Topic: foo_ui_panels (Read 1317942 times) previous topic - next topic
0 Members and 22 Guests are viewing this topic.
foo_ui_panels
Reply #1900
Thank you!
It works very good but the only problem is that the volume is on -100db on the next start!
try this.
add a fading: set volume to -100db with fade xx sec
add stop playback
add : set volume to xx db
add exit foobar
should work.
foo_ui_panels
Reply #1901
I'm very sorry about asking that here, but I didn't wanted to create a new topic for this short question.
The only question I want to ask is, if there is any tutorial on how to create your own theme?
The wiki files I wound aren't very useful at all if you are lacking of elementary skills (and I'm totally noob on this one).
But I really, I really want create my own style and sharing this with you.
This one is a good place to start with:
http://tagz.brother-john.net/requirements.html
foo_ui_panels
Reply #1902
First I want to ask if I has missed some note about where the 'Always on Top' has gone?
I can't find it in the PanelsUI-preferences but I suspect it has gone to the $windowstyle() command or somewhere similar?
Using latest version from the "main-page" (Panels UI 0.13.8 beta)
Then I want to know when we can expect the new display stuff (what you're currently developing in the 14.X) to be released (roughly this month?)
I currently wait with my new layout because I have quite few Track displays in there and I don't want to rewrite them all when you finish the new version!
foo_ui_panels
Reply #1903
I already had 3 foobar2000 crashes with the latest development release. Here is the log:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 056F9880h
Access violation, operation: read, address: 06D8D000h
Call path:
entry=>app_mainloop
Code bytes (056F9880h):
056F9840h:  84 02 00 83 C4 04 39 5C 24 50 BE 07 00 00 00 89
056F9850h:  74 24 6C 89 6C 24 68 66 89 6C 24 58 72 0D 8B 44
056F9860h:  24 3C 50 E8 9C 84 02 00 83 C4 04 8B 54 24 14 89
056F9870h:  74 24 50 89 6C 24 4C 66 89 6C 24 3C 8B 44 24 1C
056F9880h:  03 10 83 C0 04 83 C7 02 89 44 24 1C 0F B7 07 66
056F9890h:  3B C5 89 54 24 14 0F 85 A8 FE FF FF 8B 4C 24 28
056F98A0h:  89 39 8B C2 8B 8C 24 80 00 00 00 64 89 0D 00 00
056F98B0h:  00 00 59 5F 5E 5D 5B 8B 4C 24 68 33 CC E8 94 76
Stack (0012B61Ch):
0012B5FCh:  00000000 0000000C BC659120 0012CFAC
0012B60Ch:  00009A10 B3C4FB60 E46DE5E8 B3C4FD38
0012B61Ch:  0E94B92D 06D42B38 0012BA60 06D2DE60
0012B62Ch:  00000000 4977BBD4 00000004 06D8D000
0012B63Ch:  06D4336E 06D43368 0012B7F0 00000002
0012B64Ch:  00000002 06D43368 00000066 00000000
0012B65Ch:  00000000 00000002 06D42B38 00000000
0012B66Ch:  00000007 0575D7E0 00090000 000A000D
0012B67Ch:  00000000 00FFFFFF 00000000 00000007
0012B68Ch:  00120001 06D43372 056FE801 0E94B93D
0012B69Ch:  0012BAE4 0573BA28 FFFFFFFF 056FC6E4
0012B6ACh:  06D8ADC0 0012B7F0 0E94B9B5 00000000
0012B6BCh:  00000008 0012CC64 00000000 011F0125
0012B6CCh:  06D42BEA 00000000 0012B740 00000000
0012B6DCh:  00000000 00000036 00000006 06D42B38
0012B6ECh:  00000018 00000000 06CE1C88 016F5EAF
0012B6FCh:  000000FF 06D41EF0 0000005A 0012B678
0012B70Ch:  06D8ADC0 00000000 00000003 FFFFFEA8
0012B71Ch:  00000003 000005B5 00000011 05790000
0012B72Ch:  00000000 00000002 00000000 06D2DE48
Registers:
EAX: 06D8D000, EBX: 00000008, ECX: 00000004, EDX: 4977BBD4
ESI: 00000007, EDI: 06D43F86, EBP: 00000000, ESP: 0012B61C
Crash location: "foo_ui_panels", loaded at 056B0000h - 05775000h
Symbol: "foobar2000_get_interface" (+00006590h)
Loaded modules:
foobar2000                       loaded at 00400000h - 004F3000h
ntdll                            loaded at 7C900000h - 7C9AF000h
kernel32                         loaded at 7C800000h - 7C8F5000h
COMCTL32                         loaded at 773C0000h - 774C3000h
msvcrt                           loaded at 77C00000h - 77C58000h
ADVAPI32                         loaded at 77DC0000h - 77E6B000h
RPCRT4                           loaded at 77E70000h - 77F01000h
GDI32                            loaded at 77F10000h - 77F57000h
USER32                           loaded at 7E360000h - 7E3F0000h
SHLWAPI                          loaded at 77F60000h - 77FD6000h
SHELL32                          loaded at 7C9C0000h - 7D1D6000h
ole32                            loaded at 774D0000h - 7760D000h
shared                           loaded at 10000000h - 10029000h
comdlg32                         loaded at 76390000h - 763D9000h
uxtheme                          loaded at 5B250000h - 5B288000h
MSCTF                            loaded at 746F0000h - 7473B000h
foo_abx                          loaded at 00A90000h - 00AC3000h
foo_adpcm                        loaded at 00AF0000h - 00B42000h
foo_albumlist                    loaded at 00B70000h - 00BB7000h
OLEAUT32                         loaded at 77110000h - 7719C000h
foo_audioscrobbler               loaded at 00BE0000h - 00C18000h
WS2_32                           loaded at 71A90000h - 71AA7000h
WS2HELP                          loaded at 71A80000h - 71A88000h
foo_autoplaylist                 loaded at 00C40000h - 00C72000h
foo_bitcompare                   loaded at 00CA0000h - 00CC6000h
foo_browser                      loaded at 00CF0000h - 00D29000h
foo_cdda                         loaded at 00D50000h - 00D85000h
foo_channel_mixer                loaded at 00DB0000h - 00DEB000h
foo_common                       loaded at 00E00000h - 00E3A000h
foo_converter                    loaded at 00E60000h - 00EC9000h
foo_cuesheet_creator             loaded at 00EF0000h - 00F1D000h
foo_cwb_hooks                    loaded at 00F40000h - 00F8D000h
foo_dbsearch                     loaded at 00FB0000h - 0100C000h
foo_discogs                      loaded at 01030000h - 010A2000h
gdiplus                          loaded at 4EBE0000h - 4ED83000h
WINMM                            loaded at 76B30000h - 76B5D000h
foo_dsp_centercut                loaded at 01150000h - 01175000h
foo_dsp_continuator              loaded at 011A0000h - 011CF000h
foo_dsp_crossfader               loaded at 011E0000h - 0123D000h
libmmd                           loaded at 01250000h - 01501000h
MSVCR80                          loaded at 78130000h - 781CB000h
foo_dsp_delta                    loaded at 01530000h - 0154E000h
foo_dsp_silence                  loaded at 01570000h - 01599000h
foo_dsp_skip_silence             loaded at 015C0000h - 015CA000h
foo_dsp_soundtouch               loaded at 015E0000h - 015EF000h
MSVCP80                          loaded at 7C420000h - 7C4A7000h
foo_dsp_std                      loaded at 01600000h - 01641000h
foo_dsp_vlevel                   loaded at 01670000h - 01694000h
foo_freedb2                      loaded at 016C0000h - 01700000h
foo_input_alac                   loaded at 01720000h - 0173D000h
foo_input_awma                   loaded at 01760000h - 01779000h
WMVCore                          loaded at 15110000h - 1536A000h
WMASF                            loaded at 11C70000h - 11CA9000h
foo_input_dts                    loaded at 01790000h - 017F5000h
foo_input_matroska               loaded at 01820000h - 018A6000h
foo_input_monkey                 loaded at 018D0000h - 01919000h
foo_input_mslive                 loaded at 01940000h - 0195E000h
foo_input_shorten                loaded at 01970000h - 0199E000h
foo_input_std                    loaded at 019C0000h - 01AD3000h
foo_input_tta                    loaded at 01B00000h - 01B2D000h
foo_lnk                          loaded at 01B50000h - 01B69000h
foo_lyricsdb                     loaded at 01B90000h - 01BAE000h
WININET                          loaded at 771A0000h - 77246000h
CRYPT32                          loaded at 77A70000h - 77B05000h
MSASN1                           loaded at 77B10000h - 77B22000h
foo_managedWrapper               loaded at 01BC0000h - 01C62000h
mscoree                          loaded at 79000000h - 79045000h
msvcm80                          loaded at 7C4C0000h - 7C53D000h
mscorwks                         loaded at 79E70000h - 7A3D1000h
mscorlib.ni                      loaded at 790C0000h - 79BA8000h
mscorjit                         loaded at 79060000h - 790B3000h
rsaenh                           loaded at 0FFD0000h - 0FFF8000h
System.ni                        loaded at 7A440000h - 7ABFE000h
System.Drawing.ni                loaded at 7ADE0000h - 7AF74000h
System.Windows.Forms.ni          loaded at 7AFD0000h - 7BC56000h
xpsp2res                         loaded at 20000000h - 20502000h
dotnet_title                     loaded at 11000000h - 11014000h
foo_masstag                      loaded at 04620000h - 0466F000h
foo_masstag_addons               loaded at 04790000h - 0479E000h
foo_midi                         loaded at 047B0000h - 0485A000h
foo_packet_decoder_ac3           loaded at 04880000h - 048A7000h
foo_packet_decoder_wavpack       loaded at 048D0000h - 048F5000h
foo_playback_custom              loaded at 04920000h - 04965000h
WINSPOOL                         loaded at 72FC0000h - 72FE6000h
foo_playlist_bind                loaded at 049B0000h - 049D5000h
