Topic: Secure Ripper Test (part 2 concise results) (Read 145654 times) previous topic - next topic
Reply #325
I noticed this problem has occurred to others before but not sure if a solution was found.  I am trying to use my USB connected drive to rip CD's but at some point the drive "disappears".  That is, it is no longer available to R12 and no longer exists in windows explorer.  If I disconnect and re-connect the drive it reappears (in windows at least).  I don't have this problem with EAC.  Error information as follows:
Information ripping to mp3 (Lame), 'Track 2' to 'G:\Albums\12th Man - 2006 - Boned!\Disc 1\02 The Golf Course.mp3'
  Track 2:  Ripped LBA 27924 to 35911 (1:46) in 0:05. Filename: G:\Albums\12th Man - 2006 - Boned!\Disc 1\02 The Golf Course.mp3
    AccurateRip: Accurate (confidence 1)    [Pass 1]
    CRC32: CBA8AD61
Information ripping to mp3 (Lame), 'Track 1' to 'G:\Albums\12th Man - 2006 - Boned!\Disc 1\01 The Boning.mp3'
  Track 1:  Ripped LBA 0 to 27924 (6:12) in 0:22. Filename: G:\Albums\12th Man - 2006 - Boned!\Disc 1\01 The Boning.mp3
    CRC32: 4D1F0056
Information ripping to mp3 (Lame), 'Track 3' to 'G:\Albums\12th Man - 2006 - Boned!\Disc 1\03 The Dream.mp3'
  Track 3:  Ripped LBA 35911 to 63622 (6:09) in 0:22. Filename: G:\Albums\12th Man - 2006 - Boned!\Disc 1\03 The Dream.mp3
    CRC32: E12F5E3B
Information ripping to mp3 (Lame), 'Track 5' to 'G:\Albums\12th Man - 2006 - Boned!\Disc 1\05 The Shithole 1.mp3'
  Track 5:  ERROR Ripping LBA 108143 to 126572 (4:05) in 0:10. Filename: G:\Albums\12th Man - 2006 - Boned!\Disc 1\05 The Shithole 1.mp3
  Unable to read CD, check CD disc (frame LBA 108195  ripping 26 frames  track end LBA 126572)
Information ripping to mp3 (Lame), 'Track 6' to 'G:\Albums\12th Man - 2006 - Boned!\Disc 1\06 Alan Jones Radio Show.mp3'
  Track 6:  ERROR Ripping LBA 126572 to 169957 (9:38) in 0:00. Filename: G:\Albums\12th Man - 2006 - Boned!\Disc 1\06 Alan Jones Radio Show.mp3
  Unable to read CD, check CD disc (frame LBA 126572  ripping 26 frames  track end LBA 169957)
Information ripping to mp3 (Lame), 'Track 7' to 'G:\Albums\12th Man - 2006 - Boned!\Disc 1\07 The Shithole 2.mp3'
  Track 7:  ERROR Ripping LBA 169957 to 210004 (8:53) in 0:00. Filename: G:\Albums\12th Man - 2006 - Boned!\Disc 1\07 The Shithole 2.mp3
  Unable to read CD, check CD disc (frame LBA 169957  ripping 26 frames  track end LBA 210004)
Information ripping to mp3 (Lame), 'Track 8' to 'G:\Albums\12th Man - 2006 - Boned!\Disc 1\08 The Gabba.mp3'
  Track 8:  ERROR Ripping LBA 210004 to 349080 (30:54) in 0:00. Filename: G:\Albums\12th Man - 2006 - Boned!\Disc 1\08 The Gabba.mp3
  Unable to read CD, check CD disc (frame LBA 210004  ripping 26 frames  track end LBA 349080)
Information ripping to mp3 (Lame), 'Track 4' to 'G:\Albums\12th Man - 2006 - Boned!\Disc 1\04 Team Meeting 1.mp3'
  Track 4:  Ripped LBA 63622 to 108143 (9:53) in 0:32. Filename: G:\Albums\12th Man - 2006 - Boned!\Disc 1\04 Team Meeting 1.mp3
    CRC32: 4D3A7969
Can anyone help?
spockman.
Reply #326
I updated my drive's firmware and then my drive stopped disappearing. But then it wouldn't burn DVDs anymore (CDRs were ok). Luckily there was an intermediate firmware that I could go to where everything worked -- both the disappearing issue and DVD burning issues were gone.
Reply #327
Thanks singaiya.  I've just updated the firmware but alas I still have the same problem.  Back to EAC for now....
Reply #328
Seems that I am having problems with Plextor PX-230A connected over USB. I am able to rip with EAC in secure mode all the time, but with dBpowerAMP, sometime it works, but most of the time it doesn't. The drive spins up a bit but the progress bar of the first track remains at 0 and after a couple of minutes, I get an error that reading at LBA 1 or something like that failed.
Edit: Log:
Error ripping to WavPack, 'Track 1' to 'C:\Dokumente und Einstellungen\Sebastian\Eigene Dateien\Eigene Musik\Verschiedene\Die Hit Giganten - Disco Hits\Disc 2\01 Patrick Hernandez - Born To Be Alive.wv'
  Unable to read CD, check CD disc (frame LBA 1  ripping 26 frames  track end LBA 14405)  [clRipperSecure::Rip]
Don't have this problem with my LG E10L that is an external unit by design.
Another funny thing is that dBpowerAMP doesn't recognize that a CD was ejected or inserted when using the PX-230A. I will try with the unit connected via IDE once my new Seagate HDD is here.
