Topic: foo_dsp_vst (Read 62307 times) previous topic - next topic
foo_dsp_vst
Cannibal,
Nice work; this plugin is way over due.  I noticed a short noise burst after hitting stop and then resuming play again; perhaps you need to make sure a buffer gets flushed out after hitting stop?
Would there be anyway I could bribe you to port this plugin to the old foobar .83 version?  I use .83 for playback at shows due to the lack of a real crossfading solution in .94.  Thanks and good luck polishing this one up.
foo_dsp_vst
Hey, this is great news!
I did some testing. The classic vst of www.kjaerhusaudio.com worked.
Some plugins of him http://bram.smartelectronix.com/plugins.php don't show up in the vst editor. Bouncy, supatrigga, crazy ivan. I have no other proper vst host avail. at the moment; is this possibly because those vst fx do not have a gui? Will you make it possible?
Please allow a vst chain, afaics we can only use one vst effect plugin.
Thank you so much!
EDIT: No matter if your plugin is in the dsp chain or not, the vst editor appears on fb2k startup.
EDIT: Crash when a vst is loaded and starting a stream:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 0043E3ABh
Access violation, operation: read, address: 00000000h
Call path:
playback_process entry=>output::volume_set
Code bytes (0043E3ABh):
0043E36Bh:  E8 48 9E 05 00 8B 4C 24 10 DD 44 24 18 8B 01 56
0043E37Bh:  FF 74 24 18 8B 75 08 51 51 DD 1C 24 8D 54 24 48
0043E38Bh:  52 56 FF 50 0C 8B 3D C8 44 4B 00 68 74 23 4C 00
0043E39Bh:  8D 4C 24 18 FF D7 C6 44 24 54 01 DD 46 08 8B 0E
0043E3ABh:  8B 01 51 51 DD 1C 24 FF 50 24 C6 44 24 54 00 8B
0043E3BBh:  1D C4 44 4B 00 8D 4C 24 14 FF D3 80 7E 10 00 74
0043E3CBh:  24 68 88 23 4C 00 8D 4C 24 18 FF D7 C6 44 24 54
0043E3DBh:  02 8B 0E 8B 01 6A 01 FF 50 18 8D 4C 24 14 C6 44
Stack (09AEF668h):
09AEF648h:  0012F89C 01BFE9E0 FFFFFFFF 77F46B8D
09AEF658h:  0012F778 77E23021 0012F784 77E3158F
09AEF668h:  057F3B68 057F3B60 77887EE0 00000000
09AEF678h:  00AD2F5C 00000016 00000000 40000000
09AEF688h:  00000000 00000000 0F5D2A82 43366E82
09AEF698h:  B4B49C84 6E04CA92 BD6DD71A 11D13DEB
09AEF6A8h:  C00071B1 0200C24F 00000000 09AEFEDC
09AEF6B8h:  004A6FB2 00000001 00000000 09AEFEE8
09AEF6C8h:  00442D3A 057F3B68 057F3898 0044518C
09AEF6D8h:  00000004 00000001 057F3898 00000000
09AEF6E8h:  00000000 00000000 00000000 00000000
09AEF6F8h:  00000000 00000000 00000000 00000000
09AEF708h:  00000000 00000000 00000000 00000000
09AEF718h:  00000000 00000000 00000000 00000000
09AEF728h:  00000000 00000000 00000000 00000000
09AEF738h:  00000000 00000000 00000000 00000000
09AEF748h:  00000000 00000000 00000000 00000000
09AEF758h:  00000000 00000000 00000000 00000000
09AEF768h:  00000000 00000000 00000000 00000000
09AEF778h:  00000000 00000000 00000000 00000000
Registers:
EAX: 09AEF67C, EBX: 09AEF678, ECX: 00000000, EDX: 00000002
ESI: 057F3B68, EDI: 10002DA0, EBP: 09AEF6C4, ESP: 09AEF668
Crash location: "foobar2000", loaded at 00400000h - 004F3000h
Loaded modules:
foobar2000                      loaded at 00400000h - 004F3000h
ntdll                            loaded at 77880000h - 77902000h
COMCTL32                        loaded at 71710000h - 71794000h
GDI32                            loaded at 77F40000h - 77F7F000h
KERNEL32                        loaded at 77E70000h - 77F30000h
USER32                          loaded at 77E00000h - 77E69000h
ADVAPI32                        loaded at 79350000h - 793B5000h
RPCRT4                          loaded at 77D20000h - 77D98000h
SHLWAPI                          loaded at 70BD0000h - 70C35000h
msvcrt                          loaded at 78000000h - 78045000h
SHELL32                          loaded at 7CF90000h - 7D1EC000h
ole32                            loaded at 7CE80000h - 7CF81000h
shared                          loaded at 10000000h - 10029000h
comdlg32                        loaded at 76B00000h - 76B3F000h
foo_autoplaylist                loaded at 008C0000h - 008F0000h
foo_cdda                        loaded at 00900000h - 00935000h
