Topic: foo_bubble_coverflow (Read 422051 times) previous topic - next topic
Reply #325
I don't use CUI.
Ah sorry, I though it was necessary for dockable panels to work.
Note: my  fb 0.9.5.1 config is very minimalistic: just dockable panels and facets as additional components
Reply #326
Open a new dockable panel, rightclick add>coverflow.
Cover Flow opened in it's own window, I closed the window and right-clicked on the panel.
Same occurs when I try to close the panel.
If I run it in it's own window, the following occurs (sorry if these are "known")
1) won't bind to facets playlist
2) freezes system with large playlists (over 100 covers)
crash
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 090E4572h
Access violation, operation: read, address: DDDDDE09h
Call path:
entry=>app_mainloop
Code bytes (090E4572h):
090E4532h:  70 08 C7 00 B0 E3 0F 09 C7 40 04 B8 E3 0F 09 89
090E4542h:  70 10 89 70 14 89 70 18 C7 40 0C D8 E3 0F 09 8B
090E4552h:  F0 85 F6 89 74 24 20 74 0A 8D 4E 08 51 FF 15 AC
090E4562h:  C0 0F 09 C7 44 24 70 07 00 00 00 8B 4B 24 8B 11
090E4572h:  8B 42 2C 56 FF D0 FF 15 C0 C1 0F 09 8B F8 57 E8
090E4582h:  BA 52 00 00 8B 53 20 8B 45 14 6A 00 52 6A 00 0F
090E4592h:  B7 C8 C1 E8 10 50 51 68 80 01 00 00 57 FF 15 5C
090E45A2h:  C1 0F 09 85 C0 7E 05 E8 E2 52 00 00 57 FF 15 E0
Stack (0012F9F4h):
0012F9D4h:  00000000 0012FB98 0012FB70 00000000
0012F9E4h:  A8E84AC8 00000001 804DA3EE A8E84B00
0012F9F4h:  116D2542 0012FAD0 090E4000 00000000
0012FA04h:  012D05B4 00000020 000001A4 02000001
0012FA14h:  09132498 0000029E 00000000 0012FB18
0012FA24h:  7E41B33C 00000000 02000001 09B2FB00
0012FA34h:  09B2FB00 0012FA58 09A59A98 0012FC00
0012FA44h:  00740140 09B2FB00 09B2FB00 0012FA70
0012FA54h:  09A59A98 012D05B4 0012FAF0 090FB3D8
0012FA64h:  00000007 0012FA94 7E418734 011C058E
0012FA74h:  0000007B 011C058E 01D102A3 090E4000
0012FA84h:  DCBAABCD 00000000 0012FAD0 090E4000
0012FA94h:  0012FB00 7E423745 090E4000 011C058E
0012FAA4h:  0000007B 011C058E 01D102A3 0000007B
0012FAB4h:  011C058E 0075A740 00000014 00000001
0012FAC4h:  00000000 00000000 00000010 00000000
0012FAD4h:  0C1620B4 00000000 00000000 00000000
0012FAE4h:  00000000 0012FAB0 0012F618 0012FCC4
0012FAF4h:  7E440457 7E423768 00000000 0012FB48
0012FB04h:  7E423591 00000000 090E4000 011C058E
Registers:
EAX: 00000001, EBX: 09135088, ECX: 08EDA3B0, EDX: DDDDDDDD
ESI: 09132498, EDI: 011C058E, EBP: 0012FA68, ESP: 0012F9F4
Crash location: "foo_dockable_panels", loaded at 090E0000h - 09113000h
Loaded modules:
foobar2000                      loaded at 00400000h - 00523000h
ntdll                            loaded at 7C900000h - 7C9B0000h
kernel32                        loaded at 7C800000h - 7C8F5000h
COMCTL32                        loaded at 773D0000h - 774D3000h
msvcrt                          loaded at 77C10000h - 77C68000h
ADVAPI32                        loaded at 77DD0000h - 77E6B000h
RPCRT4                          loaded at 77E70000h - 77F02000h
Secur32                          loaded at 77FE0000h - 77FF1000h
GDI32                            loaded at 77F10000h - 77F57000h
USER32                          loaded at 7E410000h - 7E4A0000h
SHLWAPI                          loaded at 77F60000h - 77FD6000h
SHELL32                          loaded at 7C9C0000h - 7D1D6000h
ole32                            loaded at 774E0000h - 7761D000h
shared                          loaded at 10000000h - 1002A000h
COMDLG32                        loaded at 763B0000h - 763F9000h
foo_abx                          loaded at 003C0000h - 003F3000h
foo_albumlist                    loaded at 00A30000h - 00A97000h
foo_audioscrobbler              loaded at 00AC0000h - 00AF8000h
WS2_32                          loaded at 71AB0000h - 71AC7000h
WS2HELP                          loaded at 71AA0000h - 71AA8000h
foo_bubble_coverflow            loaded at 00B60000h - 00EA2000h
OPENGL32                        loaded at 5ED00000h - 5EDCC000h
GLU32                            loaded at 68B20000h - 68B40000h
DDRAW                            loaded at 73760000h - 737A9000h
DCIMAN32                        loaded at 73BC0000h - 73BC6000h
gdiplus                          loaded at 4EC50000h - 4EDF3000h
UxTheme                          loaded at 5AD70000h - 5ADA8000h
foo_converter                    loaded at 08EE0000h - 08F49000h
foo_custominfo                  loaded at 08F70000h - 08FF5000h
foo_cwbowron                    loaded at 09020000h - 09048000h
foo_cwb_hooks                    loaded at 09070000h - 090BC000h
foo_dockable_panels              loaded at 090E0000h - 09113000h
