Topic: Secure Ripper Test (part 2 concise results) (Read 145760 times) previous topic - next topic
Reply #125
12 tracks that are 'V accurate(5)' en two of them are 'X AR (21) i Secure'.
Did either of these tracks require re-reads?  If so, I'd say that they are probably not accurate.
Reply #126
This looks very promising. I'm using it at this moment with a PX-716UF on a disc that I had given up for dead and it is ripping it accurately.
I have a very minor feature request: Can you add the cddb/freedb-style eight-character disc ID as a File Naming Element? Or better yet, the 28-character CD index as used by Musicbrainz? Or both?
I already have my own backend process for encoding audio and editing and storing metadata but I would like to use this as a front end for ripping. I have managed to script EAC to be a front end using AutoIt and I'm hoping it will not be difficult to do the same thing with this. Using a disc ID for a directory name instead of artist/title will make it easier to feed into this process.
Reply #127
Yes both required a reread of 1 frame.
Track 7:  Ripped LBA 127682 to 148392 (4:36) in 1:29. Filename: D:\My Documents\My Music\U2\...
...U2 - The Best of 1980-1990 - 07 - Where the Streets Have No Name.wav
AccurateRip: Inaccurate (confidence 21)  Secure (Warning)  [Pass 1, Ultra 1 to 1, Re-Rip 1 Frames]
CRC32: ABF87DF7
Re-rip Frame: 148392 (00:04:36,133) matched 10 / 11
Track 12:  Ripped LBA 214092 to 233450 (4:18) in 1:21. Filename: D:\My Documents\My Music\U2\...
...U2 - The Best of 1980-1990 - 12 - When Love Comes to Town.wav
AccurateRip: Inaccurate (confidence 20)  Secure (Warning)  [Pass 1, Ultra 1 to 1, Re-Rip 1 Frames]
CRC32: 8ED24E57
Re-rip Frame: 233450 (00:04:18,106) matched 10 / 11
Reply #128
So you mean to ask how secure is spoon's new ripper?  I can't answer that but can suggest that you see what EAC does with the track.  Make sure you have it enabled to use null samples in CRC calculations and you can compare the CRCs directly (provided the drive is offset corrected in EAC).
This http://users.pandora.be/satcp/eac-qs-en.htm#options says...
Also make sure the top four options match the settings from the screenshot below.
Mike
Reply #129
Unchecked.
@Scidd0w:
1 frame isn't much to re-rip, but you could be getting a consistent error.  I see you're also using C2.  I'm not sure what to say about this.  Spoon's seemed to have changed his opinion (and code?) regarding C2 since he first announced the software.  I'm curious to see what he has to say.  Did you also try EAC?
Reply #130
Spoon, I know dMC is still in alpha, but in your opinion is it ready to start being used for archiving?? Any outstanding issues with the flac encoder?
Reply #131
eli:
None that I know, the ripper is almost complete and for flac you can use the verify option after ripping.
eb:
you can add the freedb id (or cddb id) to the id tag.
Reply #132
Consistent errors and non are the thing to worry about here.  When they both can be implemented, reliably then we are good to go.  If you use the new ripper without a drive that does GOOD c2 detection, then the only benifit besides Spoons interface, is the interpolation, which will make some errors inaudible.  But if you have a drive with good c2 detection, and use this ripper with ultra passes, c2, and re rip then yes, TRUST THE GREEN CHECK =))))  then theres accurateRip, plus when its there.  Nessesary if you don't have c2 in my mind...
Have fun!!!
Thank Spoon!
  Spoon???
is the logic, that was first implemented and in your test still completely there?
Reply #133
I did some more testing with my small sampling of problem discs using my PX-716A.  I have to say that I too am becomming a believer, especially with the C2 performance.  There is still one more disc I want to try to see how well it does compared to PlexTools, but so far it is beating out EAC.  I have to think this is because of the use of C2 during re-reads.
I did not get these kinds of results with r5.
Unfortunately I still can't use C2 with my Sony CDU5221.
Great job Spoon!
Reply #135
FUA...best option to use for my drive or should i just use the 36KB cache?
FUA has really only been tested on the Plextors, 36kb would be safer.
