Topic: foo_uie_single_column_playlist (Read 743264 times) previous topic - next topic
Reply #725
Unfortunately, the display glitch remains. Playback on enter works, thank you. Maybe upload another debug version?
Confirmed, unfortunately. And I confirm that with the debug version the symptom is gone (though there's an extra blank line at the end of the playlist).
Alessandro
Reply #726
Is it possible to sort files coming from a playlist. I have favourite tracks on a playlist call favourites. When i load this into foobar i group using !noheader! as i just want a list of tracks. However i have two tracks that are 3rd and 4th in playlist (Artist: Oasis, Album: Whats The Story) I also have a different track by same artist and on same album that is 14th in list. I would like to get them to be displayed together (e.g 3rd, 4th and 5th).
I tried to sort incoming playlist by %artist% but nothing changed
This image give you a better idea of whats going on
foobar
Reply #727
foobar
Although I don't know how to help you, you can use $if($stricmp(%playlist_name%,Favourites),,) instead of your current method.
There's a storm on the loose, there's sirens in my head...
Reply #728
EDIT: a small bug introduced with this update, it seems. I can't get it to focus on the playing item when changing tracks anymore.
I can confirm this bug.
I'm not quite sure I understand what this bug is?
Whenever changing tracks, the panel does not move to the song that is playing, even when 'Playback follows cursor' and 'Cursor follows playback' in the Playback menu are selected.
Also, whenever a playlist redraw (I guess) occurs, the list moves back to the top. This happens for example when editing file properties.
Also, when pressing the up or down key on the keyboard, the list moves to the track now playing.
Reply #729
I got the follow crash 2 times in the last half hour. Since nothing has changed in my configuration except the new version, I suspect it is related (and also because of the 'foobar2000_get_interface' in the crash log). I use Windows Vista RC2.
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 779218D3h
Access violation, operation: write, address: 00000014h
Call path:
Code bytes (779218D3h):
77921893h:  C0 89 4D F0 0F 84 37 88 FD FF 8B 4E 04 F6 C1 01
779218A3h:  8D 7E 04 0F 85 CF C6 00 00 8B 55 0C 90 8B C1 2B
779218B3h:  C2 8B D8 8B C1 F0 0F B1 1F 3B C1 0F 85 A8 C6 00
779218C3h:  00 33 C0 89 45 0C 89 45 08 8B 06 83 F8 FF 74 04
779218D3h:  83 40 14 01 8B 5D F4 8B 7D F0 90 80 3D 82 03 FE
779218E3h:  7F 00 0F 85 9B C6 00 00 8B 45 FC 83 F8 FF 57 6A
779218F3h:  00 0F 84 F1 C6 00 00 50 E8 C0 C3 FF FF 3D 02 01
77921903h:  00 00 0F 84 F1 C6 00 00 85 C0 0F 8C 87 C7 00 00
Stack (0635FE04h):
0635FDE4h:  00000000 00000000 00000000 00000000
0635FDF4h:  00000000 00000000 00000000 00000000
0635FE04h:  01320D50 01320D54 00000000 00000010
0635FE14h:  01320CF8 003DE0F8 004DE4B8 00000002
0635FE24h:  011B2548 00000002 0635FE50 C0000008
0635FE34h:  FFFFFFFF 00000002 0635FDD4 00000000
0635FE44h:  00000000 00000000 7FFDC000 0000011C
0635FE54h:  0635FE7C 7792181B 00000000 00000000
0635FE64h:  00000000 00000010 01320CF8 00000004
0635FE74h:  00000000 00000001 0635FEE0 003DC5AD
0635FE84h:  01320D50 1315F065 00000000 00000000
0635FE94h:  01322320 00000000 00004B4F 00000052
0635FEA4h:  01320178 00000000 00000002 0000000F
0635FEB4h:  01320148 00000000 013222B0 01322760
0635FEC4h:  00000000 00000000 00000000 0635FE88
0635FED4h:  0635FF88 003F0178 FFFFFFFF 0635FF50
0635FEE4h:  778D6396 00000118 0000011C 0635FE68
0635FEF4h:  01320CF8 00000035 00322320 00000035
0635FF04h:  003F90A8 504F5453 663D6320 000A6F6F
0635FF14h:  01320000 0000000B 0000000F 0635FF60
Registers:
EAX: 00000000, EBX: FFFFFFFC, ECX: 00000000, EDX: 00000004
ESI: 01320D50, EDI: 01320D54, EBP: 0635FE54, ESP: 0635FE04
Crash location: "ntdll", loaded at 778C0000h - 779DD000h
Symbol: "RtlTimeFieldsToTime" (+000002DCh)
Loaded modules:
