Topic: foo_ui_panels (Read 1026261 times) previous topic - next topic
foo_ui_panels
Reply #1851
I need some help please regarding the layout of the s-columns playlist. I would like to add some space/blank lines between the last track and the beginning of a new album (see red arrows). Any advice?
foo_ui_panels
Reply #1852
[quote author=John n' y link=msg=503075 date=1183742096]I need some help please regarding the layout of the s-columns playlist. I would like to add some space/blank lines between the last track and the beginning of a new album (see red arrows). Any advice?
[/quote]You need to fake it.
Add 2 or 3 more rows to your group rows and then move everything in your header down further.
elevatorladylevitateme
foo_ui_panels
Reply #1853
anyone tested vertical alignment with $alignr()? for me vertical alignment in SCPL does not work. (0.14.1)
$alignr(middle) will adjust alignment within a line. if you want to align the line itself within a larger space use $alignabs()
Terrestial
I use Cepiperez's Dark config and with new version of plugin  (14.3) I have next screen
I don't see all buttons with images now - only text buttons on bottom of screen!
Also when I want change settings od SCPL (right mouse click on SCPL and choose settings) Foobar200 is crash.
make sure you're using the version dated Jul 5 2007 - 21:39:43. also please post the crash log.
foo_ui_panels
Reply #1854
[/quote]
thx shakey_snake. i got it
foo_ui_panels
Reply #1855
Terrestial
I move image folder Dark1 from \foobar\dark1 to \panelsui\dark1.32\dark1
and change  global "Imagelocation" to  /dark1....
And now I can see all buttons again.
But SCPL crash when I want change it's settins.
I use Xp SP2 and last version of plugin 1.4.3 at 21:40 05.0.7.07.
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 055014C7h
Access violation, operation: read, address: 00000000h
Call path:
entry=>app_mainloop
Code bytes (055014C7h):
05501487h:  A4 59 05 33 C4 50 8D 44 24 60 64 A3 00 00 00 00
05501497h:  33 DB BE 8C 2B 58 05 89 74 24 38 89 5C 24 3C 89
055014A7h:  5C 24 40 89 5C 24 44 89 5C 24 48 8B 4C 24 74 68
055014B7h:  F8 59 58 05 51 89 5C 24 70 8B AC 24 80 00 00 00
055014C7h:  8B 45 00 8D 94 24 80 00 00 00 52 8B 10 8D 4C 24
055014D7h:  44 51 8B CD FF D2 89 74 24 24 89 5C 24 28 89 5C
055014E7h:  24 2C 89 5C 24 30 89 5C 24 34 8B 74 24 7C 8B C6
055014F7h:  C6 44 24 68 01 8D 50 01 90 8A 08 83 C0 01 3A CB
Stack (0012E574h):
0012E554h:  00000000 0012F3A4 0012F37C 00000000
0012E564h:  AA19B908 AA19B610 81F5BDA8 AA19B6D0
0012E574h:  0012E634 055859F8 E0AA7B8F 00000000
0012E584h:  00000000 02321118 00000000 0012E644
0012E594h:  054C14CD 00000021 0000000A 00000000
0012E5A4h:  022FFEC4 054CA16E 003DA710 0040A6DF
0012E5B4h:  05582B8C 00000000 00000000 00000000
0012E5C4h:  00000000 00000000 00000000 02321118
0012E5D4h:  00000000 00000013 0012E66C 055785E8
0012E5E4h:  00000000 05501835 00190D12 0012E634
0012E5F4h:  00000000 05582376 05E6AC88 05584F38
0012E604h:  E0AA7807 7E36B8BA 00190D12 0012F148
0012E614h:  0012F534 05501451 00000000 02321118
0012E624h:  05971B00 00000001 0000000A 003DA710
0012E634h:  05582BFC 05E06250 00000001 00000001
0012E644h:  05582B8C 05E6AC88 00000021 00000021
0012E654h:  00000010 05582B8C 05E03A98 00000011
0012E664h:  00000011 00000000 0012F13C 05579178
0012E674h:  00000005 054EBC15 00190D12 05584F38
0012E684h:  00190D12 05584F34 E0AA789F 00220B8A
Registers:
EAX: 0012E5DC, EBX: 00000000, ECX: 0012E634, EDX: 05584F38
ESI: 05582B8C, EDI: 00000000, EBP: 00000000, ESP: 0012E574
Crash location: "foo_ui_panels", loaded at 054C0000h - 055B3000h
Loaded modules:
foobar2000                      loaded at 00400000h - 004F3000h
ntdll                            loaded at 7C900000h - 7C9B1000h
kernel32                        loaded at 7C800000h - 7C8F7000h
COMCTL32                        loaded at 773C0000h - 774C3000h
msvcrt                          loaded at 77C00000h - 77C58000h
ADVAPI32                        loaded at 77DC0000h - 77E6C000h
RPCRT4                          loaded at 77E70000h - 77F01000h
GDI32                            loaded at 77F10000h - 77F57000h
USER32                          loaded at 7E360000h - 7E3F0000h
SHLWAPI                          loaded at 77F60000h - 77FD6000h
SHELL32                          loaded at 7C9C0000h - 7D1D9000h
ole32                            loaded at 774D0000h - 7760D000h
shared                          loaded at 10000000h - 10029000h
comdlg32                        loaded at 76380000h - 763C9000h
IMM32                            loaded at 76360000h - 7637D000h