I have a cd that has 12 tracks that are 'V accurate(5)' en two of them are 'X AR (21) i Secure'. If I rip those tracks in burst mode they are ripped as 'V accurate(4)! What is better to use and can someone please explain to me what 'X AR (21) i Secure' means?
If you rip twice in secure what are the CRCs (enable that column by right clicking on ripping status at the top. If you rip twice in burst what are the crcs?
is there logic, that was first implemented and in your test still completely there?
Through out my testing (with how c2 is implemented in R12) c2 only did good, the thing to remember about c2 detection is it is an unknown quantity across drives, some might not report all errors, I see it as an extra help, not a hinderance no matter which drive it is on.
Reply #136
Ok, I tested a problem track, track 7 (Where The Streets Have No Name) from the CD (U2 - The Best Of 1980-1990) some more. I ripped it 5 times with different tools and settings.
One remarkable thing is that for the 1st time the secure with c2 setting ended with a secure rip and corresponding CRC. (I ripped this track with this setting for over 10 times.)
<update>
An other remark is that EAC says the drive does not cache after its drive features test while dMC says the cache is 36KB.
</update>
Player: Sony DRU-510a (1.1a)
Tools: dMC-r12-alpha7 & EAC V0.95 prebeta 3
CRC's:
87D6958C  - X AR (21) I Secure
ABF87DF7 - V Accurate(4)
	dMC-r12-alpha7	dMC-r12-alpha7	dMC-r12-alpha7	EAC		EAC burst
Secure C2 Secure No C2 Burst No C2 C2
1st run ABF87DF7 87D6958C 87D6958C 87D6958C 87D6958C
2nd run 87D6958C 87D6958C 87D6958C 87D6958C 87D6958C
3rd run ABF87DF7 87D6958C 87D6958C 87D6958C 87D6958C
4th run ABF87DF7 87D6958C 87D6958C 87D6958C 87D6958C
5th run ABF87DF7 87D6958C 87D6958C 87D6958C 87D6958C
Reply #137
what exactly does the "i" report again spoon?
Reply #138
EAC does not need to flush the cache for drives that use less than ~63kB.  This is why it says that it doesn't cache.
Reply #139
I use a BenQ DW-1650 to rip my CD collection, I use these settings in R12.
What do you think of my settings? Would you change any of them to get better results?
Reply #140
I would put max re reads at 700 like spoon said.  Did you detect cache for that drive?  Are you sure you want interpolation?
I would buy a good c2 capable drive for 50 bucks and use that.  The gain in eliminating consistent errors is worth it.
Reply #141
I ran the "Detect Cache" option for this drive and got this result;
"Drive does not appear to cache, no cache clearing will be used."
"Detected cache size 0 KB (0 frames)."
I thought the interpolation option was meant for drives with no C2 like mine? What are the downsides of using interpolation with this drive?
Reply #142
Hello,
I am using the current dMC-r12-alpha7 version of this program on Windows XP Pro SP2
This program is very interesting, and looks like something I will use soon.  A few caveats exist however that I have come across, in addition I have a few questions.
The Read into Lead-in Lead-out option has 2 options listed:  1) SCSI Pass through (SPT), and 2) Windows Internal [for limited accounts],
I am using a Plextor PX-716SA, as well as a Plextor PX-716UF, they support overreading into lead in and lead out
Option 2 is not an option as it states that C2 error reporting nor FUA cache clear would be avialable.
Option 1 is also a non-option for use with Plextor drives, because it is now known (and can even be tested with dBpowerAMP) that SCSI Pass through interferes with/disables FUA from working at all.  If you have SPT enabled (and installed of course) and you do the FUA test, it will show that the drive does not support it (the separate cache test also reports the PX-716SA/UF as having a cache of 1173KB).  When you uninstall SPT via the run command "sptdinst_x86.exe remove" followed by a reboot--both drives show that the support FUA, and subsequently, once enabled, doing the cache test will reveal that the cache is 0KB (this coming after a popup box I believe that stated that no audio cd was detected however. --strange)
Thinking a litte bit I though to myself "Isn't an ASPI layer supposed to be at play here somewhere?"  As it is with EAC (Exact Audio Copy) for example.  Well here's where things get very weird.  1st of all, using my internal PX-716SA on CD "Dry Kill Logic -The Dead And Dreaming" wiht dBpowerAMP (FUA DISABLED, using SPT --you will see why in a minute why I chose those options).  The disc extracts correctly (and quickly I might add-impressive as far as speed is concerned) without errors (log included at bottom).