foo_cmd_playlist                loaded at 00950000h - 00968000h
foo_common                      loaded at 00980000h - 009BA000h
foo_converter                    loaded at 009D0000h - 00A39000h
foo_cwb_hooks                    loaded at 00A50000h - 00A86000h
foo_dsp_crossfader              loaded at 00AA0000h - 00AF6000h
libmmd                          loaded at 00B00000h - 00DB1000h
MSVCR80                          loaded at 78130000h - 781CB000h
foo_dsp_delta                    loaded at 00DE0000h - 00DFE000h
foo_dsp_std                      loaded at 00E10000h - 00E51000h
foo_dsp_tube                    loaded at 00E70000h - 00E96000h
foo_dsp_vlevel                  loaded at 00EB0000h - 00ED4000h
foo_dsp_vst                      loaded at 00EF0000h - 00F10000h
foo_freedb2                      loaded at 00F20000h - 00F60000h
foo_fullscreen                  loaded at 00F70000h - 00F8B000h
foo_input_monkey                loaded at 00FA0000h - 00FEA000h
foo_input_mslive                loaded at 01000000h - 01076000h
WMVCore                          loaded at 07EB0000h - 080B0000h
wmidx                            loaded at 07650000h - 07679000h
WMASF                            loaded at 07270000h - 072AA000h
OLEAUT32                        loaded at 779A0000h - 77A3B000h
msdmo                            loaded at 01080000h - 01087000h
WININET                          loaded at 70200000h - 70296000h
CRYPT32                          loaded at 799D0000h - 79A5C000h
MSASN1                          loaded at 77400000h - 77411000h
urlmon                          loaded at 702B0000h - 7032A000h
VERSION                          loaded at 77810000h - 77817000h
LZ32                            loaded at 75940000h - 75946000h
MSACM32                          loaded at 773E0000h - 773F3000h
WINMM                            loaded at 77540000h - 77571000h
MSVFW32                          loaded at 6A770000h - 6A790000h
WSOCK32                          loaded at 74FC0000h - 74FC9000h
WS2_32                          loaded at 74FA0000h - 74FB4000h
WS2HELP                          loaded at 74F90000h - 74F98000h
DRMClien                        loaded at 08B20000h - 08B6F000h
foo_input_std                    loaded at 01530000h - 01643000h
foo_input_tak                    loaded at 01660000h - 016A7000h
tak_deco_lib                    loaded at 016B0000h - 016E1000h
foo_masstag                      loaded at 01810000h - 0185F000h
foo_masstag_addons              loaded at 01870000h - 0187E000h
foo_menu_addons                  loaded at 01880000h - 018CD000h
foo_playlist_bind                loaded at 018D0000h - 018F5000h
foo_playlist_manager            loaded at 01910000h - 01956000h
foo_random                      loaded at 01970000h - 019AF000h
foo_rgscan                      loaded at 019C0000h - 01A08000h
foo_runcmd                      loaded at 01A20000h - 01A4F000h
foo_sic                          loaded at 01A60000h - 01AB7000h
foo_uie_bookmarks                loaded at 01BD0000h - 01C1D000h
foo_uie_explorer                loaded at 01C30000h - 01C6C000h
foo_uie_queuemanager            loaded at 01C80000h - 01CB6000h
msvcm80                          loaded at 7C4C0000h - 7C53D000h
mscoree                          loaded at 79000000h - 79045000h
mscorwks                        loaded at 79E70000h - 7A3D1000h
mscorlib.ni                      loaded at 04030000h - 04B18000h
mscorjit                        loaded at 79060000h - 790B3000h
rsaenh                          loaded at 7CA00000h - 7CA23000h
USERENV                          loaded at 791A0000h - 79205000h
System.ni                        loaded at 7A440000h - 7ABFE000h
System.Drawing.ni                loaded at 7ADE0000h - 7AF74000h
Gdiplus                          loaded at 70D00000h - 70E91000h
foo_uie_quicksearch              loaded at 04FD0000h - 05016000h
foo_uie_tabs                    loaded at 05030000h - 0505A000h
foo_ui_columns                  loaded at 05070000h - 05107000h