Reply #332
I have a disc that EAC and Plextools can rip, but dbPowerAmp can not. This disc is not copy protected. Plextools positively flew through the disc, taking ~9 mins for two rips while EAC took just over 20 to Test and Copy.
Plextor PX-708A
EAC: Secure mode, C2.
Plextools: Secure (Recover the best sectors (least errors). CD ripped twice and binary file compare carried out to ensure consistency. Also compared output to EAC, they were identical.
dbPowerAmp Secure mode, C2. No C2 and Burst mode at a reduced speed showed the same problems, no log to show for bust mode.
EAC log
EAC extraction logfile from 26. January 2007, 11:20 for CD
Robert Palmer / Don't Explain C2
Used drive  : PLEXTOR DVDR  PX-708A  Adapter: 1  ID: 0
Read mode  : Secure with C2, accurate stream, disable cache
Combined read/write offset correction : 0
Overread into Lead-In and Lead-Out : Yes
Used output format : Internal WAV Routines
                    44.100 Hz; 16 Bit; Stereo
Other options      :
    Delete leading and trailing silent blocks : No
    Native Win32 interface for Win NT & 2000
Track  1
    Filename N:\converted\tracks\Don't Explain C2\Robert Palmer (1990) Don't Explain C2\01. Your Mother Should Have Told You.wav
    Peak level 99.9 %
    Track quality 100.0 %
    Test CRC 3E6590C9
    Copy CRC 3E6590C9
    Copy OK
Track  2
    Filename N:\converted\tracks\Don't Explain C2\Robert Palmer (1990) Don't Explain C2\02. Light-years.wav
    Peak level 100.0 %
    Test CRC E55BAFC7
    Copy CRC E55BAFC7
    Copy OK
Track  3
    Filename N:\converted\tracks\Don't Explain C2\Robert Palmer (1990) Don't Explain C2\03. You Can't Get Enough Of A Good Thing.wav
    Peak level 100.0 %
    Test CRC 5F09C77A
    Copy CRC 5F09C77A
    Copy OK
Track  4
    Filename N:\converted\tracks\Don't Explain C2\Robert Palmer (1990) Don't Explain C2\04. Dreams To Remember.wav
    Peak level 93.9 %
    Test CRC C76CEB2F
    Copy CRC C76CEB2F
    Copy OK
Track  5
    Filename N:\converted\tracks\Don't Explain C2\Robert Palmer (1990) Don't Explain C2\05. You're Amazing.wav
    Peak level 91.8 %
    Track quality 99.9 %
    Test CRC 0FD27E2F
    Copy CRC 0FD27E2F
    Copy OK
Track  6
    Filename N:\converted\tracks\Don't Explain C2\Robert Palmer (1990) Don't Explain C2\06. Mess Around.wav
    Peak level 100.0 %
    Test CRC 16367978
    Copy CRC 16367978
    Copy OK
Track  7
    Filename N:\converted\tracks\Don't Explain C2\Robert Palmer (1990) Don't Explain C2\07. Happiness.wav
    Peak level 99.9 %
    Test CRC F8456CA2
    Copy CRC F8456CA2
    Copy OK
Track  8
    Filename N:\converted\tracks\Don't Explain C2\Robert Palmer (1990) Don't Explain C2\08. History.wav
    Peak level 100.0 %
    Test CRC 1674D5F2
    Copy CRC 1674D5F2
    Copy OK
Track  9
    Filename N:\converted\tracks\Don't Explain C2\Robert Palmer (1990) Don't Explain C2\09. I'll Be Your Baby Tonight.wav
    Peak level 100.0 %
    Test CRC A615F8C4
    Copy CRC A615F8C4
    Copy OK
Track 10
    Filename N:\converted\tracks\Don't Explain C2\Robert Palmer (1990) Don't Explain C2\10. Housework.wav
    Peak level 100.0 %
    Test CRC 2406D485
    Copy CRC 2406D485
    Copy OK
Track 11
    Filename N:\converted\tracks\Don't Explain C2\Robert Palmer (1990) Don't Explain C2\11. Mercy Mercy Me , I Want You.wav
    Peak level 100.0 %
    Test CRC CE777039
    Copy CRC CE777039
    Copy OK
Track 12
    Filename N:\converted\tracks\Don't Explain C2\Robert Palmer (1990) Don't Explain C2\12. Don't Explain.wav
    Peak level 75.9 %
    Test CRC 8A2CF353
    Copy CRC 8A2CF353
    Copy OK
Track 13
    Filename N:\converted\tracks\Don't Explain C2\Robert Palmer (1990) Don't Explain C2\13. Aeroplane.wav
    Peak level 100.0 %
    Test CRC 6CE0823E
    Copy CRC 6CE0823E
    Copy OK
Track 14
    Filename N:\converted\tracks\Don't Explain C2\Robert Palmer (1990) Don't Explain C2\14. People Will Say We're In Love.wav
    Peak level 99.9 %
    Track quality 99.8 %
    Test CRC BB1148EB
    Copy CRC BB1148EB
    Copy OK
Track 15
    Filename N:\converted\tracks\Don't Explain C2\Robert Palmer (1990) Don't Explain C2\15. Not A Word.wav