foobar2000                       loaded at 00400000h - 004F3000h
ntdll                            loaded at 778C0000h - 779DD000h
kernel32                         loaded at 77320000h - 773F8000h
COMCTL32                         loaded at 74F30000h - 750C5000h
msvcrt                           loaded at 77400000h - 774AA000h
ADVAPI32                         loaded at 77260000h - 7731F000h
RPCRT4                           loaded at 76220000h - 762E3000h
GDI32                            loaded at 762F0000h - 7633B000h
USER32                           loaded at 76180000h - 7621E000h
SHLWAPI                          loaded at 77A80000h - 77AD5000h
SHELL32                          loaded at 76690000h - 7715B000h
ole32                            loaded at 77770000h - 778B4000h
shared                           loaded at 10000000h - 1002A000h
comdlg32                         loaded at 771E0000h - 77254000h
IMM32                            loaded at 77AE0000h - 77AFE000h
MSCTF                            loaded at 763D0000h - 76498000h
LPK                              loaded at 779F0000h - 779F9000h
USP10                            loaded at 77A00000h - 77A7D000h
uxtheme                          loaded at 75190000h - 751CF000h
foo_albumlist                    loaded at 00500000h - 00547000h
OLEAUT32                         loaded at 76340000h - 763CD000h
foo_audioscrobbler               loaded at 003D0000h - 00400000h
WS2_32                           loaded at 76600000h - 7662D000h
NSI                              loaded at 76680000h - 76686000h
foo_autoplaylist                 loaded at 00550000h - 00580000h
foo_cdda                         loaded at 012B0000h - 012E6000h
foo_converter                    loaded at 013A0000h - 01409000h
foo_dsp_std                      loaded at 01330000h - 01371000h
foo_freedb2                      loaded at 01410000h - 01450000h
foo_infobox                      loaded at 01450000h - 01490000h
foo_input_shorten                loaded at 014E0000h - 0150E000h
foo_input_std                    loaded at 01510000h - 01624000h
foo_masstag                      loaded at 01650000h - 016A0000h
foo_run                          loaded at 016A0000h - 016CB000h
foo_uie_albumart                 loaded at 01730000h - 01767000h
gdiplus                          loaded at 74830000h - 749DA000h
foo_uie_quicksearch              loaded at 01770000h - 017B7000h
foo_uie_single_column_playlist   loaded at 01820000h - 01873000h
MSVCP80                          loaded at 7C420000h - 7C4A7000h
MSVCR80                          loaded at 78130000h - 781CB000h
foo_uie_trackinfo_mod            loaded at 01880000h - 018CE000h
foo_ui_columns                   loaded at 01A10000h - 01AA7000h
foo_ui_std                       loaded at 018D0000h - 01927000h
dciman32                         loaded at 74360000h - 74366000h
PROPSYS                          loaded at 74730000h - 747E5000h
SETUPAPI                         loaded at 775E0000h - 77768000h
apphelp                          loaded at 75FB0000h - 75FDC000h
CLBCatQ                          loaded at 764A0000h - 76524000h
wpdshext                         loaded at 6BE50000h - 6C0BE000h
WINMM                            loaded at 72190000h - 721C3000h
OLEACC                           loaded at 74A10000h - 74A49000h
shdocvw                          loaded at 72F00000h - 73007000h
ieframe                          loaded at 71170000h - 71738000h
PSAPI                            loaded at 760E0000h - 760E6000h
iertutil                         loaded at 76630000h - 76675000h
USERENV                          loaded at 76030000h - 7604E000h
Secur32                          loaded at 76010000h - 76024000h
urlmon                           loaded at 774B0000h - 775D3000h
NLAapi                           loaded at 749E0000h - 749EF000h
IPHLPAPI                         loaded at 75A20000h - 75A39000h
dhcpcsvc                         loaded at 759E0000h - 75A14000h