LPK                              loaded at 62F00000h - 62F09000h
USP10                            loaded at 75540000h - 755AB000h
uxtheme                          loaded at 5B260000h - 5B298000h
MSCTF                            loaded at 746E0000h - 7472B000h
UnlockerHook                    loaded at 003F0000h - 003F4000h
RollWindows                      loaded at 00A80000h - 00A84000h
DM2                              loaded at 00AA0000h - 00AA6000h
msctfime                        loaded at 75310000h - 7533E000h
foo_abx                          loaded at 00AD0000h - 00B03000h
foo_albumlist                    loaded at 00B30000h - 00B77000h
OLEAUT32                        loaded at 77110000h - 7719C000h
foo_autoplaylist                loaded at 00BA0000h - 00BD0000h
foo_bitcompare                  loaded at 00BF0000h - 00C17000h
foo_cdda                        loaded at 00C40000h - 00C75000h
foo_channel_mixer                loaded at 00CA0000h - 00CDB000h
foo_cleartype                    loaded at 10040000h - 1005A000h
foo_common                      loaded at 00D10000h - 00D43000h
foo_converter                    loaded at 00D70000h - 00DD9000h
foo_convolve                    loaded at 00E00000h - 00E51000h
foo_cuesheet_creator            loaded at 00E80000h - 00EAC000h
foo_custominfo                  loaded at 00ED0000h - 00F55000h
foo_cwb_hooks                    loaded at 00F80000h - 00FCD000h
foo_dbsearch                    loaded at 00FF0000h - 01060000h
foo_default_videoplayer          loaded at 01080000h - 0108D000h
MSVCR80                          loaded at 78130000h - 781CB000h
foo_discogs                      loaded at 010B0000h - 0112D000h
gdiplus                          loaded at 4EBE0000h - 4ED83000h
WS2_32                          loaded at 71A90000h - 71AA7000h
WS2HELP                          loaded at 71A80000h - 71A88000h
WINMM                            loaded at 76B20000h - 76B4E000h
foo_dockable_panels              loaded at 011D0000h - 01203000h
foo_dsp_crossfader              loaded at 01230000h - 0123F000h
foo_dsp_delta                    loaded at 10110000h - 1012E000h
foo_dsp_std                      loaded at 01270000h - 012B1000h
foo_explorer                    loaded at 012E0000h - 012F8000h
foo_freedb2                      loaded at 01320000h - 01360000h
foo_freedb2_fix                  loaded at 01380000h - 01395000h
foo_fullscreen                  loaded at 013C0000h - 013DB000h
foo_guidlookup                  loaded at 01400000h - 01418000h
foo_history                      loaded at 01440000h - 0145C000h
foo_infobox                      loaded at 01480000h - 014C0000h
foo_input_awma                  loaded at 014E0000h - 0151D000h
WMVCore                          loaded at 01530000h - 0174C000h
wmidx                            loaded at 4B380000h - 4B3A9000h
WMASF                            loaded at 59C10000h - 59C4C000h
msdmo                            loaded at 73670000h - 73677000h
WININET                          loaded at 771A0000h - 77246000h
CRYPT32                          loaded at 77A70000h - 77B05000h
MSASN1                          loaded at 77B10000h - 77B22000h
urlmon                          loaded at 7DF10000h - 7DFB0000h
VERSION                          loaded at 77BF0000h - 77BF8000h
MSACM32                          loaded at 77BD0000h - 77BE5000h
MSVFW32                          loaded at 75A40000h - 75A61000h
WSOCK32                          loaded at 71AB0000h - 71ABA000h
DRMClien                        loaded at 01750000h - 0179F000h
libmmd                          loaded at 017A0000h - 01A51000h
foo_input_monkey                loaded at 01A80000h - 01ACA000h
foo_input_shorten                loaded at 01B30000h - 01B5D000h
foo_input_std                    loaded at 01B60000h - 01C73000h
foo_input_tta                    loaded at 01CA0000h - 01CCD000h
foo_lnk                          loaded at 01CF0000h - 01D09000h
foo_lock                        loaded at 01D30000h - 01D48000h
foo_locktest                    loaded at 01D70000h - 01D88000h
foo_masstag                      loaded at 01DB0000h - 01DFF000h
foo_masstag_addons              loaded at 01E20000h - 01E2E000h
foo_menu_addons                  loaded at 01E40000h - 01E8D000h
foo_metadbstats                  loaded at 01EA0000h - 01ECE000h
foo_noss                        loaded at 01EF0000h - 01F07000h
foo_out_ks                      loaded at 01F30000h - 01F5A000h
SETUPAPI                        loaded at 77910000h - 77A04000h
foo_out_nonstop                  loaded at 01F80000h - 01F9B000h