foo_ui_panels                    loaded at 05120000h - 051FE000h
IMM32                            loaded at 75DF0000h - 75E0A000h
foo_utils                        loaded at 05210000h - 05249000h
CLBCATQ                          loaded at 784A0000h - 78530000h
cscui                            loaded at 77840000h - 7787F000h
CSCDLL                          loaded at 77090000h - 770B3000h
MPR                              loaded at 782F0000h - 78301000h
ntlanman                        loaded at 750D0000h - 750DC000h
NETAPI32                        loaded at 7CE20000h - 7CE73000h
DNSAPI                          loaded at 77970000h - 77994000h
NETRAP                          loaded at 75130000h - 75136000h
NTDSAPI                          loaded at 77BE0000h - 77BF1000h
WLDAP32                          loaded at 77940000h - 7796C000h
SECUR32                          loaded at 79430000h - 7943F000h
SAMLIB                          loaded at 750C0000h - 750D0000h
NETUI0                          loaded at 75180000h - 75195000h
NETUI1                          loaded at 75140000h - 75178000h
System.Windows.Forms.ni          loaded at 7AFD0000h - 7BC56000h
Msimg32                          loaded at 6B150000h - 6B155000h
Classic Flanger                  loaded at 09040000h - 09124000h
keyboard                        loaded at 099A0000h - 099B0000h
DSOUND                          loaded at 51080000h - 510DA000h
wdmaud                          loaded at 77530000h - 77538000h
msacm32                          loaded at 773D0000h - 773D8000h
imagehlp                        loaded at 77910000h - 77933000h
DBGHELP                          loaded at 72970000h - 7299D000h
Stack dump analysis:
Address: 77887EE0h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 00AD2F5Ch, location: "foo_dsp_crossfader", loaded at 00AA0000h - 00AF6000h
Address: 004A6FB2h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00442D3Ah, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0044518Ch, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 77885C09h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 77885DA7h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 778CE748h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 77885D6Fh, location: "ntdll", loaded at 77880000h - 77902000h
Address: 05210000h, location: "foo_utils", loaded at 05210000h - 05249000h
Address: 77E9C147h, location: "KERNEL32", loaded at 77E70000h - 77F30000h
Address: 7813231Ah, location: "MSVCR80", loaded at 78130000h - 781CB000h
Address: 778B2C0Ch, location: "ntdll", loaded at 77880000h - 77902000h
Address: 778B7E64h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 77883148h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 778CAE15h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 090C8664h, location: "Classic Flanger", loaded at 09040000h - 09124000h
Address: 778CB0FFh, location: "ntdll", loaded at 77880000h - 77902000h
Address: 778CB4BEh, location: "ntdll", loaded at 77880000h - 77902000h
Address: 778CB618h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 019C0000h, location: "foo_rgscan", loaded at 019C0000h - 01A08000h
Address: 779410FEh, location: "WLDAP32", loaded at 77940000h - 7796C000h
Address: 004C7008h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 77E700C8h, location: "KERNEL32", loaded at 77E70000h - 77F30000h
Address: 778ABDB6h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 77E70000h, location: "KERNEL32", loaded at 77E70000h - 77F30000h
Address: 7788DB62h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 7788DC33h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 7788DBE0h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 05231B5Ch, location: "foo_utils", loaded at 05210000h - 05249000h
Address: 77E9C100h, location: "KERNEL32", loaded at 77E70000h - 77F30000h
Address: 77881338h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 77E90B81h, location: "KERNEL32", loaded at 77E70000h - 77F30000h