    Peak level 83.3 %
    Test CRC B8383435
    Copy CRC B8383435
    Copy OK
Track 16
    Filename N:\converted\tracks\Don't Explain C2\Robert Palmer (1990) Don't Explain C2\16. Top 40.wav
    Peak level 100.0 %
    Test CRC 23B52435
    Copy CRC 23B52435
    Copy OK
Track 17
    Filename N:\converted\tracks\Don't Explain C2\Robert Palmer (1990) Don't Explain C2\17. You're So Desirable.wav
    Peak level 100.0 %
    Test CRC 9C587A50
    Copy CRC 9C587A50
    Copy OK
Track 18
    Filename N:\converted\tracks\Don't Explain C2\Robert Palmer (1990) Don't Explain C2\18. You're My Thrill.wav
    Peak level 95.8 %
    Test CRC D6BA6C95
    Copy CRC D6BA6C95
    Copy OK
No errors occured
End of status report
dbPowerAmp log, see tracks 1, 11, 12 and 16
dBpoweramp Release 12 Digital Audio Extraction Log from 25 January 2007 8:13 PM
Drive & Settings
Ripping with drive 'F:  [PLEXTOR  - DVDR  PX-708A  ]',  Drive offset: 30,  Overread Lead-in/out: Yes
AccurateRip: Active,  Using C2: Yes,  Cache: 583 KB,  FUA Cache Invalidate: Yes
Pass 1 Drive Speed: Max,  Pass 2 Drive Speed: 4
Ultra::  Vary Drive Speed: Yes,  Min Passes: 2,  Max Passes: 10,  Finish After Clean Passes: 2
Bad Sector Re-rip::  Drive Speed: Max,  Maximum Re-reads: 34
Encoder: WavPack
Extraction Log
Track 1:  ERROR Ripping LBA 0 to 16547 (3:40) in 2:14. Filename: N:\converted\tracks\Don't Explain (2003)\01. Your Mother Should Have Told You.wv
Unable to read CD, check CD disc (frame LBA 12324  ripping 26 frames  track end LBA 16547)
Track 2:  Ripped LBA 16547 to 36535 (4:26) in 1:59. Filename: N:\converted\tracks\Don't Explain (2003)\02. Light Years.wv
  Secure  [Pass 1, Ultra 1 to 2]
  CRC32: EB081ADE
Track 3:  Ripped LBA 36535 to 55140 (4:08) in 1:50. Filename: N:\converted\tracks\Don't Explain (2003)\03. You Can't Get Enough Of A Good Thing.wv
  CRC32: 653C577C
User Stopped Ripping
dBpoweramp Release 12 Digital Audio Extraction Log from 26 January 2007 9:27 AM
Drive & Settings
Encoder: WavPack
Extraction Log
Track 1:  ERROR Ripping LBA 0 to 16547 (3:40) in 1:58. Filename: N:\converted\tracks\Don't Explain (2003)\01. Your Mother Should Have Told You.wv
Unable to read CD, check CD disc (frame LBA 12376  ripping 26 frames  track end LBA 16547)
Track 2:  Ripped LBA 16547 to 36535 (4:26) in 2:00. Filename: N:\converted\tracks\Don't Explain (2003)\02. Light Years.wv
  CRC32: EB081ADE
  CRC32: 653C577C
Track 4:  Ripped LBA 55140 to 75007 (4:24) in 1:58. Filename: N:\converted\tracks\Don't Explain (2003)\04. Dreams To Remember.wv
  CRC32: FE37D474
Track 5:  Ripped LBA 75007 to 92192 (3:49) in 1:44. Filename: N:\converted\tracks\Don't Explain (2003)\05. You're Amazing.wv
  CRC32: 4D71C234
Track 6:  Ripped LBA 92192 to 113977 (4:50) in 2:27. Filename: N:\converted\tracks\Don't Explain (2003)\06. Mess Around.wv
  Secure (Warning)  [Pass 1, Ultra 1 to 2, Re-Rip 281 Frames]
  CRC32: 1DD55648
    Re-rip Frame: 94126 (00:00:25.786) matched 10 / 11
    Re-rip Frame: 94127 (00:00:25.800) matched 10 / 11
    Re-rip Frame: 95906 (00:00:49.520) matched 10 / 11
    Re-rip Frame: 96045 (00:00:51.373) matched 10 / 11
    Re-rip Frame: 96046 (00:00:51.386) matched 10 / 11
    Re-rip Frame: 96143 (00:00:52.680) matched 10 / 11
    Re-rip Frame: 96226 (00:00:53.786) matched 10 / 11
    Re-rip Frame: 96227 (00:00:53.800) matched 10 / 11
    Re-rip Frame: 96268 (00:00:54.346) matched 10 / 11
    Re-rip Frame: 96352 (00:00:55.466) matched 10 / 11
    Re-rip Frame: 96366 (00:00:55.653) matched 10 / 11
    Re-rip Frame: 96394 (00:00:56.026) matched 10 / 11
    Re-rip Frame: 96491 (00:00:57.320) matched 10 / 11
    Re-rip Frame: 96492 (00:00:57.333) matched 10 / 11
    Re-rip Frame: 96519 (00:00:57.693) matched 10 / 11
    Re-rip Frame: 96520 (00:00:57.706) matched 10 / 11
    Re-rip Frame: 96575 (00:00:58.440) matched 10 / 11
    Re-rip Frame: 96589 (00:00:58.626) matched 10 / 11
    Re-rip Frame: 96590 (00:00:58.640) matched 10 / 11
    Re-rip Frame: 96631 (00:00:59.186) matched 10 / 11
    Re-rip Frame: 96632 (00:00:59.200) matched 10 / 11
    Re-rip Frame: 96659 (00:00:59.560) matched 10 / 11