DNSAPI                           loaded at 75C60000h - 75C8B000h
WINNSI                           loaded at 759D0000h - 759D7000h
dhcpcsvc6                        loaded at 759B0000h - 759D0000h
mswsock                          loaded at 757E0000h - 7581B000h
winrnr                           loaded at 726F0000h - 726F8000h
WLDAP32                          loaded at 77160000h - 771A9000h
napinsp                          loaded at 72630000h - 7263F000h
pnrpnsp                          loaded at 724B0000h - 724C2000h
wshbth                           loaded at 72620000h - 7262C000h
rasadhlp                         loaded at 751E0000h - 751E6000h
DSOUND                           loaded at 6F340000h - 6F3B1000h
POWRPROF                         loaded at 754D0000h - 754EA000h
MMDevApi                         loaded at 74700000h - 74727000h
WINTRUST                         loaded at 752D0000h - 752FD000h
CRYPT32                          loaded at 75AD0000h - 75BC1000h
MSASN1                           loaded at 75C20000h - 75C32000h
imagehlp                         loaded at 771B0000h - 771D9000h
audioses                         loaded at 704F0000h - 70511000h
audioeng                         loaded at 70150000h - 701B7000h
AVRT                             loaded at 74A00000h - 74A07000h
rsaenh                           loaded at 75570000h - 755A8000h
mlang                            loaded at 6F230000h - 6F260000h
dbghelp                          loaded at 72010000h - 720EC000h
Stack dump analysis:
Address: 003DE0F8h, location: "foo_audioscrobbler", loaded at 003D0000h - 00400000h
Symbol: "foobar2000_get_interface" (+00009948h)
Address: 004DE4B8h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7792181Bh, location: "ntdll", loaded at 778C0000h - 779DD000h
Symbol: "RtlTimeFieldsToTime" (+00000224h)
Address: 003DC5ADh, location: "foo_audioscrobbler", loaded at 003D0000h - 00400000h
Symbol: "foobar2000_get_interface" (+00007DFDh)
Address: 003F0178h, location: "foo_audioscrobbler", loaded at 003D0000h - 00400000h
Symbol: "foobar2000_get_interface" (+0001B9C8h)
Address: 778D6396h, location: "ntdll", loaded at 778C0000h - 779DD000h
Symbol: "RtlGetLongestNtPathLength" (+00000056h)
Address: 003DE3F3h, location: "foo_audioscrobbler", loaded at 003D0000h - 00400000h
Symbol: "foobar2000_get_interface" (+00009C43h)
Address: 003DC8C9h, location: "foo_audioscrobbler", loaded at 003D0000h - 00400000h
Symbol: "foobar2000_get_interface" (+00008119h)
Address: 003DFE0Ah, location: "foo_audioscrobbler", loaded at 003D0000h - 00400000h
Symbol: "foobar2000_get_interface" (+0000B65Ah)
Address: 003E49C0h, location: "foo_audioscrobbler", loaded at 003D0000h - 00400000h
Symbol: "foobar2000_get_interface" (+00010210h)
Address: 003DFEAFh, location: "foo_audioscrobbler", loaded at 003D0000h - 00400000h
Symbol: "foobar2000_get_interface" (+0000B6FFh)
Address: 7735C71Ch, location: "kernel32", loaded at 77320000h - 773F8000h
Symbol: "BaseThreadInitThunk" (+00000012h)
Address: 778EE2CFh, location: "ntdll", loaded at 778C0000h - 779DD000h
Symbol: "RtlIsCurrentThreadAttachExempt" (+00000042h)
Address: 778EF0DDh, location: "ntdll", loaded at 778C0000h - 779DD000h
Symbol: "RtlLCIDToCultureName" (+00000310h)
Address: 003DFE30h, location: "foo_audioscrobbler", loaded at 003D0000h - 00400000h
Symbol: "foobar2000_get_interface" (+0000B680h)
Address: 00480020h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 003D003Ch, location: "foo_audioscrobbler", loaded at 003D0000h - 00400000h
Address: 003F003Eh, location: "foo_audioscrobbler", loaded at 003D0000h - 00400000h
Symbol: "foobar2000_get_interface" (+0001B88Eh)
Address: 00410040h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00430042h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00450044h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00470046h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00490048h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004B004Ah, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004D004Ch, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004F004Eh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00510050h, location: "foo_albumlist", loaded at 00500000h - 00547000h