Address: 77881370h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 090C60C8h, location: "Classic Flanger", loaded at 09040000h - 09124000h
Address: 77881650h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 77E7919Dh, location: "KERNEL32", loaded at 77E70000h - 77F30000h
Address: 09043C5Ah, location: "Classic Flanger", loaded at 09040000h - 09124000h
Address: 09043FC7h, location: "Classic Flanger", loaded at 09040000h - 09124000h
Address: 099A18A7h, location: "keyboard", loaded at 099A0000h - 099B0000h
Address: 099A0000h, location: "keyboard", loaded at 099A0000h - 099B0000h
Address: 099A1857h, location: "keyboard", loaded at 099A0000h - 099B0000h
Address: 7788806Ch, location: "ntdll", loaded at 77880000h - 77902000h
Address: 7788AB2Fh, location: "ntdll", loaded at 77880000h - 77902000h
Address: 77883A8Fh, location: "ntdll", loaded at 77880000h - 77902000h
Address: 77883A52h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 77881188h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 77891B93h, location: "ntdll", loaded at 77880000h - 77902000h
Address: 77891B9Bh, location: "ntdll", loaded at 77880000h - 77902000h
Address: 004C2BF8h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004AF20Dh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7CFE824Ch, location: "SHELL32", loaded at 7CF90000h - 7D1EC000h
Address: 00444FC5h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C2AD8h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 10002D87h, location: "shared", loaded at 10000000h - 10029000h
Symbol: "uPrintCrashInfo_SetDumpPath" (+000000A7h)
Address: 004AF228h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00444F67h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004A6749h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 77E7B388h, location: "KERNEL32", loaded at 77E70000h - 77F30000h
Address: 77EC1F54h, location: "KERNEL32", loaded at 77E70000h - 77F30000h
Address: 77E72B08h, location: "KERNEL32", loaded at 77E70000h - 77F30000h
Address: 00444F30h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00C80008h, location: "libmmd", loaded at 00B00000h - 00DB1000h
Symbol: "_csqrtq_f90" (+0017D6CCh)
Version info:
foobar2000 v0.9.4.3 beta
UNICODE
Additional info:
Gapless Crossfader 0.3 (Intel SSE)  (foo_dsp_crossfader)
Playlist Commandline Tools 0.0.1  (foo_cmd_playlist)
ReplayGain Scanner 2.0.2  (foo_rgscan)
CD Audio Decoder 2.1.1  (foo_cdda)
VLevel 20060324.0  (foo_dsp_vlevel)
VST bridge 0.40 Beta  (foo_dsp_vst)
Autoplaylist Manager 1.0  (foo_autoplaylist)
Panels UI 0.10.0 beta [Apr 22 2007 - 17:07:58]  (foo_ui_panels)
TAK Decoder 0.3.1  (foo_input_tak)
Menu Addons 0.3.9.3 (Intel SSE)  (foo_menu_addons)
mslive 0.3.7 (Intel SSE)  (foo_input_mslive)
Monkey's Audio decoder 2.1.2  (foo_input_monkey)
Playlist Manager 1.0  (foo_playlist_manager)
Tube Sound 0.8  (foo_dsp_tube)
Standard DSP array 1.0  (foo_dsp_std)
Explorer Tree 1.04.6b  (foo_uie_explorer)
Masstagger Addons 0.3.3  (foo_masstag_addons)
freedb Tagger 0.5.2a  (foo_freedb2)
Converter 1.0.1  (foo_converter)
FLAC Decoder 1.1.0  (foo_input_std)
WMA Decoder 1.1  (foo_input_std)
Columns UI 0.1.3 beta 1v7  (foo_ui_columns)
Common services 0.1  (foo_common)
foosic music database 1.0 beta 11  (foo_sic)
Randomized playlist entry 1.2.3  (foo_random)
LPCM <--> delta-PCM converter 0.1.1  (foo_dsp_delta)
Playlist Bind 2.2  (foo_playlist_bind)
Masstagger 1.6  (foo_masstag)
Fullscreen 0.3.1  (foo_fullscreen)
Queue manager panel 0.2.2  (foo_uie_queuemanager)
cwbowron's title format hooks 1.1.1 [May  4 2007 - 12:39:47]  (foo_cwb_hooks)
Playlist tools 0.5.7  (foo_utils)
Bookmarks 0.2.3  (foo_uie_bookmarks)
foobar2000 core 0.9.4.3 beta  (Core)
Tabbed panel modified 0.2.5  (foo_uie_tabs)
Quick Search Toolbar 2.8k  (foo_uie_quicksearch)
Run Command 1.0 beta 1  (foo_runcmd)
foo_dsp_vst
ears
I'm using ProcessReplacing method of VST plugin, there is no additional buffers in my host - current audio chunk passes directly to VST plugin. It seems, that I use methods of  suspending and resuming VST processing incorrectly, thanks.
