Topic: REACT 2 Released (Read 1289888 times) previous topic - next topic
0 Members and 6 Guests are viewing this topic.
REACT 2 Released
Reply #675
If you use b16h that should do it.
Why, what is happening?
AFAIK if "E:\Documents and Settings\Chase\My Documents\My Music\MP3s\MP3s ~VBR 0\$artist$\$album$\folder.jpg" exists it should be copied to the working directory and the cover downloader will not open.
I'm on a horse.
REACT 2 Released
Reply #676
It does exit... trust me on that one.
The MP3 tracks end up in the folder where the coverart (folder.jpg) is sitting, but none of the are embeded with the image.
The coverdownloader does not open either...
No big deal though. Would have been nice, but ohwell.
I also notice that the coverdownloader does not come up anymore either, even when the directory is correct (eg: CoverDownloader=D:\Program Files\REACT2\coverdownloader\albumart.exe) and the coverdownloader is set to run (eg: RunCoverDownloader=1). You would have seen these in my last posts.
Originally when I first installed REACT2 the coverdownloader was working fine. Sorry to say, but I haven't used REACT2 in a while, and so I reinstalled everything and set up my .ini file and .cgc file again, but can't seem to get the coverdownloader to run automatically after the burning process starts in EAC (through REACT).
It wasn't running before I used this newer version of REACT2 (REACT_2.0.ssb16h) so I'm not saying it's that. I reinstalled my original version of REACT2 a couple of weeks ago and since then it hasn't run (the exact same version as I originally installed). I'm just wondering how to activate it. I've tried using the original coverdownloader as well as the newer version, but I can't seem to get it to prompt me after telling it to burn tracks in EAC.
That's why I thought of having it so REACT2 would embed the image (folder.jpg) if it was found it the same directory (or any) as the tracks being burnt.
Help would be much appreciated. I've probably overlooked something small.
REACT 2 Released
Reply #677
There's a CoverArtXUI=1 flag that must be set for it to pass the correct values to the XUI program. (That might not be the exact name. Look for it in your .INI file. In the first section I believe.)
REACT 2 Released
Reply #678
Hi SS, just wanted to say thanks again for the REACT mod.  I've finally finished ripping all 328 cd's from my collection and owe it all to you.  Easy as pie...
BTW - the latest ssb16h reports it's version number as 16f in the top bar of eac.  Is this a value set in the ini file, or do you need to update the code?
REACT 2 Released
Reply #679
Well, I think Tycho and yourself deserve most credit, but I'll accept a little thanks.
I wonder whether you have a proxy caching issue.  Mine definately says 'h'; I have just downloaded the zip, replaced my EXE, and that also says 'h'.  You may still be running 'f'.  The EXE should be dated 2007-09-17 12:19.
Hmm... if it wasn't working for earlier versions then we can't test b16h.
As far as I understand it, you just need to set RunCoverDownloader=1 and CoverDownloader=C:\Path\To\AlbumArt.exe in the [Settings] section of your INI for the cover downloader to open.
Is it possible that you don't have the .NET framework installed?  Try running AlbumArt.exe by double-clicking on it, and see if it runs.
NB: Although you don't appear to be getting that far, to actually embed the artwork, you need to set EmbedCover=1 in the [UserSettings] section of your INI.
Edit: Actually, you could try putting b16h back on, and setting DebugMode=1 in the [UserSettings] section of your REACT.ini.  After amending your INI, open REACT, and rip a disc which you know has existing artwork.  Check the "debugging.txt" file in your REACT directory and post it here.  It won't help the fact that AlbumArt.exe is not running (as it seems that this is not a b16h issue) but it will tell us whether b16h can find your artwork, and maybe something else.
Oh, and to be pedantic: I assume that you are talking about "ripping" - not "burning" ("ripping" is extracting from a CD, and "burning" is writing to a CD).  I'm sure you know this, but I just want to be clear on what we are discussing.
As reference, here's an explanation of all relevant cover downloader INI variables (since b16h):
[Settings] RunCoverDownloader
Set to 1 to run AlbumArt.exe.
[Settings] CoverDownloader
The full path to AlbumArt.exe - whether it be the original or XUI.
[Settings] CoverDownloaderXUI
Set to 1 to tell REACT that you are using Album Art XUI.  REACT will then be able to deal with BMP, GIF, PNG and JPEG artwork (although you may need to amend your CFG to process non-JPEG files - depending on whether you are embedding).  I would stick with JPEGS where possible.  You do not need to set this to 1 if you are using XUI - If left out, or set to 0, REACT will still run XUI - it just won't be able to deal with non-JPEG files.
[Settings] CoverDownloaderLocalPath
If RunCoverDownloader is set, and you set this to the path of your existing artwork, REACT will check for the existence of a file before opening AlbumArt.exe.  If a file exists it will copy that file to the working directory, renaming it "<album>.jpg" (as REACT expects artwork to be called) and AlbumArt.exe will not be opened.  If the path is not set, or a file does not exist, AlbumArt.exe will open as normal.  You can use $artist$ and $album$ tokens in the path.
[UserSettings] EmbedCover
Set to 1 to embed the artwork in your files.
I'm on a horse.
REACT 2 Released
Reply #680
Thanks. And yes, ripping, not burning, my bad.
About the coverdownloader...
Firstly, I have the path for the coverdownloader set correctly,. I'm running 'coverdownloader_4_0b_1' now. I tried the original which didn't work (although it did originally [don't know what's changed]) and so I tried the newest version which doesn't work either.
The albumart program does run when opened, as I have used this to find some of my album art manually before.
I do have the .net framework installed (only 2 not 3, 3 doesn't want to install [dumb Microsoft] and so I can't check if AlbumArt XUI works unfortunately).
Hence the CoverDownloaderXUI is set to =0 because I am not running this.
Embed cover is set to =1 and always have been.
I just figured it out sorry for my uselessness! I'm used to pressing the MP3 button on the side panel of EAC instead of F4... my bad.
This is the reason the coverdownloader wouldn't run. Stupid mistake. I've done heaps of rips using EAC without REACT that's why.
So now, when I have the RunCoverDownloader set to =1 the coverdownloader runs, even when the folder.jpg is present in the correct path. If I rip with RunCoverDownloader set to =0 then it rips an MP3 file without the folder.jpg embeded even when the ripped MP3 track ends up sitting right next to the folder.jpg and the are both using the same path. And yes, Embed cover is still set to =1. This happens when pressing f4 within EAC via REACT.
Cheers, hope you can make some sense out of that.
REACT 2 Released
Reply #681
Ah, at least we are getting somewhere.
Can you provide debugging.txt, and also the full path to the artwork image that should be found please.
I'm on a horse.
REACT 2 Released
Reply #682
I changed the variable of the debug to =1 and eveytime it ripped a track it would ask me to 'press any key to continue'. I couldn't find a deugging.txt anywhere though. Checked where MP3 tracks dir and REACT2 dir and C:\ but couldn't find one. I did however find the batch file resulting from the debug.
Can I post this to you some how?
REACT 2 Released
Reply #683
Add DebugMode=1.