    Re-rip Frame: 96673 (00:00:59.746) matched 10 / 11
    Re-rip Frame: 96771 (00:01:01.053) matched 10 / 11
    Re-rip Frame: 96841 (00:01:01.986) matched 10 / 11
    Re-rip Frame: 96897 (00:01:02.733) matched 10 / 11
    Re-rip Frame: 96966 (00:01:03.653) matched 10 / 11
    Re-rip Frame: 96967 (00:01:03.666) matched 10 / 11
    Re-rip Frame: 96980 (00:01:03.840) matched 10 / 11
    Re-rip Frame: 97022 (00:01:04.400) matched 10 / 11
    Re-rip Frame: 97023 (00:01:04.413) matched 10 / 11
    Re-rip Frame: 97106 (00:01:05.520) matched 10 / 11
    Re-rip Frame: 97107 (00:01:05.533) matched 10 / 11
    Re-rip Frame: 97120 (00:01:05.706) matched 10 / 11
    Re-rip Frame: 97121 (00:01:05.720) matched 10 / 11
    Re-rip Frame: 97148 (00:01:06.080) matched 10 / 11
    Re-rip Frame: 97149 (00:01:06.093) matched 10 / 11
    Re-rip Frame: 97162 (00:01:06.266) matched 10 / 11
    Re-rip Frame: 97204 (00:01:06.826) matched 10 / 11
    Re-rip Frame: 97233 (00:01:07.213) matched 10 / 11
    Re-rip Frame: 97246 (00:01:07.386) matched 10 / 11
    Re-rip Frame: 97274 (00:01:07.760) matched 10 / 11
    Re-rip Frame: 97275 (00:01:07.773) matched 10 / 11
    Re-rip Frame: 97288 (00:01:07.946) matched 10 / 11
    Re-rip Frame: 97302 (00:01:08.133) matched 10 / 11
    Re-rip Frame: 97303 (00:01:08.146) matched 10 / 11
    Re-rip Frame: 97316 (00:01:08.320) matched 10 / 11
    Re-rip Frame: 97330 (00:01:08.506) matched 10 / 11
    Re-rip Frame: 97372 (00:01:09.066) matched 10 / 11
    Re-rip Frame: 97428 (00:01:09.813) matched 10 / 11
    Re-rip Frame: 97429 (00:01:09.826) matched 10 / 11
    Re-rip Frame: 97470 (00:01:10.373) matched 10 / 11
    Re-rip Frame: 97471 (00:01:10.386) matched 10 / 11
    Re-rip Frame: 97512 (00:01:10.933) matched 10 / 11
    Re-rip Frame: 97513 (00:01:10.946) matched 10 / 11
    Re-rip Frame: 97540 (00:01:11.306) matched 10 / 11
    Re-rip Frame: 97596 (00:01:12.053) matched 10 / 11
    Re-rip Frame: 97610 (00:01:12.240) matched 10 / 11
    Re-rip Frame: 97652 (00:01:12.800) matched 10 / 11
    Re-rip Frame: 97694 (00:01:13.360) matched 10 / 11
    Re-rip Frame: 97695 (00:01:13.373) matched 10 / 11
    Re-rip Frame: 97722 (00:01:13.733) matched 10 / 11
    Re-rip Frame: 97723 (00:01:13.746) matched 10 / 11
    Re-rip Frame: 97750 (00:01:14.106) matched 10 / 11
    Re-rip Frame: 97751 (00:01:14.120) matched 10 / 11
    Re-rip Frame: 97764 (00:01:14.293) matched 10 / 11
    Re-rip Frame: 97765 (00:01:14.306) matched 10 / 11
    Re-rip Frame: 97778 (00:01:14.480) matched 10 / 11
    Re-rip Frame: 97779 (00:01:14.493) matched 10 / 11
    Re-rip Frame: 97820 (00:01:15.040) matched 10 / 11
    Re-rip Frame: 97821 (00:01:15.053) matched 10 / 11
    Re-rip Frame: 97848 (00:01:15.413) matched 10 / 11
    Re-rip Frame: 97849 (00:01:15.426) matched 10 / 11
    Re-rip Frame: 97876 (00:01:15.786) matched 10 / 11
    Re-rip Frame: 97877 (00:01:15.800) matched 10 / 11
    Re-rip Frame: 97890 (00:01:15.973) matched 10 / 11
    Re-rip Frame: 97891 (00:01:15.986) matched 10 / 11
    Re-rip Frame: 97904 (00:01:16.160) matched 10 / 11
    Re-rip Frame: 97905 (00:01:16.173) matched 10 / 11
    Re-rip Frame: 97918 (00:01:16.346) matched 10 / 11
    Re-rip Frame: 97919 (00:01:16.360) matched 10 / 11
    Re-rip Frame: 97932 (00:01:16.533) matched 10 / 11
    Re-rip Frame: 97933 (00:01:16.546) matched 10 / 11
    Re-rip Frame: 97946 (00:01:16.720) matched 10 / 11
    Re-rip Frame: 98017 (00:01:17.666) matched 10 / 11
    Re-rip Frame: 98045 (00:01:18.040) matched 10 / 11
    Re-rip Frame: 98087 (00:01:18.600) matched 10 / 11
    Re-rip Frame: 98115 (00:01:18.973) matched 10 / 11
    Re-rip Frame: 98157 (00:01:19.533) matched 10 / 11
    Re-rip Frame: 98171 (00:01:19.720) matched 10 / 11
    Re-rip Frame: 98199 (00:01:20.093) matched 10 / 11
    Re-rip Frame: 98227 (00:01:20.466) matched 10 / 11
    Re-rip Frame: 98241 (00:01:20.653) matched 10 / 11
    Re-rip Frame: 98255 (00:01:20.840) matched 10 / 11
    Re-rip Frame: 98269 (00:01:21.026) matched 10 / 11
    Re-rip Frame: 98297 (00:01:21.400) matched 10 / 11
    Re-rip Frame: 98325 (00:01:21.773) matched 10 / 11