foo_playlist_manager             loaded at 049F0000h - 04A36000h
foo_playlist_tree                loaded at 04A60000h - 04AD5000h
libmzsch360_000                  loaded at 10400000h - 105D0000h
WSOCK32                          loaded at 71AB0000h - 71ABA000h
libmzgc360_000                   loaded at 04B00000h - 04BA4000h
foo_pqview                       loaded at 04BF0000h - 04C0C000h
foo_prettypop                    loaded at 04C30000h - 04C7D000h
foo_random                       loaded at 04D30000h - 04D6F000h
foo_removeplayed                 loaded at 04D70000h - 04D88000h
foo_rgscan                       loaded at 04DB0000h - 04DF8000h
foo_run                          loaded at 04E20000h - 04E4B000h
foo_scheduler                    loaded at 04E70000h - 04EDF000h
POWRPROF                         loaded at 74AA0000h - 74AA8000h
foo_scrobblecharts               loaded at 04F00000h - 04F33000h
foo_tradersfriend                loaded at 04F60000h - 04F9D000h
foo_uie_albumart                 loaded at 04FC0000h - 04FFA000h
foo_uie_albumlist                loaded at 05020000h - 05063000h
foo_uie_lyrics                   loaded at 05090000h - 050F4000h
foo_uie_lyrics_panel             loaded at 05120000h - 05189000h
foo_uie_queuemanager             loaded at 051B0000h - 051E9000h
foo_uie_quicksearch              loaded at 05280000h - 052C6000h
foo_uie_vis_egoh                 loaded at 052F0000h - 0530D000h
foo_uie_vis_projectm             loaded at 05320000h - 0536C000h
OPENGL32                         loaded at 5F210000h - 5F2DC000h
GLU32                            loaded at 61AE0000h - 61B01000h
DDRAW                            loaded at 73720000h - 73769000h
DCIMAN32                         loaded at 73B80000h - 73B86000h
foo_ui_columns                   loaded at 055E0000h - 05683000h
foo_ui_panels                    loaded at 056B0000h - 05775000h
IMM32                            loaded at 76370000h - 7638D000h
foo_ui_std                       loaded at 057A0000h - 057F7000h
foo_unpack                       loaded at 05820000h - 0584E000h
foo_utils                        loaded at 05870000h - 058A9000h
foo_utils_matroska               loaded at 058D0000h - 058EA000h
foo_verifier                     loaded at 05910000h - 05940000h
foo_version                      loaded at 05960000h - 05985000h
dbghelp                          loaded at 59C50000h - 59CF1000h
VERSION                          loaded at 77BF0000h - 77BF8000h
foo_ui_minilyrics                loaded at 05AB0000h - 05AD2000h
ctagent                          loaded at 05D00000h - 05D06000h
System.Xml.ni                    loaded at 69BE0000h - 6A148000h
MiniLyrics                       loaded at 07040000h - 0713F000h
Msimg32                          loaded at 76360000h - 76365000h
mswsock                          loaded at 71A30000h - 71A70000h
DNSAPI                           loaded at 76F10000h - 76F37000h
iphlpapi                         loaded at 76D50000h - 76D69000h
winrnr                           loaded at 76FA0000h - 76FA8000h
WLDAP32                          loaded at 76F50000h - 76F7D000h
CavEmLSP                         loaded at 082F0000h - 08304000h
hnetcfg                          loaded at 698B0000h - 69908000h
wshtcpip                         loaded at 71A70000h - 71A78000h
rasadhlp                         loaded at 76FB0000h - 76FB6000h
DSOUND                           loaded at 73ED0000h - 73F2C000h
mscorlib.resources               loaded at 0B310000h - 0B35E000h
wdmaud                           loaded at 72CE0000h - 72CE9000h
WINTRUST                         loaded at 76C20000h - 76C4E000h
IMAGEHLP                         loaded at 76C80000h - 76CA8000h
msacm32                          loaded at 72CD0000h - 72CD8000h
MSACM32                          loaded at 77BD0000h - 77BE5000h
midimap                          loaded at 77BC0000h - 77BC7000h
KsUser                           loaded at 73EA0000h - 73EA4000h
Stack dump analysis:
Address: 0575D7E0h, location: "foo_ui_panels", loaded at 056B0000h - 05775000h
Address: 00FFFFFFh, location: "foo_dbsearch", loaded at 00FB0000h - 0100C000h
Address: 056FE801h, location: "foo_ui_panels", loaded at 056B0000h - 05775000h
Symbol: "foobar2000_get_interface" (+0000B511h)
Address: 0573BA28h, location: "foo_ui_panels", loaded at 056B0000h - 05775000h
Address: 056FC6E4h, location: "foo_ui_panels", loaded at 056B0000h - 05775000h
Symbol: "foobar2000_get_interface" (+000093F4h)
Address: 011F0125h, location: "foo_dsp_crossfader", loaded at 011E0000h - 0123D000h
Address: 0045DFA4h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C911538h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "wcsncpy" (+00000AA9h)
Address: 7C9106EBh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Address: 7C911596h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "wcsncpy" (+00000B07h)
Address: 7C9105D4h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAllocateHeap" (+00000000h)
Address: 7C917BB0h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlReAllocateHeap" (+000001B3h)
Address: 7C910570h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlFreeHeap" (+00000133h)
Address: 7C91056Dh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlFreeHeap" (+00000130h)
Address: 7C9105C8h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlFreeHeap" (+0000018Bh)
Address: 7C910551h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlFreeHeap" (+00000114h)
Address: 7C910732h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAllocateHeap" (+0000015Eh)
Address: 004C1EE4h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C90EE18h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "strchr" (+00000117h)
Address: 7C910738h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAllocateHeap" (+00000164h)
Address: 0572A2B0h, location: "foo_ui_panels", loaded at 056B0000h - 05775000h
Address: 056B149Dh, location: "foo_ui_panels", loaded at 056B0000h - 05775000h
Address: 7C910E91h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "wcsncpy" (+00000402h)
Address: 0045004Dh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 056C759Ah, location: "foo_ui_panels", loaded at 056B0000h - 05775000h
Address: 018A0021h, location: "foo_input_matroska", loaded at 01820000h - 018A6000h
Address: 7C900000h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Address: 057211ADh, location: "foo_ui_panels", loaded at 056B0000h - 05775000h
Address: 056B0000h, location: "foo_ui_panels", loaded at 056B0000h - 05775000h
Address: 0573E67Bh, location: "foo_ui_panels", loaded at 056B0000h - 05775000h
Address: 056F279Ah, location: "foo_ui_panels", loaded at 056B0000h - 05775000h
Address: 05745F94h, location: "foo_ui_panels", loaded at 056B0000h - 05775000h
Address: 7C9106F0h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAllocateHeap" (+0000011Ch)
Address: 05721BFDh, location: "foo_ui_panels", loaded at 056B0000h - 05775000h
Address: 057211FDh, location: "foo_ui_panels", loaded at 056B0000h - 05775000h
Address: 0573E6CBh, location: "foo_ui_panels", loaded at 056B0000h - 05775000h
Address: 056C359Fh, location: "foo_ui_panels", loaded at 056B0000h - 05775000h
Address: 7C912270h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlInitializeCriticalSection" (+00000743h)
Address: 4EC05331h, location: "gdiplus", loaded at 4EBE0000h - 4ED83000h
Address: 01000000h, location: "foo_dbsearch", loaded at 00FB0000h - 0100C000h
Address: 7C90D4EAh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "ZwAllocateVirtualMemory" (+0000000Ch)
Address: 7C9180FFh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlReAllocateHeap" (+00000702h)
Address: 7C91825Dh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlReAllocateHeap" (+00000860h)
Address: 7C9106ABh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAllocateHeap" (+000000D7h)
Address: 7C910F46h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "wcsncpy" (+000004B7h)
Address: 4ED3A00Fh, location: "gdiplus", loaded at 4EBE0000h - 4ED83000h
Address: 7C911BFFh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlInitializeCriticalSection" (+000000D2h)
Address: 7C911DACh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlInitializeCriticalSection" (+0000027Fh)
Address: 4ECE2F2Ch, location: "gdiplus", loaded at 4EBE0000h - 4ED83000h
Address: 4ECDAFC0h, location: "gdiplus", loaded at 4EBE0000h - 4ED83000h
Address: 4ECDAF5Ch, location: "gdiplus", loaded at 4EBE0000h - 4ED83000h
Address: 4ED5EE10h, location: "gdiplus", loaded at 4EBE0000h - 4ED83000h
Address: 77F1BAC2h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "StretchBlt" (+00000000h)
Address: 4ECD31CCh, location: "gdiplus", loaded at 4EBE0000h - 4ED83000h
Address: 4EC36FFFh, location: "gdiplus", loaded at 4EBE0000h - 4ED83000h
Address: 7C918331h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlReAllocateHeap" (+00000934h)
Address: 7C9182BAh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlReAllocateHeap" (+000008BDh)