You can post the contents of the batch file here using [CODEBOX][/CODEBOX] tags.
I'm on a horse.
REACT 2 Released
Reply #684
This is form the debugging.txt file.
The same code is found for each track ripped...
The batch file gives a better rendition of the rip though (found below).
Debugging.txt:
2007-09-20 21:40:34  Version: 2.0.ssb16h
2007-09-20 21:40:34  INI version: 2.0.ssb16
2007-09-20 21:40:34  VariousFileNamingConvention: %D - %C - %N - %T (%A)
2007-09-20 21:41:26  Command line: REACT "Pink Floyd - Pulse - 01 - Shine On You Crazy Diamond.wav" "C:\Ptmp1!542.wav" "C:\Ptmp1!542.eac" "Pink Floyd" "Pulse" "Shine On You Crazy Diamond" "01" "11" "1995" "Progressive Rock" "Track 1" "A9122F0B" "24A435F2" 128
2007-09-20 21:41:26  Source directory: C:
2007-09-20 21:41:26  Base name: Pink Floyd - Pulse - 01 - Shine On You Crazy Diamond
2007-09-20 21:41:26  Artist: Pink Floyd
2007-09-20 21:41:26  Album: Pulse
2007-09-20 21:41:26  Title: Shine On You Crazy Diamond
2007-09-20 21:41:26  Track: 1
2007-09-20 21:41:26  Total tracks: 11
2007-09-20 21:41:26  Year: 1995
2007-09-20 21:41:26  Genre: Progressive Rock
2007-09-20 21:41:26  Comment: Track 1
2007-09-20 21:41:26  FreeDB ID: A9122F0B
2007-09-20 21:41:26  CRC: 24A435F2
2007-09-20 21:41:26  Bitrate: 128
2007-09-20 21:41:26  Various artist: No
2007-09-20 21:41:26  Rip mode: Tracks
2007-09-20 21:41:26  Log: C:\Pink Floyd - Pulse.log
2007-09-20 21:41:26  Album file: C:\Pulse
2007-09-20 21:41:26  Log file: C:\Pink Floyd - Pulse
2007-09-20 21:41:26  Cover file: C:\Pulse.jpg
Batch file:
@ECHO OFF
CHCP 1252 | PROMPT
TITLE 11/11 - "Pulse"
REM Copyright © Tycho, 2006
REM
REM ** Create compressed audio tracks from ripped .wav tracks.
REM **
REM ** You may consider using image mode (F10)
REM ** as it supports creating tracks via acdir.exe,
REM ** and post-processing will always work (see below).
REM **
REM ** Flac requires flac.exe/metaflac.exe (v1.1.3)
REM ** NeroAac requires NeroAacEnc.exe/NeroAacTag.exe/AacGain.exe.
REM ** OggEnc2 requires OggEnc2.exe/VorbisGain.exe.
REM **
REM ** I prefer applying album gain 92dB to get a reasonable
REM ** volume for my DAP. The RG tags are still relative
REM ** to 89dB SPL, i.e. album gain will be about -3.0dB.
REM ============== Begin Main Script ==================
IF 1==1 ECHO ON
REM ** Create Disc-related tags if we have a set
REM If a disc name has been provided
IF "" EQU "" GOTO end_discname
SET discName=discname
SET discName=@%discname%@
IF "" EQU "%discName%" GOTO end_discname
REM Set tagging switches
SET Disc_Flac=-T "discname="
SET Disc_Wavpack=-w "discname="
REM SET Disc_MP3=--frame TSST:""
SET Disc_MP3=--frame "TXXX[setsubtitle]:"
SET Disc_OggEnc2=-c "discname="
SET Disc_Tak=-t "discname="
REM Add disc name to folder path
SET trackDir=%trackDir%\
GOTO :end_discnumber
:end_discname
REM Ensure that we have numeric values
SET /A discNumber = 1 + 0
SET /A totalDiscs = 1 + 0
REM IF a valid disc number and total number of discs has been provided
IF %totalDiscs% LEQ 1 GOTO :end_discnumber
IF %discNumber% LEQ 0 GOTO :end_discnumber
SET Disc_Flac=-T "discnumber=1" -T "totaldiscs=1"
SET Disc_Wavpack=-w "discnumber=1" -w "totaldiscs=1"
SET Disc_MP3=--frame TPOS:"1/1"
SET Disc_NeroAac=--disk "1/1"
SET Disc_OggEnc2=-c "discnumber=1" -c "totaldiscs=1"
SET Disc_Tak=-t "discnumber=1" -t "totaldiscs=1"
REM Add disc number to folder path
SET trackDir=%trackDir%\Disc 1
:end_discnumber
SET TrackDir_Flac="@TrackDir_Flac@%trackDir%"
SET TrackDir_Wavpack="@TrackDir_Wavpack@%trackDir%"
SET TrackDir_MP3="E:\Documents and Settings\Chase\My Documents\My Music\MP3s\MP3s ~VBR 0\Pink Floyd\Pulse%trackDir%"
SET TrackDir_AAC="@TrackDir_AAC@%trackDir%"
SET TrackDir_OGG="@TrackDir_OGG@%trackDir%"
SET TrackDir_Tak="@TrackDir_Tak@%trackDir%"
SET TrackName=11 - Breathe In The Air
SET have_cover=0
SET embed_cover=0
IF EXIST "C:\Pulse.jpg" (
SET have_cover=1
SET embed_cover=1
REM ---- Track ----
IF NOT 1==1 GOTO end_lame_tracks
IF NOT EXIST %TrackDir_MP3% MKDIR %TrackDir_MP3%
PUSHD %TrackDir_MP3%
IF 0==1 SET VA_tag=--user-text "[album artist]Various Artists" --frame "TPE2:Various Artists"
IF %embed_cover%==1 SET Cover_tag=--pict "{3}C:\Pulse.jpg"
ECHO ON
D:\PROGRA~1\REACT2\tools\lame.exe -V0 --vbr-new --noreplaygain --nohist "C:\Ptmp!4!2).wav" "%TrackName%.mp3"
D:\PROGRA~1\REACT2\tools\metamp3.exe %Cover_tag% %VA_tag% %Disc_MP3% --artist "Pink Floyd" --album "Pulse" --track 11/11 --title "Breathe In The Air" --year "1995" --genre "Progressive Rock" --comment "Created with EAC/REACT2, 2007-09-20" --frame TENC:"%USERNAME%" --frame TSSE:"LAME 3.97 -V0 --vbr-new --noreplaygain --nohist" "%TrackName%.mp3"
@ECHO OFF
IF %have_cover%==1 IF NOT EXIST folder.jpg COPY "C:\Pulse.jpg" folder.jpg
POPD
:end_lame_tracks
REM ** Delete the source .wav
DEL "C:\Ptmp!4!2).wav"
REM ---- Post-processing ----
rem ** Scan and compute ReplayGain and add cover picture for supported formats.
rem ** NB: The following will only work if at least the last track is selected,
rem ** and it is a regular audio track.