foo_facets                      loaded at 09140000h - 091C0000h
OLEAUT32                        loaded at 77120000h - 771AB000h
MSIMG32                          loaded at 76380000h - 76385000h
foo_fileops                      loaded at 091E0000h - 09226000h
foo_info_samurize                loaded at 09250000h - 09272000h
foo_input_std                    loaded at 093B0000h - 094D8000h
foo_masstag                      loaded at 09500000h - 09550000h
foo_navigator                    loaded at 09570000h - 095A1000h
foo_out_asio                    loaded at 095D0000h - 095FF000h
foo_playcount                    loaded at 09620000h - 09645000h
foo_quicktag                    loaded at 09670000h - 096AE000h
foo_rgscan                      loaded at 096D0000h - 0972A000h
foo_run                          loaded at 09750000h - 0977B000h
foo_scheduler                    loaded at 097A0000h - 0980F000h
POWRPROF                        loaded at 74AD0000h - 74AD8000h
WINMM                            loaded at 76B40000h - 76B6D000h
usbnp4x4                        loaded at 6BD00000h - 6BD1A000h
foo_scrobblecharts              loaded at 098B0000h - 098E3000h
WININET                          loaded at 771B0000h - 77256000h
CRYPT32                          loaded at 77A80000h - 77B14000h
MSASN1                          loaded at 77B20000h - 77B32000h
foo_skip                        loaded at 09910000h - 0992B000h
foo_tradersfriend                loaded at 09950000h - 0998A000h
foo_uie_lyrics                  loaded at 099C0000h - 09A1F000h
foo_ui_std                      loaded at 09A40000h - 09B01000h
foo_utils                        loaded at 09B30000h - 09BA9000h
mswsock                          loaded at 71A50000h - 71A8F000h
DNSAPI                          loaded at 76F20000h - 76F47000h
iphlpapi                        loaded at 76D60000h - 76D79000h
hnetcfg                          loaded at 662B0000h - 66308000h
wshtcpip                        loaded at 71A90000h - 71A98000h
rasadhlp                        loaded at 76FC0000h - 76FC6000h
ig4icd32                        loaded at 0BFA0000h - 0C1E9000h
ig4dev32                        loaded at 0C1F0000h - 0C362000h
imagehlp                        loaded at 76C90000h - 76CB8000h
DBGHELP                          loaded at 59A60000h - 59B01000h
VERSION                          loaded at 77C00000h - 77C08000h
Stack dump analysis:
Address: 090E4000h, location: "foo_dockable_panels", loaded at 090E0000h - 09113000h
Address: 7E41B33Ch, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DefWindowProcW" (+00000000h)
Address: 09A59A98h, location: "foo_ui_std", loaded at 09A40000h - 09B01000h
Address: 090FB3D8h, location: "foo_dockable_panels", loaded at 090E0000h - 09113000h
Address: 7E418734h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetDC" (+0000006Dh)
Address: 7E423745h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "PrivateExtractIconExW" (+000002B2h)
Address: 0C1620B4h, location: "ig4icd32", loaded at 0BFA0000h - 0C1E9000h
Symbol: "DrvCreateContext" (+00001424h)
Address: 7E440457h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E423768h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "PrivateExtractIconExW" (+000002D5h)
Address: 7E423591h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "PrivateExtractIconExW" (+000000FEh)
Address: 0C161FA0h, location: "ig4icd32", loaded at 0BFA0000h - 0C1E9000h
Symbol: "DrvCreateContext" (+00001310h)
Address: 7E41B50Ch, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DefWindowProcW" (+000001D0h)
Address: 7C90EAE3h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "KiUserCallbackDispatcher" (+00000013h)
Address: 7E423512h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "PrivateExtractIconExW" (+0000007Fh)
Address: 7E4194BEh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetWindowLongA" (+00000061h)
Address: 7E42F586h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "SetWindowTextA" (+0000005Bh)
Address: 7E423761h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "PrivateExtractIconExW" (+000002CEh)
Address: 7E42366Bh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "PrivateExtractIconExW" (+000001D8h)
Address: 7E42379Ah, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DefDlgProcW" (+00000000h)
Address: 7E4184FCh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E4185A4h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E4237BCh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DefDlgProcW" (+00000022h)
Address: 7E418816h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetDC" (+0000014Fh)