    Re-rip Frame: 98326 (00:01:21.786) matched 10 / 11
    Re-rip Frame: 98339 (00:01:21.960) matched 10 / 11
    Re-rip Frame: 98340 (00:01:21.973) matched 10 / 11
    Re-rip Frame: 98353 (00:01:22.146) matched 10 / 11
    Re-rip Frame: 98354 (00:01:22.160) matched 10 / 11
    Re-rip Frame: 98367 (00:01:22.333) matched 10 / 11
    Re-rip Frame: 98368 (00:01:22.346) matched 10 / 11
    Re-rip Frame: 98395 (00:01:22.706) matched 10 / 11
    Re-rip Frame: 98396 (00:01:22.720) matched 10 / 11
    Re-rip Frame: 98409 (00:01:22.893) matched 10 / 11
    Re-rip Frame: 98410 (00:01:22.906) matched 10 / 11
    Re-rip Frame: 98423 (00:01:23.080) matched 10 / 11
    Re-rip Frame: 98424 (00:01:23.093) matched 10 / 11
    Re-rip Frame: 98437 (00:01:23.266) matched 10 / 11
    Re-rip Frame: 98452 (00:01:23.466) matched 10 / 11
    Re-rip Frame: 98494 (00:01:24.026) matched 10 / 11
    Re-rip Frame: 98522 (00:01:24.400) matched 10 / 11
    Re-rip Frame: 98536 (00:01:24.586) matched 10 / 11
    Re-rip Frame: 98564 (00:01:24.960) matched 10 / 11
    Re-rip Frame: 98578 (00:01:25.146) matched 10 / 11
    Re-rip Frame: 98592 (00:01:25.333) matched 10 / 11
    Re-rip Frame: 98593 (00:01:25.346) matched 10 / 11
    Re-rip Frame: 98634 (00:01:25.893) matched 10 / 11
    Re-rip Frame: 98648 (00:01:26.080) matched 10 / 11
    Re-rip Frame: 98662 (00:01:26.266) matched 10 / 11
    Re-rip Frame: 98663 (00:01:26.280) matched 10 / 11
    Re-rip Frame: 98676 (00:01:26.453) matched 10 / 11
    Re-rip Frame: 98733 (00:01:27.213) matched 10 / 11
    Re-rip Frame: 98747 (00:01:27.400) matched 10 / 11
    Re-rip Frame: 98760 (00:01:27.573) matched 10 / 11
    Re-rip Frame: 98761 (00:01:27.586) matched 10 / 11
    Re-rip Frame: 98775 (00:01:27.773) matched 10 / 11
    Re-rip Frame: 98789 (00:01:27.960) matched 10 / 11
    Re-rip Frame: 98817 (00:01:28.333) matched 10 / 11
    Re-rip Frame: 98845 (00:01:28.706) matched 10 / 11
    Re-rip Frame: 98846 (00:01:28.720) matched 10 / 11
    Re-rip Frame: 98859 (00:01:28.893) matched 10 / 11
    Re-rip Frame: 98860 (00:01:28.906) matched 10 / 11
    Re-rip Frame: 98873 (00:01:29.080) matched 10 / 11
    Re-rip Frame: 98916 (00:01:29.653) matched 10 / 11
    Re-rip Frame: 98929 (00:01:29.826) matched 10 / 11
    Re-rip Frame: 98930 (00:01:29.840) matched 10 / 11
    Re-rip Frame: 98943 (00:01:30.013) matched 10 / 11
    Re-rip Frame: 98944 (00:01:30.026) matched 10 / 11
    Re-rip Frame: 98957 (00:01:30.200) matched 10 / 11
    Re-rip Frame: 98958 (00:01:30.213) matched 10 / 11
    Re-rip Frame: 98985 (00:01:30.573) matched 10 / 11
    Re-rip Frame: 98986 (00:01:30.586) matched 10 / 11
    Re-rip Frame: 99000 (00:01:30.773) matched 10 / 11
    Re-rip Frame: 99014 (00:01:30.960) matched 10 / 11
    Re-rip Frame: 99028 (00:01:31.146) matched 10 / 11
    Re-rip Frame: 99042 (00:01:31.333) matched 10 / 11
    Re-rip Frame: 99070 (00:01:31.706) matched 10 / 11
    Re-rip Frame: 99098 (00:01:32.080) matched 10 / 11
    Re-rip Frame: 99099 (00:01:32.093) matched 10 / 11
    Re-rip Frame: 99140 (00:01:32.640) matched 10 / 11
    Re-rip Frame: 99141 (00:01:32.653) matched 10 / 11
    Re-rip Frame: 99253 (00:01:34.146) matched 10 / 11
    Re-rip Frame: 99281 (00:01:34.520) matched 10 / 11
    Re-rip Frame: 99295 (00:01:34.706) matched 10 / 11
    Re-rip Frame: 99309 (00:01:34.893) matched 10 / 11
    Re-rip Frame: 99310 (00:01:34.906) matched 10 / 11
    Re-rip Frame: 99323 (00:01:35.080) matched 10 / 11
    Re-rip Frame: 99324 (00:01:35.093) matched 10 / 11
    Re-rip Frame: 99365 (00:01:35.640) matched 10 / 11
    Re-rip Frame: 99366 (00:01:35.653) matched 10 / 11
    Re-rip Frame: 99408 (00:01:36.213) matched 10 / 11
    Re-rip Frame: 99450 (00:01:36.773) matched 10 / 11
    Re-rip Frame: 99451 (00:01:36.786) matched 10 / 11
    Re-rip Frame: 99478 (00:01:37.146) matched 10 / 11
    Re-rip Frame: 99492 (00:01:37.333) matched 10 / 11
    Re-rip Frame: 99493 (00:01:37.346) matched 10 / 11
    Re-rip Frame: 99577 (00:01:38.466) matched 10 / 11
    Re-rip Frame: 99633 (00:01:39.213) matched 10 / 11
    Re-rip Frame: 99661 (00:01:39.586) matched 10 / 11