Address: 7C91849Fh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlReAllocateHeap" (+00000AA2h)
Address: 7C911962h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlDeleteCriticalSection" (+000000D8h)
Address: 7C911993h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlDeleteCriticalSection" (+00000109h)
Address: 7C97C080h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Address: 7C911970h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlDeleteCriticalSection" (+000000E6h)
Address: 7C911978h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlDeleteCriticalSection" (+000000EEh)
Address: 7C911902h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlDeleteCriticalSection" (+00000078h)
Address: 4ECCD8B8h, location: "gdiplus", loaded at 4EBE0000h - 4ED83000h
Address: 4EC058A7h, location: "gdiplus", loaded at 4EBE0000h - 4ED83000h
Address: 4EC3F77Ah, location: "gdiplus", loaded at 4EBE0000h - 4ED83000h
Address: 4EC3D393h, location: "gdiplus", loaded at 4EBE0000h - 4ED83000h
Address: 4EC4C164h, location: "gdiplus", loaded at 4EBE0000h - 4ED83000h
Address: 4EC4C184h, location: "gdiplus", loaded at 4EBE0000h - 4ED83000h
Address: 4EBE1580h, location: "gdiplus", loaded at 4EBE0000h - 4ED83000h
Address: 00FF0000h, location: "foo_dbsearch", loaded at 00FB0000h - 0100C000h
Address: 77F19210h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "SetDIBitsToDevice" (+00000204h)
Address: 77F198EBh, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "CreateFontIndirectExW" (+00000084h)
Address: 77F198C6h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "CreateFontIndirectExW" (+0000005Fh)
Address: 77F199AFh, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "CreateFontIndirectW" (+00000046h)
Address: 77F199B7h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "CreateFontIndirectW" (+0000004Eh)
Address: 77F18EF9h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "GetMapMode" (+00000124h)
Address: 5B254B63h, location: "uxtheme", loaded at 5B250000h - 5B288000h
Symbol: "Ordinal45" (+0000007Ah)
Address: 7C910000h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlNtStatusToDosErrorNoTeb" (+00000477h)
Version info:
foobar2000 v0.9.4.3
UNICODE
Additional info:
Acro WMA decoder 0.1.5  (foo_input_awma)
mslive streaming support 0.1.6.3  (foo_input_mslive)
Playlist Manager 1.0  (foo_playlist_manager)
Post-track silence 0.0.2  (foo_dsp_silence)
WavPack Packet Decoder 0.9.0  (foo_packet_decoder_wavpack)
freedb Tagger 0.5.2a  (foo_freedb2)
foo_lyricsdb 0.0.7 beta 4  (foo_lyricsdb)
Playlist Bind 2.2  (foo_playlist_bind)
BRR decoder and converter 0.7  (foo_adpcm)
DTS decoder 0.1.7  (foo_input_dts)
File Integrity Verifier 1.0.1  (foo_verifier)
Shorten decoder 0.4.2a  (foo_input_shorten)
CD Audio Decoder 2.1.1  (foo_cdda)
Shell link resolver 1.1  (foo_lnk)
Egoh Spectrum analyser (uie) 1.1.2  (foo_uie_vis_egoh)
cwbowron's title format hooks 1.2.5 [Jun  8 2007 - 08:49:42]  (foo_cwb_hooks)
Last.fm Chart Player 0.2.3  (foo_scrobblecharts)
Cuesheet Creator 0.4.5  (foo_cuesheet_creator)
Scheduler 3.53  (foo_scheduler)
ReplayGain Scanner 2.0.2  (foo_rgscan)
Album list panel 0.2.3 beta  (foo_uie_albumlist)
Continuator 0.4.1  (foo_dsp_continuator)
Queue manager panel 0.2.3  (foo_uie_queuemanager)
Playback Statistics Custom 1.0.1  (foo_playback_custom)
XA ADPCM decoder 1.2  (foo_adpcm)
Standard DSP array 1.0  (foo_dsp_std)
Database search 1.3.1 beta 11  (foo_dbsearch)
Music Browser 1.2.3b [Mar 23 2007 - 16:52:56]  (foo_browser)
foo_managedWrapper 0.3  (foo_managedWrapper)
Monkey's Audio decoder 2.1.1  (foo_input_monkey)
RAR reader 1.1  (foo_unpack)
WMA Decoder 1.1  (foo_input_std)
foobar2000 core 0.9.4.3  (Core)
Audioscrobbler 1.3.2  (foo_audioscrobbler)
LPCM <--> delta-PCM converter 0.1.1  (foo_dsp_delta)
Playlist tools 0.5.7  (foo_utils)
Discogs Tagger 0.92  (foo_discogs)
Gapless Crossfader 0.3.2.2 (Intel SSE)  (foo_dsp_crossfader)
Playlist Tree Panel 3.0.BETA_3 [Apr  3 2007 - 11:39:32]  (foo_playlist_tree)
Center Cut 1.0.1  (foo_dsp_centercut)
Tagger Panel Window 1.0.5 [Jun 12 2007 - 15:14:00]  (foo_cwb_hooks)
RAC decoder 1.0  (foo_adpcm)
Interplay ACM decoder 1.0  (foo_adpcm)
Skip silence 0.1  (foo_dsp_skip_silence)
Columns UI 0.2.0 alpha 2  (foo_ui_columns)
Default User Interface 0.9acc  (foo_ui_std)
Converter 1.0.1  (foo_converter)
TTA Audio Decoder (unofficial) 2.4.1  (foo_input_tta)
Lyrics panel 0.35  (foo_uie_lyrics_panel)
OKI-ADPCM decoder 0.14  (foo_adpcm)
VLevel 20060324.0  (foo_dsp_vlevel)
Panels UI 0.14.5 beta [Jul  7 2007 - 16:06:22]  (foo_ui_panels)
SoundTouch DSP 0.1  (foo_dsp_soundtouch)
Live show tagger 0.6.1  (foo_tradersfriend)
MIDI synthesizer host 1.7  (foo_midi)
kode's ADPCM decoders 1.2  (foo_adpcm)
ZIP/GZIP reader 1.0  (foo_unpack)
Channel Mixer 0.9.6.2  (foo_channel_mixer)
Randomized playlist entry 1.2.3  (foo_random)
ATSC A/52 (AC3) Packet Decoder 0.9  (foo_packet_decoder_ac3)
Matroska Plugin 0.9.1.2  (foo_input_matroska)
Album List 3.2.0  (foo_albumlist)
Remove played Files 1.3.0  (foo_removeplayed)
Lyric Show Panels 0.3.1.1b6 [Jul  3 2007 - 19:59:05]  (foo_uie_lyrics)
ALAC Decoder 1.0  (foo_input_alac)
ABX Comparator 1.3.1  (foo_abx)
Album Art Panel 0.2.5.2  (foo_uie_albumart)
Pretty Popup 1.2.3  (foo_prettypop)
Common services 0.1  (foo_common)
Run services 0.3.2  (foo_run)
FLAC Decoder 1.1.0  (foo_input_std)
Masstagger Addons 0.3.2  (foo_masstag_addons)
Matroska Utility Plugin 1.0.2  (foo_utils_matroska)
GCN DSP decoder 1.2  (foo_adpcm)
Standard Input Array 1.0  (foo_input_std)
projectM visualization (Panel) 0.4 (SSE2)  (foo_uie_vis_projectm)
Components versions viewer 0.1  (foo_version)
Binary comparator 1.0  (foo_bitcompare)
Quick Search Toolbar 2.8l  (foo_uie_quicksearch)
Masstagger 1.6  (foo_masstag)
ADX decoder 1.6  (foo_adpcm)
foo_ui_panels
Reply #1904
The problem that the text is lying upon each other if there isn't enought space persists in the new version.
Is this a bug? Or is this feature not available any longer?
In the old versions this didn't happen ...
the "avoiding text" feature isn't available yet... but it should be easier to position text with the new $alignr() function.
The new test version does not support negative values for panels. Is that intended? I found it very useful for hiding the left margin in albumlist. Thanks.
changed it back in the new version.
I have a small problem with my config, using panels ui.
When I close foobar when it was minimized, on the next start, this is what appears, whereas I should see the whole window, only the titlebar appears.
So I need to restart foobar in order to see my normal window.
you should be able to click on the tray icon to restore the window instead of having to restart. I will see if I can fix the bug for the next version.
always on top will be moved to the $windowstyle()... but its not implemented yet. The new display stuff is basically done and should be pretty much compatible with your old layout.
Unfortunately, I seem to have misplaced the debug info for this version  Please try the new version and post a crash log (if one occurs).
I've uploaded a new test version here/url].
Barring any new bugs, I will replace the beta with this version in the next couple of days.
foo_ui_panels
Reply #1905
At first i didnt wnat to try the very last version because i was not sure my skin would work. But now that i did i must say Terrestrial you keep on surprising me, you work is awesome. I love the drag n drop feature(i still hope for a way to change the icon), it allows some very new things(because the drop can be out of foobar). Moreover i want to point out that run services work again and that s huge for me !
I dont know if it s me but dragging the window in the last version seems also a lot more fluent. I am gona investigate all those new little things.
THanks a lot for your work Terrestrial
foo_ui_panels
Reply #1906
@terrestrial: Will the "avoidung text" be reintegrated? When not it isn't to difficult to create a string which cuts the text at a specific length.
foo_ui_panels
Reply #1907
Hi I am wanting to add a button to my track info display that will change the front cover to back cover to, cd, inlay, booklet etc. My question is would I have to create a display mode for each one of the images or is there a much easier way.
I love π
foo_ui_panels
Reply #1908
Question does buttonfunction work inthe testversion in a track display?
Where is dokumented which command will work in Trakc Display. I didn`t find a thing.
I just want to create a miniplayer with a dockable panel.
foo_ui_panels
Reply #1909
They work for me
foo_ui_panels
Reply #1910
Are you using the test version? I tried to add a button in a normal Track Display but this didn't work.
Sorry for some reason it seems to work now.
I found a strange behaviour: A Track Display which uses the same code as the Track display in the panel ui shows [unknown function] when using a panel inside while the originally Trackdisplay works.
I think this is a dockable panel problem...
foo_ui_panels
Reply #1911
terrestrial, I got a crash using your newest test version.
