That option read into lead in/out is on its own, it is a checkbox, SCSI & Windows internal fall under communication. Regardless...
> that SCSI Pass through interferes with/disables FUA from working at all. If you have SPT enabled
Windows XP has SPT as default, you cannot uninstall it. There exists demon tools which inserts something into the middle of programs accessing SPT and the drive, that is causing the FUA to stop working. SPT is normally the best you can use, much better than ASPI.
Did you try the USB plextor on SPT?
Ok, here's an update:
1st, you are correct in that I was confused with regards to the SPTI option (thank you for clarifying that it is independent of the overread options), I wasn't aware this was an integral part of WinXP, but rather thought that it was only something added by Daemon tools, which I in fact, had installed, but had uninstalled, as well as removed the SPTI pass through "filter driver" or whatever that Daemon Tools adds.
Yes, I did try the USB plextor with SPT, in secure mode with the settings that you've recommended on this site (as can be seen in the logs also). But it nonetheless errors out every time, I even tried changing a setting and added some spin-up time to it, tried it without overread, etc --all to no avail.
The external PX-716UF however will rip in Burst mode, and it even shows to get accurate results against accuraterip database. Switching back to secure mode though, it refuses to read a single track (see the LBA erros in my above log). Initially, my PX-716UF had had firmware revision 1.04U flashed to it. This is what had been on it during all my tests. Just prior to this post here, I flashed it to the latest 1.10 firmware, and the flash was successful and was in no way interrupted.
I rebooted my PC as standard procedure then proceeded to test it again, only to get the same errors reading every single track in secure mode, with a clean, scratch, and DRM free disc.
BUT OMG Spoon now the plot thickens!!! =)
---->C2 Error Pointers for Error Detection The PX-716A is is supposed to support C2 yes? Because guess what, **unchecking** the C2 option, for the 1st time, the external drive ripped the entire CD in secure mode, but it will not do so with C2 enabled, and this is with firmware v1.10, the latest. Included are the logs from a different, scratch-free, non-copy protected CD.
1st log = PX-716UF using C2 Drive I
2nd log= PX-716UF *without* C2 Drive I
3rd log= PX-716SA *using* C2 Drive G
Possible issue with my drive, or your program have an issue with enabling C2 on an external PX-716UF? And if so, how could there possibly *just* be a problem with the C2 of the drive to such a severe extent that it totally errors out but yet all other functions work fine? Thank you for your assistance.
dBpowerAMP Release 12 Alpha 7 Digital Audio Extraction Log from Thursday, October 19, 2006 2:49 PM
Drive & Settings
Ripping with drive 'I: [PLEXTOR - DVDR PX-716A ]', Drive offset: 30, Overread Lead-in/out: Yes
AccurateRip: Active, Using C2: Yes, Cache: None, FUA Cache Invalidate: Yes
Pass 1 Drive Speed: Max, Pass 2 Drive Speed: Max
Ultra:: Vary Drive Speed: No, Min Passes: 1, Max Passes: 6, Finish After Clean Passes: 1
Bad Sector Re-rip:: Drive Speed: Max, Maximum Re-reads: 700
Encoder: Wave -compression="PCM"
Extraction Log
Track 1: ERROR Ripping LBA 0 to 20640 (4:35) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 01 - Reckoning Day.wav
Unable to read CD, check CD disc (frame LBA 0)
Track 2: ERROR Ripping LBA 20640 to 36092 (3:26) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 02 - Train of Consequences.wav
Unable to read CD, check CD disc (frame LBA 20640)
Track 3: ERROR Ripping LBA 36092 to 60585 (5:26) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 03 - Addicted to Chaos.wav
Unable to read CD, check CD disc (frame LBA 36092)
Track 4: ERROR Ripping LBA 60585 to 80682 (4:27) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 04 - A Tout le Monde.wav