Switching to using my external USB 2.0 Plextor PX-716UF with the same settings results in massive errors (log included below).  My External drive is working fine, is almost brand new, and also works perfectly with plextools or EAC.  It is plugged directly into a USB 2.0 port in the back of my PC.
In contemplating what to do to resolve this issue, I downloaded the NERO ASPI layer, the same one which is used and recommened for EAC by "The Uber Standard".  I placed this file wnaspi32.dll v 2.0.1.74 Win32 nero ASPI library, within C:\Program Files\Illustrate\dBpowerAMP.
I figured this might have a shot at the weird errors, thinking that the SCSI pass through would not work through a USB 2.0 interface.  Once this was done I re-opened dBpowerAMP and what happened is ALL of the drive letters for my 4 CD/DVD-RW drives showed up with THE SAME DRIVE LETTER, that being "F".  No drive would recognize an audio CD, it would just constantly refresh the pop-up box if I tried to click "Retry".  Nothing is wrong with the allocation of my drive letters as confirmed by Logical Disk Manager in Administrative Tools, Computer Management.  I figured that it must be something that exists simply because it is still alpha software, and is a bug that will be worked out.
ONly problem with that however is the fact that someone here had previously posted that they had successfully extracted an audio CD using the external PX-716UF.  Here are the logs so you can see what has happened, perhaps there's something that I am overlooking or not doing correctly, but like I said, it does work fine with my Internal drive using the exact same settings except that I had detected the cache for the external drive (with SPT, and hence, no capability of using FUA for now -nothing works using the Nero ASPI layer).
dBpowerAMP Release 12 Alpha 7 Digital Audio Extraction Log from Thursday, October 19, 2006 11:02 AM
Drive & Settings
Ripping with drive 'G:  [PLEXTOR  - DVDR  PX-716A  ]',  Drive offset: 30,  Overread Lead-in/out: Yes
AccurateRip: Active,  Using C2: Yes,  Cache: None,  FUA Cache Invalidate: No
Pass 1 Drive Speed: Max,  Pass 2 Drive Speed: Max
Ultra::  Vary Drive Speed: No,  Min Passes: 1,  Max Passes: 6,  Finish After Clean Passes: 1
Bad Sector Re-rip::  Drive Speed: Max,  Maximum Re-reads: 700
Encoder: Wave -compression="PCM"
Extraction Log
Track 1:  Ripped LBA 0 to 11515 (2:33) in 0:08. Filename: K:\DBPWRAMP_EXT_AUDIO\Dry Kill Logic\Dry Kill Logic - Dead and Dreaming - 01 - Lost.wav
  AccurateRip: Accurate (confidence 2)    [Pass 1]
  CRC32: BD3E21F1
Track 2:  Ripped LBA 11515 to 28728 (3:49) in 0:11. Filename: K:\DBPWRAMP_EXT_AUDIO\Dry Kill Logic\Dry Kill Logic - Dead and Dreaming - 02 - Paper Tiger.wav
  CRC32: 6AB7A4FB
Track 3:  Ripped LBA 28728 to 44613 (3:31) in 0:09. Filename: K:\DBPWRAMP_EXT_AUDIO\Dry Kill Logic\Dry Kill Logic - Dead and Dreaming - 03 - Buckles.wav
  CRC32: 6EA31EF1
Track 4:  Ripped LBA 44613 to 61892 (3:50) in 0:10. Filename: K:\DBPWRAMP_EXT_AUDIO\Dry Kill Logic\Dry Kill Logic - Dead and Dreaming - 04 - With Deepest Regrets....wav
  CRC32: 7E1C488E
Track 5:  Ripped LBA 61892 to 81444 (4:20) in 0:10. Filename: K:\DBPWRAMP_EXT_AUDIO\Dry Kill Logic\Dry Kill Logic - Dead and Dreaming - 05 - Neither Here nor Missed.wav
  CRC32: 74E8F69C
Track 6:  Ripped LBA 81444 to 94095 (2:48) in 0:06. Filename: K:\DBPWRAMP_EXT_AUDIO\Dry Kill Logic\Dry Kill Logic - Dead and Dreaming - 06 - The Perfect Enemy.wav
  CRC32: BFDCEF1D