IF NOT 11==11 GOTO end_post_process
SET add_rg=0
SET aac_enc=@NeroAac@
IF @iTunesAac@==1 SET aac_enc=1
IF NOT 0==1 GOTO end_RG
SET RG_MetaFlac=--add-replay-gain
SET RG_MetaMP3=--replay-gain
:end_RG
IF NOT 1==1 GOTO end_apply_AG
SET RG_MetaMP3=--apply-gain album+1.0
SET RG_AacGain=/a /o /c /d +1.0
SET add_rg=1
:end_apply_AG
REM ** Audio Formats:
IF 1==1 (
IF %add_rg%==1 D:\PROGRA~1\REACT2\tools\metamp3.exe %RG_MetaMP3% *.mp3
REM COPY /Y "C:\Pink Floyd - Pulse.log" "EAClog.txt"
POPD
REM ** Cleanup
DEL "C:\Pink Floyd - Pulse.log"
DEL "C:\Pulse.[*].cue"
DEL "C:\Pulse.jpg"
:end_post_process
REM ================ End Main Script ===================
IF 1==1 (
PAUSE
EXIT
REM ** Delete this .bat file:
DEL %0
[!--sizeo:1--][span style=\"font-size:8pt;line-height:100%\"][!--/sizeo--]Moderation: CODE to CODEBOX[/size]
Oops, my bad on the "code" instead of "codebox"...
At the end of the batch file it says:
Could Not FindC:\Pulse.jpg
REACT 2 Released
Reply #685
OK, well it looks like REACT doesn't think that CoverDownloaderLocalPath has been set.
Presumably you have restarted REACT since setting the value?
Confused...
I'm on a horse.
REACT 2 Released
Reply #686
Yup, that was a clean REACT. Boot a new window of REACT up every time I make a change to the .ini file.
REACT 2 Released
Reply #687
I just tried your CoverDownloaderLocalPath setting:
CoverDownloaderLocalPath=E:\Documents and Settings\Chase\My Documents\My Music\MP3s\MP3s ~VBR 0\$artist$\$album$\folder.jpg
And got this in debugging.txt (process started for both image and track ripping but not allowed to complete):
2007-09-20 11:39:04  Version: 2.0.ssb16h
2007-09-20 11:39:04  INI version: 2.0.ss
2007-09-20 11:39:04  VariousFileNamingConvention: %D - %C - %N - %T (%A)
2007-09-20 11:39:10  CoverDownloaderLocalPath: E:\Documents an
2007-09-20 11:39:10  Local cover art file does not exist
2007-09-20 11:39:10  CoverDownloader command: "C:\Program Files\AlbumArtDownloaderXUI\AlbumArt.exe" /artist "The Go! Team" /album "Grip Like A Vice" /path "C:\Documents and Settings\Neil\My Documents\Audio\Grip Like A Vice.%extension%" /autoclose  /localImagesPath "E:\Documents and Settings\Chase\My Documents\My Music\MP3s\MP3s ~VBR 0\%artist%\%album%\folder.jpg"
2007-09-20 11:39:10  Copy Image Beginning...
2007-09-20 11:39:11  - END -
2007-09-20 11:39:33  CoverDownloaderLocalPath: E:\Documents and Settings\Chase\My Documents\My Music\MP3s\MP3s ~VBR 0\$artist$\$album$\folder.jpg
2007-09-20 11:39:33  Local cover art file does not exist
2007-09-20 11:39:33  CoverDownloader command: "C:\Program Files\AlbumArtDownloaderXUI\AlbumArt.exe" /artist "The Go! Team" /album "Grip Like A Vice" /path "C:\Documents and Settings\Neil\My Documents\Audio\Grip Like A Vice.%extension%" /autoclose  /localImagesPath "E:\Documents and Settings\Chase\My Documents\My Music\MP3s\MP3s ~VBR 0\%artist%\%album%\folder.jpg"
2007-09-20 11:39:38  Copy Tracks Beginning...
2007-09-20 11:39:38  - END -
Still confused...
Edit: Hang on a minute.  Note that both my tests end with "Copy Image/Tracks Beginning..." - while yours doesn't.  Did you hit F4?
That's not really an issue for now - all that means is that you didn't save from the cover downloader (and the local file was not moved - which we know).
Once the local file is correctly found, or you chose to download an image, that should not happen.
I'm on a horse.
REACT 2 Released
Reply #688
I'll try again... rebooting REACT and definitely pressing F4. Maybe I clicked on that damn MP3 button again without even realising...
Hang on...
Here...
2007-09-20 22:44:40  Version: 2.0.ssb16h
2007-09-20 22:44:40  INI version: 2.0.ssb16
2007-09-20 22:44:40  VariousFileNamingConvention: %D - %C - %N - %T (%A)
2007-09-20 22:44:46  Copy Tracks Beginning...
2007-09-20 22:44:46  - END -
2007-09-20 22:45:03  Command line: REACT "Pink Floyd - Pulse - 01 - Shine On You Crazy Diamond.wav" "C:\Ptmp1!542.wav" "C:\Ptmp1!542.eac" "Pink Floyd" "Pulse" "Shine On You Crazy Diamond" "01" "11" "1995" "Progressive Rock" "Track 1" "A9122F0B" "24A435F2" 128
2007-09-20 22:45:03  Source directory: C:
2007-09-20 22:45:03  Base name: Pink Floyd - Pulse - 01 - Shine On You Crazy Diamond
2007-09-20 22:45:03  Artist: Pink Floyd
2007-09-20 22:45:03  Album: Pulse
2007-09-20 22:45:03  Title: Shine On You Crazy Diamond
2007-09-20 22:45:03  Track: 1
2007-09-20 22:45:03  Total tracks: 11
2007-09-20 22:45:03  Year: 1995
2007-09-20 22:45:03  Genre: Progressive Rock
2007-09-20 22:45:03  Comment: Track 1
2007-09-20 22:45:03  FreeDB ID: A9122F0B
2007-09-20 22:45:03  CRC: 24A435F2
2007-09-20 22:45:03  Bitrate: 128
2007-09-20 22:45:03  Various artist: No
2007-09-20 22:45:03  Rip mode: Tracks
2007-09-20 22:45:03  Log: C:\Pink Floyd - Pulse.log
2007-09-20 22:45:03  Album file: C:\Pulse
2007-09-20 22:45:03  Log file: C:\Pink Floyd - Pulse
2007-09-20 22:45:03  Cover file: C:\Pulse.jpg
2007-09-20 22:46:24  - END -
2007-09-20 22:46:31  Command line: REACT "Pink Floyd - Pulse - 02 - Learning To Fly.wav" "C:\Ptmp660-!.wav" "C:\Ptmp660-!.eac" "Pink Floyd" "Pulse" "Learning To Fly" "02" "11" "1995" "Progressive Rock" "Track 2" "A9122F0B" "458BCDDE" 128
2007-09-20 22:46:31  Source directory: C:
2007-09-20 22:46:31  Base name: Pink Floyd - Pulse - 02 - Learning To Fly