Unable to read CD, check CD disc (frame LBA 60585)
Track 5: ERROR Ripping LBA 80682 to 98942 (4:03) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 05 - Elysian Fields.wav
Unable to read CD, check CD disc (frame LBA 80682)
Track 6: ERROR Ripping LBA 98942 to 116770 (3:57) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 06 - The Killing Road.wav
Unable to read CD, check CD disc (frame LBA 98942)
Track 7: ERROR Ripping LBA 116770 to 134585 (3:57) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 07 - Blood of Heroes.wav
Unable to read CD, check CD disc (frame LBA 116770)
Track 8: ERROR Ripping LBA 134585 to 153137 (4:07) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 08 - Family Tree.wav
Unable to read CD, check CD disc (frame LBA 134585)
Track 9: ERROR Ripping LBA 153137 to 171867 (4:09) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 09 - Youthanasia.wav
Unable to read CD, check CD disc (frame LBA 153137)
Track 10: ERROR Ripping LBA 171867 to 188712 (3:44) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 10 - I Thought I Knew It All.wav
Unable to read CD, check CD disc (frame LBA 171867)
Track 11: ERROR Ripping LBA 188712 to 205147 (3:39) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 11 - Black Curtains.wav
Unable to read CD, check CD disc (frame LBA 188712)
Track 12: ERROR Ripping LBA 205147 to 225157 (4:26) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 12 - Victory.wav
Unable to read CD, check CD disc (frame LBA 205147)
12 Tracks Could Not Be Ripped
dBpowerAMP Release 12 Alpha 7 Digital Audio Extraction Log from Thursday, October 19, 2006 2:50 PM
Drive & Settings
AccurateRip: Active, Using C2: No, Cache: None, FUA Cache Invalidate: Yes
Extraction Log
Track 1: Ripped LBA 0 to 20640 (4:35) in 0:14. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 01 - Reckoning Day.wav
AccurateRip: Accurate (confidence 10) [Pass 1]
CRC32: F69C517A
Track 2: Ripped LBA 20640 to 36092 (3:26) in 0:09. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 02 - Train of Consequences.wav
CRC32: 0A60AFD1
Track 3: Ripped LBA 36092 to 60585 (5:26) in 0:14. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 03 - Addicted to Chaos.wav
CRC32: 36487E2E
Track 4: Ripped LBA 60585 to 80682 (4:27) in 0:10. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 04 - A Tout le Monde.wav
CRC32: EF1EFF9C
Track 5: Ripped LBA 80682 to 98942 (4:03) in 0:09. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 05 - Elysian Fields.wav
CRC32: 13734873
Track 6: Ripped LBA 98942 to 116770 (3:57) in 0:08. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 06 - The Killing Road.wav
CRC32: 6C333F8E
Track 7: Ripped LBA 116770 to 134585 (3:57) in 0:08. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 07 - Blood of Heroes.wav
CRC32: 11245D01
Track 8: Ripped LBA 134585 to 153137 (4:07) in 0:08. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 08 - Family Tree.wav
CRC32: 337BB47C
Track 9: Ripped LBA 153137 to 171867 (4:09) in 0:07. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 09 - Youthanasia.wav
CRC32: 0117DC77
Track 10: Ripped LBA 171867 to 188712 (3:44) in 0:06. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 10 - I Thought I Knew It All.wav
CRC32: D7DD7B56
Track 11: Ripped LBA 188712 to 205147 (3:39) in 0:06. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 11 - Black Curtains.wav
CRC32: BD2FA571
Track 12: Ripped LBA 205147 to 225157 (4:26) in 0:07. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 12 - Victory.wav
CRC32: 9FF48970
12 Tracks Ripped Accurately
dBpowerAMP Release 12 Alpha 7 Digital Audio Extraction Log from Thursday, October 19, 2006 2:59 PM
Drive & Settings
Ripping with drive 'G: [PLEXTOR - DVDR PX-716A ]', Drive offset: 30, Overread Lead-in/out: Yes
Extraction Log
CRC32: F69C517A
CRC32: 0A60AFD1
CRC32: 36487E2E
CRC32: EF1EFF9C
CRC32: 13734873
CRC32: 6C333F8E
CRC32: 11245D01
CRC32: 337BB47C
CRC32: 0117DC77
CRC32: D7DD7B56
CRC32: BD2FA571
CRC32: 9FF48970
