From the change log, there's %gb_isplaying% command (among others) which may make some of you really happy.
Reply #106
Yeah, me included, but this new version has so much more to be happy with. It's just getting better and better.
@Keikonium: I've sent you the new readme.
Reply #107
Thanks for a great update - I love the per-track pop-up and am using it already!
Reply #108
Updated config:
Require graphical browser rev010
Images required:
Play icon
Glare image
Put those images into foobar components folder, or any other places you like. In this case, you need to change the path for these images.
Prominent changes: all are in popup rendering:
* Half transparent popup background frame.
* Display currently playing song in popup of the currently playing item.
* Total length of item and total played times.
* [!--sizeo:2--][span style=\"font-size:10pt;line-height:100%\"][!--/sizeo--]Arithmetic mean album rating.[/size][!--sizeo:2--][span style=\"font-size:10pt;line-height:100%\"][!--/sizeo--] Later, I might be able to do weighted mean album rating [/size][!--sizeo:2--][span style=\"font-size:10pt;line-height:100%\"][!--/sizeo--](using play_count statistic)[/size][!--sizeo:2--][span style=\"font-size:10pt;line-height:100%\"][!--/sizeo--] with future version of this component.
[/size]
Settings:
As before, you have some freedom with item size and popup size. For item size, horizontal size is about double of vertical size. And for popup size, vertical size is bigger (about 40 pixels is best) than horizontal size. Remember that, if you set those sizes too small, everything will be out of order. But with suitable size, my code will automatically set itself in fine.
Item code:
//cover sources, if you add more sources please add more $draw_image functions below
$puts(cpath1,$replace(%path%,%filename_ext%,*))
$puts(cpath2,$replace(%path%,%directory%\%filename_ext%,*))
//no cover source, remember to change this if needed
$puts(nocover,components\default.png)
//other image sources
$puts(glareImage,components\glareyo0.png)
$puts(playIcon,components\Play-icon256-by-nagaya.png)
//font settings
$puts(fontName,Segoe UI)
$puts(fontSize,9)
$puts(fontStyle1,)
$puts(fontStyle2,i)
//dimensions and positions of objects
$puts(itemW,$eval(%gb_width%-1))
$puts(itemH,$eval(%gb_height%-1))
$puts(frameD,$eval(%gb_height%-8))
$puts(frameCu,$eval(%gb_height%/30))
$puts(coverD,$eval($get(frameD)-4))
$puts(textX,$eval($get(frameD)+7))
$puts(textW,$eval(%gb_width%-$get(textX)-4))
$puts(textH,$eval(%gb_height%-20))
$puts(subitem_countY,$eval($get(textH)+6))
$if(%gb_focused%,
$set_pen(44-98-139)
$draw_rect(0,0,$get(itemW),$get(itemH))
$gp_set_brush(255-109-182-221,0,%gb_height%,0-255-255-255,0,0)
$gp_fill_rectangle(1,1,$eval(%gb_width%-2),$eval(%gb_height%-2)),
$set_brush(240-240-240,cross)
$fill_rect(0,0,%gb_width%,%gb_height%)
$select($add($mod(%gb_item_index%,2),1),
$gp_set_brush(100-200-200-200),
$gp_set_brush(100-240-240-240)
$gp_fill_rectangle(0,0,%gb_width%,%gb_height%)
$set_pen(0-0-0)
$set_brush(0-0-0)
$round_rect(5,4,$get(frameD),$get(frameD),$get(frameCu),$get(frameCu))
//add more cover sources here
$if3(
$draw_image(7,6,$get(coverD),$get(coverD),$get(cpath1),255,nokeepaspect),
$draw_image(7,6,$get(coverD),$get(coverD),$get(cpath2),255,nokeepaspect),
$draw_image(7,6,$get(coverD),$get(coverD),$get(nocover),255,nokeepaspect)
