Topic: foo_bubble_coverflow (Read 422198 times) previous topic - next topic
Reply #250
Hi to you Bubble, and thanx again forthis marvellous plugin !
I've detected a lack in Cover Flow, Could it be possible to refresh Coverflow when adding a new track in a playlist ?
i've a PUI config with : 1 cover flow + 1 Single Column Playlist +...
- when creating a new playlist, it is empty, so CF is empty and Playlist too !
- but when i add a track into it, only the playlist update and CF stay empty ... it show the new cover(s) only when i selecte (click) on a track in this new playlist.
Thanx for feedback
Bye
Sure! I don't think I handle all playlists notifications yet, that's the reason.
ok, i hope you'll add this feature soon
(hability to choose background color would be nice too ... )
Reply #251
Im guessing the next release is gonna be a big one since Bubble has been quiet for three days.
Is he intentionally creating  an element of suspense?...
A teacher is a student in denial.
Reply #252
Coverflow doesn't want to go into a panel.
I thought it was my coding that was wrong before, but since Falstaff released a working config with coverflow, I tried it out but still have the same problem. It seems that others are having the same problem, but so far no one has managed to get a solution....
Any help, much appreciated. This is a nice component and I'd love to get it to work properly
I have no idea why the window is not in the panel...you just launch the config and it appears like that right ?
I've got embedded cover working (only ID3V2.3 for now). Do you guys use embedded art a lot ?  Embedded art can be interesting for small panels because usually the images are smaller and then the performance should be greater (btw, itunes only display embedded covers).
Hi, I have the same problem, but curious: desktop computer without problems...but on notebook a seperate window for cover flow...
MfG Frank
Incidentally, I'm on a notebook as well.....but I can't see that to be much of a problem. If it's the integrated graphics card problem, cover flow probably wouldn't work at all instead of giving us this weird problem.
Well, I hope someone can figure out the problem. In the meantime I'm stuck with using coverflow as a window...
I Have the same problems here. I Use a notebook, with Ati mobility Radeon 9100 IGp
Reply #253
Maybe you could try my coverflow alpha (http://chron.visiondesigns.de/foobar2000/f...flow_v0.1.1.zip), and see if it works - if it does, bubbleguuum could have a look at the differences in our implementations. I guess that would help a lot.
Reply #254
I also have the problem that I can't put Coverflow into a panel... I use an Fujitsu Laptop with Intel 82852/82855 GM/GME Graphics.
Tested with some old panel_ui and with the latest stable release.
@ Chronial: Your Plugin makes my foobar crash, but i'll post that in your own thread later...
Reply #255
Still one more question:
Are there any plans to let one search the whole library with this plugin, not only the current playlist? I have my music organized with the album list plugin and the playlist only consists of the one album which is played at the given time, so the plugin (no matter how cool it looks) makes not much sense to my foobar config...
Reply #256
I Had tried before, and the Chronflow crashs foobar. I've tested all versions, and the previous standalone version. Both crash...
Tried Panelsui 14.12/14.9
I will post the crash log in your thread
thanx for help
Reply #257
Yeah, I never got Chronoflow to work on my laptop. It always crashes, even after removing bubble's coverflow.
It seems that more laptop users are facing the same problems. Hopefully bubble can solve this problem for us..
Reply #258
Hi Bubble,
some news to give ?
So, i write here today 'cause i found an incompatibility problem when using this coverflow panel in panelsUI and Styler running (program that manage visual style, spécifics Toolbar ine Explorer and IE, and special effects like drop shadow for windows) :
the CF panel appears transparent and show nothing ... when i click on it, it displays well for a second and disapear after ... so this panel blink...
when i disable the 'Drop Shadow effect' in Styler, all is fine, so i think that Styler program consider your panel like a window or it's not good, no problem with other visual components, maybe is there a specific coding to fix this ? Have you any idea about that ?