2007-09-20 22:46:31  Artist: Pink Floyd
2007-09-20 22:46:31  Album: Pulse
2007-09-20 22:46:31  Title: Learning To Fly
2007-09-20 22:46:31  Track: 2
2007-09-20 22:46:31  Total tracks: 11
2007-09-20 22:46:31  Year: 1995
2007-09-20 22:46:31  Genre: Progressive Rock
2007-09-20 22:46:31  Comment: Track 2
2007-09-20 22:46:31  FreeDB ID: A9122F0B
2007-09-20 22:46:31  CRC: 458BCDDE
2007-09-20 22:46:31  Bitrate: 128
2007-09-20 22:46:31  Various artist: No
2007-09-20 22:46:31  Rip mode: Tracks
2007-09-20 22:46:32  Log: C:\Pink Floyd - Pulse.log
2007-09-20 22:46:32  Album file: C:\Pulse
2007-09-20 22:46:32  Log file: C:\Pink Floyd - Pulse
2007-09-20 22:46:32  Cover file: C:\Pulse.jpg
2007-09-20 22:47:19  - END -
2007-09-20 22:47:22  Command line: REACT "Pink Floyd - Pulse - 03 - High Hopes.wav" "C:\Ptmp556)!.wav" "C:\Ptmp556)!.eac" "Pink Floyd" "Pulse" "High Hopes" "03" "11" "1995" "Progressive Rock" "Track 3" "A9122F0B" "AA9098EC" 128
2007-09-20 22:47:22  Source directory: C:
2007-09-20 22:47:22  Base name: Pink Floyd - Pulse - 03 - High Hopes
2007-09-20 22:47:22  Artist: Pink Floyd
2007-09-20 22:47:22  Album: Pulse
2007-09-20 22:47:22  Title: High Hopes
2007-09-20 22:47:22  Track: 3
2007-09-20 22:47:22  Total tracks: 11
2007-09-20 22:47:22  Year: 1995
2007-09-20 22:47:22  Genre: Progressive Rock
2007-09-20 22:47:22  Comment: Track 3
2007-09-20 22:47:22  FreeDB ID: A9122F0B
2007-09-20 22:47:22  CRC: AA9098EC
2007-09-20 22:47:22  Bitrate: 128
2007-09-20 22:47:22  Various artist: No
2007-09-20 22:47:22  Rip mode: Tracks
2007-09-20 22:47:22  Log: C:\Pink Floyd - Pulse.log
2007-09-20 22:47:22  Album file: C:\Pulse
2007-09-20 22:47:22  Log file: C:\Pink Floyd - Pulse
2007-09-20 22:47:22  Cover file: C:\Pulse.jpg
2007-09-20 22:48:17  - END -
2007-09-20 22:48:20  Command line: REACT "Pink Floyd - Pulse - 04 - Take It Back.wav" "C:\Ptmp58)58.wav" "C:\Ptmp58)58.eac" "Pink Floyd" "Pulse" "Take It Back" "04" "11" "1995" "Progressive Rock" "Track 4" "A9122F0B" "53D7F5DE" 128
2007-09-20 22:48:20  Source directory: C:
2007-09-20 22:48:20  Base name: Pink Floyd - Pulse - 04 - Take It Back
2007-09-20 22:48:20  Artist: Pink Floyd
2007-09-20 22:48:20  Album: Pulse
2007-09-20 22:48:20  Title: Take It Back
2007-09-20 22:48:20  Track: 4
2007-09-20 22:48:20  Total tracks: 11
2007-09-20 22:48:20  Year: 1995
2007-09-20 22:48:20  Genre: Progressive Rock
2007-09-20 22:48:20  Comment: Track 4
2007-09-20 22:48:20  FreeDB ID: A9122F0B
2007-09-20 22:48:20  CRC: 53D7F5DE
2007-09-20 22:48:20  Bitrate: 128
2007-09-20 22:48:20  Various artist: No
2007-09-20 22:48:20  Rip mode: Tracks
2007-09-20 22:48:20  Log: C:\Pink Floyd - Pulse.log
2007-09-20 22:48:20  Album file: C:\Pulse
2007-09-20 22:48:20  Log file: C:\Pink Floyd - Pulse
2007-09-20 22:48:20  Cover file: C:\Pulse.jpg
2007-09-20 22:48:51  - END -
2007-09-20 22:48:53  Command line: REACT "Pink Floyd - Pulse - 05 - Coming Back To Life.wav" "C:\Ptmp-!)!3.wav" "C:\Ptmp-!)!3.eac" "Pink Floyd" "Pulse" "Coming Back To Life" "05" "11" "1995" "Progressive Rock" "Track 5" "A9122F0B" "433AF999" 128
2007-09-20 22:48:53  Source directory: C:
2007-09-20 22:48:53  Base name: Pink Floyd - Pulse - 05 - Coming Back To Life
2007-09-20 22:48:53  Artist: Pink Floyd
2007-09-20 22:48:53  Album: Pulse
2007-09-20 22:48:53  Title: Coming Back To Life
2007-09-20 22:48:53  Track: 5
2007-09-20 22:48:53  Total tracks: 11
2007-09-20 22:48:53  Year: 1995
2007-09-20 22:48:53  Genre: Progressive Rock
2007-09-20 22:48:53  Comment: Track 5
2007-09-20 22:48:53  FreeDB ID: A9122F0B
2007-09-20 22:48:53  CRC: 433AF999
2007-09-20 22:48:53  Bitrate: 128
2007-09-20 22:48:53  Various artist: No
2007-09-20 22:48:53  Rip mode: Tracks
2007-09-20 22:48:54  Log: C:\Pink Floyd - Pulse.log
2007-09-20 22:48:54  Album file: C:\Pulse
2007-09-20 22:48:54  Log file: C:\Pink Floyd - Pulse
2007-09-20 22:48:54  Cover file: C:\Pulse.jpg
2007-09-20 22:49:21  - END -
2007-09-20 22:49:24  Command line: REACT "Pink Floyd - Pulse - 06 - Sorrow.wav" "C:\Ptmp!)(0(.wav" "C:\Ptmp!)(0(.eac" "Pink Floyd" "Pulse" "Sorrow" "06" "11" "1995" "Progressive Rock" "Track 6" "A9122F0B" "984F45D3" 128
2007-09-20 22:49:24  Source directory: C:
2007-09-20 22:49:24  Base name: Pink Floyd - Pulse - 06 - Sorrow
2007-09-20 22:49:24  Artist: Pink Floyd
2007-09-20 22:49:24  Album: Pulse
2007-09-20 22:49:24  Title: Sorrow
2007-09-20 22:49:24  Track: 6
2007-09-20 22:49:24  Total tracks: 11
2007-09-20 22:49:24  Year: 1995
2007-09-20 22:49:24  Genre: Progressive Rock
2007-09-20 22:49:24  Comment: Track 6
2007-09-20 22:49:24  FreeDB ID: A9122F0B
2007-09-20 22:49:24  CRC: 984F45D3
2007-09-20 22:49:24  Bitrate: 128
2007-09-20 22:49:24  Various artist: No
2007-09-20 22:49:24  Rip mode: Tracks
2007-09-20 22:49:24  Log: C:\Pink Floyd - Pulse.log
2007-09-20 22:49:24  Album file: C:\Pulse
2007-09-20 22:49:24  Log file: C:\Pink Floyd - Pulse
2007-09-20 22:49:24  Cover file: C:\Pulse.jpg
2007-09-20 22:50:08  - END -
2007-09-20 22:50:10  Command line: REACT "Pink Floyd - Pulse - 07 - Keep Talking.wav" "C:\Ptmp842(2.wav" "C:\Ptmp842(2.eac" "Pink Floyd" "Pulse" "Keep Talking" "07" "11" "1995" "Progressive Rock" "Track 7" "A9122F0B" "D933DAAA" 128
2007-09-20 22:50:10  Source directory: C:
2007-09-20 22:50:10  Base name: Pink Floyd - Pulse - 07 - Keep Talking