Track 7:  Ripped LBA 94095 to 105948 (2:38) in 0:05. Filename: K:\DBPWRAMP_EXT_AUDIO\Dry Kill Logic\Dry Kill Logic - Dead and Dreaming - 07 - Living Witness.wav
  CRC32: F5050F73
Track 8:  Ripped LBA 105948 to 119185 (2:56) in 0:06. Filename: K:\DBPWRAMP_EXT_AUDIO\Dry Kill Logic\Dry Kill Logic - Dead and Dreaming - 08 - One Handed Knife Fight.wav
  CRC32: D1F75A1F
Track 9:  Ripped LBA 119185 to 135534 (3:37) in 0:07. Filename: K:\DBPWRAMP_EXT_AUDIO\Dry Kill Logic\Dry Kill Logic - Dead and Dreaming - 09 - As Thick as Thieves.wav
  CRC32: 58DD8068
Track 10:  Ripped LBA 135534 to 150726 (3:22) in 0:06. Filename: K:\DBPWRAMP_EXT_AUDIO\Dry Kill Logic\Dry Kill Logic - Dead and Dreaming - 10 - 200 Years.wav
  CRC32: 73893AA5
Track 11:  Ripped LBA 150726 to 167928 (3:49) in 0:07. Filename: K:\DBPWRAMP_EXT_AUDIO\Dry Kill Logic\Dry Kill Logic - Dead and Dreaming - 11 - No Reason.wav
  CRC32: 6F1E29D5
11 Tracks Ripped Accurately
dBpowerAMP Release 12 Alpha 7 Digital Audio Extraction Log from Thursday, October 19, 2006 11:12 AM
Drive & Settings
Ripping with drive 'N:  [PLEXTOR  - DVDR  PX-716A  ]',  Drive offset: 30,  Overread Lead-in/out: Yes
AccurateRip: Active,  Using C2: Yes,  Cache: 1173 KB,  FUA Cache Invalidate: No
Extraction Log
Track 1:  ERROR Ripping LBA 0 to 11515 (2:33) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Dry Kill Logic\Dry Kill Logic - Dead and Dreaming - 01 - Lost.wav
Unable to read CD, check CD disc (frame LBA 0)
Track 2:  ERROR Ripping LBA 11515 to 28728 (3:49) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Dry Kill Logic\Dry Kill Logic - Dead and Dreaming - 02 - Paper Tiger.wav
Unable to read CD, check CD disc (frame LBA 11515)
Track 3:  ERROR Ripping LBA 28728 to 44613 (3:31) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Dry Kill Logic\Dry Kill Logic - Dead and Dreaming - 03 - Buckles.wav
Unable to read CD, check CD disc (frame LBA 28728)
Track 4:  ERROR Ripping LBA 44613 to 61892 (3:50) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Dry Kill Logic\Dry Kill Logic - Dead and Dreaming - 04 - With Deepest Regrets....wav
Unable to read CD, check CD disc (frame LBA 44613)
Track 5:  ERROR Ripping LBA 61892 to 81444 (4:20) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Dry Kill Logic\Dry Kill Logic - Dead and Dreaming - 05 - Neither Here nor Missed.wav
Unable to read CD, check CD disc (frame LBA 61892)
Track 6:  ERROR Ripping LBA 81444 to 94095 (2:48) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Dry Kill Logic\Dry Kill Logic - Dead and Dreaming - 06 - The Perfect Enemy.wav
Unable to read CD, check CD disc (frame LBA 81444)
Track 7:  ERROR Ripping LBA 94095 to 105948 (2:38) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Dry Kill Logic\Dry Kill Logic - Dead and Dreaming - 07 - Living Witness.wav
Unable to read CD, check CD disc (frame LBA 94095)
Track 8:  ERROR Ripping LBA 105948 to 119185 (2:56) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Dry Kill Logic\Dry Kill Logic - Dead and Dreaming - 08 - One Handed Knife Fight.wav
Unable to read CD, check CD disc (frame LBA 105948)
Track 9:  ERROR Ripping LBA 119185 to 135534 (3:37) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Dry Kill Logic\Dry Kill Logic - Dead and Dreaming - 09 - As Thick as Thieves.wav
Unable to read CD, check CD disc (frame LBA 119185)
Track 10:  ERROR Ripping LBA 135534 to 150726 (3:22) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Dry Kill Logic\Dry Kill Logic - Dead and Dreaming - 10 - 200 Years.wav
Unable to read CD, check CD disc (frame LBA 135534)