Address: 7E418830h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetDC" (+00000169h)
Address: 7E4189CDh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetWindowLongW" (+00000127h)
Address: 7E41DAEAh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DestroyWindow" (+00000000h)
Address: 7E42D950h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "IsDialogMessageW" (+0000008Eh)
Address: 7E4189F0h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetWindowLongW" (+0000014Ah)
Address: 7E418A10h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DispatchMessageW" (+0000000Fh)
Address: 0042C161h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 10002638h, location: "shared", loaded at 10000000h - 1002A000h
Symbol: "uPrintCrashInfo_SetDumpPath" (+000000C8h)
Address: 0041DAEAh, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 0042CCE4h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 004CBDC8h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 004D4B70h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 00400000h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 004D4B54h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 7C90EE18h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "strchr" (+00000117h)
Address: 004A3443h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 0049DAE0h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 004A1898h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 004CB984h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 004B7429h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 0042CF29h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 0049EB1Eh, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 0049BF01h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 0049BEFBh, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 004BE55Ch, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 004BC470h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 0049BF0Fh, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 004B781Bh, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 0049D88Fh, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 7C816FD7h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "RegisterWaitForInputIdle" (+00000049h)
Address: 7C839AA8h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "ValidateLocale" (+000002B0h)
Address: 7C816FE0h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "RegisterWaitForInputIdle" (+00000052h)
Address: 0049D8FAh, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 004E0049h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 004F0044h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 004B0063h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 003D006Eh, location: "foo_abx", loaded at 003C0000h - 003F3000h
Address: 003D0065h, location: "foo_abx", loaded at 003C0000h - 003F3000h
Address: 00500069h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 00410072h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 004D002Eh, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 0044002Eh, location: "foobar2000", loaded at 00400000h - 00523000h
Version info:
foobar2000 v0.9.5.1 beta 2
UNICODE
Windows 5.1
Additional info:
File Operations 2.1  (foo_fileops)
ReplayGain Scanner 2.0.3  (foo_rgscan)
Dockable Panels 1.0.7b [Mar 28 2007 - 09:18:48]  (foo_dockable_panels)
Quick Tagger 1.0  (foo_quicktag)
Playlist Tools 0.6.2 beta 3  (foo_utils)
Scheduler 3.53  (foo_scheduler)
cwbowron's title format hooks 1.2.6 [Jan  2 2008 - 15:50:05]  (foo_cwb_hooks)
ABX Comparator 1.3.1  (foo_abx)
Default User Interface 0.9.5  (foo_ui_std)
Converter 1.1  (foo_converter)
foo_skip 0.2  (foo_skip)
Samurize Info Server (AMPI) 1.64  (foo_info_samurize)
Navigator 0.61a  (foo_navigator)
Live Show Tagger 0.6.1  (foo_tradersfriend)
Cover Flow 0.18  (foo_bubble_coverflow)
foobar2000 core 0.9.5.1 beta 2  (Core)
foo_custominfo 0.1.2  (foo_custominfo)
Album List 4.2  (foo_albumlist)
Lyric Show Panels 0.3.2.2 [Feb 14 2008 - 13:57:22]  (foo_uie_lyrics)
Masstagger 1.6  (foo_masstag)
Run services 0.3.2  (foo_run)
Album Art Browser 0.0.5 [Jul 13 2007 - 10:15:45]  (foo_cwbowron)
Playback Statistics 2.0  (foo_playcount)
Tagger Panel Window 1.0.6 [Jan  2 2008 - 15:50:49]  (foo_cwb_hooks)
ASIO support 1.2.5  (foo_out_asio)
Last.fm Chart Player 0.2.3  (foo_scrobblecharts)
Audioscrobbler 1.3.11  (foo_audioscrobbler)
Facets 2007-12-16  (foo_facets)
Reply #327
Looks like a foo_dockable_panels crash but there's not much more info. Maybe it's an OpenGL driver issue, you could try to update them (what is you video card ?).