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 02A8ECFFh
Access violation, operation: read, address: 0000000Ch
Call path:
entry=>app_mainloop
Code bytes (02A8ECFFh):
02A8ECBFh:  24 14 8B 16 8B 52 0C 51 8B CE FF D2 8B F8 85 FF
02A8ECCFh:  74 23 8B 06 8B 50 08 6A 00 57 8B CE FF D2 8B 4E
02A8ECDFh:  0C 2B 41 0C 3B 44 24 14 76 0B 8B CF 8B C6 E8 6E
02A8ECEFh:  F5 FF FF 8B F8 8B 43 0C 8B 56 0C 3B 42 0C 7C 0C
02A8ECFFh:  3B 47 0C 7F 07 B0 01 5F 83 C4 18 C3 32 C0 5F 83
02A8ED0Fh:  C4 18 C3 CC CC CC CC CC CC CC CC CC CC CC CC CC
02A8ED1Fh:  CC 51 55 56 8B F1 8B 4E 0C 8B 51 0C 57 8B F8 8B
02A8ED2Fh:  06 8B 40 0C 03 D7 52 8B CE FF D0 85 C0 74 0E 8B
Stack (0012F950h):
0012F930h:  00000000 00000000 00000000 00000000
0012F940h:  00000000 00000000 00000000 00000000
0012F950h:  00710454 04357938 00000000 00000000
0012F960h:  00000000 00000000 0435AFE8 02A8E577
0012F970h:  0435AFE8 01500001 00000100 0012F9AC
0012F980h:  02A8E6CB 00710454 00000100 00000028
0012F990h:  01500001 02A8E758 00710454 0435AFE8
0012F9A0h:  01500001 00000028 0012FA68 00000100
0012F9B0h:  02A9EB77 0435AFE8 00710454 00000100
0012F9C0h:  00000028 01500001 0012FA50 00000100
0012F9D0h:  0012FA00 00000000 76CA1A10 00710454
0012F9E0h:  00000100 00000028 01500001 00000100
0012F9F0h:  DCBAABCD 00000000 0012FA50 00000100
0012FA00h:  0012FA78 76CA1AE8 02A9EB30 00710454
0012FA10h:  00000100 00000028 01500001 256F56D7
0012FA20h:  0012FB08 0012FB00 00E0B000 00000024
0012FA30h:  00000001 00000000 00000000 00000030
0012FA40h:  FFFFFFFF FFFFFFFF 76CA1A91 00000000
0012FA50h:  53B400F7 00000001 00000000 00000000
0012FA60h:  0012FA1C 0012F570 0012FACC 76CE76CC
Registers:
EAX: 00000003, EBX: 043579A0, ECX: 04357938, EDX: 04357938
ESI: 0435AFE8, EDI: 00000000, EBP: 0012F9AC, ESP: 0012F950
Crash location: "foo_ui_panels", loaded at 02A50000h - 02B1E000h
Loaded modules:
foobar2000                      loaded at 00400000h - 004FE000h
ntdll                            loaded at 77230000h - 7734E000h
kernel32                        loaded at 76D70000h - 76E48000h
ADVAPI32                        loaded at 75C90000h - 75D4F000h
RPCRT4                          loaded at 76E50000h - 76F13000h
COMCTL32                        loaded at 74930000h - 74AC4000h
msvcrt                          loaded at 770B0000h - 7715A000h
GDI32                            loaded at 75C40000h - 75C8B000h
USER32                          loaded at 76C80000h - 76D1E000h
SHLWAPI                          loaded at 77390000h - 773E5000h
ole32                            loaded at 75E20000h - 75F64000h
shared                          loaded at 10000000h - 1002F000h
comdlg32                        loaded at 760A0000h - 76114000h
SHELL32                          loaded at 761B0000h - 76C7E000h
IMM32                            loaded at 77350000h - 7736E000h
MSCTF                            loaded at 77160000h - 77227000h
LPK                              loaded at 75AF0000h - 75AF9000h
USP10                            loaded at 773F0000h - 7746D000h
wbload                          loaded at 66800000h - 6680E000h
WBLIND                          loaded at 66000000h - 66088000h
WINMM                            loaded at 74540000h - 74573000h
OLEAUT32                        loaded at 75B00000h - 75B8C000h
OLEACC                          loaded at 74500000h - 74538000h
UXTHEME                          loaded at 748F0000h - 7492F000h
msimg32                          loaded at 74E30000h - 74E35000h
wbhelp                          loaded at 66600000h - 66617000h
RocketDock                      loaded at 00D10000h - 00D22000h
PSAPI                            loaded at 75AE0000h - 75AE7000h
AM27105                          loaded at 010F0000h - 0112B000h
ws2_32                          loaded at 75B90000h - 75BBD000h
NSI                              loaded at 77380000h - 77386000h
HKDll                            loaded at 014F0000h - 014FE000h
DWMAPI                          loaded at 73940000h - 7394C000h
foo_audioscrobbler              loaded at 015A0000h - 015DB000h
foo_common                      loaded at 01610000h - 01649000h
foo_controlserver                loaded at 01650000h - 0168D000h
foo_converter                    loaded at 01860000h - 018CF000h
foo_convolve                    loaded at 016A0000h - 016F5000h
foo_cwb_hooks                    loaded at 018D0000h - 01922000h
foo_dsp_bs2b                    loaded at 01960000h - 0197F000h
foo_dsp_crossfader              loaded at 01990000h - 019EE000h
libmmd                          loaded at 01DD0000h - 0208E000h
MSVCR80                          loaded at 734D0000h - 7356B000h
foo_dsp_dolbyhp                  loaded at 01A00000h - 01A29000h
VERSION                          loaded at 751C0000h - 751C8000h
foo_dsp_stereoconv              loaded at 01A90000h - 01AC3000h
foo_dsp_vlevel                  loaded at 01AD0000h - 01AF8000h
foo_dumb                        loaded at 01C10000h - 01C99000h
foo_infobox                      loaded at 01B90000h - 01BD4000h
foo_input_std                    loaded at 02250000h - 0236B000h
foo_input_tak                    loaded at 01CA0000h - 01CEB000h
tak_deco_lib                    loaded at 01B40000h - 01B75000h
foo_masstag                      loaded at 02090000h - 020E4000h
foo_misc_addons                  loaded at 01D30000h - 01D70000h
foo_navigator                    loaded at 01D80000h - 01DB5000h
foo_osd                          loaded at 020F0000h - 02126000h
foo_playback_custom              loaded at 021C0000h - 02204000h
WINSPOOL                        loaded at 73F20000h - 73F61000h
foo_pqview                      loaded at 02170000h - 0218E000h
foo_rgscan                      loaded at 02550000h - 0259D000h
foo_run                          loaded at 02210000h - 0223F000h
foo_scheduler                    loaded at 02610000h - 0267F000h
POWRPROF                        loaded at 74E40000h - 74E5A000h
foo_uie_lyrics                  loaded at 02700000h - 02764000h
gdiplus                          loaded at 74590000h - 7473A000h
WININET                          loaded at 75D50000h - 75E1F000h
Normaliz                        loaded at 77370000h - 77373000h
iertutil                        loaded at 75BC0000h - 75C05000h
foo_uie_peakmeter                loaded at 025C0000h - 025EC000h
foo_uie_playlists_dropdown      loaded at 027B0000h - 027EE000h
foo_uie_quicksearch              loaded at 027F0000h - 0283B000h
foo_uie_tabs                    loaded at 026C0000h - 026EE000h
foo_uie_vis_egoh                loaded at 02770000h - 02791000h
foo_ui_columns                  loaded at 028F0000h - 0299C000h
foo_ui_panels                    loaded at 02A50000h - 02B1E000h
foo_utils                        loaded at 02870000h - 028AD000h
foo_version                      loaded at 029A0000h - 029CA000h
dbghelp                          loaded at 70A60000h - 70B3C000h
zlib1                            loaded at 02B20000h - 02B35000h
DolbyHph                        loaded at 04D00000h - 04E00000h
NLAapi                          loaded at 744E0000h - 744EF000h
IPHLPAPI                        loaded at 75380000h - 75399000h
dhcpcsvc                        loaded at 75340000h - 75375000h
DNSAPI                          loaded at 757E0000h - 7580B000h
Secur32                          loaded at 75980000h - 75994000h
WINNSI                          loaded at 755A0000h - 755A7000h
dhcpcsvc6                        loaded at 75320000h - 75340000h
mswsock                          loaded at 75150000h - 7518B000h
winrnr                          loaded at 73960000h - 73968000h
WLDAP32                          loaded at 76D20000h - 76D69000h
napinsp                          loaded at 73950000h - 7395F000h
pnrpnsp                          loaded at 73910000h - 73922000h
wshtcpip                        loaded at 74E20000h - 74E26000h
rasadhlp                        loaded at 73C20000h - 73C26000h
wship6                          loaded at 751B0000h - 751B6000h
DSOUND                          loaded at 6FFB0000h - 70021000h
RASAPI32                        loaded at 72760000h - 727A7000h
rasman                          loaded at 74760000h - 74774000h
NETAPI32                        loaded at 75750000h - 757BA000h
TAPI32                          loaded at 72630000h - 72661000h
rtutils                          loaded at 74750000h - 7475C000h
USERENV                          loaded at 759A0000h - 759BE000h
CLBCatQ                          loaded at 76120000h - 761A4000h
MMDevApi                        loaded at 743B0000h - 743D7000h