foo_playback_custom              loaded at 01FB0000h - 01FEF000h
WINSPOOL                        loaded at 72FC0000h - 72FE6000h
foo_playlist_manager            loaded at 02030000h - 02074000h
foo_playlist_name_enhanced      loaded at 020A0000h - 020C0000h
foo_playlist_tree                loaded at 020E0000h - 02155000h
libmzsch360_000                  loaded at 10400000h - 105D0000h
libmzgc360_000                  loaded at 02180000h - 02224000h
foo_pqview                      loaded at 02270000h - 0228B000h
foo_preview                      loaded at 022B0000h - 022D1000h
foo_random                      loaded at 022F0000h - 0232D000h
foo_removeplayed                loaded at 02350000h - 02368000h
foo_rgscan                      loaded at 02390000h - 023D8000h
foo_run                          loaded at 02400000h - 0242B000h
foo_runcmd                      loaded at 02450000h - 0247F000h
foo_scheduler                    loaded at 024A0000h - 0250F000h
POWRPROF                        loaded at 74A90000h - 74A98000h
foo_sendtodevice                loaded at 02530000h - 0255F000h
foo_sic                          loaded at 02580000h - 025D9000h
foo_skip                        loaded at 02700000h - 0271B000h
foo_trackfinder                  loaded at 02740000h - 02766000h
foo_trackpos                    loaded at 02790000h - 027AF000h
foo_tradersfriend                loaded at 027D0000h - 0280A000h
foo_uie_albumart                loaded at 02830000h - 0286C000h
foo_uie_albumlist                loaded at 02890000h - 028D3000h
foo_uie_bookmarks                loaded at 02900000h - 0294B000h
foo_uie_console                  loaded at 02960000h - 0297B000h
foo_uie_explorer                loaded at 029A0000h - 029DD000h
foo_uie_playlists_dropdown      loaded at 02A00000h - 02A39000h
foo_uie_queuemanager            loaded at 02A60000h - 02A99000h
mscoree                          loaded at 79000000h - 79045000h
msvcm80                          loaded at 7C4C0000h - 7C53D000h
mscorwks                        loaded at 79E70000h - 7A3D1000h
mscorlib.ni                      loaded at 790C0000h - 79BA8000h
mscorjit                        loaded at 79060000h - 790B3000h
rsaenh                          loaded at 0FFD0000h - 0FFF8000h
System.ni                        loaded at 7A440000h - 7ABFE000h
System.Drawing.ni                loaded at 7ADE0000h - 7AF74000h
foo_uie_quicksearch              loaded at 051F0000h - 05236000h
foo_uie_tabs                    loaded at 05250000h - 0527A000h
foo_uie_trackinfo                loaded at 052A0000h - 052CF000h
foo_uie_vis_egoh                loaded at 052F0000h - 0530D000h
foo_uie_wsh_panel                loaded at 05320000h - 05356000h
foo_ui_columns                  loaded at 053A0000h - 05443000h
foo_ui_egoh                      loaded at 05470000h - 054AE000h
foo_ui_panels                    loaded at 054C0000h - 055B3000h
foo_ui_std                      loaded at 055E0000h - 05637000h
foo_unpack                      loaded at 05660000h - 0568E000h
foo_utils                        loaded at 056B0000h - 056E8000h
foo_utils_playback              loaded at 05710000h - 05729000h
foo_verifier                    loaded at 05750000h - 05780000h
foo_version                      loaded at 057A0000h - 057C6000h
dbghelp                          loaded at 59C60000h - 59D01000h
foo_write_http                  loaded at 058F0000h - 0592B000h
correct                          loaded at 05B70000h - 05B76000h
CLBCATQ                          loaded at 76FC0000h - 7703F000h
COMRes                          loaded at 77040000h - 77107000h
wtsapi32                        loaded at 76F40000h - 76F48000h
WINSTA                          loaded at 76330000h - 76340000h
NETAPI32                        loaded at 5BD50000h - 5BDA4000h
Msimg32                          loaded at 76350000h - 76355000h
appHelp                          loaded at 77B30000h - 77B52000h
cscui                            loaded at 77A10000h - 77A65000h
CSCDLL                          loaded at 765D0000h - 765ED000h
vlmshlp                          loaded at 06AB0000h - 06AB7000h
imagehlp                        loaded at 76C80000h - 76CA8000h
Stack dump analysis:
Address: 02321118h, location: "foo_random", loaded at 022F0000h - 0232D000h
Address: 054C14CDh, location: "foo_ui_panels", loaded at 054C0000h - 055B3000h
Address: 022FFEC4h, location: "foo_random", loaded at 022F0000h - 0232D000h
Address: 054CA16Eh, location: "foo_ui_panels", loaded at 054C0000h - 055B3000h