What happens if you use the standalone window (View->Show cover flow window), can you make it crash ?
Reply #328
Wow!!! Thanks again for the new version... seems like you have improved this awesome component more and more
Pleaaaase... could you try to implement Unicode next? I know I'm nobody around here to be asking for stuff but it's just I'm sure not only few of us have "weird" artist names in our collections
Reply #329
crash
Illegal operation:
Call path:
entry=>app_mainloop
Stack (0012F9F4h):
Registers:
Loaded modules:
Version info:
UNICODE
Windows 5.1
Additional info:
That is exactly my problem. And I haven't installed CUI either. Maybe it really is a necessity for the entire thing to work? But then why would my Lyrics Show panel work? I wonder if trying the last stable CUI version could make a difference.
Edit: Nevermind that didn't help. Besides I already had CUI installed.
Reply #330
1) Can you check when you bind to the facet playlist, that the entry menu for this playlist is ticked in "Bind to playlist". A black screen (do you have that when binding ?) does not mean necessarily than the playlist is unbound or an error occurred, but it can also mean that no item is selected in the bound playlist.
2) You mean no crash but a freeze right ? Can you try to specify something else than folder.jpg in the config (any file that does not exist), and tell me if it crashes then. If it does not, then the problem is probably related to the folder.jpg files.
Otherwise no idea, works great here...
Reply #331
Reply #332
didn't crash, but I stopped waiting at some point and Ctrl_Alt-Deleted to get out of it.
Reply #333
On facets:
It will "bind" with facets, but it will not show covers until a track is selected/playing in the playlist view.
(example: bind it to facets, select and artist in facets. The playlist view changes to show that artist's tracks, but Cover Flow stays blank. Click to select a track in playlist view and Cover Flow shows the covers)
Doesn't appear to occur when binding it to any other playlists.
On crash(es)
rev18 WILL lock into a dockable panel on my other system running Foo b1 and appears to work without crashing (even on large playlists).
Not sure if it is a beta 1-2 issue or an issue specific to one system. If I get the time I will try to swap foos and see what happens.
Reply #334
I tried 0.9.5 and 0.9.5.1 finals and same problem with both versions. What I'm wondering about is why would a GFX driver kill dockable_panels rather than the Coverflow plugin which uses the OpenGL driver X_X
Reply #335
Am I the only one that cannot download the dll file? Is the file mirrored somewhere else?
Reply #336
I'm happy to report that the latest version of this component appears to finally function under wine. The coverflow display appears in a separate window and wont bind into my main foobar where I defined in ColumnsUI setup however the art displays fine and I can modify the settings without a problem (which were issues with previous releases). Keep up the good work!
This component stopped working under wine and I have been unable to get it working again despite several clean installs and foobar rebuilds.
Reply #337
Would it be possible to add an option to colour the background? Or is that already available and I'm missing something.
Reply #338
I can't ever get this component 2 dock 2 my foobar. Could anyone help me out. I have the latest version.
Reply #339
Coverflow doesn't want to go into a panel.
I thought it was my coding that was wrong before, but since Falstaff released a working config with coverflow, I tried it out but still have the same problem. It seems that others are having the same problem, but so far no one has managed to get a solution....