2007-09-20 22:50:10  Artist: Pink Floyd
2007-09-20 22:50:10  Album: Pulse
2007-09-20 22:50:10  Title: Keep Talking
2007-09-20 22:50:10  Track: 7
2007-09-20 22:50:10  Total tracks: 11
2007-09-20 22:50:10  Year: 1995
2007-09-20 22:50:10  Genre: Progressive Rock
2007-09-20 22:50:10  Comment: Track 7
2007-09-20 22:50:10  FreeDB ID: A9122F0B
2007-09-20 22:50:10  CRC: D933DAAA
2007-09-20 22:50:10  Bitrate: 128
2007-09-20 22:50:10  Various artist: No
2007-09-20 22:50:10  Rip mode: Tracks
2007-09-20 22:50:10  Log: C:\Pink Floyd - Pulse.log
2007-09-20 22:50:10  Album file: C:\Pulse
2007-09-20 22:50:10  Log file: C:\Pink Floyd - Pulse
2007-09-20 22:50:10  Cover file: C:\Pulse.jpg
2007-09-20 22:50:43  - END -
2007-09-20 22:50:45  Command line: REACT "Pink Floyd - Pulse - 08 - Another Brick In The Wall (Part 2).wav" "C:\Ptmp07!55.wav" "C:\Ptmp07!55.eac" "Pink Floyd" "Pulse" "Another Brick In The Wall (Part 2)" "08" "11" "1995" "Progressive Rock" "Track 8" "A9122F0B" "86A78313" 128
2007-09-20 22:50:45  Source directory: C:
2007-09-20 22:50:45  Base name: Pink Floyd - Pulse - 08 - Another Brick In The Wall (Part 2)
2007-09-20 22:50:45  Artist: Pink Floyd
2007-09-20 22:50:45  Album: Pulse
2007-09-20 22:50:45  Title: Another Brick In The Wall (Part 2)
2007-09-20 22:50:45  Track: 8
2007-09-20 22:50:45  Total tracks: 11
2007-09-20 22:50:45  Year: 1995
2007-09-20 22:50:45  Genre: Progressive Rock
2007-09-20 22:50:45  Comment: Track 8
2007-09-20 22:50:45  FreeDB ID: A9122F0B
2007-09-20 22:50:45  CRC: 86A78313
2007-09-20 22:50:45  Bitrate: 128
2007-09-20 22:50:45  Various artist: No
2007-09-20 22:50:45  Rip mode: Tracks
2007-09-20 22:50:46  Log: C:\Pink Floyd - Pulse.log
2007-09-20 22:50:46  Album file: C:\Pulse
2007-09-20 22:50:46  Log file: C:\Pink Floyd - Pulse
2007-09-20 22:50:46  Cover file: C:\Pulse.jpg
2007-09-20 22:51:14  - END -
2007-09-20 22:51:16  Command line: REACT "Pink Floyd - Pulse - 09 - One Of These Days.wav" "C:\Ptmp7)4)!.wav" "C:\Ptmp7)4)!.eac" "Pink Floyd" "Pulse" "One Of These Days" "09" "11" "1995" "Progressive Rock" "Track 9" "A9122F0B" "E2CCD8A9" 128
2007-09-20 22:51:16  Source directory: C:
2007-09-20 22:51:16  Base name: Pink Floyd - Pulse - 09 - One Of These Days
2007-09-20 22:51:16  Artist: Pink Floyd
2007-09-20 22:51:16  Album: Pulse
2007-09-20 22:51:16  Title: One Of These Days
2007-09-20 22:51:16  Track: 9
2007-09-20 22:51:16  Total tracks: 11
2007-09-20 22:51:16  Year: 1995
2007-09-20 22:51:16  Genre: Progressive Rock
2007-09-20 22:51:16  Comment: Track 9
2007-09-20 22:51:16  FreeDB ID: A9122F0B
2007-09-20 22:51:16  CRC: E2CCD8A9
2007-09-20 22:51:16  Bitrate: 128
2007-09-20 22:51:16  Various artist: No
2007-09-20 22:51:16  Rip mode: Tracks
2007-09-20 22:51:16  Log: C:\Pink Floyd - Pulse.log
2007-09-20 22:51:16  Album file: C:\Pulse
2007-09-20 22:51:16  Log file: C:\Pink Floyd - Pulse
2007-09-20 22:51:16  Cover file: C:\Pulse.jpg
2007-09-20 22:51:45  - END -
2007-09-20 22:51:47  Command line: REACT "Pink Floyd - Pulse - 10 - Speak To Me.wav" "C:\Ptmp3--91.wav" "C:\Ptmp3--91.eac" "Pink Floyd" "Pulse" "Speak To Me" "10" "11" "1995" "Progressive Rock" "Track 10" "A9122F0B" "63617A9B" 128
2007-09-20 22:51:47  Source directory: C:
2007-09-20 22:51:47  Base name: Pink Floyd - Pulse - 10 - Speak To Me
2007-09-20 22:51:47  Artist: Pink Floyd
2007-09-20 22:51:47  Album: Pulse
2007-09-20 22:51:47  Title: Speak To Me
2007-09-20 22:51:47  Track: 10
2007-09-20 22:51:47  Total tracks: 11
2007-09-20 22:51:47  Year: 1995
2007-09-20 22:51:47  Genre: Progressive Rock
2007-09-20 22:51:47  Comment: Track 10
2007-09-20 22:51:47  FreeDB ID: A9122F0B
2007-09-20 22:51:47  CRC: 63617A9B
2007-09-20 22:51:47  Bitrate: 128
2007-09-20 22:51:47  Various artist: No
2007-09-20 22:51:47  Rip mode: Tracks
2007-09-20 22:51:48  Log: C:\Pink Floyd - Pulse.log
2007-09-20 22:51:48  Album file: C:\Pulse
2007-09-20 22:51:48  Log file: C:\Pink Floyd - Pulse
2007-09-20 22:51:48  Cover file: C:\Pulse.jpg
2007-09-20 22:51:57  - END -
2007-09-20 22:52:00  Command line: REACT "Pink Floyd - Pulse - 11 - Breathe In The Air.wav" "C:\Ptmp--658.wav" "C:\Ptmp--658.eac" "Pink Floyd" "Pulse" "Breathe In The Air" "11" "11" "1995" "Progressive Rock" "Track 11" "A9122F0B" "36F42A5B" 128
2007-09-20 22:52:00  Source directory: C:
2007-09-20 22:52:00  Base name: Pink Floyd - Pulse - 11 - Breathe In The Air
2007-09-20 22:52:00  Artist: Pink Floyd
2007-09-20 22:52:00  Album: Pulse
2007-09-20 22:52:00  Title: Breathe In The Air
2007-09-20 22:52:00  Track: 11
2007-09-20 22:52:00  Total tracks: 11
2007-09-20 22:52:00  Year: 1995
2007-09-20 22:52:00  Genre: Progressive Rock
2007-09-20 22:52:00  Comment: Track 11
2007-09-20 22:52:00  FreeDB ID: A9122F0B
2007-09-20 22:52:00  CRC: 36F42A5B
2007-09-20 22:52:00  Bitrate: 128
2007-09-20 22:52:00  Various artist: No
2007-09-20 22:52:00  Rip mode: Tracks
2007-09-20 22:52:00  Log: C:\Pink Floyd - Pulse.log
2007-09-20 22:52:00  Album file: C:\Pulse
2007-09-20 22:52:00  Log file: C:\Pink Floyd - Pulse
2007-09-20 22:52:00  Cover file: C:\Pulse.jpg
2007-09-20 22:54:20  - END -
REACT 2 Released
Reply #689
OK, well it's either not running the cover downloader function (because it thinks that RunCoverDownloader is not 1) or it can't find a value for CoverDownloaderLocalPath.