urlmon                          loaded at 75F70000h - 76094000h
SETUPAPI                        loaded at 76F20000h - 770A8000h
WINTRUST                        loaded at 74310000h - 7433D000h
CRYPT32                          loaded at 75420000h - 75511000h
MSASN1                          loaded at 75600000h - 75612000h
imagehlp                        loaded at 75C10000h - 75C39000h
audioses                        loaded at 73AA0000h - 73AC1000h
audioeng                        loaded at 73A30000h - 73A96000h
AVRT                            loaded at 744F0000h - 744F7000h
rsaenh                          loaded at 74EE0000h - 74F18000h
browseui                        loaded at 72D30000h - 72E75000h
PROPSYS                          loaded at 743E0000h - 74497000h
DUser                            loaded at 748C0000h - 748F0000h
tiptsf                          loaded at 6F950000h - 6F9B0000h
WindowsCodecs                    loaded at 73230000h - 732E2000h
apphelp                          loaded at 758F0000h - 7591C000h
cscui                            loaded at 73190000h - 73225000h
CSCDLL                          loaded at 73670000h - 73679000h
CSCAPI                          loaded at 73660000h - 7366A000h
SAMLIB                          loaded at 757C0000h - 757D1000h
ntshrui                          loaded at 6D690000h - 6D6DA000h
slc                              loaded at 753E0000h - 75419000h
msshsq                          loaded at 72C00000h - 72C38000h
thumbcache                      loaded at 6FC20000h - 6FC32000h
actxprxy                        loaded at 703B0000h - 70403000h
SHDOCVW                          loaded at 72E80000h - 72F87000h
ieframe                          loaded at 713A0000h - 7196B000h
events                          loaded at 16000000h - 16036000h
MSVCP71                          loaded at 7C3A0000h - 7C41B000h
MSVCR71                          loaded at 7C340000h - 7C396000h
Address: 02A8E577h, location: "foo_ui_panels", loaded at 02A50000h - 02B1E000h
Address: 02A8E6CBh, location: "foo_ui_panels", loaded at 02A50000h - 02B1E000h
Address: 02A8E758h, location: "foo_ui_panels", loaded at 02A50000h - 02B1E000h
Address: 02A9EB77h, location: "foo_ui_panels", loaded at 02A50000h - 02B1E000h
Symbol: "foobar2000_get_interface" (+0000B887h)
Address: 76CA1A10h, location: "USER32", loaded at 76C80000h - 76D1E000h
Symbol: "GetMessageW" (+0000006Eh)
Address: 76CA1AE8h, location: "USER32", loaded at 76C80000h - 76D1E000h
Symbol: "GetMessageW" (+00000146h)
Address: 02A9EB30h, location: "foo_ui_panels", loaded at 02A50000h - 02B1E000h
Symbol: "foobar2000_get_interface" (+0000B840h)
Address: 76CA1A91h, location: "USER32", loaded at 76C80000h - 76D1E000h
Symbol: "GetMessageW" (+000000EFh)
Address: 76CE76CCh, location: "USER32", loaded at 76C80000h - 76D1E000h
Symbol: "AlignRects" (+00001926h)
Address: 76CA2A47h, location: "USER32", loaded at 76C80000h - 76D1E000h
Symbol: "IsWindow" (+0000014Dh)
Address: 76C98C2Eh, location: "USER32", loaded at 76C80000h - 76D1E000h
Symbol: "DestroyWindow" (+00000000h)
Address: 76CA2A98h, location: "USER32", loaded at 76C80000h - 76D1E000h
Symbol: "DispatchMessageW" (+0000000Fh)
Address: 0042FE21h, location: "foobar2000", loaded at 00400000h - 004FE000h
Address: 10002DD2h, location: "shared", loaded at 10000000h - 1002F000h
Symbol: "uCallStackTracker::uCallStackTracker" (+00000032h)
Address: 004C0530h, location: "foobar2000", loaded at 00400000h - 004FE000h
Address: 00430967h, location: "foobar2000", loaded at 00400000h - 004FE000h
Address: 004C07D0h, location: "foobar2000", loaded at 00400000h - 004FE000h
Address: 004BC438h, location: "foobar2000", loaded at 00400000h - 004FE000h
Address: 02000002h, location: "libmmd", loaded at 01DD0000h - 0208E000h
Symbol: "_csqrtq_f90" (+0022D6C6h)
Address: 77292447h, location: "ntdll", loaded at 77230000h - 7734E000h
Symbol: "RtlTryEnterCriticalSection" (+00000B61h)
Address: 016B009Eh, location: "foo_convolve", loaded at 016A0000h - 016F5000h
Symbol: "foobar2000_get_interface" (+0000AEBEh)
Address: 00400000h, location: "foobar2000", loaded at 00400000h - 004FE000h
Address: 004C70E0h, location: "foobar2000", loaded at 00400000h - 004FE000h
Address: 77238BF2h, location: "ntdll", loaded at 77230000h - 7734E000h
Symbol: "EtwLogTraceEvent" (+000000FBh)
Address: 7727C56Bh, location: "ntdll", loaded at 77230000h - 7734E000h
Symbol: "RtlConvertUlongToLargeInteger" (+000075E5h)
Address: 7729214Ch, location: "ntdll", loaded at 77230000h - 7734E000h
Symbol: "RtlTryEnterCriticalSection" (+00000866h)
Address: 7729240Bh, location: "ntdll", loaded at 77230000h - 7734E000h
Symbol: "RtlTryEnterCriticalSection" (+00000B25h)
Address: 77291843h, location: "ntdll", loaded at 77230000h - 7734E000h
Symbol: "RtlAllocateHeap" (+00000216h)
Address: 7727CCF3h, location: "ntdll", loaded at 77230000h - 7734E000h
Symbol: "RtlConvertUlongToLargeInteger" (+00007D6Dh)
Address: 772916DCh, location: "ntdll", loaded at 77230000h - 7734E000h
Symbol: "RtlAllocateHeap" (+000000AFh)
Address: 7729162Dh, location: "ntdll", loaded at 77230000h - 7734E000h
Address: 0043D4DDh, location: "foobar2000", loaded at 00400000h - 004FE000h
Address: 00407E27h, location: "foobar2000", loaded at 00400000h - 004FE000h
Address: 00491E58h, location: "foobar2000", loaded at 00400000h - 004FE000h
Address: 004E4218h, location: "foobar2000", loaded at 00400000h - 004FE000h
Address: 00447AE7h, location: "foobar2000", loaded at 00400000h - 004FE000h
Address: 004991DDh, location: "foobar2000", loaded at 00400000h - 004FE000h
Address: 00497110h, location: "foobar2000", loaded at 00400000h - 004FE000h
Address: 004C0540h, location: "foobar2000", loaded at 00400000h - 004FE000h
Address: 10002D87h, location: "shared", loaded at 10000000h - 1002F000h
Symbol: "uPrintCrashInfo_SetDumpPath" (+000000A7h)
Address: 004AF4F4h, location: "foobar2000", loaded at 00400000h - 004FE000h
Address: 00430B6Eh, location: "foobar2000", loaded at 00400000h - 004FE000h
Address: 004E0928h, location: "foobar2000", loaded at 00400000h - 004FE000h
Address: 004973CAh, location: "foobar2000", loaded at 00400000h - 004FE000h
Address: 004936FCh, location: "foobar2000", loaded at 00400000h - 004FE000h
Address: 004936F6h, location: "foobar2000", loaded at 00400000h - 004FE000h
Address: 004B49E0h, location: "foobar2000", loaded at 00400000h - 004FE000h
Address: 004B33D0h, location: "foobar2000", loaded at 00400000h - 004FE000h
Address: 004E4210h, location: "foobar2000", loaded at 00400000h - 004FE000h
Address: 004AF8E8h, location: "foobar2000", loaded at 00400000h - 004FE000h
Address: 00496284h, location: "foobar2000", loaded at 00400000h - 004FE000h
Address: 76DB3833h, location: "kernel32", loaded at 76D70000h - 76E48000h
Symbol: "BaseThreadInitThunk" (+00000012h)
Address: 7726A9BDh, location: "ntdll", loaded at 77230000h - 7734E000h
Symbol: "LdrInitializeThunk" (+0000004Dh)
Address: 76E05984h, location: "kernel32", loaded at 76D70000h - 76E48000h
Symbol: "UnhandledExceptionFilter" (+00000000h)
Address: 7727C033h, location: "ntdll", loaded at 77230000h - 7734E000h
Symbol: "RtlConvertUlongToLargeInteger" (+000070ADh)
Address: 004F53B0h, location: "foobar2000", loaded at 00400000h - 004FE000h
Address: 01C6FE65h, location: "foo_dumb", loaded at 01C10000h - 01C99000h
Symbol: "foobar2000_get_interface" (+000578F5h)
Address: 004B0063h, location: "foobar2000", loaded at 00400000h - 004FE000h
Address: 00440020h, location: "foobar2000", loaded at 00400000h - 004FE000h
Address: 00430020h, location: "foobar2000", loaded at 00400000h - 004FE000h
Address: 01C6FE66h, location: "foo_dumb", loaded at 01C10000h - 01C99000h
Symbol: "foobar2000_get_interface" (+000578F6h)
Address: 00410072h, location: "foobar2000", loaded at 00400000h - 004FE000h
Address: 00430022h, location: "foobar2000", loaded at 00400000h - 004FE000h
Address: 0041006Eh, location: "foobar2000", loaded at 00400000h - 004FE000h
Address: 01C6FE68h, location: "foo_dumb", loaded at 01C10000h - 01C99000h
Symbol: "foobar2000_get_interface" (+000578F8h)
Version info:
foobar2000 v0.9.4.3
UNICODE
Additional info:
Panels UI 0.14.6 beta [Jul 10 2007 - 02:05:50]  (foo_ui_panels)
Tabbed panel modified 0.2.5  (foo_uie_tabs)
DUMB module decoder 0.9.8.4  (foo_dumb)
Control Server 1.0.0 beta 1  (foo_controlserver)
Playlists Dropdown 0.6 alpha 3  (foo_uie_playlists_dropdown)
Components versions viewer 0.3  (foo_version)
Gapless Crossfader 0.3.2 (Intel SSE)  (foo_dsp_crossfader)
Lyric Show Panels 0.3.1.1b3 (SSE2) [Jun 23 2007 - 16:12:06]  (foo_uie_lyrics)
