Hey, this is great news!
I did some testing. The classic vst of www.kjaerhusaudio.com worked.
Some plugins of him http://bram.smartelectronix.com/plugins.php don't show up in the vst editor. Bouncy, supatrigga, crazy ivan. I have no other proper vst host avail. at the moment; is this possibly because those vst fx do not have a gui? Will you make it possible?
Please allow a vst chain, afaics we can only use one vst effect plugin.
Thank you so much!
EDIT: No matter if your plugin is in the dsp chain or not, the vst editor appears on fb2k startup.
EDIT: Crash when a vst is loaded and starting a stream:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 0043E3ABh
Access violation, operation: read, address: 00000000h
Call path:
playback_process entry=>output::volume_set
Code bytes (0043E3ABh):
0043E36Bh: E8 48 9E 05 00 8B 4C 24 10 DD 44 24 18 8B 01 56
0043E37Bh: FF 74 24 18 8B 75 08 51 51 DD 1C 24 8D 54 24 48
0043E38Bh: 52 56 FF 50 0C 8B 3D C8 44 4B 00 68 74 23 4C 00
0043E39Bh: 8D 4C 24 18 FF D7 C6 44 24 54 01 DD 46 08 8B 0E
0043E3ABh: 8B 01 51 51 DD 1C 24 FF 50 24 C6 44 24 54 00 8B
0043E3BBh: 1D C4 44 4B 00 8D 4C 24 14 FF D3 80 7E 10 00 74
0043E3CBh: 24 68 88 23 4C 00 8D 4C 24 18 FF D7 C6 44 24 54
0043E3DBh: 02 8B 0E 8B 01 6A 01 FF 50 18 8D 4C 24 14 C6 44
Stack (09AEF668h):
09AEF648h: 0012F89C 01BFE9E0 FFFFFFFF 77F46B8D
09AEF658h: 0012F778 77E23021 0012F784 77E3158F
09AEF668h: 057F3B68 057F3B60 77887EE0 00000000
09AEF678h: 00AD2F5C 00000016 00000000 40000000
09AEF688h: 00000000 00000000 0F5D2A82 43366E82
09AEF698h: B4B49C84 6E04CA92 BD6DD71A 11D13DEB
09AEF6A8h: C00071B1 0200C24F 00000000 09AEFEDC
09AEF6B8h: 004A6FB2 00000001 00000000 09AEFEE8
09AEF6C8h: 00442D3A 057F3B68 057F3898 0044518C
09AEF6D8h: 00000004 00000001 057F3898 00000000
09AEF6E8h: 00000000 00000000 00000000 00000000
09AEF6F8h: 00000000 00000000 00000000 00000000
09AEF708h: 00000000 00000000 00000000 00000000
09AEF718h: 00000000 00000000 00000000 00000000
09AEF728h: 00000000 00000000 00000000 00000000
09AEF738h: 00000000 00000000 00000000 00000000
09AEF748h: 00000000 00000000 00000000 00000000
09AEF758h: 00000000 00000000 00000000 00000000
09AEF768h: 00000000 00000000 00000000 00000000
09AEF778h: 00000000 00000000 00000000 00000000
Registers:
EAX: 09AEF67C, EBX: 09AEF678, ECX: 00000000, EDX: 00000002
ESI: 057F3B68, EDI: 10002DA0, EBP: 09AEF6C4, ESP: 09AEF668
Crash location: "foobar2000", loaded at 00400000h - 004F3000h
Loaded modules:
foobar2000 loaded at 00400000h - 004F3000h
ntdll loaded at 77880000h - 77902000h
COMCTL32 loaded at 71710000h - 71794000h
GDI32 loaded at 77F40000h - 77F7F000h
KERNEL32 loaded at 77E70000h - 77F30000h
USER32 loaded at 77E00000h - 77E69000h
ADVAPI32 loaded at 79350000h - 793B5000h
RPCRT4 loaded at 77D20000h - 77D98000h
SHLWAPI loaded at 70BD0000h - 70C35000h
msvcrt loaded at 78000000h - 78045000h
SHELL32 loaded at 7CF90000h - 7D1EC000h
ole32 loaded at 7CE80000h - 7CF81000h
shared loaded at 10000000h - 10029000h
comdlg32 loaded at 76B00000h - 76B3F000h
foo_autoplaylist loaded at 008C0000h - 008F0000h
foo_cdda loaded at 00900000h - 00935000h
foo_cmd_playlist loaded at 00950000h - 00968000h
foo_common loaded at 00980000h - 009BA000h
foo_converter loaded at 009D0000h - 00A39000h