Symbol: "foobar2000_get_interface" (+00005700h)
Address: 00530052h, location: "foo_albumlist", loaded at 00500000h - 00547000h
Symbol: "foobar2000_get_interface" (+00025702h)
Address: 00550054h, location: "foo_autoplaylist", loaded at 00550000h - 00580000h
Address: 00570056h, location: "foo_autoplaylist", loaded at 00550000h - 00580000h
Symbol: "foobar2000_get_interface" (+0001B436h)
Address: 0192201Ah, location: "foo_ui_std", loaded at 018D0000h - 01927000h
Symbol: "foobar2000_get_interface" (+0003BA2Ah)
Address: 0178017Eh, location: "foo_uie_quicksearch", loaded at 01770000h - 017B7000h
Symbol: "foobar2000_get_interface" (+0000D7AEh)
Address: 00500060h, location: "foo_albumlist", loaded at 00500000h - 00547000h
Address: 778CFF20h, location: "ntdll", loaded at 778C0000h - 779DD000h
Symbol: "RtlFindAceByType" (+00000A98h)
Address: 7799271Ah, location: "ntdll", loaded at 778C0000h - 779DD000h
Symbol: "fltused" (+000093EAh)
Version info:
foobar2000 v0.9.4.1
UNICODE
Additional info:
Autoplaylist Manager 1.0  (foo_autoplaylist)
Run services 0.3.2  (foo_run)
Shorten decoder 0.4.2a  (foo_input_shorten)
CD Audio Decoder 2.1.1  (foo_cdda)
Album Art Panel 0.2.5.1  (foo_uie_albumart)
Masstagger 1.6  (foo_masstag)
Columns UI 0.1.3 beta 1v6 TEST  (foo_ui_columns)
Track info panel mod 0.6 beta [Oct 12 2006 - 10:42:55]  (foo_uie_trackinfo_mod)
FLAC Decoder 1.1.0  (foo_input_std)
freedb Tagger 0.5.2a  (foo_freedb2)
Converter 1.0.1  (foo_converter)
Standard Input Array 1.0  (foo_input_std)
Album List 3.2.0  (foo_albumlist)
Default User Interface 0.9acc  (foo_ui_std)
Quick Search Toolbar 2.8j  (foo_uie_quicksearch)
WMA Decoder 1.1  (foo_input_std)
Single Column Playlist Display 0.3.2 beta [Oct 16 2006 - 12:21:19]  (foo_uie_single_column_playlist)
Standard DSP array 1.0  (foo_dsp_std)
Special file info box 2.0.4  (foo_infobox)
Audioscrobbler 2.1  (foo_audioscrobbler)
foobar2000 core v0.9.4.1  (Core)
Reply #730
Thanks, i will give it a look. My whole config is a mess as it was a case of getting it working, then attempting to clean it up
Reply #731
What's the best way of handling different formats of album covers ? Or should I just convert it all into pngs?
Reply #732
You could just make copies with the extension .png. They don't actually have to be in png format, as GDI+ ignores the filename (a filthy hack, I know).
Reply #733
I wouldn't recommend doing that way.
Its quite simple really. All you need to do is copy your string and add different formats like I've done with mine
$imageabs2(76,76,,,,,12,2,'D:\Multimedia Tools\Audio Tools\foobar2000\images\no-cover.jpg',)
$imageabs2(76,76,,,,,12,2,$replace(%path%,%filename_ext%,)cover.jpg,)
$imageabs2(76,76,,,,,12,2,$replace(%path%,%filename_ext%,)cover.jpeg,)
$imageabs2(76,76,,,,,12,2,$replace(%path%,%filename_ext%,)cover.bmp,)
$imageabs2(76,76,,,,,12,2,$replace(%path%,%filename_ext%,)cover.png,)
Reply #734
I have a question
Most of my cover images are stored in C:\Program Files\Samurize\covers in format artist - album
Part of covers are in album folders, various names in jpeg format
My group display is (thank you moxamax for sharing )
$puts(artfnt0,$font(Calibri,10,bold,195-195-195))
$puts(abmfnt0,$font(Calibri,11,,120-120-120))
$puts(techfnt0,$font(Calibri,8,,195-195-195))
$if($greater($strstr(%playlist_name%,Radio),0),$puts(is_single,1))
$if($greater($strstr(%playlist_name%,Single),0),$puts(is_single,1))
$if($not(%tracknumber%),$puts(is_single,1))
$ifequal($mod(%_playlist_number%,2),0,
$drawrect(0,0,0,1,brushcolor-240-240-240 pencolor-null),
$drawrect(0,87,0,1,brushcolor-240-240-240 pencolor-null))
$drawrect($sub(%_width%,15),10,15,0,brushcolor-241-249-250 pencolor-null)