    Re-rip Frame: 99662 (00:01:39.600) matched 10 / 11
    Re-rip Frame: 99704 (00:01:40.160) matched 10 / 11
    Re-rip Frame: 99718 (00:01:40.346) matched 10 / 11
    Re-rip Frame: 99788 (00:01:41.280) matched 10 / 11
    Re-rip Frame: 99789 (00:01:41.293) matched 10 / 11
    Re-rip Frame: 99816 (00:01:41.653) matched 10 / 11
    Re-rip Frame: 99817 (00:01:41.666) matched 10 / 11
    Re-rip Frame: 99830 (00:01:41.840) matched 10 / 11
    Re-rip Frame: 99831 (00:01:41.853) matched 10 / 11
    Re-rip Frame: 99845 (00:01:42.040) matched 10 / 11
    Re-rip Frame: 99859 (00:01:42.226) matched 10 / 11
    Re-rip Frame: 99873 (00:01:42.413) matched 10 / 11
    Re-rip Frame: 99887 (00:01:42.600) matched 10 / 11
    Re-rip Frame: 99915 (00:01:42.973) matched 10 / 11
    Re-rip Frame: 100014 (00:01:44.293) matched 10 / 11
    Re-rip Frame: 100028 (00:01:44.480) matched 10 / 11
    Re-rip Frame: 100113 (00:01:45.613) matched 10 / 11
    Re-rip Frame: 100127 (00:01:45.800) matched 10 / 11
    Re-rip Frame: 100155 (00:01:46.173) matched 10 / 11
    Re-rip Frame: 100169 (00:01:46.360) matched 10 / 11
    Re-rip Frame: 100170 (00:01:46.373) matched 10 / 11
    Re-rip Frame: 100183 (00:01:46.546) matched 10 / 11
    Re-rip Frame: 100184 (00:01:46.560) matched 10 / 11
    Re-rip Frame: 100197 (00:01:46.733) matched 10 / 11
    Re-rip Frame: 100198 (00:01:46.746) matched 10 / 11
    Re-rip Frame: 100296 (00:01:48.053) matched 10 / 11
    Re-rip Frame: 100297 (00:01:48.066) matched 10 / 11
    Re-rip Frame: 100310 (00:01:48.240) matched 10 / 11
    Re-rip Frame: 100324 (00:01:48.426) matched 10 / 11
    Re-rip Frame: 100325 (00:01:48.440) matched 10 / 11
    Re-rip Frame: 100338 (00:01:48.613) matched 10 / 11
    Re-rip Frame: 100339 (00:01:48.626) matched 10 / 11
    Re-rip Frame: 100367 (00:01:49.000) matched 10 / 11
    Re-rip Frame: 100381 (00:01:49.186) matched 10 / 11
    Re-rip Frame: 100437 (00:01:49.933) matched 10 / 11
    Re-rip Frame: 100438 (00:01:49.946) matched 10 / 11
    Re-rip Frame: 100465 (00:01:50.306) matched 10 / 11
    Re-rip Frame: 100466 (00:01:50.320) matched 10 / 11
    Re-rip Frame: 100536 (00:01:51.253) matched 10 / 11
    Re-rip Frame: 100578 (00:01:51.813) matched 10 / 11
    Re-rip Frame: 100607 (00:01:52.200) matched 10 / 11
    Re-rip Frame: 100748 (00:01:54.080) matched 10 / 11
    Re-rip Frame: 100749 (00:01:54.093) matched 10 / 11
    Re-rip Frame: 100762 (00:01:54.266) matched 10 / 11
    Re-rip Frame: 100889 (00:01:55.960) matched 10 / 11
    Re-rip Frame: 100890 (00:01:55.973) matched 10 / 11
    Re-rip Frame: 100904 (00:01:56.160) matched 10 / 11
    Re-rip Frame: 100918 (00:01:56.346) matched 10 / 11
    Re-rip Frame: 100960 (00:01:56.906) matched 10 / 11
    Re-rip Frame: 101045 (00:01:58.040) matched 10 / 11
    Re-rip Frame: 101173 (00:01:59.746) matched 10 / 11
    Re-rip Frame: 101201 (00:02:00.120) matched 10 / 11
    Re-rip Frame: 101243 (00:02:00.680) matched 10 / 11
    Re-rip Frame: 101244 (00:02:00.693) matched 10 / 11
    Re-rip Frame: 101257 (00:02:00.866) matched 10 / 11
    Re-rip Frame: 101258 (00:02:00.880) matched 10 / 11
    Re-rip Frame: 101314 (00:02:01.626) matched 10 / 11
    Re-rip Frame: 101357 (00:02:02.200) matched 10 / 11
    Re-rip Frame: 101441 (00:02:03.320) matched 10 / 11
    Re-rip Frame: 101555 (00:02:04.840) matched 10 / 11
    Re-rip Frame: 101767 (00:02:07.666) matched 10 / 11
    Re-rip Frame: 101768 (00:02:07.680) matched 10 / 11
    Re-rip Frame: 101994 (00:02:10.693) matched 10 / 11
    Re-rip Frame: 101995 (00:02:10.706) matched 10 / 11
    Re-rip Frame: 102023 (00:02:11.080) matched 10 / 11
    Re-rip Frame: 102179 (00:02:13.160) matched 10 / 11
    Re-rip Frame: 102221 (00:02:13.720) matched 10 / 11
    Re-rip Frame: 102222 (00:02:13.733) matched 10 / 11
    Re-rip Frame: 102292 (00:02:14.666) matched 10 / 11
    Re-rip Frame: 102293 (00:02:14.680) matched 10 / 11
    Re-rip Frame: 102434 (00:02:16.560) matched 10 / 11
    Re-rip Frame: 102435 (00:02:16.573) matched 10 / 11
    Re-rip Frame: 102534 (00:02:17.893) matched 10 / 11