Peakmeter Panel 0.0.3.1  (foo_uie_peakmeter)
On-Screen Display 1.52  (foo_osd)
Stereo Convolution 1.0.1  (foo_dsp_stereoconv)
Misc. Addons 0.1 (Intel SSE)  (foo_misc_addons)
Audioscrobbler 1.3.6  (foo_audioscrobbler)
bs2b 2.1.0  (foo_dsp_bs2b)
Dolby Headphone Wrapper 1.1  (foo_dsp_dolbyhp)
Playback Statistics Custom 1.0.3  (foo_playback_custom)
Special file info box 2.0.4  (foo_infobox)
Playlist Tools 0.5.9  (foo_utils)
Convolver 0.3  (foo_convolve)
TAK Decoder 0.3.1  (foo_input_tak)
Navigator 0.61a  (foo_navigator)
foo_ui_panels
Reply #1912
I had the crash again with the latest release. This time it is on a different computer. fb2k crashed after cca 30 minutes. After the crash fb2k keeps playing current song, but I get the usual window telling me that foobar2000 has crashed and the window with log appears. It might be the same problem as Andreasvb already reported, but some addresses are different. Here is the log:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 0CFF988Ch
Access violation, operation: read, address: 0D704000h
Call path:
entry=>app_mainloop
Code bytes (0CFF988Ch):
0CFF984Ch:  00 00 00 89 74 24 6C 89 6C 24 68 66 89 6C 24 58
0CFF985Ch:  72 0D 8B 44 24 3C 50 E8 56 7E 02 00 83 C4 04 8B
0CFF986Ch:  54 24 14 89 74 24 50 89 6C 24 4C 66 89 6C 24 3C
0CFF987Ch:  8B 44 24 1C 03 10 83 C0 04 83 C7 02 89 44 24 1C
0CFF988Ch:  0F B7 07 66 3B C5 89 54 24 14 0F 85 A8 FE FF FF
0CFF989Ch:  8B 4C 24 28 89 39 8B C2 8B 8C 24 80 00 00 00 64
0CFF98ACh:  89 0D 00 00 00 00 59 5F 5E 5D 5B 8B 4C 24 68 33
0CFF98BCh:  CC E8 29 7C 02 00 83 C4 78 C3 CC CC CC CC CC CC
Stack (0013E0D4h):
0013E0B4h:  E27C8EB0 00000000 0000000C BC687E90
0013E0C4h:  0013FA98 00009D60 AAA34B64 BF815DEE
0013E0D4h:  780F7086 00000000 0D6F61B0 0D703530
0013E0E4h:  0D6F61B0 000001D8 00000004 0D6EB050
0013E0F4h:  0D703D62 0D703D5C 0013E314 00000002
0013E104h:  00000002 0D703D5C 00000066 00000000
0013E114h:  00000000 0013E520 00000001 00000000
0013E124h:  00000007 0D05E7F0 00090000 000A000D
0013E134h:  00000000 00FFFFFF 00000000 00000007
0013E144h:  00130001 0D703D66 0CFFED01 780F70B6
0013E154h:  0013E5A4 0D03C038 FFFFFFFF 0CFFC6E1
0013E164h:  0D6EA0F8 0013E314 780F712E 00000000
0013E174h:  00000008 0013F714 00000000 0D7035E2
0013E184h:  00000000 003DD9A8 00000006 00000000
0013E194h:  0000003E 00000003 780F4D7A 00000000
0013E1A4h:  00000000 0D6D7C80 01000018 0D6E94B0
0013E1B4h:  00000000 00000000 0000005A 0D6EA0F8
0013E1C4h:  00000000 FFFFFE8F 00000003 000005CD
0013E1D4h:  00000011 FFFF0000 00000000 004935B9
0013E1E4h:  00000001 00000000 0D6F6198 0D6F61F8
Registers:
EAX: 0D6EB050, EBX: 00000008, ECX: 00000004, EDX: 000001D8
ESI: 00000007, EDI: 0D704000, EBP: 00000000, ESP: 0013E0D4
Crash location: "foo_ui_panels", loaded at 0CFB0000h - 0D076000h
Symbol: "foobar2000_get_interface" (+0000659Ch)
Loaded modules:
foo_autoplaylist                 loaded at 00BE0000h - 00C12000h
foo_bitcompare                   loaded at 00C40000h - 00C66000h
foo_browser                      loaded at 00C90000h - 00CCB000h
foo_cdda                         loaded at 00CF0000h - 00D25000h
foo_channel_mixer                loaded at 00D50000h - 00D8A000h
foo_common                       loaded at 00DA0000h - 00DDA000h
foo_converter                    loaded at 00E00000h - 00E69000h
foo_cuesheet_creator             loaded at 00E90000h - 00EBD000h
foo_cwb_hooks                    loaded at 00EE0000h - 00F20000h
foo_dbsearch                     loaded at 00F40000h - 00F9C000h
foo_discogs                      loaded at 00FC0000h - 01032000h
foo_dsp_centercut                loaded at 010E0000h - 01105000h
foo_dsp_continuator              loaded at 01130000h - 01162000h
foo_dsp_crossfader               loaded at 01190000h - 0119D000h
foo_dsp_delta                    loaded at 011C0000h - 011DE000h
foo_dsp_fsurround                loaded at 01200000h - 01223000h
foo_dsp_silence                  loaded at 01250000h - 01279000h
foo_dsp_skip_silence             loaded at 012A0000h - 012AA000h
foo_dsp_soundtouch               loaded at 012C0000h - 012CF000h
foo_dsp_std                      loaded at 012E0000h - 01321000h
foo_dsp_vlevel                   loaded at 01350000h - 01374000h
foo_freedb2                      loaded at 013A0000h - 013E0000h
foo_input_alac                   loaded at 01400000h - 0141D000h
foo_input_awma                   loaded at 01440000h - 01459000h
foo_input_dts                    loaded at 01470000h - 014D5000h
foo_input_matroska               loaded at 01500000h - 01586000h
foo_input_monkey                 loaded at 015B0000h - 015F9000h
foo_input_mslive                 loaded at 01620000h - 0163E000h
foo_input_shorten                loaded at 01650000h - 0167E000h
foo_input_std                    loaded at 016A0000h - 017B3000h
foo_input_tta                    loaded at 017E0000h - 0180D000h
foo_lnk                          loaded at 01830000h - 01849000h
foo_managedWrapper               loaded at 01870000h - 0193A000h
mscorlib.ni                      loaded at 790C0000h - 79BA6000h
xpsp2res                         loaded at 20000000h - 202CC000h
dotnet_title                     loaded at 11000000h - 1101C000h
foo_masstag                      loaded at 04400000h - 0444F000h
foo_masstag_addons               loaded at 04470000h - 0447E000h
foo_midi                         loaded at 04490000h - 0453A000h
foo_packet_decoder_ac3           loaded at 04560000h - 04587000h
foo_packet_decoder_wavpack       loaded at 045B0000h - 045D5000h
foo_playcount_mod                loaded at 04600000h - 04615000h
foo_playlist_bind                loaded at 04630000h - 04655000h
foo_playlist_manager             loaded at 04670000h - 046B6000h
foo_playlist_tree                loaded at 046E0000h - 0474B000h
foo_pqview                       loaded at 04770000h - 0478C000h
foo_prettypop                    loaded at 047B0000h - 047FD000h
foo_random                       loaded at 048B0000h - 048EF000h
foo_rgscan                       loaded at 04910000h - 04958000h
foo_run                          loaded at 04980000h - 049AB000h
foo_scheduler                    loaded at 049D0000h - 04A3F000h
foo_tradersfriend                loaded at 04A60000h - 04A9D000h
foo_uie_albumart                 loaded at 04AC0000h - 04AFC000h
foo_uie_albumlist                loaded at 04B20000h - 04B5F000h
foo_uie_lyrics                   loaded at 04B80000h - 04BDE000h
foo_uie_queuemanager             loaded at 04C00000h - 04C39000h
foo_uie_quicksearch              loaded at 04CF0000h - 04D36000h
foo_uie_tabs                     loaded at 04D40000h - 04D6A000h
foo_uie_trackinfo                loaded at 04D90000h - 04DBE000h
foo_uie_trackinfo_mod            loaded at 04DE0000h - 04E37000h
foo_uie_vis_egoh                 loaded at 04E50000h - 04E6D000h
foo_uie_vis_projectm             loaded at 04E80000h - 04ECC000h
foo_ui_columns                   loaded at 0CEE0000h - 0CF82000h
foo_ui_panels                    loaded at 0CFB0000h - 0D076000h
foo_ui_std                       loaded at 0D0A0000h - 0D0F7000h
foo_unpack                       loaded at 0D120000h - 0D14E000h
foo_utils                        loaded at 0D170000h - 0D1A9000h
foo_utils_matroska               loaded at 0D1D0000h - 0D1EA000h
foo_verifier                     loaded at 0D210000h - 0D240000h
foo_version                      loaded at 0D260000h - 0D285000h
mscorlib.resources               loaded at 0DB00000h - 0DB4E000h
diasymreader                     loaded at 5E380000h - 5E409000h
Address: 0D05E7F0h, location: "foo_ui_panels", loaded at 0CFB0000h - 0D076000h
Address: 00FFFFFFh, location: "foo_discogs", loaded at 00FC0000h - 01032000h
Address: 0CFFED01h, location: "foo_ui_panels", loaded at 0CFB0000h - 0D076000h
Symbol: "foobar2000_get_interface" (+0000BA11h)
Address: 0D03C038h, location: "foo_ui_panels", loaded at 0CFB0000h - 0D076000h
Address: 0CFFC6E1h, location: "foo_ui_panels", loaded at 0CFB0000h - 0D076000h
Symbol: "foobar2000_get_interface" (+000093F1h)
Address: 01000018h, location: "foo_discogs", loaded at 00FC0000h - 01032000h
Address: 004935B9h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0D02A880h, location: "foo_ui_panels", loaded at 0CFB0000h - 0D076000h
Address: 0CFBBE1Dh, location: "foo_ui_panels", loaded at 0CFB0000h - 0D076000h
Address: 0CFC755Ah, location: "foo_ui_panels", loaded at 0CFB0000h - 0D076000h
Address: 018A0021h, location: "foo_managedWrapper", loaded at 01870000h - 0193A000h
Address: 01010007h, location: "foo_discogs", loaded at 00FC0000h - 01032000h