Track 11:  ERROR Ripping LBA 150726 to 167928 (3:49) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Dry Kill Logic\Dry Kill Logic - Dead and Dreaming - 11 - No Reason.wav
Unable to read CD, check CD disc (frame LBA 150726)
11 Tracks Could Not Be Ripped
Perhaps the ASPI layer has to go into a Windows directory instead of the main program (to be able to use FUA and not lose C2 capability as the Windows Internal setting says it will do if enabled)?  Or perhaps the specific ASPI layer isnt compatible with thie program?  I look forward to your analysis of these issues.  Thank you
Reply #143
To clarify this a bit  --dBpowerAMP did not automatically change the drive letters to all "F"'s until I manually selected "ASPI" from the drop-down list  next to Read into lead in lead out; Communication.  Once that was selected and the program closed and re-opened it did this, and the problem was repeatable.  When swithcing back to SCSI pass through (SPT), then closing and re-opening the program it then correctly recognized my four drives and would actually recognize an audio CD then.
To illustrate exactly what I was seeing with the Nero aspi layer selected, in the drop down box, was the following:
Insert Audio CD Into:
        F:  [_NEC  -DVD_RW ND-2500A ]
        F:  [PLEXTOR -DVDR PX716A  ]
        F:  [BENQ  -DVD DD DW1640 ]
If changed back to SCSI pass through (SPT) (which I don't want) the drive letters go back to normal,
        G:  [PLEXTOR -DVDR PX716A  ]
        H:  [BENQ  -DVD DD DW1640 ]
        N:  [PLEXTOR -DVDR PX716A  ]
Reply #144
It suggests that ABF87DF7 is correct as that is the only one verified by accuratte rip, and hte confidence is very reasonable.
i Secure:  the i stands for an informational warning, that a re-rip was required so the track might not be 100% secure (as relies on the drives re-read ability).
TrueAudio:
There does seem to be an issue regarding drive letter detection and the Nero ASPI layer, perhaps even the normal aspi layer as well. I will look into that.
That option read into lead in/out is on its own, it is a checkbox, SCSI & Windows internal fall under communication. Regardless...
Windows XP has SPT as default, you cannot uninstall it. There exists demon tools which inserts something into the middle of programs accessing SPT and the drive, that is causing the FUA to stop working. SPT is normally the best you can use, much better than ASPI.
Did you try the USB plextor on SPT?
Reply #145
TrueAudio:
Yeah, I also think TrueAudio is confusing the Win32 SPT Interface (SPTI) with filter drivers that hook into the middle of the SPT/SPTI layers.  Typically you see copy protection related drivers causing this sort of problem, but as you mentioned DT's filter driver appears to interfere as well.
-brendan
Reply #146
I only get "i" very very rarely and when i do just a clean of the disk or a brasso, turtle wax combo does the trick.  But a lot of the discs i have tried needed re-rips but never had an i.
Is this only for a certain kind of re rip or something?  or re rip with no c2 feedback or something?
Reply #147
Ok, here's an update:
1st, you are correct in that I was confused with regards to the SPTI option (thank you for clarifying that it is independent of the overread options), I wasn't aware this was an integral part of WinXP, but rather thought that it was only something added by Daemon tools, which I in fact, had installed, but had uninstalled, as well as removed the SPTI pass through "filter driver" or whatever that Daemon Tools adds.