I could put some more debug statements in the code to see which it is - maybe I need to create a special debug version of b16h for you to run, so we can try to pin this down.  You up for it?
I'm on a horse.
REACT 2 Released
Reply #690
Well, here is a version that spits out a lot more debug info anyway:
http://www.synthetic-soul.co.uk/temp/REACT...sb16h_debug.zip
Close REACT; replace the exe with the one in the zip; open REACT; rip; paste debugging,txt here (using CODEBOX).
Maybe it wouldn't hurt to hit Ctrl+F2 with REACT open to reconfigure EAC as well.  Maybe something has gotten out of sync.  I just have no explanation for what you are seeing.
Here's debugging.txt for my test (both image and track mode in full):
2007-09-20 12:16:27  Version: 2.0.ssb16h_debug
2007-09-20 12:16:27  INI version: 2.0.ss
2007-09-20 12:16:27  VariousFileNamingConvention: %D - %C - %N - %T (%A)
2007-09-20 12:16:33  Reading INI
2007-09-20 12:16:33  ImageExt:wv
2007-09-20 12:16:33  ImageNaming: $artist$ - $album$
2007-09-20 12:16:33  ImageHotKey: {F10}
2007-09-20 12:16:33  TracksHotKey: {F4}
2007-09-20 12:16:33  TracksHotVal: +{F5}
2007-09-20 12:16:33  RunCoverDownloader: 1
2007-09-20 12:16:33  CoverDownloader: C:\Program Files\AlbumArtDownloaderXUI\AlbumArt.exe
2007-09-20 12:16:33  CoverDownloaderXUI: 1
2007-09-20 12:16:33  CoverDownloaderLocalPath: E:\Documents and Settings\Chase\My Documents\My Music\MP3s\MP3s ~VBR 0\$artist$\$album$\folder.jpg
2007-09-20 12:16:33  Setting EAC window title
2007-09-20 12:16:35  Image hot key pressed
2007-09-20 12:16:35  Setting variables from EAC meta data
2007-09-20 12:16:35  Testing whether we can create cuesheets
2007-09-20 12:16:35  fGUIRunWaitCoverDownloader(0) called
2007-09-20 12:16:35  CoverDownloaderLocalPath: E:\Documents and Settings\Chase\My Documents\My Music\MP3s\MP3s ~VBR 0\$artist$\$album$\folder.jpg
2007-09-20 12:16:35  Actual Path: E:\Documents and Settings\Chase\My Documents\My Music\MP3s\MP3s ~VBR 0\The Go! Team\Grip Like A Vice\folder.jpg
2007-09-20 12:16:35  Local cover art file does not exist
2007-09-20 12:16:35  CoverDownloader command: "C:\Program Files\AlbumArtDownloaderXUI\AlbumArt.exe" /artist "The Go! Team" /album "Grip Like A Vice" /path "C:\Documents and Settings\Neil\My Documents\Audio\Grip Like A Vice.%extension%" /autoclose /localImagesPath "E:\Documents and Settings\Chase\My Documents\My Music\MP3s\MP3s ~VBR 0\%artist%\%album%\folder.jpg"
2007-09-20 12:16:35  Copy Image Beginning...
2007-09-20 12:16:35  Substituting tokens using EAC meta data
2007-09-20 12:16:36  - END -
2007-09-20 12:16:49  Command line: REACT "The Go! Team - Grip Like A Vice.wav" "C:\Documents and Settings\Neil\My Documents\Audio\Ttmp1!542.wav" "C:\Documents and Settings\Neil\My Documents\Audio\Ttmp1!542.eac" "The Go! Team" "Grip Like A Vice" "A Version Of Myself" "02" "2" "2007" "Fusion" "DISCNO" "0D018902" "512B21EC" 128
2007-09-20 12:16:49  Source directory: C:\Documents and Settings\Neil\My Documents\Audio
2007-09-20 12:16:49  Base name: The Go! Team - Grip Like A Vice
2007-09-20 12:16:49  Artist: The Go! Team
2007-09-20 12:16:49  Album: Grip Like A Vice
2007-09-20 12:16:49  Title: A Version Of Myself
2007-09-20 12:16:49  Track: 2
2007-09-20 12:16:49  Total tracks: 2
2007-09-20 12:16:49  Year: 2007
2007-09-20 12:16:49  Genre: Fusion
2007-09-20 12:16:49  Comment: DISCNO
2007-09-20 12:16:49  FreeDB ID: 0D018902
2007-09-20 12:16:49  CRC: 512B21EC
2007-09-20 12:16:49  Bitrate: 128
2007-09-20 12:16:49  Various artist: No
2007-09-20 12:16:49  Rip mode: Image
2007-09-20 12:16:49  Log: C:\Documents and Settings\Neil\My Documents\Audio\The Go! Team - Grip Like A Vice.log
2007-09-20 12:16:49  Album file: C:\Documents and Settings\Neil\My Documents\Audio\Grip Like A Vice
2007-09-20 12:16:49  Log file: C:\Documents and Settings\Neil\My Documents\Audio\The Go! Team - Grip Like A Vice
2007-09-20 12:16:49  Cover file: C:\Documents and Settings\Neil\My Documents\Audio\Grip Like A Vice.jpg
2007-09-20 12:16:52  Setting EAC window title
2007-09-20 12:17:09  - END -
2007-09-20 12:20:19  Setting EAC window title
2007-09-20 12:20:24  Reading INI
2007-09-20 12:20:24  ImageExt:wv
2007-09-20 12:20:24  ImageNaming: $artist$ - $album$
2007-09-20 12:20:24  ImageHotKey: {F10}
2007-09-20 12:20:24  TracksHotKey: {F4}
2007-09-20 12:20:24  TracksHotVal: +{F5}
2007-09-20 12:20:24  RunCoverDownloader: 1
2007-09-20 12:20:24  CoverDownloader: C:\Program Files\AlbumArtDownloaderXUI\AlbumArt.exe
2007-09-20 12:20:24  CoverDownloaderXUI: 1
2007-09-20 12:20:24  CoverDownloaderLocalPath: E:\Documents and Settings\Chase\My Documents\My Music\MP3s\MP3s ~VBR 0\$artist$\$album$\folder.jpg
2007-09-20 12:20:24  Setting EAC window title
2007-09-20 12:20:33  Setting EAC window title
2007-09-20 12:20:36  Tracks hot key pressed
2007-09-20 12:20:36  Setting variables from EAC meta data
2007-09-20 12:20:36  Testing whether we can create cuesheets
2007-09-20 12:20:36  fGUIRunWaitCoverDownloader(1) called
2007-09-20 12:20:36  CoverDownloaderLocalPath: E:\Documents and Settings\Chase\My Documents\My Music\MP3s\MP3s ~VBR 0\$artist$\$album$\folder.jpg
2007-09-20 12:20:36  Actual Path: E:\Documents and Settings\Chase\My Documents\My Music\MP3s\MP3s ~VBR 0\The Go! Team\Grip Like A Vice\folder.jpg
2007-09-20 12:20:36  Local cover art file does not exist
2007-09-20 12:20:36  CoverDownloader command: "C:\Program Files\AlbumArtDownloaderXUI\AlbumArt.exe" /artist "The Go! Team" /album "Grip Like A Vice" /path "C:\Documents and Settings\Neil\My Documents\Audio\Grip Like A Vice.%extension%" /autoclose /localImagesPath "E:\Documents and Settings\Chase\My Documents\My Music\MP3s\MP3s ~VBR 0\%artist%\%album%\folder.jpg"
2007-09-20 12:20:37  Copy Tracks Beginning...