Address: 0D021790h, location: "foo_ui_panels", loaded at 0CFB0000h - 0D076000h
Address: 0CFB0000h, location: "foo_ui_panels", loaded at 0CFB0000h - 0D076000h
Address: 0D03ECBBh, location: "foo_ui_panels", loaded at 0CFB0000h - 0D076000h
Address: 0CFF287Ah, location: "foo_ui_panels", loaded at 0CFB0000h - 0D076000h
Address: 0D046FB4h, location: "foo_ui_panels", loaded at 0CFB0000h - 0D076000h
Address: 0D021FC5h, location: "foo_ui_panels", loaded at 0CFB0000h - 0D076000h
Address: 0D0219B3h, location: "foo_ui_panels", loaded at 0CFB0000h - 0D076000h
Address: 0D03ED0Bh, location: "foo_ui_panels", loaded at 0CFB0000h - 0D076000h
Address: 0CFC355Fh, location: "foo_ui_panels", loaded at 0CFB0000h - 0D076000h
Address: 7C90DA54h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "NtFreeVirtualMemory" (+0000000Ch)
Address: 01010053h, location: "foo_discogs", loaded at 00FC0000h - 01032000h
Address: 4ED387DDh, location: "gdiplus", loaded at 4EBE0000h - 4ED83000h
Address: 4ECE5B38h, location: "gdiplus", loaded at 4EBE0000h - 4ED83000h
Address: 4EC387B2h, location: "gdiplus", loaded at 4EBE0000h - 4ED83000h
Address: 4ED65EB0h, location: "gdiplus", loaded at 4EBE0000h - 4ED83000h
Address: 00FF0000h, location: "foo_discogs", loaded at 00FC0000h - 01032000h
Symbol: "curl_share_cleanup" (+00000C90h)
Address: 01000000h, location: "foo_discogs", loaded at 00FC0000h - 01032000h
Address: 7B0A0FFBh, location: "System.Windows.Forms.ni", loaded at 7AFD0000h - 7BC56000h
Version info:
foobar2000 v0.9.4.3
UNICODE
Additional info:
Queue manager panel 0.2.1  (foo_uie_queuemanager)
Quick Search Toolbar 2.8k  (foo_uie_quicksearch)
Track info panel mod 0.8.0 beta [Dec  6 2006 - 14:21:24]  (foo_uie_trackinfo_mod)
Track info panel 0.8  (foo_uie_trackinfo)
Play Count Mod 1.0.2  (foo_playcount_mod)
FreeSurround 0.1  (foo_dsp_fsurround)
Music Browser 1.2.2c [Jul  6 2006 - 09:42:02]  (foo_browser)
Playlist Tree Panel 2.2.4 [Nov 17 2006 - 16:34:17]  (foo_playlist_tree)
Lyric Show Panels 0.3.1.0  (foo_uie_lyrics)
Continuator 0.4.0  (foo_dsp_continuator)
Columns UI 0.2.0 alpha 1  (foo_ui_columns)
Channel Mixer 0.9.4  (foo_channel_mixer)
foo_managedWrapper 0.4  (foo_managedWrapper)
cwbowron's title format hooks 1.2.beta1 [May 30 2007 - 15:36:21]  (foo_cwb_hooks)
Album list panel 0.2.1 beta 1  (foo_uie_albumlist)
Playlist Bind 3.1  (foo_playlist_bind)
Album Art Panel 0.2.6  (foo_uie_albumart)
Crossfader 0.1.6.2  (foo_dsp_crossfader)
Btw. do you have any idea why $button2 isn't working in the development versions?
My fault, the $button2 works correctly. But the problem was in $calcwidth(), which doesn't work correctly. If I let it calculate width of "$font(lucida sans unicode, 8, bold glow-100-100-200,255-255-255)SOME TEXT", it calculates it as if everything was real text. But in older version only length of "SOME TEXT" was taken in account, which is correct IMHO.
foo_ui_panels
Reply #1913
you can use reshacker to change the image in the dll (although it has to be the same size)
no, not at the moment. what exactly are you trying to do?
were you doing something with the library filter when the crash occurred? have you modified the default library filter criteria?
can you post your pui please... something on your layout isn't getting parsed correctly.
foo_ui_panels
Reply #1914
Sure I can. I already publicized my config here.  Of course the actual version is little bit different. I also modified 2 things since the crash - fixed rating buttons behaviour and corrected replaygain display in SCPL. I hope the crash wasn't here.
The latest version is here.
foo_ui_panels
Reply #1915
I used the Quick Search Toolbar. After I picked a song it crashed. It works with the stable version.
Edit: Seems it crash if you press up/down if SCPL is out of focus.
How to recreate: Minimize foobar2000 then restore but don't select anything, just press up or down and it will crash.
Choosen interface: Columns UI.
Using SCPL, Track Display, Library Filter.
foo_ui_panels
Reply #1916
$button2($sub(%_width%,55),$sub(%_height%,60),0,0,16,14,
'$imageabs2(,,16,,0,,0,0,/images\albumlist.png,)',
'$imageabs2(,,32,,0,,0,0,/images\albumlist.png,)',
SORTGROUP-PRESETS-MENU,TOOLTIP:"Sort Playlist")
Why doesn't the group get sorted when I use this button? When I choose to sort from the right click menu the groups also change but with the button only the tracks of a group get sorted.
foo_ui_panels
Reply #1917
So far no more crashes, so I probably fixed it by modifying the config. I'll let you know if my fb2k crashes again.
foo_ui_panels
Reply #1918
Up/Down keys dont work for selecting tracks in SCPL when the quicksearch toolbar resides in a tabbed panel.
foo_ui_panels
Reply #1919
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 01745BCAh
Access violation, operation: read, address: 01BB2000h
Call path:
entry=>app_mainloop
Code bytes (01745BCAh):
01745B8Ah:  0F 82 A4 01 00 00 81 F9 00 01 00 00 72 1F 83 3D
01745B9Ah:  64 54 78 01 00 74 16 57 56 83 E7 0F 83 E6 0F 3B
01745BAAh:  FE 5E 5F 75 08 5E 5F 5D E9 5C 9E 00 00 F7 C7 03
01745BBAh:  00 00 00 75 15 C1 E9 02 83 E2 03 83 F9 08 72 2A
01745BCAh:  F3 A5 FF 24 95 E4 5C 74 01 90 8B C7 BA 03 00 00
01745BDAh:  00 83 E9 04 72 0C 83 E0 03 03 C8 FF 24 85 F8 5B
01745BEAh:  74 01 FF 24 8D F4 5C 74 01 90 FF 24 8D 78 5C 74
01745BFAh:  01 90 08 5C 74 01 34 5C 74 01 58 5C 74 01 23 D1
Stack (0013DEE0h):
0013DEC0h:  00000000 BF803426 A991ABD0 00000000
0013DED0h:  BF803426 E740DAB0 00000001 00000000
0013DEE0h:  00000064 00000000 0013DF04 01741790
0013DEF0h:  01AF39B8 01BB1FD0 00000064 00000064
0013DF00h:  0013DF88 01BB1FD0 016DB46B 01AF39B8
0013DF10h:  0000006E 01BB1FD0 00000064 01BB1FD0
0013DF20h:  017B7988 00000000 01718A5C 01BB1FD0
0013DF30h:  00000032 182E5754 00000026 000001B7
0013DF40h:  00000002 00000000 00720041 00610069
0013DF50h:  0000006C 00000000 00000000 00000000
0013DF60h:  00000000 00000000 00000000 00000000
0013DF70h:  00000000 00000000 0013E3B4 00000000
0013DF80h:  00000000 00000000 001D0000 01AF39B8
0013DF90h:  0013E064 00160178 0013E064 00000000
0013DFA0h:  00000037 01785418 017B7988 7C9105C8
0013DFB0h:  01B08230 0013E080 7C910551 017B08F8
0013DFC0h:  0000001F 00000022 01AF8E90 01AFDF20
0013DFD0h:  00000000 00000000 00160178 0000001F
0013DFE0h:  0000001F 00000011 01AFAB88 FFFFFFF5
0013DFF0h:  001D4AE8 00000000 00000014 00000017
Registers:
EAX: 01BB2034, EBX: 0013DF8C, ECX: 0000000D, EDX: 00000000
ESI: 01BB2000, EDI: 01AF39E8, EBP: 0013DEE8, ESP: 0013DEE0
Crash location: "foo_ui_panels", loaded at 016D0000h - 01796000h
Loaded modules:
ntdll                            loaded at 7C900000h - 7C9B6000h
kernel32                        loaded at 7C800000h - 7C8FF000h
COMCTL32                        loaded at 77390000h - 77493000h
msvcrt                          loaded at 77BE0000h - 77C38000h
ADVAPI32                        loaded at 77F40000h - 77FEB000h
RPCRT4                          loaded at 77DA0000h - 77E31000h
GDI32                            loaded at 77E40000h - 77E87000h
USER32                          loaded at 7E390000h - 7E420000h
SHLWAPI                          loaded at 77E90000h - 77F06000h
SHELL32                          loaded at 7C9C0000h - 7D1E0000h
ole32                            loaded at 774A0000h - 775DD000h
comdlg32                        loaded at 76350000h - 7639A000h
IMM32                            loaded at 76330000h - 7634D000h
uxtheme                          loaded at 5B190000h - 5B1C8000h
apphelp                          loaded at 77B00000h - 77B22000h
msctfime                        loaded at 75250000h - 7527E000h
foo_abx                          loaded at 00A30000h - 00A64000h
foo_albumlist                    loaded at 00A70000h - 00AB7000h
OLEAUT32                        loaded at 770E0000h - 7716C000h
foo_cdda                        loaded at 00AD0000h - 00B06000h
foo_converter                    loaded at 00B30000h - 00B99000h
foo_custominfo                  loaded at 00BC0000h - 00C45000h
foo_custom_pc                    loaded at 00C70000h - 00CAC000h
WINSPOOL                        loaded at 72F70000h - 72F96000h
foo_cwb_hooks                    loaded at 00D70000h - 00DA6000h
foo_discogs                      loaded at 00DD0000h - 00E4D000h
gdiplus                          loaded at 4EB80000h - 4ED23000h
WS2_32                          loaded at 71A30000h - 71A47000h
WS2HELP                          loaded at 71A20000h - 71A28000h
WINMM                            loaded at 76AF0000h - 76B1E000h
foo_dsp_std                      loaded at 00E70000h - 00EB1000h
foo_infobox                      loaded at 00EE0000h - 00F20000h