Yes, I did try the USB plextor with SPT, in secure mode with the settings that you've recommended on this site (as can be seen in the logs also).  But it nonetheless errors out every time, I even tried changing a setting and added some spin-up time to it, tried it without overread, etc --all to no avail.
The external PX-716UF however will rip in Burst mode, and it even shows to get accurate results against accuraterip database.  Switching back to secure mode though, it refuses to read a single track (see the LBA erros in my above log).  Initially, my PX-716UF had had firmware revision 1.04U flashed to it.  This is what had been on it during all my tests.  Just prior to this post here, I flashed it to the latest 1.10 firmware, and the flash was successful and was in no way interrupted.
I rebooted my PC as standard procedure then proceeded to test it again, only to get the same errors reading every single track in secure mode, with a clean, scratch, and DRM free disc.
BUT OMG Spoon now the plot thickens!!! =)
---->C2 Error Pointers for Error Detection  The PX-716A is is supposed to support C2 yes?  Because guess what, **unchecking** the C2 option, for the 1st time, the external drive ripped the entire CD in secure mode, but it will not do so with C2 enabled, and this is with firmware v1.10, the latest.  Included are the logs from a different, scratch-free, non-copy protected CD.
1st log = PX-716UF using C2        Drive I
2nd log= PX-716UF *without* C2  Drive I
3rd log= PX-716SA *using* C2      Drive G
Possible issue with my drive, or your program have an issue with enabling C2 on an external PX-716UF?  And if so, how could there possibly *just* be a problem with the C2 of the drive to such a severe extent that it totally errors out but yet all other functions work fine?  Thank you for your assistance.
dBpowerAMP Release 12 Alpha 7 Digital Audio Extraction Log from Thursday, October 19, 2006 2:49 PM
Drive & Settings
Ripping with drive 'I:   [PLEXTOR  - DVDR   PX-716A  ]',  Drive offset: 30,  Overread Lead-in/out: Yes
AccurateRip: Active,  Using C2: Yes,  Cache: None,  FUA Cache Invalidate: Yes
Extraction Log
Track 1:  ERROR Ripping LBA 0 to 20640 (4:35) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 01 - Reckoning Day.wav
Track 2:  ERROR Ripping LBA 20640 to 36092 (3:26) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 02 - Train of Consequences.wav
Unable to read CD, check CD disc (frame LBA 20640)
Track 3:  ERROR Ripping LBA 36092 to 60585 (5:26) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 03 - Addicted to Chaos.wav
Unable to read CD, check CD disc (frame LBA 36092)
Track 4:  ERROR Ripping LBA 60585 to 80682 (4:27) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 04 - A Tout le Monde.wav
Unable to read CD, check CD disc (frame LBA 60585)
Track 5:  ERROR Ripping LBA 80682 to 98942 (4:03) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 05 - Elysian Fields.wav
Unable to read CD, check CD disc (frame LBA 80682)
Track 6:  ERROR Ripping LBA 98942 to 116770 (3:57) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 06 - The Killing Road.wav
Unable to read CD, check CD disc (frame LBA 98942)
Track 7:  ERROR Ripping LBA 116770 to 134585 (3:57) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 07 - Blood of Heroes.wav
Unable to read CD, check CD disc (frame LBA 116770)
Track 8:  ERROR Ripping LBA 134585 to 153137 (4:07) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 08 - Family Tree.wav
Unable to read CD, check CD disc (frame LBA 134585)
Track 9:  ERROR Ripping LBA 153137 to 171867 (4:09) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 09 - Youthanasia.wav
Unable to read CD, check CD disc (frame LBA 153137)