2007-09-20 12:20:37  - END -
2007-09-20 12:20:46  Command line: REACT "The Go! Team - Grip Like A Vice - 01 - Grip Like A Vice.wav" "C:\Documents and Settings\Neil\My Documents\Audio\Ttmp0-!55.wav" "C:\Documents and Settings\Neil\My Documents\Audio\Ttmp0-!55.eac" "The Go! Team" "Grip Like A Vice" "Grip Like A Vice" "01" "2" "2007" "Fusion" "DISCNO" "0D018902" "ED0A9DE5" 128
2007-09-20 12:20:46  Source directory: C:\Documents and Settings\Neil\My Documents\Audio
2007-09-20 12:20:46  Base name: The Go! Team - Grip Like A Vice - 01 - Grip Like A Vice
2007-09-20 12:20:46  Artist: The Go! Team
2007-09-20 12:20:46  Album: Grip Like A Vice
2007-09-20 12:20:46  Title: Grip Like A Vice
2007-09-20 12:20:46  Track: 1
2007-09-20 12:20:46  Total tracks: 2
2007-09-20 12:20:46  Year: 2007
2007-09-20 12:20:46  Genre: Fusion
2007-09-20 12:20:46  Comment: DISCNO
2007-09-20 12:20:46  FreeDB ID: 0D018902
2007-09-20 12:20:46  CRC: ED0A9DE5
2007-09-20 12:20:46  Bitrate: 128
2007-09-20 12:20:46  Various artist: No
2007-09-20 12:20:46  Rip mode: Tracks
2007-09-20 12:20:47  Log: C:\Documents and Settings\Neil\My Documents\Audio\The Go! Team - Grip Like A Vice.log
2007-09-20 12:20:47  Album file: C:\Documents and Settings\Neil\My Documents\Audio\Grip Like A Vice
2007-09-20 12:20:47  Log file: C:\Documents and Settings\Neil\My Documents\Audio\The Go! Team - Grip Like A Vice
2007-09-20 12:20:47  Cover file: C:\Documents and Settings\Neil\My Documents\Audio\Grip Like A Vice.jpg
2007-09-20 12:21:15  - END -
2007-09-20 12:21:18  Command line: REACT "The Go! Team - Grip Like A Vice - 02 - A Version Of Myself.wav" "C:\Documents and Settings\Neil\My Documents\Audio\Ttmp6)!58.wav" "C:\Documents and Settings\Neil\My Documents\Audio\Ttmp6)!58.eac" "The Go! Team" "Grip Like A Vice" "A Version Of Myself" "02" "2" "2007" "Fusion" "DISCNO" "0D018902" "512B21EC" 128
2007-09-20 12:21:18  Source directory: C:\Documents and Settings\Neil\My Documents\Audio
2007-09-20 12:21:18  Base name: The Go! Team - Grip Like A Vice - 02 - A Version Of Myself
2007-09-20 12:21:18  Artist: The Go! Team
2007-09-20 12:21:18  Album: Grip Like A Vice
2007-09-20 12:21:18  Title: A Version Of Myself
2007-09-20 12:21:18  Track: 2
2007-09-20 12:21:18  Total tracks: 2
2007-09-20 12:21:18  Year: 2007
2007-09-20 12:21:18  Genre: Fusion
2007-09-20 12:21:18  Comment: DISCNO
2007-09-20 12:21:18  FreeDB ID: 0D018902
2007-09-20 12:21:18  CRC: 512B21EC
2007-09-20 12:21:18  Bitrate: 128
2007-09-20 12:21:18  Various artist: No
2007-09-20 12:21:18  Rip mode: Tracks
2007-09-20 12:21:18  Log: C:\Documents and Settings\Neil\My Documents\Audio\The Go! Team - Grip Like A Vice.log
2007-09-20 12:21:18  Album file: C:\Documents and Settings\Neil\My Documents\Audio\Grip Like A Vice
2007-09-20 12:21:18  Log file: C:\Documents and Settings\Neil\My Documents\Audio\The Go! Team - Grip Like A Vice
2007-09-20 12:21:18  Cover file: C:\Documents and Settings\Neil\My Documents\Audio\Grip Like A Vice.jpg
2007-09-20 12:21:38  - END -
I'm on a horse.
REACT 2 Released
Reply #691
What is wrong with this setup?...
