Topic: foo_bubble_coverflow (Read 422199 times) previous topic - next topic
Reply #225
v 0.15 released, supporting embedded art (not all formats yet). Please test, as I just tested on a few isolated samples. There's an option in the Sources tab, to display only covert art and ignore the external art source.
If unticked, external art i used first and then embedded if there's no external image
add support for embedded covert art:
   - mp3: ID3V2 tag
   - FLAC: FLAC tag or ID3V2 tag
   - ogg: image embedded in COVERTART vorbis comment, encoded as base64
   - mpc: APEv2 tag
Reply #226
   - mp3: ID3V2 tag
   - mpc: APEv2 tag
oh... so much code will probably will be rewriten just becuase some cant wait ... hope youll have patiance with us after sdk is released (if it ever will)... but nontheless really big thanx for what youre doin for this comunity its really exciting to see another component grow rapidly into perfectness  keep up good work  and again thank you
Reply #227
   - mp3: ID3V2 tag
   - mpc: APEv2 tag
it works but when scrolling the coverflow with embedded cover, foobar crash (stop prog 'handled'/'trapped' by windows Vista 'program had stopped ...'
no dump generated
Reply #228
What type of files is this ? Wouldn't it be mp3s with ID3V2.4 tag (you can check in mp3tag) ? Can you have a look at the console if there's not an error message or even the last file it tried to load.
Reply #229
foobar crash, so can'rt see console !!
it crash when a spécific cover appear in coverflow, maybe it has a non supported Tag format ... how do i check the Tag format (i.e ID3V2.4) of the embedded picture ?
Reply #230
Install mp3tag (mp3tag.de); open the files in it, it will display the exact tag type
Reply #231
ok, i'll try this .. here is a screenshot just after crash and the console display :
Reply #233
file that causes the crash :
Fixed (redownload 0.15) ! You mp3 was smewhat buggy, containing 2 images, the first one being empty (size = 0) and causing the crash. Even foobar 0.9.5 is confused by this and don't display the second valid image  (but does not crash).
Reply #234
@Darkchaser
Ok, Br3tt's ifoo is not guilty.
Seems to me that it's a problem of panelsUI component or maybe graphic card. Do you have installed newest drivers?
Just another idea: Could be a vista problem, change theme to Windows classic
EDIT: btw, were other panels displayed correctly. Please try panel-component peakmeter
http://www.hydrogenaudio.org/forums/index....showtopic=55562
Insert code:
$panel(Peakmeter,Peakmeter,5,5,1000,250,)
Other panels are ok. Peakmeter works well. Here's a screen of both coverflow and peakmeter
Could it really be my graphics card? I have no problem running it as a window, it's just weird that it doesn't want to go into a panel.
If it helps, here's what I'm running:
Windows XP
Windowblinds (tested, not the problem)
CDArtdisplay (tested, not the problem)
Yahoowidgets (tested, not the problem)
Styler
Findexer
Reply #235
are you on a laptop,.. ive got an inspiron 6000, and it would do the same thing.
since then just switched to default UI
Reply #236
Yes.....so I guess it's the integrated graphics card problem? sigh.....
Well, if that's so I hope bubble can figure out a way to make it compatible with laptops..... if not, I'll just live with coverflow as a window.
Reply #237
Great start to what will be an awesome plugin!
The problem I am having, is that I also have live DVD collections converted to mp3 and the albumart that is embedded is not square (1:1), it is the usual DVD cover aspect.
So I was wondering if there was a way of not stretching; or squashing it depending on which way you look at it.
Cheers
Reply #238
HI bubbleguuum. 0.15 shows incorrect covers with FLAC.
FLAC supports type of the cover (Mp3tag is unable to do this, I use FLAC command line tool to add my covers)
         [TYPE]|[MIME-TYPE]|[DESCRIPTION]|[WIDTHxHEIGHTxDEPTH[/COLORS]]|FILE
           TYPE is optional; it is a number from one of:
              0: Other
              1: 32x32 pixels 'file icon' (PNG only)
              2: Other file icon
              3: Cover (front)
              4: Cover (back)
              5: Leaflet page
              6: Media (e.g. label side of CD)
              7: Lead artist/lead performer/soloist
              8: Artist/performer
              9: Conductor
             10: Band/Orchestra
             11: Composer
             12: Lyricist/text writer
             13: Recording Location
             14: During recording
             15: During performance
             16: Movie/video screen capture
             17: A bright coloured fish
             18: Illustration
             19: Band/artist logotype
             20: Publisher/Studio logotype
             The default is 3 (front cover).  There may only be one picture each
             of type 1 and 2 in a file.
In coverflow window I see only cd-covers (type 6), but sometimes front or back.. It's very strange  Can you correct it to show front cover by default?
Thinking Outside The Box
Reply #239
@bubbleguuum:
It seems the freezing when leaving fullscreen mode is related to Windows Vista. I booted in Windows XP on the exact same machine as I use Vista and I didn't experience any freezing. Perhaps this article which describes OpenGL related changes in Vista can help you fix the problem.
On a different matter: Since you support embedded album art in mpc files it would be nice if you did the same for wavpack files since they should work the same way regarding embedded album art (both using apev2 tags). But I'm not 100% sure.
Reply #240
Cheers
I already thought about this and will probably add an option to keep the aspect ratio
              0: Other
              2: Other file icon
              3: Cover (front)
              4: Cover (back)
              5: Leaflet page
              8: Artist/performer
              9: Conductor
             10: Band/Orchestra
             11: Composer
             18: Illustration
Yup, I'll make a bit more intelligent: right now it just displays the first image it finds....
@bubbleguuum:
Thanks for the info, I'll look into it. Wavpack and APE support for embedded art in  the todo list
Reply #242
Oh wow, I pretty much gave up on foobar when Terrestrial disappeared and haven't really used it since I got a mac but this looks like it is worthy of a revisit . Looks very impressive Bubble. Good stuff.
Apart from the OpenGL requirement are there any other minimum specs? My desktop pc is probably too poop to run it but this Macbook may be capable in boot camp. It's one of the new ones running the X3100 GMA. Does anyone know if it can handle it?
Reply #243
Please add an opacity option for the reflection. It's still too dark.
Reply #244
Thx a lot for this component. It works very well and looks very clean and eyecandy.
I just suggest you two things :
- White background (or simply a transparent background).
- An option to change font.
Reply #245
Why I double-click  the cover will not start playing that associated album ?
Reply #246
You need to enable "Playback follow cursor" in the View menu
Reply #247
It's in the Playback menu, not in view menu!
Reply #248
Hi to you Bubble, and thanx again forthis marvellous plugin !
I've detected a lack in Cover Flow, Could it be possible to refresh Coverflow when adding a new track in a playlist ?
i've a PUI config with : 1 cover flow + 1 Single Column Playlist +...
- when creating a new playlist, it is empty, so CF is empty and Playlist too !
- but when i add a track into it, only the playlist update and CF stay empty ... it show the new cover(s) only when i selecte (click) on a track in this new playlist.
Thanx for feedback
Bye
Reply #249
Thanx for feedback
Bye
Sure! I don't think I handle all playlists notifications yet, that's the reason.