foo_cwb_hooks loaded at 00A50000h - 00A86000h
foo_dsp_crossfader loaded at 00AA0000h - 00AF6000h
libmmd loaded at 00B00000h - 00DB1000h
MSVCR80 loaded at 78130000h - 781CB000h
foo_dsp_delta loaded at 00DE0000h - 00DFE000h
foo_dsp_std loaded at 00E10000h - 00E51000h
foo_dsp_tube loaded at 00E70000h - 00E96000h
foo_dsp_vlevel loaded at 00EB0000h - 00ED4000h
foo_dsp_vst loaded at 00EF0000h - 00F10000h
foo_freedb2 loaded at 00F20000h - 00F60000h
foo_fullscreen loaded at 00F70000h - 00F8B000h
foo_input_monkey loaded at 00FA0000h - 00FEA000h
foo_input_mslive loaded at 01000000h - 01076000h
WMVCore loaded at 07EB0000h - 080B0000h
wmidx loaded at 07650000h - 07679000h
WMASF loaded at 07270000h - 072AA000h
OLEAUT32 loaded at 779A0000h - 77A3B000h
msdmo loaded at 01080000h - 01087000h
WININET loaded at 70200000h - 70296000h
CRYPT32 loaded at 799D0000h - 79A5C000h
MSASN1 loaded at 77400000h - 77411000h
urlmon loaded at 702B0000h - 7032A000h
VERSION loaded at 77810000h - 77817000h
LZ32 loaded at 75940000h - 75946000h
MSACM32 loaded at 773E0000h - 773F3000h
WINMM loaded at 77540000h - 77571000h
MSVFW32 loaded at 6A770000h - 6A790000h
WSOCK32 loaded at 74FC0000h - 74FC9000h
WS2_32 loaded at 74FA0000h - 74FB4000h
WS2HELP loaded at 74F90000h - 74F98000h
DRMClien loaded at 08B20000h - 08B6F000h
foo_input_std loaded at 01530000h - 01643000h
foo_input_tak loaded at 01660000h - 016A7000h
tak_deco_lib loaded at 016B0000h - 016E1000h
foo_masstag loaded at 01810000h - 0185F000h
foo_masstag_addons loaded at 01870000h - 0187E000h
foo_menu_addons loaded at 01880000h - 018CD000h
foo_playlist_bind loaded at 018D0000h - 018F5000h
foo_playlist_manager loaded at 01910000h - 01956000h
foo_random loaded at 01970000h - 019AF000h
foo_rgscan loaded at 019C0000h - 01A08000h
foo_runcmd loaded at 01A20000h - 01A4F000h
foo_sic loaded at 01A60000h - 01AB7000h
foo_uie_bookmarks loaded at 01BD0000h - 01C1D000h
foo_uie_explorer loaded at 01C30000h - 01C6C000h
foo_uie_queuemanager loaded at 01C80000h - 01CB6000h
msvcm80 loaded at 7C4C0000h - 7C53D000h
mscoree loaded at 79000000h - 79045000h
mscorwks loaded at 79E70000h - 7A3D1000h
mscorlib.ni loaded at 04030000h - 04B18000h
mscorjit loaded at 79060000h - 790B3000h
rsaenh loaded at 7CA00000h - 7CA23000h
USERENV loaded at 791A0000h - 79205000h
System.ni loaded at 7A440000h - 7ABFE000h
System.Drawing.ni loaded at 7ADE0000h - 7AF74000h
Gdiplus loaded at 70D00000h - 70E91000h
foo_uie_quicksearch loaded at 04FD0000h - 05016000h
foo_uie_tabs loaded at 05030000h - 0505A000h
foo_ui_columns loaded at 05070000h - 05107000h
foo_ui_panels loaded at 05120000h - 051FE000h
IMM32 loaded at 75DF0000h - 75E0A000h
foo_utils loaded at 05210000h - 05249000h
CLBCATQ loaded at 784A0000h - 78530000h
cscui loaded at 77840000h - 7787F000h
CSCDLL loaded at 77090000h - 770B3000h
MPR loaded at 782F0000h - 78301000h
ntlanman loaded at 750D0000h - 750DC000h
NETAPI32 loaded at 7CE20000h - 7CE73000h
DNSAPI loaded at 77970000h - 77994000h
NETRAP loaded at 75130000h - 75136000h
NTDSAPI loaded at 77BE0000h - 77BF1000h
WLDAP32 loaded at 77940000h - 7796C000h
SECUR32 loaded at 79430000h - 7943F000h
SAMLIB loaded at 750C0000h - 750D0000h
NETUI0 loaded at 75180000h - 75195000h
NETUI1 loaded at 75140000h - 75178000h