    Re-rip Frame: 102662 (00:02:19.600) matched 10 / 11
    Re-rip Frame: 102747 (00:02:20.733) matched 10 / 11
    Re-rip Frame: 102748 (00:02:20.746) matched 10 / 11
    Re-rip Frame: 102889 (00:02:22.626) matched 10 / 11
    Re-rip Frame: 102890 (00:02:22.640) matched 10 / 11
    Re-rip Frame: 103373 (00:02:29.080) matched 10 / 11
    Re-rip Frame: 103402 (00:02:29.466) matched 10 / 11
    Re-rip Frame: 104415 (00:02:42.973) matched 10 / 11
    Re-rip Frame: 104543 (00:02:44.680) matched 10 / 11
    Re-rip Frame: 104672 (00:02:46.400) matched 10 / 11
    Re-rip Frame: 105015 (00:02:50.973) matched 10 / 11
    Re-rip Frame: 105016 (00:02:50.986) matched 10 / 11
    Re-rip Frame: 106967 (00:03:17.000) matched 10 / 11
    Re-rip Frame: 107125 (00:03:19.106) matched 10 / 11
    Re-rip Frame: 107456 (00:03:23.520) matched 10 / 11
    Re-rip Frame: 107687 (00:03:26.600) matched 10 / 11
    Re-rip Frame: 108004 (00:03:30.826) matched 10 / 11
    Re-rip Frame: 108019 (00:03:31.026) matched 10 / 11
    Re-rip Frame: 108062 (00:03:31.600) matched 10 / 11
    Re-rip Frame: 108076 (00:03:31.786) matched 10 / 11
    Re-rip Frame: 108077 (00:03:31.800) matched 10 / 11
    Re-rip Frame: 108091 (00:03:31.986) matched 10 / 11
    Re-rip Frame: 108120 (00:03:32.373) matched 10 / 11
    Re-rip Frame: 108784 (00:03:41.226) matched 10 / 11
    Re-rip Frame: 108813 (00:03:41.613) matched 10 / 11
    Re-rip Frame: 109117 (00:03:45.666) matched 10 / 11
    Re-rip Frame: 109276 (00:03:47.786) matched 10 / 11
    Re-rip Frame: 109291 (00:03:47.986) matched 10 / 11
    Re-rip Frame: 109320 (00:03:48.373) matched 10 / 11
    Re-rip Frame: 109580 (00:03:51.840) matched 10 / 11
    Re-rip Frame: 109581 (00:03:51.853) matched 10 / 11
    Re-rip Frame: 110059 (00:03:58.226) matched 10 / 11
    Re-rip Frame: 110378 (00:04:02.480) matched 10 / 11
    Re-rip Frame: 110379 (00:04:02.493) matched 10 / 11
    Re-rip Frame: 110408 (00:04:02.880) matched 10 / 11
    Re-rip Frame: 110640 (00:04:05.973) matched 10 / 11
Track 7:  Ripped LBA 113977 to 126887 (2:52) in 1:17. Filename: N:\converted\tracks\Don't Explain (2003)\07. Happiness.wv
  CRC32: 22F123AD
Track 8:  Ripped LBA 126887 to 147287 (4:32) in 2:01. Filename: N:\converted\tracks\Don't Explain (2003)\08. History.wv
  CRC32: F68684B3
Track 9:  Ripped LBA 147287 to 162700 (3:25) in 1:32. Filename: N:\converted\tracks\Don't Explain (2003)\09. I'll Be Your Baby Tonight.wv
  CRC32: C3698C36
Track 10:  Ripped LBA 162700 to 177117 (3:12) in 1:26. Filename: N:\converted\tracks\Don't Explain (2003)\10. Housework.wv
  CRC32: DA002864
Track 11:  ERROR Ripping LBA 177117 to 204042 (5:59) in 2:56. Filename: N:\converted\tracks\Don't Explain (2003)\11. Mercy Mercy Me-I Want You.wv
Unable to read CD, check CD disc (frame LBA 200907  ripping 26 frames  track end LBA 204042)
Track 12:  ERROR Ripping LBA 204042 to 215122 (2:27) in 0:47. Filename: N:\converted\tracks\Don't Explain (2003)\12. Don't Explain.wv
Unable to read CD, check CD disc (frame LBA 205966  ripping 26 frames  track end LBA 215122)
Track 13:  Ripped LBA 215122 to 228960 (3:04) in 1:23. Filename: N:\converted\tracks\Don't Explain (2003)\13. Aeroplane.wv
  CRC32: 9A6CBE72
Track 14:  Ripped LBA 228960 to 239430 (2:19) in 1:03. Filename: N:\converted\tracks\Don't Explain (2003)\14. People Will Say We're in Love.wv
  CRC32: D0985B5B
Track 15:  Ripped LBA 239430 to 258815 (4:18) in 1:55. Filename: N:\converted\tracks\Don't Explain (2003)\15. Not a Word.wv
  CRC32: 55DDFDDA
Track 16:  ERROR Ripping LBA 258815 to 270777 (2:39) in 0:44. Filename: N:\converted\tracks\Don't Explain (2003)\16. Top 40.wv
Unable to read CD, check CD disc (frame LBA 259855  ripping 26 frames  track end LBA 270777)
Track 17:  Ripped LBA 270777 to 281620 (2:24) in 1:06. Filename: N:\converted\tracks\Don't Explain (2003)\17. You're So Desirable.wv
  CRC32: 46C47FD1
Track 18:  Ripped LBA 281620 to 299485 (3:58) in 1:46. Filename: N:\converted\tracks\Don't Explain (2003)\18. You're My Thrill.wv
  CRC32: C0D877B7
18 Tracks Ripped: 13 Secure, 1 Secure (Warning), 0 Could Not Be Ripped
Anything I can try here spoon?