Track 10:  ERROR Ripping LBA 171867 to 188712 (3:44) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 10 - I Thought I Knew It All.wav
Unable to read CD, check CD disc (frame LBA 171867)
Track 11:  ERROR Ripping LBA 188712 to 205147 (3:39) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 11 - Black Curtains.wav
Unable to read CD, check CD disc (frame LBA 188712)
Track 12:  ERROR Ripping LBA 205147 to 225157 (4:26) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 12 - Victory.wav
Unable to read CD, check CD disc (frame LBA 205147)
12 Tracks Could Not Be Ripped
dBpowerAMP Release 12 Alpha 7 Digital Audio Extraction Log from Thursday, October 19, 2006 2:50 PM
Drive & Settings
AccurateRip: Active,  Using C2: No,  Cache: None,  FUA Cache Invalidate: Yes
Extraction Log
Track 1:  Ripped LBA 0 to 20640 (4:35) in 0:14. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 01 - Reckoning Day.wav
  AccurateRip: Accurate (confidence 10)     [Pass 1]
  CRC32: F69C517A
Track 2:  Ripped LBA 20640 to 36092 (3:26) in 0:09. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 02 - Train of Consequences.wav
  CRC32: 0A60AFD1
Track 3:  Ripped LBA 36092 to 60585 (5:26) in 0:14. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 03 - Addicted to Chaos.wav
  CRC32: 36487E2E
Track 4:  Ripped LBA 60585 to 80682 (4:27) in 0:10. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 04 - A Tout le Monde.wav
  CRC32: EF1EFF9C
Track 5:  Ripped LBA 80682 to 98942 (4:03) in 0:09. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 05 - Elysian Fields.wav
  CRC32: 13734873
Track 6:  Ripped LBA 98942 to 116770 (3:57) in 0:08. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 06 - The Killing Road.wav
  CRC32: 6C333F8E
Track 7:  Ripped LBA 116770 to 134585 (3:57) in 0:08. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 07 - Blood of Heroes.wav
  CRC32: 11245D01
Track 8:  Ripped LBA 134585 to 153137 (4:07) in 0:08. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 08 - Family Tree.wav
  CRC32: 337BB47C
Track 9:  Ripped LBA 153137 to 171867 (4:09) in 0:07. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 09 - Youthanasia.wav
  CRC32: 0117DC77
Track 10:  Ripped LBA 171867 to 188712 (3:44) in 0:06. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 10 - I Thought I Knew It All.wav
  CRC32: D7DD7B56
Track 11:  Ripped LBA 188712 to 205147 (3:39) in 0:06. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 11 - Black Curtains.wav
  CRC32: BD2FA571
Track 12:  Ripped LBA 205147 to 225157 (4:26) in 0:07. Filename: K:\DBPWRAMP_EXT_AUDIO\Megadeth\Megadeth - Youthanasia - 12 - Victory.wav
  CRC32: 9FF48970
12 Tracks Ripped Accurately
dBpowerAMP Release 12 Alpha 7 Digital Audio Extraction Log from Thursday, October 19, 2006 2:59 PM
Drive & Settings
Extraction Log
  CRC32: F69C517A
  CRC32: 0A60AFD1
  CRC32: 36487E2E
  CRC32: EF1EFF9C
  CRC32: 13734873
  CRC32: 6C333F8E
  CRC32: 11245D01
  CRC32: 337BB47C
  CRC32: 0117DC77
  CRC32: D7DD7B56
  CRC32: BD2FA571
  CRC32: 9FF48970
Reply #148
Why don't you try downloading nero cd speed and see if it returns like a bajillion c2 erros on that cd... or whether its working at all...
Reply #149
Well, did another very significant test.
I have alot of drives, as I have kind of hoarded the good ones that aren't made anymore.  I just hooked up another brand new PX-716UF, this one is even newer than my other one.  The original PX-716UF that I did the tests with had TLA# 0203 (which is still supposed to be ok to use, according to Jean Luc, as its the same TLA that he had).  The one that I just hooked up is TLA# 0304.  The CD is 100% fine (remember I've tried 2 different CD's now) IMHO there's no need to try more, it's not going to make any difference, but I will just to reinforce my findings.  Same error messages when having C2 enabled.
