Topic: foo_bubble_coverflow (Read 422065 times) previous topic - next topic
Reply #126
Warning!!! Changing from one pui (without coverflow panel) to another pui with 0.12 coverflow panel could harm first pui. (Sorry Br3tt, it hit your ifoo)
right, its happen to me too but with 0.11 version ... but i wasn't sure that was due to coverflow component ...
Reply #127
Where can I get the PUI version you're using ?
Reply #128
get it here
http://brett.free.fr/foobar/foo_ui_panels_0.14.9.zip
thanx for your research for debugg!
Reply #131
v0.13 out (first post). Fixed a few crashes, in particular the damn "Uncaught exception" popup on launch.
0.13
- fix: bad read of config was causing a "Uncaught exception: Unsupported or corrupted file format" error popup
- fix: click in panel if playlist was empty crashed foobar
- fix attempt: sometimes reflection displayed over text
Reply #132
Man, this is so damn sweet. 0.11 was a bit buggy and some covers wouldn't show plus I experienced crashes... now 0.13 seems to be a whole different business!!!
This is really beautiful, thanks once again bubbleguuum!!!
Reply #133
0.13
YAY! Works perfectly so far here in Panels UI 14.12 beta and foobar 0.9.5 beta 8. The only bugs I can seem to find right now are:
1. Opening windowed mode doesn't use the same settings as my panel. Is it possible to have the settings sent over to the windowed version? Maybe an export settings to file button?
2. Full screen still doesn't function correctly in Panels UI (don't know about CUI).
Great work bubbleguuum ^__^.
Reply #134
Great work!!!
(and so fast  )
Brilliant!! mipmapping is very useful, since it avoids ugly moire-effects.
But I found a little bug: mipmapping settings are lost after restart of foobar.
Reply #135
mipmapping is greyed out for me... I'm confused as to why?
Reply #137
Just wanted to say I really like this component, and am anxiously awaiting some of the features listed for the future.
Please add a transparent panel background option to the list if you haven't already done so. In the mean time, if you could add the option for choosing a solid color background that would be great.
I wrote a new PUI theme to use this component but the solid black background doesn't go that well with it unfortunately.
Also, would it be possible to allow an option for this component to view all album covers in your media library as opposed to just the covers in the current playlist?
Reply #138
Please add a transparent panel background option to the list if you haven't already done so. In the mean time if you could add the option for choosing a solid color background that would be great.
I second the transparent background, that would be great. And johnredcorn (love king of the hill btw) your config is really nicely done! Great job . What component are you using on the left with the heading "Collection"?
Reply #139
Thanks, it's the newest version of foo_uie_albumlist with "Themed appearance on Windows Vista" option enabled. You can get it from musicmusic's foobar stuff page.
Reply #140
Ah, I've never used that component, thank you . I'll give it a try .
Reply #141
(pIv @ Jan 24 2008, 12:42)
bubbleguuum
I don't solve next thing.
When I include your component in CUI, I have cover flow in separate window and blank CUI element
I can change preferences of coverflow window with right click on blank CUI element.
I use FB 0.9.5, colunms_ui 0.2.1 alpha 10 v4, your plugin version 0.12.
With plugin version 0.11 result is the same.
Separate windows from View/Show cove rflow window work good.
Very strange, I suppose this might be a bug of the version of CUI you're using. Could you try an older version to see it it works ?
Now I setup minimum foobar 0.9.5 to another folder. I add ui_columns.dll ver. 1.3 and last version of your plugin. Result is the same as last  point - I have cover flow in separate window and blank CUI element.
I use Windows XP SP2. I check this situation on two PC (first have GFORCE4 video, second - Intel 910GL).
Reply #142
I still consistently get crashes when leaving fullscreen mode. Basically it makes foobar not respond and take high cpu usage until I kill the process.
Reply #143
Hi bubbleguuum and big thanx !!
0.13 works fine now (main function in panel) in PanelsUI
i have detected a new pb : foobar crash when i put in settings of your coverflow a bad path for the nocover picture source.
PS: i haven't tested again the fullscreen mode yet (i'm at work now and can't do it before this evening)
Thanx again, you're a bugg-killer
Reply #144
Reflections aren't visible for me. They are way too dark. Also, all covers appears to be much darker than before, even with flat shading removed.
EDIT: Using WinXP SP2, ATI Radeon X1300.
Reply #145
This happens to me too...Anyway, i'm sure bubbleguuum will fix it.
Bubbleguuum thanks a lot for this component! its GREAT! It just needs animation now and some options about the font used, and the "click" actions...cool!!! I will soon post my config...i was waiting for a coverflow panel to make it an option inside my config. It will look great! Thanks again!
Reply #146
you should add an option to set the opacity of the reflections to a user definable value.
Reply #148
fullscreen bugg always here with panelsUI, here is in 5 steps with screenshots what happens (often but not always, sometime it works!)
1) before double-click on coverflow backgroud :
[a href="http://xs223.xs.to/xs223/08045/_full_before537.jpg" target="_blank"] )
Reply #149
Hi bubbleguuum.Please ,can you fix this?
Can't load cover.jpg 6,29mb and more(mb)!!!
I have only covers with high resolution.For me this is a big problem.
QUOTE(radecke @ Jan 25 2008, 13:40) *
+1