Address: 0040A6DFh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 05582B8Ch, location: "foo_ui_panels", loaded at 054C0000h - 055B3000h
Address: 055785E8h, location: "foo_ui_panels", loaded at 054C0000h - 055B3000h
Address: 05501835h, location: "foo_ui_panels", loaded at 054C0000h - 055B3000h
Address: 05584F38h, location: "foo_ui_panels", loaded at 054C0000h - 055B3000h
Address: 7E36B8BAh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "SendMessageW" (+00000000h)
Address: 05501451h, location: "foo_ui_panels", loaded at 054C0000h - 055B3000h
Address: 05582BFCh, location: "foo_ui_panels", loaded at 054C0000h - 055B3000h
Address: 05579178h, location: "foo_ui_panels", loaded at 054C0000h - 055B3000h
Address: 054EBC15h, location: "foo_ui_panels", loaded at 054C0000h - 055B3000h
Address: 05584F34h, location: "foo_ui_panels", loaded at 054C0000h - 055B3000h
Address: 054C0000h, location: "foo_ui_panels", loaded at 054C0000h - 055B3000h
Address: 7C9105C8h, location: "ntdll", loaded at 7C900000h - 7C9B1000h
Symbol: "RtlFreeHeap" (+0000018Bh)
Address: 7C910551h, location: "ntdll", loaded at 7C900000h - 7C9B1000h
Symbol: "RtlFreeHeap" (+00000114h)
Address: 7C91056Dh, location: "ntdll", loaded at 7C900000h - 7C9B1000h
Symbol: "RtlFreeHeap" (+00000130h)
Address: 7C809A09h, location: "kernel32", loaded at 7C800000h - 7C8F7000h
Symbol: "lstrlenW" (+00000000h)
Address: 7E3688A6h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetWindowLongW" (+00000000h)
Address: 773DEFB3h, location: "COMCTL32", loaded at 773C0000h - 774C3000h
Symbol: "Ordinal384" (+00003113h)
Address: 7E3688D1h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetWindowLongW" (+0000002Bh)
Address: 7E3688DAh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetWindowLongW" (+00000034h)
Address: 7E3818E3h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "UnhookWinEvent" (+00000077h)
Address: 7E3BAE04h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetRawInputDeviceInfoA" (+0000011Fh)
Address: 7C9106EBh, location: "ntdll", loaded at 7C900000h - 7C9B1000h
Symbol: "RtlAllocateHeap" (+00000117h)
Address: 7C90EE18h, location: "ntdll", loaded at 7C900000h - 7C9B1000h
Symbol: "strchr" (+00000117h)
Address: 7C910570h, location: "ntdll", loaded at 7C900000h - 7C9B1000h
Symbol: "RtlFreeHeap" (+00000133h)
Address: 77C1C2DEh, location: "msvcrt", loaded at 77C00000h - 77C58000h
Symbol: "free" (+000000C3h)
Address: 77C1C2E3h, location: "msvcrt", loaded at 77C00000h - 77C58000h
Symbol: "free" (+000000C8h)
Address: 5B2678E9h, location: "uxtheme", loaded at 5B260000h - 5B298000h
Symbol: "GetThemeSysColor" (+0000072Fh)
Address: 773C1840h, location: "COMCTL32", loaded at 773C0000h - 774C3000h
Symbol: "Ordinal249" (+00001840h)
Address: 77C25C94h, location: "msvcrt", loaded at 77C00000h - 77C58000h
Symbol: "except_handler3" (+00000000h)
Address: 77C02070h, location: "msvcrt", loaded at 77C00000h - 77C58000h
Symbol: "__non_rtti_object::`vftable'" (+00000C78h)
Address: 5B267A3Fh, location: "uxtheme", loaded at 5B260000h - 5B298000h
Symbol: "GetThemeSysColor" (+00000885h)
Address: 7C910340h, location: "ntdll", loaded at 7C900000h - 7C9B1000h
Symbol: "RtlRestoreLastWin32Error" (+00000000h)
Address: 5B267A4Dh, location: "uxtheme", loaded at 5B260000h - 5B298000h
Symbol: "GetThemeSysColor" (+00000893h)
Address: 7E36882Ah, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetDC" (+00000163h)
Address: 7E390457h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DeregisterShellHookWindow" (+000001CFh)
Address: 77F198EBh, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "CreateFontIndirectExW" (+00000084h)
Address: 77F198C6h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "CreateFontIndirectExW" (+0000005Fh)
Address: 77F199AFh, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "CreateFontIndirectW" (+00000046h)
Address: 77F199B7h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "CreateFontIndirectW" (+0000004Eh)
Address: 01000000h, location: "foo_dbsearch", loaded at 00FF0000h - 01060000h
Address: 7E368B26h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetWindowThreadProcessId" (+000000A6h)
Address: 0550DF70h, location: "foo_ui_panels", loaded at 054C0000h - 055B3000h
Symbol: "foobar2000_get_interface" (+0000B630h)
Address: 7E36F896h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "CallNextHookEx" (+0000003Bh)
Address: 00AA2647h, location: "DM2", loaded at 00AA0000h - 00AA6000h
Symbol: "CreateMenuFromString" (+00000D27h)
Address: 7E368BD9h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetWindowThreadProcessId" (+00000159h)