   About supporting 0.83 – may be later, when this plugin will come more usable.
Squeller
VST chains are available under MultiFXVST chainer: http://www.kvraudio.com/get/1068.html. It is doubtful, that I’ll can implement such functionality in recent time.
Yes, it’s the firs item in my to-do list.
I’ll check it.
foo_dsp_vst
The chainer is a workaround for GUIless VST as well.
Hey, btw, with your plugin ppl. are now able to produce cleaner and richer hi fidelity sound, with the great Anechoic Room Simulator, http://bram.smartelectronix.com/plugins.php?id=5.
foo_dsp_vst
WOW!! Thank you so much Squeller for that Anechoic Room Simulator. My music are cleaner and feel more smooth now
Man.. aren't this a bit old trick :-)
foo_dsp_vst
How do you make it work. I have both the dll of foo_dsp_vst and the dll of Anechoic Room Simulator, but by putting both of them in the components directory doesnt work. any help?
foo_dsp_vst
in DSP manager. add VST bridge to the chain. and configure it.
browse to the DLL of the VST plugin file. and you are good to go
Plugin that Squeller post are so awsome! You won't believe what you are hearing!!
oh and Thanks CannibalZerg for this plugin.
foo_dsp_vst
Ok found out how to use it now. Yet with the one squeller gave i dont see any sound difference (i am using shure SE530PTH earphones). Am i deaf
foo_dsp_vst
Oh, you need to check your technical/human gear. The ARS is BTW not a plugin for testing if foo_dsp_vst works. Use any other out of the millions (see kvraudio.com); ARS can only be enjoyed by the fines ears alive.
foo_dsp_vst
Squeller
please what is the difference with ARS and without?
because i can't hear nothing
Music is my first love.
foo_dsp_vst
GOOD NEWS
Regarding bit identical output, it's no problem having your vst wrapper and the above mentioned (empty) MultiFXVST chainer in the dsp chain: The output is bit identical, I tested by converting to wav (with and without the dsps in the chain) and compared via foo_bitcompare.
EDIT: The output is bit identical, if the MultiFXVST chain is empty. If plugins are loaded, but toggled off, the output is not identical.
This is great, because this way we can access the vst chainer as an additional main effect central directly via command and leave it always in the dsp chain.
Minor improvevent
If the vst editor is in the background and I click "view -> show vst editor", nothing happens. It should come to front.
foo_dsp_vst
Cannibal,
Thanks for the great plugin. Been waiting for this for a while. I would also to throw my request in the hat for a port to .83 as well. I do realtime equalizer/crossover through .83's recorder function, and would love to add some VST stuff without doing the Winamp DSP bridge.
foo_dsp_vst
Can we get a rehost please? I am very interested in trying this out.
foo_dsp_vst
This looks like an older, buggier version. It does open the vst window at fb2k startup even is foo_dsp_vst is not in the vst chain. The latest dll does not have this bug...
foo_dsp_vst
CannibalZerg, you are the greatest!!!
Thank you so much! I've been waiting for this for ages...
Finally I can use the wonderful Antares Tube with Foobar. Due to its copy protection it doesn't work with vista. Having paid for it that's really annoying. Gladly there is a cracked version by Arctic floating around which runs just fine with Vista, Foobar, and your plugin.
foo_dsp_vst
can you post this please?
foo_dsp_vst
I am running a lynxone with asio in fb 0.9.4.4, and am finding that when i am running the vst plugin, if I stop the track then foobar crashes.  maybe you might want to look into this, and if you need any more details, then just ask...