Any help, much appreciated. This is a nice component and I'd love to get it to work properly
I am having the same problem.  And not just on a laptop...
fortunately,    my Dell desktop also uses an integrated intel display adapter.
It does work properly on a HP laptop that I have.
Here is what I captured from the console on the three machines:
Mobile Intel® 945GM Express Chipset Family
(Dell laptop -- bad)
Startup time : 0:01.167787
foo_bubble_coverflow: OpenGL vendor: Intel
foo_bubble_coverflow: OpenGL version: 1.4.0 - Build 7.14.10.4814
foo_bubble_coverflow: OpenGL extensions: GL_ARB_depth_texture GL_ARB_fragment_program GL_ARB_multitexture GL_ARB_point_parameters GL_ARB_shadow GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_env_crossbar GL_ARB_transpose_matrix GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_compiled_vertex_array GL_EXT_cull_vertex GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_packed_pixels GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture_compression_s3tc GL_EXT_texture_env_add GL_EXT_texture_env_combine GL_EXT_texture_filter_anisotropic GL_EXT_texture3D GL_3DFX_texture_compression_FXT1 GL_IBM_texture_mirrored_repeat GL_NV_blend_square GL_NV_texgen_reflection GL_SGIS_generate_mipmap GL_WIN_swap_hint
foo_bubble_coverflow: EXT_blend_color: no
foo_bubble_coverflow: ARB_texture_non_power_of_two: no
foo_bubble_coverflow: ARB_texture_rectangle: no
foo_bubble_coverflow: EXT_texture_rectangle: no
foo_bubble_coverflow: EXT_texture_filter_anisotropic: yes
foo_bubble_coverflow: SGIS_generate_mipmap: yes
foo_bubble_coverflow: WGL_ARB_multisample: no
foo_bubble_coverflow: WGL_EXT_swap_control: yes
foo_bubble_coverflow: Swap interval = 1
foo_bubble_coverflow: loading cover file: C:\Program Files\foobar2000\nocover.png
Intel 82845G/GL/GE/PE/GV Graphics Controller
(Dell desktop -- bad)
Startup time : 0:02.339952
foo_bubble_coverflow: OpenGL version: 1.3.0 - Build 4.14.10.4342
foo_bubble_coverflow: OpenGL extensions: GL_ARB_multitexture GL_ARB_point_parameters GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_env_crossbar GL_ARB_transpose_matrix GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_compiled_vertex_array GL_EXT_cull_vertex GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_packed_pixels GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_stencil_wrap GL_EXT_texture_compression_s3tc GL_EXT_texture_env_add GL_EXT_texture_env_combine GL_EXT_texture_filter_anisotropic GL_3DFX_texture_compression_FXT1 GL_IBM_texture_mirrored_repeat GL_NV_blend_square GL_NV_texgen_reflection GL_SGIS_generate_mipmap GL_WIN_swap_hint
ATI display adapter
(HP laptop -- good)
Startup time : 0:00.930101
foo_bubble_coverflow: OpenGL vendor: ATI Technologies Inc.
foo_bubble_coverflow: OpenGL version: 2.0.5150 WinXP Release
foo_bubble_coverflow: OpenGL extensions: GL_ARB_multitexture GL_EXT_texture_env_add GL_EXT_compiled_vertex_array GL_S3_s3tc GL_ARB_depth_texture GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_multisample GL_ARB_occlusion_query GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_shadow_ambient GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_transpose_matrix GL_ARB_vertex_blend GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_element_array GL_ATI_envmap_bumpmap GL_ATI_fragment_shader GL_ATI_map_object_buffer GL_ATI_separate_stencil GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_ATI_vertex_array_object GL_ATI_vertex_attrib_array_object GL_ATI_vertex_streams GL_ATIX_texture_env_combine3 GL_ATIX_texture_env_route GL_ATIX_vertex_shader_output_point_size GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_EXT_texgen_reflection GL_EXT_texture3D GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_rectangle GL_EXT_vertex_array GL_EXT_vertex_shader GL_HP_occlusion_test GL_NV_blend_square GL_NV_occlusion_query GL_NV_texgen_reflection GL_SGI_color_matrix GL_SGIS_generate_mipmap GL_SGIS_multitexture GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_SUN_multi_draw_arrays GL_WIN_swap_hint WGL_EXT_extensions_string WGL_EXT_swap_control
foo_bubble_coverflow: EXT_texture_rectangle: yes
foo_bubble_coverflow: WGL_ARB_multisample: yes
foo_bubble_coverflow: Using full scene antialiasing
@bubbleguuum (or anyone else for that matter):
Might this be an OpenGL problem?  Does bubble_coverflow require OpenGL 2.0+?