$imageabs(,,'FCS\unique\head_bg.png',)
$ifequal($get(is_single),1,
$if(%filesize%,
$imageabs2(60,60,,,,,2,20,'FCS\unique\sgcover.png',),
$imageabs2(60,60,,,,,2,20,'FCS\unique\radiocover.png',)),
$imageabs2(60,60,,,,,2,20,'FCS\unique\nocover.png',))
$imageabs2(60,60,,,,,2,20,$replace(%path%,%filename_ext%,)cover.jpg,)
$alignabs(70,42,$add(%_width%,-107),20,left,middle)
$get(abmfnt0)$if(%filesize%,SINGLES,ONLINE RADIO)
$alignabs(70,27,$add(%_width%,-107),20,left,middle)
$get(artfnt0)$if2(%album artist%,$if2(%artist%,UNKNOWN))
$get(abmfnt0)$if2($upper(%album%),UNKNOWN)
$alignabs(70,55,$add(%_width%,-107),20,left,middle)
$get(techfnt0)[%genre%', '][%codec% ][$info(bitrate)K]
what would be the best way to display my images in single column playlist?
i tried adding some lines, but unsuccesfully. i moved to single column just recentley so i'm trying to catch up.
my old album art sources were
$replace(%_path%,%_filename_ext%,)%artist%*
$replace(%path%,%filename_ext%,)*
-C:\Program Files\Samurize\covers\%artist% - %album%.*
and that worked just fine
I would appreciate any help.
Reply #735
hi foobar guys,
your images looks all really great. but i've one question. how does this single playlist work with various artist albums like v.a. - album (year)\track# - artist - title? cause all tracks have a different artist.
thx
the pi
Reply #736
hi foobar guys,
thx
the pi
For VA Cds, you should put in a %ALBUM ARTIST% tag, usually I tend to just put the CD name as it.
Edit:
@blaxima thanks
Reply #737
hi foobar guys,
thx
the pi
Edit:
@blaxima thanks
Yeah I do that to, I just put a subjective thing I'd associate with it so for the Garden State Soundtrack I put "Zach Braff" as he chose the soundtrack.
hi
Reply #738
How dose this plugin work? its installed but i can't find anywhere to edit the plugin...
Reply #739
Once you enable the panel inside ColumnsUI, the Column appears and you have to right click and choose settings to use it
Reply #740
Any idea why the playlist switcher doesn't switch playlists..?
Also, the quicksearch toolbar doesn't make the corresponding playlist become active...
And the playlist dropdown doesn't activate the playlist either..
I've had this problem for a while, but it's only just started to bug me..
Reply #741
@spex
right click on a single column playlist---activate playlist
Reply #742
Hi, i have a question.
What code i have to use to make the plugin show only the Artist and Title and no header when a song doesn't have tracknumber?
If the tracks are part of an album the plugin shows:
HEADER
title
title
title
When a song doesn't have tracknumber I want the plugin to show:
Artist-title
Artist-title
Artist-title
Thanks, i don't know how to write the code to do this...
Reply #744
suggestion: right click drag & drop (as in columns ui)
Reply #745
HEADER
title
title
title
Artist-title
Artist-title
Artist-title
here you go....
group by
$if(%tracknumber%,%album%,!noheader!)
item display
$if(%tracknumber%,%title%,%artist%' - '%title%)
Reply #746
HEADER
title
title
title
Artist-title
Artist-title
Artist-title
here you go....
group by
item display
Thank you!
Reply #747
Coppertop's description of our focus bug are correct. The plugin no longer obeys 'Playback Follow Cursor' nor 'Cursor Follows Playback' anymore.
I'll try the latest version now to see about the display glitch and playing on enter feature. Thanks again for the quick responses.
EDIT: Oh, Another thing. Scrolling sometimes 'fails' here - page down scrolls upwards from the bottom of the list no matter where i was at when clicking it. Vice versa for page up. The other single bug ive seen besides those is having to press X times to go above a header (X being the group row count).
Reply #748
I thought that its a left click!!
But its something I want very much too. I find myself jumping back and forth from columns ui to do some things still
Reply #749
Is there a site for single_column_playlist and/or trackinfomod configs?