Address: 7E3C0088h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Address: 7E36B3CCh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+00000090h)
Address: 7E36B3A7h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+0000006Bh)
Address: 00AA24B0h, location: "DM2", loaded at 00AA0000h - 00AA6000h
Symbol: "CreateMenuFromString" (+00000B90h)
Address: 7E36B50Ch, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+000001D0h)
Address: 7E36B51Ch, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+000001E0h)
Address: 7C90EAE3h, location: "ntdll", loaded at 7C900000h - 7C9B1000h
Symbol: "KiUserCallbackDispatcher" (+00000013h)
Address: 7E3BADA6h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetRawInputDeviceInfoA" (+000000C1h)
Address: 7E3694BEh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetWindowLongA" (+00000061h)
Address: 7E392135h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DeregisterShellHookWindow" (+00001EADh)
Address: 00AA1492h, location: "DM2", loaded at 00AA0000h - 00AA6000h
Symbol: "DisableFavMenu" (+000002B6h)
Address: 7E36B755h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetParent" (+00000026h)
Address: 7E36B785h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetParent" (+00000056h)
Address: 7E36B788h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetParent" (+00000059h)
Address: 00AA267Ch, location: "DM2", loaded at 00AA0000h - 00AA6000h
Address: 00AA26C1h, location: "DM2", loaded at 00AA0000h - 00AA6000h
Address: 7E36B4CBh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+0000018Fh)
Address: 00AA1210h, location: "DM2", loaded at 00AA0000h - 00AA6000h
Symbol: "DisableFavMenu" (+00000034h)
Address: 7E36FE13h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "CreateWindowExW" (+000001EEh)
Address: 7E36FDD9h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "CreateWindowExW" (+000001B4h)
Address: 7E36FDFEh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "CreateWindowExW" (+000001D9h)
Address: 7E36D0A5h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "EnumDisplayMonitors" (+00000142h)
Address: 7E36D0B5h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "EnumDisplayMonitors" (+00000152h)
Address: 7E36BAA4h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "IsWindow" (+00000171h)
Address: 7E36D5BEh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcA" (+000000D0h)
Address: 7E36D601h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcA" (+00000113h)
Address: 0557B6D4h, location: "foo_ui_panels", loaded at 054C0000h - 055B3000h
Address: 0550DFB7h, location: "foo_ui_panels", loaded at 054C0000h - 055B3000h
Symbol: "foobar2000_get_interface" (+0000B677h)
Address: 7E368734h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetDC" (+0000006Dh)
Address: 7E373B9Ch, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefDlgProcW" (+00000402h)
Address: 7E373768h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "PrivateExtractIconExW" (+000002D5h)
Address: 7E373591h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "PrivateExtractIconExW" (+000000FEh)
Address: 7E37379Ah, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefDlgProcW" (+00000000h)
Address: 7E3737BCh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefDlgProcW" (+00000022h)
Address: 7E368816h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetDC" (+0000014Fh)
Address: 055A4C58h, location: "foo_ui_panels", loaded at 054C0000h - 055B3000h
Address: 7E368830h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetDC" (+00000169h)
Address: 7E36B4C0h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+00000184h)
Address: 7E36B4D0h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+00000194h)
Address: 7E36B473h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+00000137h)
Address: 7E36D4E4h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "SetPropW" (+000000BBh)
Address: 7E3743E0h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetWindowTextLengthW" (+00000547h)
Address: 055A4968h, location: "foo_ui_panels", loaded at 054C0000h - 055B3000h
Address: 055A4C3Ch, location: "foo_ui_panels", loaded at 054C0000h - 055B3000h
Address: 055A4C56h, location: "foo_ui_panels", loaded at 054C0000h - 055B3000h
Address: 00C00000h, location: "foo_bitcompare", loaded at 00BF0000h - 00C17000h
Address: 01F000EFh, location: "foo_noss", loaded at 01EF0000h - 01F07000h
Address: 7E36021Bh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Address: 7E37592Ch, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DrawStateW" (+000001DFh)