 Illegal operation:
Code: C0000005h, flags: 00000000h, address: 6BF03149h
Access violation, operation: read, address: 6BF03149h
Call path:
Registers:
EAX: 00000001, EBX: 00156DF0, ECX: 025CFF5C, EDX: 7C90EB94
ESI: 00000001, EDI: 00000800, EBP: 025CFFA8, ESP: 025CFF78
Unable to identify crash location
Loaded modules:
ntdll                            loaded at 7C900000h - 7C9B0000h
kernel32                         loaded at 7C800000h - 7C8F5000h
COMCTL32                         loaded at 773D0000h - 774D3000h
msvcrt                           loaded at 77C10000h - 77C68000h
ADVAPI32                         loaded at 77DD0000h - 77E6B000h
RPCRT4                           loaded at 77E70000h - 77F01000h
GDI32                            loaded at 77F10000h - 77F57000h
USER32                           loaded at 7E410000h - 7E4A0000h
SHLWAPI                          loaded at 77F60000h - 77FD6000h
SHELL32                          loaded at 7C9C0000h - 7D1D5000h
ole32                            loaded at 774E0000h - 7761D000h
comdlg32                         loaded at 763B0000h - 763F9000h
IMM32                            loaded at 76390000h - 763AD000h
uxtheme                          loaded at 5AD70000h - 5ADA8000h
MSCTF                            loaded at 74720000h - 7476B000h
RTSUltraMonHook                  loaded at 18800000h - 18836000h
msctfime                         loaded at 755C0000h - 755EE000h
foo_abx                          loaded at 00EC0000h - 00EF3000h
foo_albumlist                    loaded at 00F20000h - 00F67000h
OLEAUT32                         loaded at 77120000h - 771AB000h
foo_cdda                         loaded at 00F90000h - 00FC5000h
foo_converter                    loaded at 00FF0000h - 01059000h
foo_dsp_std                      loaded at 01080000h - 010C1000h
foo_dsp_tube                     loaded at 010F0000h - 01116000h
foo_dsp_vst                      loaded at 01130000h - 01152000h
foo_freedb2                      loaded at 01180000h - 011C0000h
foo_input_std                    loaded at 011E0000h - 012F2000h
foo_masstag                      loaded at 01320000h - 01370000h
foo_out_asio                     loaded at 01390000h - 013BF000h
foo_rgscan                       loaded at 013E0000h - 01428000h
foo_ui_columns                   loaded at 01450000h - 014F6000h
foo_ui_std                       loaded at 01520000h - 01577000h
foo_unpack                       loaded at 015A0000h - 015CE000h
RTSUltraMonHookRes               loaded at 18900000h - 18903000h
MSIMG32                          loaded at 76380000h - 76385000h
mslbui                           loaded at 605D0000h - 605D9000h
CLBCATQ                          loaded at 76FD0000h - 7704F000h
COMRes                           loaded at 77050000h - 77115000h
VERSION                          loaded at 77C00000h - 77C08000h
WS2_32                           loaded at 71AB0000h - 71AC7000h
WS2HELP                          loaded at 71AA0000h - 71AA8000h
mswsock                          loaded at 71A50000h - 71A8F000h
hnetcfg                          loaded at 662B0000h - 66308000h
wshtcpip                         loaded at 71A90000h - 71A98000h
appHelp                          loaded at 77B40000h - 77B62000h
cscui                            loaded at 77A20000h - 77A74000h
CSCDLL                           loaded at 76600000h - 7661D000h
browseui                         loaded at 75F80000h - 7607D000h
USERENV                          loaded at 769C0000h - 76A73000h
SETUPAPI                         loaded at 77920000h - 77A13000h
ntshrui                          loaded at 76990000h - 769B5000h
ATL                              loaded at 76B20000h - 76B31000h
NETAPI32                         loaded at 5B860000h - 5B8B4000h
ieframe                          loaded at 42EF0000h - 434BB000h
PSAPI                            loaded at 76BF0000h - 76BFB000h
iertutil                         loaded at 42990000h - 429D5000h
shdocvw                          loaded at 77760000h - 778D0000h
CRYPT32                          loaded at 77A80000h - 77B14000h
MSASN1                           loaded at 77B20000h - 77B32000h
CRYPTUI                          loaded at 754D0000h - 75550000h