One obvious difference: on the laptop that does show coverflow properly in a panel, the console output shows the following are both "yes":
- EXT_texture_rectangle
- WGL_ARB_multisample
I don't have the first clue what the significance of that might be... anyone have any thoughts?...
(and, I haven't said this yet, just been lurking for a while, but...
@bubbleguuum:
AWESOME, awesome component!!!  Great work.  Thanks very much! )
Reply #340
I have a Dell PC with an Intel chipset at work, so I'll be able to see what's wrong. Not sure, but it might be some hacks I added to make it play nice with PUI that are causing problems in some cases.
Reply #341
bubbleguuum, thanks for your work on this component!
A couple questions:
1) I can't seem to bind to my "Browse" playlist.  Is this because of its name, or because it is the playlist that Playlist Tree and Browser are sending to?  Or is something else the issue?  (It is not the first playlist).
(edit: this is solved by selecting any track in the Browse playlist, which is generated without any track being selected.  Can this be accounted for in future versions of Cover Flow, or is it ultimately a problem with Playlist Tree and Browser?)
2) How can I unbind Cover Flow so that it follows the active playlist without having to reset all settings?
3) Do you plan to support wildcards in source filenames?  My art varies from jpg to gif to png.
4) Do you plan to allow the disabling of embedded art?  I don't like using it because some of my files are kept on external or network drives, and looking for their embedded art can cause lags.
edit:
5) If I double-click a cover to start playing, then scroll to another cover and double-click that one, it doesn't begin playing the new album, it just restarts the song I'm already listening to.  Is this fixable?
6) Can you add a "Send to New Playlist and Play" behaviour option?
7) Is it just me, or is the angle of perspective not obtuse enough for inactive albums?  The art becomes very narrow, but the shape is still almost rectangular.  Just looks off to me.
foobar 0.9.4.3
foo_bubble_coverflow 0.18
foo_playlist_tree 2.2.4
foo_browser 1.2.2c
Thanks again.
Reply #342
This seems to be a nice component!!
I just checked in to the forum after a long time.
There three things I would like to have for coverflow:
1. Wildcard for the album art path! (seems that even with proper titleformatting CF won't show all of my art. I'm using "%artist% - '['%date%']' - %album% - Front.jpg" for all of my art... FB2Kv0.9.4.3 / PUIv0.13.8 / CFv0.18)
2. Custom or transparent bg color!!!
3. Unicode support
looking forward to the next update
callisto
fb2k on OSX: flac q8 > rockboxed Sansa e280v1: Vorbis q5.0
Reply #343
As for me:
1) Would very appreciate if you add the unicode support
2) Option to play the first track of an album when doubleclicking on its cover
And, of course, tnx for making what i've been really searching for
Reply #344
It would be nice if you could add a horizontal scrollbar, just like in graphical browser. I think about something like this concept I made in ps:
Reply #345
First page:
Planned features
- Unicode support
- partly done Embedded cover support.
- done in 0.16 Bind the panel to a specific playlist instead of always the active playlist
- Animation
- partly done Reflections.
- More eye candy (dynamic lighting would be cool)
- Optimizations (aka no lag)
- Scrollbar and some UI in fullscreen
- done No cover.
In case you missed that, its on the way just hang in there.
A teacher is a student in denial.
Reply #346
can someone please check if they download the component from the first page? Is the link dead or its just happening to me?
Reply #347
Hmm... Everything seems to be fine
Reply #348
Nope must just be you, downloaded fine for me.
Reply #349
It only means that the bustards hear at work blocked the url. It works at home, but my internet connection is giving my problems, so I cant download it from there either.
Can someone please email me the latest version. I hope bubbleguuum doesnt mind and I also hope Im not violating a rule with request.
My email address: vuyani@guruhut.com
I really need this version.
thanks in advance.