Address: 7E375981h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DialogBoxIndirectParamAorW" (+00000036h)
Address: 055A46A8h, location: "foo_ui_panels", loaded at 054C0000h - 055B3000h
Address: 7E37559Eh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DialogBoxParamW" (+0000003Fh)
Address: 054E7EE2h, location: "foo_ui_panels", loaded at 054C0000h - 055B3000h
Address: 7E36EFC8h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DestroyMenu" (+00000000h)
Address: 05584E30h, location: "foo_ui_panels", loaded at 054C0000h - 055B3000h
Address: 7E36F800h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "EnableMenuItem" (+00000079h)
Version info:
foobar2000 v0.9.4.3
UNICODE
Additional info:
Playback Utilities 1.0  (foo_utils_playback)
Masstagger 1.6  (foo_masstag)
Masstagger Addons 0.3.3  (foo_masstag_addons)
Pause on Lock 0.4  (foo_lock)
Tabbed panel modified 0.2.5  (foo_uie_tabs)
Discogs Tagger 1.0  (foo_discogs)
Special file info box 2.0.3  (foo_infobox)
cwbowron's title format hooks 1.2.5 [Jun  8 2007 - 08:49:42]  (foo_cwb_hooks)
Convolver 0.3  (foo_convolve)
Database Search 1.4  (foo_dbsearch)
CD Audio Decoder 2.1.1  (foo_cdda)
Shell Link Resolver 1.2  (foo_lnk)
Console panel 0.2.1  (foo_uie_console)
Default video player 0.1.3  (foo_default_videoplayer)
Live Show Tagger 0.6.1  (foo_tradersfriend)
Fullscreen 0.3.1  (foo_fullscreen)
Cuesheet Creator 0.4.6  (foo_cuesheet_creator)
File Integrity Verifier 1.0  (foo_verifier)
No ScreenSaver 1.0  (foo_noss)
ReplayGain Scanner 2.0.2  (foo_rgscan)
LPCM <--> delta-PCM converter 0.1.1  (foo_dsp_delta)
Randomized Playlist Entry 1.2.3  (foo_random)
Playlist Name Enhanced 1.2  (foo_playlist_name_enhanced)
FLAC Decoder 1.1.0  (foo_input_std)
HTTP Writer 1.1  (foo_write_http)
Run Command 1.0 beta 2  (foo_runcmd)
Playlist Lock Test 1.0  (foo_locktest)
ZIP/GZIP reader 1.0  (foo_unpack)
WSH Panel (uie) 0.7.1  (foo_uie_wsh_panel)
Album list panel 0.2.3 beta  (foo_uie_albumlist)
Track Finder 2.1.1 [Jun 16 2006 - 12:36:15]  (foo_trackfinder)
Metadata Cache Statistics 1.2  (foo_metadbstats)
Album List 3.2.0  (foo_albumlist)
Acro WMA decoder 0.1.6.5 (Intel SSE)  (foo_input_awma)
RAR reader 1.1  (foo_unpack)
Default User Interface 0.9acc  (foo_ui_std)
Track Positioner 1.0  (foo_trackpos)
Run services 0.3.2  (foo_run)
Playlist Manager 1.0.2  (foo_playlist_manager)
foo_explorer 1.31  (foo_explorer)
Freedb2 characters fixer (masstagger addon) 0.02  (foo_freedb2_fix)
TTA Audio Decoder (unofficial) 2.4.2  (foo_input_tta)
Scheduler 3.53  (foo_scheduler)
foosic music database 1.0 beta 12  (foo_sic)
foo_skip 0.2  (foo_skip)
Egoh User Interface 1.1.0  (foo_ui_egoh)
Components versions viewer 0.3  (foo_version)
Panels UI 0.14.3 beta [Jul  5 2007 - 21:39:43]  (foo_ui_panels)
Playlist Tree Panel 3.0.BETA_3 [Apr  3 2007 - 11:39:32]  (foo_playlist_tree)
Non-Stop Output 0.1.1 (Intel SSE)  (foo_out_nonstop)
Playlists Dropdown 0.6 alpha 3  (foo_uie_playlists_dropdown)
Binary Comparator 1.1  (foo_bitcompare)
Quick Search Toolbar 2.8l  (foo_uie_quicksearch)
Cleartype font support 0.3  (foo_cleartype)
Standard DSP array 1.0  (foo_dsp_std)
foobar2000 core 0.9.4.3  (Core)
Columns UI 0.2.0 alpha 2  (foo_ui_columns)
Remove played Files 1.3.0  (foo_removeplayed)
Kernel Streaming Output 1.2.2  (foo_out_ks)
Queue manager panel 0.2.3  (foo_uie_queuemanager)
Bookmarks 0.1.8pre  (foo_uie_bookmarks)
ABX Comparator 1.3.1  (foo_abx)
Track info panel 0.82  (foo_uie_trackinfo)
History 0.2  (foo_history)
Playback Statistics Custom 1.0.3  (foo_playback_custom)
Autoplaylist Manager 1.0  (foo_autoplaylist)
Preview 1.1  (foo_preview)
Playlist Tools 0.5.9  (foo_utils)
Egoh Spectrum analyser (uie) 1.1.0  (foo_uie_vis_egoh)
Monkey's Audio decoder 2.1.2  (foo_input_monkey)
Explorer Tree 1.04.6a  (foo_uie_explorer)
Gapless Crossfader 0.2.4  (foo_dsp_crossfader)
Shorten decoder 0.4.2a  (foo_input_shorten)
Dockable Panels 1.0.7b [Mar 28 2007 - 09:18:48]  (foo_dockable_panels)
WMA Decoder 1.1  (foo_input_std)
foo_custominfo 0.1.2  (foo_custominfo)
Converter 1.0.1  (foo_converter)
Common services 0.1  (foo_common)
freedb Tagger 0.5.2a  (foo_freedb2)
Menu Addons 0.3.9.4 (Intel SSE)  (foo_menu_addons)
Channel Mixer 0.9.6.1  (foo_channel_mixer)
Album Art Panel 0.2.6  (foo_uie_albumart)
Send to Device 1.0.5 [Nov 17 2006 - 14:16:40]  (foo_sendtodevice)
Tagger Panel Window 1.0.5 [Jun 12 2007 - 15:14:00]  (foo_cwb_hooks)
foo_ui_panels
Reply #1856
Bug Report:
With $windowstyle(hidetitlebar) option in // Background section,each time i restart foobar window's height
is growing by 25 pixels,making notitlebar option useless.