WINTRUST                         loaded at 76C30000h - 76C5E000h
IMAGEHLP                         loaded at 76C90000h - 76CB8000h
WININET                          loaded at 42C10000h - 42CDF000h
Normaliz                         loaded at 02390000h - 02399000h
WLDAP32                          loaded at 76F60000h - 76F8C000h
xpsp2res                         loaded at 20000000h - 202C5000h
zipfldr                          loaded at 73380000h - 733D7000h
NBShell                          loaded at 01FD0000h - 01FE4000h
MFC71U                           loaded at 7C250000h - 7C352000h
MSVCR71                          loaded at 02B10000h - 02B66000h
MSVCP71                          loaded at 7C3A0000h - 7C41B000h
MFC71ENU                         loaded at 5D360000h - 5D36E000h
rarext                           loaded at 02000000h - 02029000h
NTMARTA                          loaded at 77690000h - 776B1000h
SAMLIB                           loaded at 71BF0000h - 71C03000h
iZotope Ozone 3                  loaded at 63920000h - 63C93000h
urlmon                           loaded at 42CF0000h - 42E14000h
DVDShell                         loaded at 51980000h - 5198D000h
SASSEH                           loaded at 03830000h - 03844000h
Secur32                          loaded at 77FE0000h - 77FF1000h
LINKINFO                         loaded at 76980000h - 76988000h
MPR                              loaded at 71B20000h - 71B32000h
drprov                           loaded at 75F60000h - 75F67000h
ntlanman                         loaded at 71C10000h - 71C1E000h
NETUI0                           loaded at 71CD0000h - 71CE7000h
NETUI1                           loaded at 71C90000h - 71CD0000h
NETRAP                           loaded at 71C80000h - 71C87000h
davclnt                          loaded at 75F70000h - 75F79000h
gdiplus                          loaded at 4EC50000h - 4EDF3000h
PortableDeviceApi                loaded at 10930000h - 10979000h
MSGINA                           loaded at 75970000h - 75A67000h
WINSTA                           loaded at 76360000h - 76370000h
ODBC32                           loaded at 74320000h - 7435D000h
odbcint                          loaded at 02370000h - 02387000h
sti                              loaded at 73BA0000h - 73BB3000h
CFGMGR32                         loaded at 74AE0000h - 74AE7000h
fsshext.8.1.0178.00              loaded at 5A500000h - 5A54E000h
msi                              loaded at 7D1E0000h - 7D49E000h
ContextMenu                      loaded at 03D00000h - 03DA6000h
WINSPOOL                         loaded at 73000000h - 73026000h
MFC80U                           loaded at 782E0000h - 783EF000h
MSVCP80                          loaded at 7C420000h - 7C4A7000h
MFC80ENU                         loaded at 04DD0000h - 04DDE000h
SASCTXMN                         loaded at 04DF0000h - 04DFF000h
shext                            loaded at 04E00000h - 04F08000h
ShExtRes                         loaded at 04F10000h - 04F13000h
PFSE120                          loaded at 38480000h - 38496000h
PFIM120EN                        loaded at 383D0000h - 383DA000h
PWRISOSH                         loaded at 04F20000h - 04F57000h
FILETE~1                         loaded at 05070000h - 05145000h
7-zipn                           loaded at 05270000h - 05293000h
mydocs                           loaded at 72410000h - 7242A000h
shdoclc                          loaded at 052D0000h - 05358000h
DBGHELP                          loaded at 59A60000h - 59B01000h
foo_dsp_vst
Now I am backing to fall in love with foobar2000, I think this is the best dsp plugin for it.
I am using just the Aixcoustic Creations Electri-Q (posihfopit edition) and I am loving.
The latest version is the 0.60beta?
foo_dsp_vst
To robcalm
Yes, I notice that with fb2k v0.9.4.4 my plugin have occasional crashes at startup. And now I have your report about another crush at stopping playback. I'll try to fix it as far as it possible.
About ASIO output plugin: I'm still using ASIO only with fb2k v.0.9.4.2, due to annoying pauses after playback stop (about 1.5 - 2 sec with 100% CPU usage).
foo_dsp_vst
Hello,
Just a bug report. I cannot see and use my vst ( an equalizer ). When I click view.