System.Windows.Forms.ni loaded at 7AFD0000h - 7BC56000h
Msimg32 loaded at 6B150000h - 6B155000h
Classic Flanger loaded at 09040000h - 09124000h
keyboard loaded at 099A0000h - 099B0000h
DSOUND loaded at 51080000h - 510DA000h
wdmaud loaded at 77530000h - 77538000h
msacm32 loaded at 773D0000h - 773D8000h
imagehlp loaded at 77910000h - 77933000h
DBGHELP loaded at 72970000h - 7299D000h
Stack dump analysis:
Address: 77887EE0h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 00AD2F5Ch, location: "foo_dsp_crossfader", loaded at 00AA0000h - 00AF6000h
Address: 004A6FB2h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00442D3Ah, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0044518Ch, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 77885C09h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 77885DA7h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 778CE748h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 77885D6Fh, location: "ntdll", loaded at 77880000h - 77902000h
Address: 05210000h, location: "foo_utils", loaded at 05210000h - 05249000h
Address: 77E9C147h, location: "KERNEL32", loaded at 77E70000h - 77F30000h
Address: 7813231Ah, location: "MSVCR80", loaded at 78130000h - 781CB000h
Address: 778B2C0Ch, location: "ntdll", loaded at 77880000h - 77902000h
Address: 778B7E64h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 77883148h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 778CAE15h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 090C8664h, location: "Classic Flanger", loaded at 09040000h - 09124000h
Address: 778CB0FFh, location: "ntdll", loaded at 77880000h - 77902000h
Address: 778CB4BEh, location: "ntdll", loaded at 77880000h - 77902000h
Address: 778CB618h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 019C0000h, location: "foo_rgscan", loaded at 019C0000h - 01A08000h
Address: 779410FEh, location: "WLDAP32", loaded at 77940000h - 7796C000h
Address: 004C7008h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 77E700C8h, location: "KERNEL32", loaded at 77E70000h - 77F30000h
Address: 778ABDB6h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 77E70000h, location: "KERNEL32", loaded at 77E70000h - 77F30000h
Address: 7788DB62h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 7788DC33h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 7788DBE0h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 05231B5Ch, location: "foo_utils", loaded at 05210000h - 05249000h
Address: 77E9C100h, location: "KERNEL32", loaded at 77E70000h - 77F30000h
Address: 77881338h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 77E90B81h, location: "KERNEL32", loaded at 77E70000h - 77F30000h
Address: 77881370h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 090C60C8h, location: "Classic Flanger", loaded at 09040000h - 09124000h
Address: 77881650h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 77E7919Dh, location: "KERNEL32", loaded at 77E70000h - 77F30000h
Address: 09043C5Ah, location: "Classic Flanger", loaded at 09040000h - 09124000h
Address: 09043FC7h, location: "Classic Flanger", loaded at 09040000h - 09124000h
Address: 099A18A7h, location: "keyboard", loaded at 099A0000h - 099B0000h
Address: 099A0000h, location: "keyboard", loaded at 099A0000h - 099B0000h