does it happen also with the latest test version? What OS are you using?
Yes it stays with the latest beta,I'm using Window Blinds (if it helps to understand the root of the problem)
Favourite artist:CD-R
Favourite album:700MB
foo_ui_panels
Reply #1857
Bug Report:
I think I reported this waaay back (but didn't describe it as well as you did) but I can also confirm this issue. It happens when I switch between PUI's also. I have been waiting for a fix to this for a while so I can ditch my titlebar.
What seems to happen is foobar adds the same amount of pixels to the bottom of its screen as the titlebars height. So if the titlebar was 15 pixels, 15 pixels would be added to the bottom of the screen. 30 pixel titlebar would add 30 to the bottom, etc. This makes the hide title bar feature rather useless to me .
Stats: Windows XP SP2, FB2K 0.9.4.3, P.UI 0.13.8 Beta (so it happens before these new betas too). I am also using windowblinds 5.0.
Song List: keikoniumboards.ke.funpic.org/files/songlist.html
foo_ui_panels
Reply #1858
Question:
I have just installed a bunch of configs that have the ability to switch between panels and choose background images. I have searched thru the code they use to do what they are doing, and I am slightly lost. I have this code here that makes a button switch between two panels:
//LYRICS AND SETTINGS
$button(1109,55,0,0,0,0,$get(dir2)music.png,$get(dir2)music.png,PVAR:SET:setlyr:$ifequal($getpvar(setlyr),0,1,0),)
$panel(Lyrics,Lyrics panel,271,51,813,211,)
$panel(Settings,Track Display,271,51,813,211,)
But a lot of configs have a single button that switches between 3, 4, 5 or even MORE panels. This is what I am trying to do, but I am not understanding how they are doing it. I see $select() being used a few times, lots of $pvars and stuff, but when I modify it to fit my config, nothing works. So could someone provide me some code I could use that will allow a button to switch between 3 or more panels (5 would be ideal, cause thats what I really need).
Thanks to whoever could help me out  .
foo_ui_panels
Reply #1859
Question:
Basically, you would rotate through different panels by rotating through different pvar values.  The rotation of pvars can be done like so:
$button([button dimensions],[mousover image],[image],PVAR:SET:[variable name]:$ifequal($getpvar([variable name]),5,1,$eval($get([variable name])+1),)
This should rotate the value between 1 and 5, giving you 5 values to rotate between.  You then use the $select function to execute the corresponding function contained in the $select command, like  such:
$select($getpvar([variable name]),$panel([panel 1 definition]),$panel([panel 2 definition]),$panel([panel 3 definition]),$panel([panel 4 definition]),$panel([panel 5 definition]))
Just replace the stuff in the square brackets witth the stuff appropriate to your setup.
Any questions, first look at the following first:
Foobar2000 Titleformat Reference wiki
PanelsUI wiki
foo_ui_panels
Reply #1860
Awesome, it makes so much sense now that you explain it like that . I have both page links in my bookmarks, and consult them before asking, the pvar and panel stuff just confused me, so I thought I'd ask.
I have been playing around with the code you have provided me, but can't seem to get it to function. I have cut down the needed panels to just 3 instead of 5, so I modified the code to suit 3 panels. Here is what I have:
$button(1109,55,0,0,0,0,$get(dir2)music.png,$get(dir2)music.png,PVAR:SET:setlyr:$ifequal($getpvar(setlyr),3,1,$eval($get(setlyr)+1),)
$select($getpvar(setlyr),
$panel(Lyrics,Lyrics panel,271,51,813,211,),
$panel(Backgrounds,Track Display,271,51,813,211,),
$panel(Settings,Track Display,271,51,813,211,))
It doesn't seem to work. I think it has something to do with the button code because nothing shows up when I use this. Near the end in the $ifequal() part is where I think its going wrong, but I am not sure. I have tried to put ' and ' around parts of the code, modify the brackets, add/remove stuff, and nothing seems to work. I made sure that there were the correct number of sections in the $button() code, but in the $ifequal() there are more commas, and I wasn't sure if made the $button() code mess up.