$draw_image(7,6,$get(coverD),$get(coverD),$get(glareImage),50,nokeepaspect)
$if(%gb_isplaying%,
$draw_image(7,6,$get(coverD),$get(coverD),$get(playIcon),128)
$set_font($get(fontName),$get(fontSize),$get(fontStyle1))
$draw_text(%gb_group%,$get(textX),6,$get(textW),$get(textH),right,wordbreak,end_ellipsis)
$set_font($get(fontName),$get(fontSize),$get(fontStyle2))
$draw_text($add(%gb_item_index%,1)/%gb_item_count% %gb_track_count%
$ifgreater(%gb_track_count%,1, tracks, track),
$get(textX),$get(subitem_countY),$get(textW),12,right,singleline,bottom)
$if(%gb_mouse_over%,
$gp_set_brush(128-255-255-255,0,0,0-255-255-255,%gb_width%,%gb_height%)
Popup code:
//Font settings for artist display
$puts(aFontName,Segoe Print)
$puts(aFontSize,9)
$puts(aFontStyle,)
//Font settings for item info
$puts(iFontName,Arial)
$puts(iFontSize,9)
$puts(iFontStyle,)
//Dimensions
$puts(coverD,$eval(%gb_width%-8))
$puts(textY,$eval($get(coverD)+6))
$puts(textH,$eval(%gb_height%-$get(textY)-2))
$puts(textW,$eval(%gb_width%-4))
$puts(infoY,$eval(%gb_width%-24))
//Album rating calculation
$puts(temp,$muldiv($sum('%rating%'),100,%gb_track_count%))
$puts(aRating,
$ifgreater($get(temp),449,5,
$ifgreater($get(temp),349,4,
$ifgreater($get(temp),249,3,
$ifgreater($get(temp),149,2,
$ifgreater($get(temp),49,1,
0
$gp_set_brush(128-128-128-128)
$gp_set_pen(255-0-0-0,1)
$gp_draw_rectangle(0,0,$eval(%gb_width%-1),$eval(%gb_height%-1))
$if3(
$draw_image(4,4,$get(coverD),$get(coverD),$get(cpath1),255),
$draw_image(4,4,$get(coverD),$get(coverD),$get(cpath2),255),
$draw_image(4,4,$get(coverD),$get(coverD),$get(nocover),255)
$gp_set_font($get(aFontName),$get(aFontSize),$get(aFontStyle))
$gp_set_pen(255-255-255-255,3,,bevel)
$gp_set_brush(255-0-0-0)
$gp_set_string_format(center,center,ellipsis_word)
$gp_set_smoothing_mode(1)
$gp_draw_string_path($if(%album artist%,by %album artist%,Unknown Artist),12,,0,$get(textY),$get(textW),$get(textH)),
$gp_set_font($get(iFontName),$get(iFontSize),$get(iFontStyle))
$gp_set_string_format(far,center)
$gp_draw_string_path(%gb_length% #$sum('%play_count%'),12,,4,$get(infoY),$get(coverD),20)
$gp_set_string_format(near,center)
$repeat(★,$get(aRating))
$repeat(☆,$sub(5,$get(aRating)))
If you're using WinXP, you need to have East Asian languages support. Those rating star characters need it.
Per track (Popup) code:
//Font settings for playing track
$gp_set_font(Tahoma,9,b)
$gp_set_pen(128-255-255-255,3,,bevel)
$gp_set_string_format(center,near)
$if(%gb_isplaying%,
$set_org(6,6)
$gp_draw_string_path([%tracknumber%. ]%title%,12,,0,0,$eval(%gb_width%-12),$eval(%gb_width%-32))
Lastly, I want to thank the developer of this component again. All of this wouldn't have been possible, if he hadn't started it.
EDIT: Add one to %gb_item_index%.
EDIT2: Fix some mistakes and add rounded rating.
Reply #109
Looking Good thuan, Thank you and every1 else for posting ur configs.
for ppl that learn from seeing(like me) it really helps
Reply #110
with the last version, 0.10, it's not possible to desactivate the  graphical browser scroll bar.
It was desactivable with the 0.9 version :
right click > settings > bottom right :
- show scroll bar
- scroll by a multiple of scroll size
- scroll size
no more choice ?
Reply #111
Those settings are in the Others Tab beside Draw Tab. Look at the 2nd picture in my previous post.
Reply #112
oh yeah !!!!