[Settings]
Version=2.0.ssb16
ImageExt=wav
ImageNaming=$artist$ - [$year$] $album$
ImageHotKey={F10}
TracksHotKey={F4}
TracksHotVal=+{F5}
VA=Various Artists
CreateAllCuesheets=0
RunCoverDownloader=0
CoverDownloaderXUI=0
EAC=D:\Program Files\Exact Audio Copy\EAC.exe
Tools=D:\Program Files\REACT2\tools
MinimizeCompressionWindow=1
ProcessPriority=1
Sla_Bks_Col_Qst_Bar_Quo_Ast_Lt_Gt=-|-|-||!|'|#|[|]
Test=0
[UserTrackFormats]
LameMP3=1
[UserOutputNames]
TrackDir_MP3=E:\Documents and Settings\Chase\My Documents\My Music\MP3s\MP3s ~VBR 0\$artist$\$album$
TrackName_SA=$track$ - $title$
TrackName_VA=$track$ - $title$ [$artist$]
TrackName_SA_acdir=$n - $~t
TrackName_VA_acdir=$n - $~t [$~a]
[UserSettings]
DebugMode=1
Debug=0
Comment=Created with EAC/REACT2, @curdate@
EmbedCover=1
ReplayGain=0
ApplyAlbumGain=1
AdjustAlbumGain_dB=+1.0
AddCuesheetAG=0
UseWaveGainAG=0
Opt_LameMP3=-V0 --vbr-new --noreplaygain --nohist
Ver_LameMP3=3.97
[DefaultMetaData]
discnumber=1
totaldiscs=1
discname=
Opt_Flac=-5 -f
Opt_Wavpack=-hmy
Opt_LameMP3=-V5 --vbr-new --noreplaygain --nohist
Opt_NeroAac=-lc -q 0.21
Opt_iTunesAac=-d -s 2000
Opt_OggEnc2=-q 3.0
Ver_Flac=1.1.3
Ver_Wavpack=4.40
Ver_LameMP3=3.97
Ver_NeroAac=1.0.0.2
Ver_OggEnc2=2.83 Lancer aoTuV b5
[DefaultMetaData]
discnumber=1
totaldiscs=1
discname=
With the "RunCoverDownloader" variable. If I just want to use the local path, do I have to have this set to 1? Or will 0 still do the trick if I don't want to download the cover art, but instead just use the local path (ie: folder.jpg)?
Ahhh... that was my problem. I think a combination of two actually. Firstly, when I had the "RunCoverDownloader" set to 1, as well as my local path set, I pressed the MP3 button instead of F4. Then When the coverdownloader didn't run, I tried running REACT with the "RunCoverDownloader" set to 0. And this won't work at all, because although the folder.jpg is present and the local path is pointing to it, it still has to pass through the coverdownloader to be saved to C:\ (REACTs temp directory).
So to embed the cover, whether local or downloaded, both have to be passed through coverdownloader.
Thanks for your guys help. Sorry I suck so much, but I've leant quite a bit already.
Cheers.
REACT 2 Released
Reply #692
Yes.  Remember, CoverDownloaderLocalPath is a bit of a hack on my part.
RunCoverDownloader is (now) not so much "Run AlbumArt.exe" but "I want cover art".
I'm glad it's resolved.
I'm on a horse.
REACT 2 Released
Reply #693
As you may have noticed from my debugging.txt output above, CoverDownloaderLocalPath is also used to specify Album Art Downloader XUI's /localImagesPath switch, if it does not match a local file.  Note: $artist$ and $album$ are correctly converted to XUI's %artist% and %album% syntax.
Therefore, if you do not want to direct REACT to a specific file, e.g:
CoverDownloaderLocalPath=C:\Documents and Settings\Neil\My Documents\My Music\$artist$\$album$\folder.jpg
... you may want to use Album Art Downloader XUI's wildcard support (see quote below) to specify a more general local search, e.g.:
CoverDownloaderLocalPath=C:\Documents and Settings\Neil\My Documents\My Music\**\*.jpg
This will then open Album Art Downloader XUI, using any JPEG in "C:\Documents and Settings\Neil\My Documents\My Music" as a potential source.
Another suggestion:
CoverDownloaderLocalPath=C:\Documents and Settings\Neil\My Documents\My Music\$artist$\**\*.jpg
/localImagesPath
              Path to search for local image  (/localImagesPath "\Art\Unsorted\**\*.jpg")
              files in. If not specified, the
              path to save art in is used.
              The following variables can be used in paths:
               %artist%     Artist searched for
               %album%      Album searched for
               *            Wildcard, matches any characters
               \**\         Subfolder search. Any folders will match
                             at this point in the path. For example
                             "\Art\Unsorted\**\*.jpg" will match:
                             "\Art\Unsorted\*\*.jpg" will match only:
I'm on a horse.
REACT 2 Released
Reply #694
Wow, I give this place a rest (to write a scientific paper and to try to move house) and I come back to find a new version of EAC which works with AccurateRip.  Can someone fill me in on the changes I will need to make to use this new EAC with React.
(Synthetic Soul will remember we were using SED to manipulate to cuesheets and also pasting in the accuraterip data, so I guess some of this will be obselete, any other issues)
REACT 2 Released
Reply #695
Hi lipidicman.
You will have to use my mod now, as the EAC log file naming has changed (my mod will work with 0.99 and previous versions, but the official REACT will not pickup the log file if you are using 0.99). I know that you were the first to ever use it, so I guess this isn't a scare for you.
The AccurateRip results are stored in the log file.  I've not seen anything about anyone extracting them from the log, or anything else.
Oh, also, if you add Test=1 to the [Settings] section of your INI REACT will run in Test & Copy mode.  It may be worth skimming the changelog to see if there's anything else of interest that I've added; there's nothing revolutionary there.
Nothing else should have changed, or need changing (IIRC).
I'm on a horse.
REACT 2 Released
Reply #696
Thanks dude, I will have a look when I have more time.
Can I just check, REACT has not been changed?  So I need to upgrade EAC and your mod only
Also I always used test and copy, or is this test and copy for images (is this in EAC now?)
REACT 2 Released
Reply #697
I apologize if this has been answered before, but I couldn't find an answer.  I want to use REACT to apply wavegain to the temporary wav file before compressing to wavpack and aac.  With only minimal editing to the ini file, I can produce compressed files but have had no luck in applying wavegain.  My goal is to produce wavpack files that can taken from different CDs to burn my own compilations with reasonably consistent volume levels.
In any case, this is a great tool and thanks in advance for my light you can shed.
REACT 2 Released
Reply #698
You shouldn't(and can't with REACT) use WaveGain.exe to directly apply the gain to the temporary WAVs, since then the lossless archive files produced wouldn't be lossless anymore.
First you need to download aacgain.exe(mp3gain.exe adapted for aac input) and place it in your 'REACT2\tools' folder. Then you run REACT and press 'Alt+F2' to open 'REACT.ini' and then set 'ReplayGain' to '1'. This will make your WavPack and AAC files RG scanned and tagged with RG tags, so that RG compatible players will be able to scale the tracks accordingly. If you want to have the gain applied directly to the AAC files(and not just in the tags), then you should set 'ApplyAlbumGain' to '1', which will make the tracks have an Album Gain of 92dB. If you want another dB value, then change 'AdjustAlbumGain_dB' to another number than '+3.0'. The number is added to the standard 89dB level, so if you e.g. want to have 89dB, then just set it to '0'.
If you want to burn an audio CD from the WavPack files, then you can e.g. use Burrrn for that, since it has options for running WaveGain.exe on the files and to apply the gain you'd like before they are written to disc.
REACT 2 Released
Reply #699
Thanks Martin for the thoughtful reply. Great advice! Everything seems to be working as you described.