In short, this code isn't doing anything, and I am not sure why. I looked for answers in the wiki, and tried to troubleshoot my problem, but no luck. A bit more help please?
foo_ui_panels
Reply #1861
Just realised I'm not too sure just what this table in the wiki is supposed to mean.  It looks as though there is only one switch (which can take on any value from 0 to 7) with the ROTATEFLIP command, and any given value is somehow equivalent to multiple different combinations of flipping and rotating?  Also what is Flip XY supposed to be?
foo_ui_panels
Reply #1862
My bad, I messed up the parentheses of the ifeaqual function a little.  I think it should be like:
$button(1109,55,0,0,0,0,$get(dir2)music.png,$get(dir2)music.png,PVAR:SET:setlyr:$ifequal($getpvar(setlyr),3,1,$eval($get(setlyr)+1)),)
That should work, hopefully...
Sorry, like Michael Bolton from Office Space, I always mess up the mundaine details
foo_ui_panels
Reply #1863
Unfortunately, that doesn't work either . I had tried that in my trouble shooting, as well as moving/adding more commas and parentheses. It looks like it should work, so I have no clue why it doesn't :/.
foo_ui_panels
Reply #1864
I have been trying to download 14.3 but every time I download the link from the fist page it gives me the older version 13.x, can someone please verify that the link is working? I like to try new versions but cannot until I can download them..
foo_ui_panels
Reply #1865
I've uploaded another test version here.
It should be pretty much identical to the older version except for some glow / alpha / blurring stuff. Let me know of any other differences.
foo_ui_panels
Reply #1866
Terrestial
fixed for the next version.
can you post a screenshot of your theme? Also does the window size still expand if you comment out the $windowstyle() with the hide titlebar, hit apply, and then uncomment it, and hit apply?
foo_ui_panels
Reply #1867
Here's the code I came up with, to use one button to choose between three panels.  It might not be as fancy as the other code, but it does work for me.  See if it works for you.........
/////////////TOGGLE ART - LIBRARY FILTER - LYRICS PANELS/////////////////////////
$ifequal($getpvar(libfilter),0,
    $button(329,474,0,0,37,37,/images\Button.png,/images\Button2.png,PVAR:SET:libfilter:1,TOOLTIP:"LibFilter")
$ifequal($getpvar(libfilter),1,
    $button(327,472,0,0,39,39,/images\Button.png,/images\Button2.png,PVAR:SET:libfilter:2,TOOLTIP:"Lyrics")
$ifequal($getpvar(libfilter),2,
    $button(324,470,0,0,39,39,/images\Button.png,/images\Button2.png,PVAR:SET:libfilter:0,TOOLTIP:"Art")
/////////////Library Filter///////////
$panel(Lib,Library Filter,3,65,445,360,),
///////// Lyric Show Panel//////////////////////////
$panel(TheLyrics,Lyric Show,3,65,445,360,),
///////// Art Panel//////////////////////////
$panel(Art,Album Art,3,65,445,360,),
foo_ui_panels
Reply #1868
Using the test version renders almost everything incorrect.
Tell me if you need any code, thanks.
Here's an image of it.
Works fine with latest stable version.
foo_ui_panels
Reply #1869
I tested the beta with the basic layout
Drag and drop works like a charm. Is it possible to change the arrow which appears or to let the arrow disappear?
You are really doing good work.
Andreasvb: Did you use an existing layout or did you copy the code manually to recreate the layout?
Is transparency activated?
foo_ui_panels
Reply #1870
I only replaced the dll.
It's my own layout.
I use Columns UI, transparency doesn't affect it.
foo_ui_panels
Reply #1871
yes, please post the code and I will take a look
foo_ui_panels
Reply #1872
I've got one request terrestrial...
Prior I was using Album List Panel, instead of Library Filter. I also sorted music by %genre%. This criterium seemed to be processed even further than other tags. Little example:
Song A - Genre: IDM, Drum n Bass
Song B - Genre: Breakcore, IDM
In Album List Panel I'd see:
- Genre
  + Breakcore
  + Drum n Bass
  + IDM
In Library Filter I see:
- Genre
  + IDM, Drum n Bass
  + Breakcore, IDM
I admit I don't use sorting by genre very often, and there are a lot of more important things to do, but this parsing of the tag, would be nice.
foo_ui_panels
Reply #1873
try replace genre with something like this:
$replace(%genre%,', ',|)
foo_ui_panels
Reply #1874
for image manipulation
FlipXY is an 180 degree flip on both the x and y axis, think 3 dimensional
flip occurs on an axis
rotate is simply turning x degrees, 2 dimensional