Address: 099A1857h, location: "keyboard", loaded at 099A0000h - 099B0000h
Address: 7788806Ch, location: "ntdll", loaded at 77880000h - 77902000h
Address: 7788AB2Fh, location: "ntdll", loaded at 77880000h - 77902000h
Address: 77883A8Fh, location: "ntdll", loaded at 77880000h - 77902000h
Address: 77883A52h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 77881188h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 77891B93h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 77891B9Bh, location: "ntdll", loaded at 77880000h - 77902000h
Address: 004C2BF8h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004AF20Dh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7CFE824Ch, location: "SHELL32", loaded at 7CF90000h - 7D1EC000h
Address: 00444FC5h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C2AD8h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 10002D87h, location: "shared", loaded at 10000000h - 10029000h
Symbol: "uPrintCrashInfo_SetDumpPath" (+000000A7h)
Address: 004AF228h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00444F67h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004A6749h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 77E7B388h, location: "KERNEL32", loaded at 77E70000h - 77F30000h
Address: 77EC1F54h, location: "KERNEL32", loaded at 77E70000h - 77F30000h
Address: 77E72B08h, location: "KERNEL32", loaded at 77E70000h - 77F30000h
Address: 00444F30h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00C80008h, location: "libmmd", loaded at 00B00000h - 00DB1000h
Symbol: "_csqrtq_f90" (+0017D6CCh)
Version info:
foobar2000 v0.9.4.3 beta
UNICODE
Additional info:
Gapless Crossfader 0.3 (Intel SSE) (foo_dsp_crossfader)
Playlist Commandline Tools 0.0.1 (foo_cmd_playlist)
ReplayGain Scanner 2.0.2 (foo_rgscan)
CD Audio Decoder 2.1.1 (foo_cdda)
VLevel 20060324.0 (foo_dsp_vlevel)
VST bridge 0.40 Beta (foo_dsp_vst)
Autoplaylist Manager 1.0 (foo_autoplaylist)
Panels UI 0.10.0 beta [Apr 22 2007 - 17:07:58] (foo_ui_panels)
TAK Decoder 0.3.1 (foo_input_tak)
Menu Addons 0.3.9.3 (Intel SSE) (foo_menu_addons)
mslive 0.3.7 (Intel SSE) (foo_input_mslive)
Monkey's Audio decoder 2.1.2 (foo_input_monkey)
Playlist Manager 1.0 (foo_playlist_manager)
Tube Sound 0.8 (foo_dsp_tube)
Standard DSP array 1.0 (foo_dsp_std)
Explorer Tree 1.04.6b (foo_uie_explorer)
Masstagger Addons 0.3.3 (foo_masstag_addons)
freedb Tagger 0.5.2a (foo_freedb2)
Converter 1.0.1 (foo_converter)
Standard Input Array 1.0 (foo_input_std)
FLAC Decoder 1.1.0 (foo_input_std)
WMA Decoder 1.1 (foo_input_std)
Columns UI 0.1.3 beta 1v7 (foo_ui_columns)
Common services 0.1 (foo_common)
foosic music database 1.0 beta 11 (foo_sic)
Randomized playlist entry 1.2.3 (foo_random)
LPCM <--> delta-PCM converter 0.1.1 (foo_dsp_delta)
Playlist Bind 2.2 (foo_playlist_bind)
Masstagger 1.6 (foo_masstag)
Fullscreen 0.3.1 (foo_fullscreen)
Queue manager panel 0.2.2 (foo_uie_queuemanager)
cwbowron's title format hooks 1.1.1 [May 4 2007 - 12:39:47] (foo_cwb_hooks)
Playlist tools 0.5.7 (foo_utils)
Bookmarks 0.2.3 (foo_uie_bookmarks)
foobar2000 core 0.9.4.3 beta (Core)
Tabbed panel modified 0.2.5 (foo_uie_tabs)
Quick Search Toolbar 2.8k (foo_uie_quicksearch)
Run Command 1.0 beta 1 (foo_runcmd)