daefeatures.co.uk
Reply #334
My post states that disabling C2 did not help.
no C2
dBpoweramp Release 12 Digital Audio Extraction Log from 26 January 2007 11:35 AM
Drive & Settings
dBpoweramp Release 12 Digital Audio Extraction Log from 26 January 2007 11:41 AM
Drive & Settings
AccurateRip: Active,  Using C2: No,  Cache: 583 KB,  FUA Cache Invalidate: Yes
Encoder: WavPack
Extraction Log
Track 11:  ERROR Ripping LBA 177117 to 204042 (5:59) in 2:50. Filename: N:\converted\tracks\Don't Explain no C2 (2003 12 23)\11. Mercy Mercy Me-I Want You.wv
Unable to read CD, check CD disc (frame LBA 201167  ripping 26 frames  track end LBA 204042)
Track 12:  ERROR Ripping LBA 204042 to 215122 (2:27) in 0:45. Filename: N:\converted\tracks\Don't Explain no C2 (2003 12 23)\12. Don't Explain.wv
Track 16:  ERROR Ripping LBA 258815 to 270777 (2:39) in 1:11. Filename: N:\converted\tracks\Don't Explain no C2 (2003 12 23)\16. Top 40.wv
Unable to read CD, check CD disc (frame LBA 259933  ripping 26 frames  track end LBA 270777)
3 Tracks Could Not Be Ripped
edit: All combinations with FUA/C2 on and off don't help either.
daefeatures.co.uk
Reply #335
Anything special about the connection to 708a? (it is odd as I have a 708a), which Windows version?
Reply #336
evereux, do you have accuraterip installed with EAC? If so did it report the tracks as accurate? If you dont have it installed can you install it with EAC and try the rip again in EAC?
Reply #337
The drive is the master on a IDE channel with a NEC1300A as slave. The operating system is XP Pro 64, motherboard an Asus A8N32-Sli Deluxe.
This disc is old and needed cleaning before I started the rip.
Interestingly, I've since tried ripping this disc with my NEC which resulted in a secure rip. The drive speed was set to maximum speed and dbPowerAmp had to re-rip many many frames. The log would have hit 1MB (all reporting on) if I hadn't slowed down the extraction for the last few tracks. I blame the drive for this, not dbPowerAmp at all.
Slowing the Plextor down to 4x helped me extract track 11 with the Plextor but still no go with 12 and 16. Something very strange is going on with the Plextor and dbPowerAmp.
Eli, yes, but the disc has no accurate rip submission.
daefeatures.co.uk
Reply #338
Thats unfortunate. While its a VERY long shot, I was wondering if there may have been consistent errors on the disc that dbpoweramp was picking up, that eac and plextools were accepting... Had the other tracks been accurate by accuraterip, and the tracks of interest been inaccurate in EAC then that would most likely have been the case. Is it possible to get another copy of the disc the should be the same pressing?
Reply #339
The LBA read failure is where dBpoweramp asks the drive to read a section of the cd, and the cd drive says 'no can do', really no cd drive should ever do this, even with a destroyed cd (it should return the error in c2).
Reply #340
EAC and Plextools seem to have no problem going back to read a section upon errors. If my drive is defective, how do they manage this when dbPowerAmp can not?
daefeatures.co.uk
Reply #341
I have a PX-W8432T that I'm trying to configure with dbPowerAmp (same system as above, drive is slave to 708A). I had a key disc inserted and dbPowerAmp would fail to configure itself for this drive. dbPowerAmp  would freeze (actually, the whole OS, even EAC hasn't managed that yet ) until ejected the disc and dbPowerAmp would then say that this wasn't a key disc. This happened several times with several discs.
I went through the process with EAC which went smoothly. EAC spun the drive up which I didn't hear dbPowerAmp do. Whilst the drive was still spinning I tried again with dbPowerAmp, this time it worked.
The same goes for when I try to rip a CD. dbPowerAmp just freezes. It doesn't seem to be able to spin up this drive.
Sorry to bend your ear again but thought you might like to know.
edit: swapped it out for a PX-W4012A and no such problem.
daefeatures.co.uk