dBpowerAMP Release 12 Alpha 7 Digital Audio Extraction Log from Thursday, October 19, 2006 4:06 PM
Drive & Settings
Extraction Log
Track 1:  ERROR Ripping LBA 62 to 114775 (25:29) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Mike Oldfield\Mike Oldfield - Tubular Bells - 01 - Tubular Bells, Pt. 1.wav
Unable to read CD, check CD disc (frame LBA 62)
Track 2:  ERROR Ripping LBA 114775 to 219745 (23:19) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Mike Oldfield\Mike Oldfield - Tubular Bells - 02 - Tubular Bells, Pt. 2.wav
Unable to read CD, check CD disc (frame LBA 114775)
dBpowerAMP Release 12 Alpha 7 Digital Audio Extraction Log from Thursday, October 19, 2006 4:08 PM
Drive & Settings
Extraction Log
Track 1:  ERROR Ripping LBA 0 to 24260 (5:23) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Fiona Apple\Fiona Apple - When the Pawn Hits the Conflicts He Thinks Like a King... - 01 - On the Bound.wav
Track 2:  ERROR Ripping LBA 24260 to 40831 (3:40) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Fiona Apple\Fiona Apple - When the Pawn Hits the Conflicts He Thinks Like a King... - 02 - To Your Love.wav
Unable to read CD, check CD disc (frame LBA 24260)
Track 3:  ERROR Ripping LBA 40831 to 56667 (3:31) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Fiona Apple\Fiona Apple - When the Pawn Hits the Conflicts He Thinks Like a King... - 03 - Limp.wav
Unable to read CD, check CD disc (frame LBA 40831)
Track 4:  ERROR Ripping LBA 56667 to 71878 (3:22) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Fiona Apple\Fiona Apple - When the Pawn Hits the Conflicts He Thinks Like a King... - 04 - Love Ridden.wav
Unable to read CD, check CD disc (frame LBA 56667)
Track 5:  ERROR Ripping LBA 71878 to 88422 (3:40) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Fiona Apple\Fiona Apple - When the Pawn Hits the Conflicts He Thinks Like a King... - 05 - Paper Bag.wav
Unable to read CD, check CD disc (frame LBA 71878)
Track 6:  ERROR Ripping LBA 88422 to 110778 (4:58) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Fiona Apple\Fiona Apple - When the Pawn Hits the Conflicts He Thinks Like a King... - 06 - A Mistake.wav
Unable to read CD, check CD disc (frame LBA 88422)
Track 7:  ERROR Ripping LBA 110778 to 131793 (4:40) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Fiona Apple\Fiona Apple - When the Pawn Hits the Conflicts He Thinks Like a King... - 07 - Fast as You Can.wav
Unable to read CD, check CD disc (frame LBA 110778)
Track 8:  ERROR Ripping LBA 131793 to 151197 (4:18) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Fiona Apple\Fiona Apple - When the Pawn Hits the Conflicts He Thinks Like a King... - 08 - The Way Things Are.wav
Unable to read CD, check CD disc (frame LBA 131793)
Track 9:  ERROR Ripping LBA 151197 to 169999 (4:10) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Fiona Apple\Fiona Apple - When the Pawn Hits the Conflicts He Thinks Like a King... - 09 - Get Gone.wav
Unable to read CD, check CD disc (frame LBA 151197)
Track 10:  ERROR Ripping LBA 169999 to 192160 (4:55) in 0:00. Filename: K:\DBPWRAMP_EXT_AUDIO\Fiona Apple\Fiona Apple - When the Pawn Hits the Conflicts He Thinks Like a King... - 10 - I Know.wav
Unable to read CD, check CD disc (frame LBA 169999)
10 Tracks Could Not Be Ripped
C2 DISABLED:
dBpowerAMP Release 12 Alpha 7 Digital Audio Extraction Log from Thursday, October 19, 2006 4:12 PM
Drive & Settings
Extraction Log
Track 1:  Ripped LBA 62 to 114775 (25:29) in 1:07. Filename: K:\DBPWRAMP_EXT_AUDIO\Mike Oldfield\Mike Oldfield - Tubular Bells - 01 - Tubular Bells, Pt. 1.wav
  AccurateRip: Accurate (confidence 9)    [Pass 1]
  CRC32: 58AAD090
Track 2:  Ripped LBA 114775 to 219745 (23:19) in 0:44. Filename: K:\DBPWRAMP_EXT_AUDIO\Mike Oldfield\Mike Oldfield - Tubular Bells - 02 - Tubular Bells, Pt. 2.wav
  CRC32: 9C606DD3
So we have the same repeatable problem with TWO different PX-716UF external drives, both brand new, and both with different hardware components, the 1st being TLA#0203, the second, showing the exact same errors, TLA#0304.