I'm stupid !!!  or, may be, becoming too old.......
Thanks, thuan.
Reply #113
Thanks for this great component!
But what is the function of the "transparent mode" checkmark in the options dialog?
Reply #114
Does anyone know how to get the track list of an album to display in the popup? I can get the currently playing track, but I want them all... Kinda like in this image: http://foobar2000.xrea.jp/up/files/up808.jpg
Also, rev011 is out if anyone hasn't updated yet . http://www.tv2ch.info/fb2k/
Song List: keikoniumboards.ke.funpic.org/files/songlist.html
Reply #115
This works for me:
$set_org(0,$mul(12,%gb_track_index%))
$if(%gb_isplaying%,$gp_set_brush(255-0-255-0),$gp_set_brush(255-0-0-0))
$gp_set_font(Tahoma,9)
$gp_set_string_format(near,near,ellipsis_word)
$gp_draw_string(%gb_playlist_number% $add(%gb_track_index%,1). %title%,0,0,%gb_width%,15)
Make sure you have "maximum tracks processed by "Per Track" set suitably high on the Others tab.
To the developer - thanks again!
I'm still getting a problem with albums with the same name where all the tracks appear under the first listing for the album - even though the tracks are in different parts of the playlist. Could you fix it so that the tracks for an album group only show only under that album?
Also, I'd love to be able to fix the display to a particular named playlist - not just the active playlist which I keep changing all the time!
Reply #116
Ah! My problem was that I had the tracks processed by // PerTrack was set to 0 lol. Thanks Kiteroa .
Also, I don't know if anyone else noticed this, but when you type a $ and wait a couple seconds, a box will pop up with the possible variables you can use... REALLY awesome.
Reply #117
Read the readme I translated in the first post. Basically, with it, you can set different transparent levels for each object you draw using GDI+. My config uses that, too.
This works for me:
And here is a code snippet to draw dynamically height popup:
$puts(recH,$add($mul(%gb_track_count%,18),46)) //46 is the static part and 18 is verticle size of each line.
//then draw a rec or whatever using the appropriate function
$draw_rect(0,0,$eval(%gb_width%-1),$get(recH))
I have tried to mimic that up808 popup config, it's pretty easy to write. The problem is with it, you have to set a very high value for vertical popup size (to accommodate long item). This pose a problem, with my vertical scroll config (unlike his is a horizontal one and drawn at upper of the screen), that is sometimes with lower item that has little tracks in it, the popup appears at the upper of the screen and not beside the mouse which looks really weird  . I have also think of a dynamic horizontal size popup with multiple tracklist columns on it. It's feasible, will do that later when I have the time.
This is actually hard to fix consider how this component works (grouping item by group titleformat which return group strings). You should do something with your group titleformat yourself or the tag of particular items to return different group strings. It can be fixed with some workaround on his side but oh well, I think this is more of a problem of your group string titleformat. Why not group items which return the same group string together?
I have mailed the developer about this, he said that this will likely be implimented when he has the time, please be patient.
Reply #118
This works for me:
I cannot seem to change the font color of the tracklist. Can I get a little help? Either it can't be done, or I am just overlooking something..whatever I do the font color stays constant.
TIA
Reply #119
Change the $gp_set_brush parameter to change the color of text drawn by $gp_draw_string function. In this code the first one is color for playing song and the 2nd is for other songs.
Reply #120
Wow, revision 11 introduces keyboard letter navigation.
Not quite what I expected (different from Album list and Filter), but still great. Thanks to the developer.
Reply #121
Rev 12 now out.
I love π
Reply #122
Changelog:
   2008/03/11   rev012
      Fixed - Resource fatal leak.
      Added - Image cache options.
The new image cache option (default) does not purges the cache when you change playlists and it has an upper limit compares to the old way.
Reply #123
rev013 is now out. Looks like it fixed some selection, and GDI Bugs.
Reply #124
Some display bugs when playing with the option 'Image Cache' (vertical shift of picture of 1 or 2 pixels)
but ok with Old cache mode
So, here is just a try inspired by Delicious Library style :
what about this gb layout ?