foo_input_std                    loaded at 00F40000h - 01054000h
foo_masstag                      loaded at 01080000h - 010D0000h
foo_menu_addons                  loaded at 010F0000h - 01141000h
libmmd                          loaded at 01160000h - 01411000h
foo_msnalt                      loaded at 01440000h - 01459000h
foo_rgscan                      loaded at 01480000h - 014C8000h
foo_run                          loaded at 014F0000h - 0151B000h
foo_uie_explorer                loaded at 01540000h - 0157C000h
foo_uie_quicksearch              loaded at 015A0000h - 015E6000h
foo_ui_columns                  loaded at 01610000h - 016A7000h
foo_ui_panels                    loaded at 016D0000h - 01796000h
foo_ui_std                      loaded at 018E0000h - 01937000h
foo_unpack                      loaded at 01960000h - 0198E000h
foo_utils                        loaded at 103E0000h - 10419000h
Msimg32                          loaded at 76320000h - 76325000h
CLBCATQ                          loaded at 76F90000h - 7700F000h
COMRes                          loaded at 77010000h - 770DD000h
VERSION                          loaded at 77BD0000h - 77BD8000h
DSOUND                          loaded at 73E80000h - 73EDC000h
WINTRUST                        loaded at 76BF0000h - 76C1E000h
CRYPT32                          loaded at 77A40000h - 77AD5000h
MSASN1                          loaded at 77AE0000h - 77AF2000h
IMAGEHLP                        loaded at 76C50000h - 76C78000h
wdmaud                          loaded at 72C90000h - 72C99000h
msacm32                          loaded at 72C80000h - 72C88000h
MSACM32                          loaded at 77BB0000h - 77BC5000h
midimap                          loaded at 77BA0000h - 77BA7000h
KsUser                          loaded at 73E50000h - 73E54000h
SETUPAPI                        loaded at 778E0000h - 779D7000h
cscui                            loaded at 779E0000h - 77A36000h
CSCDLL                          loaded at 765A0000h - 765BD000h
USERENV                          loaded at 76970000h - 76A24000h
DBGHELP                          loaded at 59E70000h - 59F11000h
Address: 01741790h, location: "foo_ui_panels", loaded at 016D0000h - 01796000h
Address: 016DB46Bh, location: "foo_ui_panels", loaded at 016D0000h - 01796000h
Address: 01718A5Ch, location: "foo_ui_panels", loaded at 016D0000h - 01796000h
Symbol: "foobar2000_get_interface" (+0000576Ch)
Address: 7C9105C8h, location: "ntdll", loaded at 7C900000h - 7C9B6000h
Address: 7C910551h, location: "ntdll", loaded at 7C900000h - 7C9B6000h
Address: 0042004Ch, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C91056Dh, location: "ntdll", loaded at 7C900000h - 7C9B6000h
Address: 77E48036h, location: "GDI32", loaded at 77E40000h - 77E87000h
Symbol: "ExtTextOutW" (+00000000h)
Address: 01746EA6h, location: "foo_ui_panels", loaded at 016D0000h - 01796000h
Address: 0171EBF0h, location: "foo_ui_panels", loaded at 016D0000h - 01796000h
Symbol: "foobar2000_get_interface" (+0000B900h)
Address: 7C910732h, location: "ntdll", loaded at 7C900000h - 7C9B6000h
Address: 7C90EE18h, location: "ntdll", loaded at 7C900000h - 7C9B6000h
Address: 7C910738h, location: "ntdll", loaded at 7C900000h - 7C9B6000h
Address: 7C9106ABh, location: "ntdll", loaded at 7C900000h - 7C9B6000h
Address: 7C9106EBh, location: "ntdll", loaded at 7C900000h - 7C9B6000h
Address: 77E480D2h, location: "GDI32", loaded at 77E40000h - 77E87000h
Symbol: "ExtTextOutW" (+0000009Ch)
Address: 016EF122h, location: "foo_ui_panels", loaded at 016D0000h - 01796000h
Address: 016EF12Bh, location: "foo_ui_panels", loaded at 016D0000h - 01796000h
Address: 016E306Ah, location: "foo_ui_panels", loaded at 016D0000h - 01796000h
Address: 016E6A4Fh, location: "foo_ui_panels", loaded at 016D0000h - 01796000h
Address: 0044096Dh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C910945h, location: "ntdll", loaded at 7C900000h - 7C9B6000h
Symbol: "RtlAcquirePebLock" (+00000028h)
Address: 7C91094Eh, location: "ntdll", loaded at 7C900000h - 7C9B6000h
Symbol: "RtlAcquirePebLock" (+00000031h)
Address: 7C914190h, location: "ntdll", loaded at 7C900000h - 7C9B6000h
Symbol: "RtlDosPathNameToNtPathName_U" (+00000093h)
Address: 7C901005h, location: "ntdll", loaded at 7C900000h - 7C9B6000h
Symbol: "RtlEnterCriticalSection" (+00000000h)
Address: 7C910970h, location: "ntdll", loaded at 7C900000h - 7C9B6000h
Symbol: "RtlReleasePebLock" (+0000000Fh)
Address: 7C97E4C0h, location: "ntdll", loaded at 7C900000h - 7C9B6000h
Address: 7C913E6Fh, location: "ntdll", loaded at 7C900000h - 7C9B6000h
Symbol: "RtlDetermineDosPathNameType_U" (+000004D0h)
Address: 0041005Fh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0047004Eh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C97CE28h, location: "ntdll", loaded at 7C900000h - 7C9B6000h
Address: 7C913E62h, location: "ntdll", loaded at 7C900000h - 7C9B6000h
Symbol: "RtlDetermineDosPathNameType_U" (+000004C3h)
Address: 77E47012h, location: "GDI32", loaded at 77E40000h - 77E87000h
Symbol: "BitBlt" (+00000089h)
Address: 016E6A19h, location: "foo_ui_panels", loaded at 016D0000h - 01796000h
Address: 00460020h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00490055h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0042005Ch, location: "foobar2000", loaded at 00400000h - 004F3000h
Version info:
foobar2000 v0.9.4.2
UNICODE
Additional info:
foobar2000 core 0.9.4.2  (Core)
Menu Addons 0.3.9.5 (Intel SSE)  (foo_menu_addons)
foo_custominfo 0.1.2  (foo_custominfo)
cwbowron's title format hooks 1.1.1 [May  4 2007 - 12:39:47]  (foo_cwb_hooks)
Columns UI 0.1.3 beta 1v7  (foo_ui_columns)
Explorer Tree 1.04.6b  (foo_uie_explorer)
Discogs Tagger 1.0  (foo_discogs)
MSN Now Playing (alt) 2.4  (foo_msnalt)
Playcounter for foo_custominfo 1.0.1  (foo_custom_pc)
I got a crash when clicking on the library filter panel.
This happend for the first time with your beta plugin.
foo_ui_panels
Reply #1920
Hi terrestrial,
just an info (maybe a request?):
i use your latest beta and added to the group header an album rating with $meta_sum(rating)...
but the header only gets updated until i click "Apply" in the settings dialog, but it should update immediatly when i rate a song... just like in the items displays
bye
foo_ui_panels
Reply #1921
$puts(coverPath,
   $if($fileexists($replace(%path%,%filename_ext%,*front*.jpg)),
   $replace(%path%,%filename_ext%,*front*.jpg),
      $if($fileexists($replace(%path%,%filename_ext%,folder.*)),
      $replace(%path%,%filename_ext%,folder.*),
         $if($fileexists($replace(%path%,%filename_ext%,*.jpg)),
         $replace(%path%,%filename_ext%,*.jpg),
When I put this in the user globals foobar goes blank. It never did this before... What's wrong with this part of code or is it just a bug that has to be fixed?
foo_ui_panels
Reply #1922
Hi terrestrial,
1. How can I stick the window/theme so that it cannot moved any more?
2. What must be done to display the current artist and track in the taskbar?
3. Can you please edit the drag&drop feature so that you can drag&drop over more then the current playlist which you can see? So when the playlist is longer then the window you cannot drag&drop tracks more then the current list because it doesn't autoscroll and/or doesn't make use of the scroll wheel.
Thank you for help!
foo_ui_panels
Reply #1923
@Terrestrial
Problem 1 which I described
Problem 2 concerning displaying of a button:
This is what it should look like:
This is the code:
$if(
$not($stricmp(%cwb_playback_order%,'Shuffle (tracks)'))
$button(930,50,0,0,28,30,images\Inas Metalseries\Shuffle.png,images\Inas Metalseries\Blankshuffle.png,'Shuffle (tracks)',)
//////SHUFFLE///
$if(
$not($stricmp(%cwb_playback_order%,default))
$button(930,50,0,0,28,30,images\Inas Metalseries\DEfaultplay.png,images\Inas Metalseries\DEfaultplaygold.png,default,)
The hover image is shown correctly.And it seems like the button doesn't work anylonger.
This happens when the music is stopped. It seems like %cwb_playback_order%  has something to do with this.
EDIT: I tested this and in older versions of Panel ui this seems to work while in the new version this happens.
foo_ui_panels
Reply #1924
Hi terrestrial,
bye
added to the new version.
$puts(coverPath,
...\Christoph's Black Layout\..
Hi terrestrial,
Thank you for help!
1) cannot be done currently
2) use $settitle() (but there is a bug with it not updating)
3) maybe in future versions
@Terrestrial
what is the code you are using for this?
please try the new version and see if it fixes it.