Bye
Reply #260
[a href="http://xs.to/xs.php?h=xs224&d=08072&f=untitled2296.jpg" target="_blank"]
    - M.
i've just create them and make them spin under a Track Display panel in PUI... this config is still in progress, but it looks very nice and spin fast when using fast fwd or backward (very realistic)
Reply #261
i've just create them and make them spin uner Track Display panels in PUI... this config is still under construction, but it looks very nice and spin fast when using fast fwd or backward (very realistic)
Sweet. Do you also have a way to make the tape feed from one reel to the other (a series of progressive shots perhaps, with differing amounts of tape shown at different chronological percentages of your playlist length)?
    - M.
Reply #262
    - M.
to lazy or not equiped to make an animated gif, so here is a little video (poor quality but do the job!) :
http://brett.free.fr/foobar/MOV01.3gp
Reply #263
...incompatibility problem when using this coverflow panel in panelsUI and Styler running ......
Hi !!!
  Now I know why.......
  Same problem. I'm using Styler too.
I love coverflow, but it was impossible to use it with iFoo. Falstaff, you found it !! I disabled "drop shadow effect", and now coverflow works well.
Hope bubble will find the code, cause I'd like "shadow" back
Reply #264
    - M.
Are you going to release this config? I would like to see it and try it out. It looks really nice.
-GreenSmurf
Reply #266
Ok I thought that this was a problem with foo_dockable_panels but now I think it's a problem with foo_bubble_coverflow. When I open a new dockable panel and then ask it to contain the coverflow window the coverflow doesn't end up in the panel but rather in a separate window. So something is wrong there.
Maybe it's a problem with 0.15? I don't recall any problems with 0.14. Not that I could try since I don't have 0.14 anymore :[.
Reply #267
Did bubblegum say he was gonna disappear for a while until his next release?
He hasnt posted anything since the 3rd.
Reply #268
Maybe he has a privat life?
Reply #269
Hello Bubble and Chronial,
this is my first post in this forum, although I have been actively reading for a couple of weeks. I currently have both Coverflow Plugins installed in my Foobar 0.9.5 installation.
Chronflow: I really like the "movement" of the covers in the plugin. The smooth scrolling through the cover-caterpillar is brilliant. Thank you for that! The only thin, that is missing now, is the interaction with the playlist. I cannot "select" an album to a plalist so far. Other than that: I really like the "caterpillar", but I assume, that the normal right to left coverflow (like bubble implemented it) is more usable, because you can implement it as a panel and do not waste too much space.
Bubble Coverflow: Also here excellent work! Thank you so far! There are only two remarks from my side: can you copy the "smoothness" of the Chronflow-Plugin, when scrolling through the covers? That would add the extra 1% on top. Another thing, and I agree to one of the former posters, is the wish to link the coverflow not to the currently active playlist, but to the total library. Usualy I create a playlist for every album I select out of the library (I use the Facet-Plugin). But Coverflow does not make sense with only one album in a playlist. It would really be appreciated, if the coverflow (at least with an option in the settings) could be tight to the library.
So far, once again, thank you for your excellent work Bubble and Chronial! I really enjoy to use you coverflow plugins.
Reply #270
hi,
could anyone say me the code for Panels_UI? tried
$panel(Cover Flow,Cover Flow,$add($get(switcherWidth),2),$get(yOffset),$sub(%_width%,$add($get(switcherWidth),2)),$get(viewerHeight),),
but this didnt worked. can anyone say the code? would be nice ;D
Reply #271
hi,
I use this code without problems :
$panel(CoverFlow,Cover flow,2,120,$eval(%_width%-4),$eval(%_height%-122),)
it's case sensitive maybe you should try Cover flow
Reply #272
thx, now it works
Reply #273
I've been busy with real life stuff the past weeks but hopefully I'll be able to work on the plugin soon.
I've been thinking to add the possibility to bind the panel to any playlist (and so having the possibility to bind it to the library using a playlist containing the whole library), but I'm not sure what it should do when you're double clinking on the central cover in this case (add to the active playlist without playing ? add to the playing queue? play immediately ?). Ideas ?
Reply #274
I think you should give the users the option to choose what double click on the center cover does. Like a drop down list with a bunch of options in it .
