Topic: GAPLESS Playback now in iPods - New! (Read 309268 times) previous topic - next topic
Reply #200
Or you're not talking about gapless in the sense of "tracks which are meant to transition seamlessly"
...or transition more quickly than the original mastering.
So you're saying that Lame MP3s will always have additional gaps? That means Lame MP3 is never truly gapless then, regardless of tags/metadata information.
No, he's not saying that, and yes it is possible for Lame MP3 to be truly gapless.
Reply #201
From the wiki:
Some compression methods such as the popular MP3 can be problematic because the MP3 standard defines no way to record the amount of padding for later removal. Even if two tracks are decompressed and merged into a single track, a gap will remain between them.
That means Lame MP3 cannot be truly gapless because of MP3 format itself. Lame MP3 can be gapless (using metadata/tags, shown with iTunes7 and new iPods), but I guess techincally it is not true gapless since the format is not gapless.
twitter.com/pika2000
Reply #202
With software that is able to use the information stored in the lame header, decoding (and hence playback) can be 100% gapless.
Reply #203
Just because the format isn't technically gapless then, as previously said, does not mean it cannot be played back gaplessly through the use of meta-data.
Reply #204
From the wiki:
The MP3 format is not inherently gapless, that is correct. Without a decoder which accounts for encoder delay/padding, songs are not exactly the same length as the original tracks. AFAIK, this is the case with most (or all?) lossy codecs.
This assumes that the file is not a LAME MP3 and that the decoder does not support ''gapless decoding''. No?
Something else seems unclear in that wiki article. AFAIK, Ogg Vorbis (and AAC?) works the same way. It's just that, unlike the case of MP3, there are provisions in the original specifications for gapless metadata to be added during encoding (which is not to say that the files are encoded without padding / gaps). Or am I mistaken?
Reply #205
Right. Most modern music codecs are not gapless by themselves (mp1,mp2,mp3,aac, Vorbis, mpc, wma,...). However, some of them are USUALLY found in CONTAINERS allowing to store the gapless info.
So once again, Vorbis or AAC are not more gapless than MP3.
Reply #206
Well I found it strange tht you have gapless using Lame (VBR) and EAC.
i have tried EAC with Lame 3.97 using VBR (-v 0 --vbr-new) and in Itune I still have a little gap between my tracks of Madonna - Confession on a dance floor
I notice at the end of the track when I check the remaining time left at the end it jump from 0 to -2 and then jump to the next song an I can hear a little gap. I have also tried using CBR 256 with lame & EAC and the same gap problem.
So far the only way i get gapless is by ripping the CD directly from Itunes using (AAC-256-VBR, MP3 VBR256). Ripping the CD from Itunes just work great ! Real Gapless !
So for my gapless CD I will use Itunes with AAC (256 VBR) and for all my other CD I will still use EAC with lame v3.97 (256 VBR).
If you still want to use EAC, you can extract to individual wavs and then encode them in itunes to aac or mp3. I've been doing this and have had perfect gapless on 12 different discs.
Reply #207
I tested gapless on my 4G 20Gb Ipod and it does not seem to work .  Although gapless is turned on in iTunes and playback is gapless in iTunes, when these files are uploaded to the iPod they are no longer played back gaplessly.
Apple doesn't support gapless on anything but the latest iPod releases... 5G iPod and 2G nano.  I think they made that fairly clear.
Yeah, I know they said that but I thought I would try anyway.  Kinda annoying that they did this since there seems to be little reason why they couldn't other than forcing people like myself to buy new iPod sooner.  Also, it seems that the gapless tag is not added when the file is uploaded by iTunes onto my 4G.  It could be that they don't add this information into the database for iPods older than 5G.  Perhaps someone will figure out how the gapless tag works and it will be possible to give your files this tag with foo_dop.  The software on my 4G iPod may be able to playback gaplessly but without the proper information it obviously can't.
Reply #208
Why would Apple update the player firmware but not allow you to update the file metadata?
If Apple is just being greedy, would they really expect that this (alleged) info will not surface? If anyone can prove it, it certainly would give Apple a lot of bad press. It doesn't seem very likely, but I guess it's not beyond belief.
Reply #209
Directly using the portalPlayer chip, it might be possible that it is NOT possible to do gapless playback. Gapless playback needs you to access the audio data after decoding but before it is sent to the DAC. There are several integrated decoding/dac chips where this is just not possible.
Reply #210
But this begs the question (or reveals my ignorance?)...
If older iPods are gapless with rockbox, wouldn't that suggest that the hardware IS capable?
What do you think kincaid?
Reply #211
No. RockBox is doing a full software decoding, thus reducing battery life. In (previous) iPods there is a chip dedicated to decoding, and this chip is not used by RockBox.
Now, in the 5G it might be possible that everything is handled on the ARM, including decoding. (but this is pure speculation from me)
Reply #212
heh, it looks like this is the death of foobar for me
oh well, thanks for the memories foobar
Reply #213
I wouldn't quit foobar just yet. Somehow I think foo_dop will find a way to upload tracks to the iPod without messing with the gapless info.
And foobar does so much more things (for example, transcoding my FLACs to MP3 and making them all the same volume!)
I'm the one in the picture, sitting on a giant cabbage in Mexico, circa 1978.
Reseñas de Rock en Español: www.estadogeneral.com
Reply #214
I don't know if anyone else posted this in this thread yet, but I just got a reply on WinAmp's Discussion forum @ winamp.com that WinAmp will be supporting iTunes/iPod encoded Gapless playback (for both MP3 and AAC/M4A files) in the soon to be released version 5.25 of WinAmp. They already have the iTunes compatible Gapless supporting code added to WinAmp the devs said.
See the thread for more at: http://forums.winamp.com/showthread.php?s=...992#post2030992
Reply #215
Does anyone find this somewhat ironic?
Reply #216
Not quite sure what you meant by this... perhaps you meant I should re-read the whole thread again. I seem to remember someone's post saying WinAmp will probably add iTunes compatible Gapless playback, but now I know for sure that WinAmp devs have definately added Gapless support for iTunes encoded files. This thread I started has sure grown into a massive one -- that's for sure -- with 216 posts and 19301 views. It's hard to read this one from scratch (let alone remember what everyone said in the posts that I previously read days ago).
Reply #217
I'd say pragmatic. And there's nothing wrong with that.
Because of this, Winamp will not only play LAME MP3's gapless (which it already did) but non-LAME MP3's as well. Or practically gapless in the latter case.
Every night with my star friends / We eat caviar and drink champagne
Sniffing in the VIP area / We talk about Frank Sinatra
Do you know Frank Sinatra? / He's dead
Reply #218
Don't take it personally goodnews, the comment wasn't directed at you.
I see no reason why Winamp (or foobar2000 for that matter) couldn't easily and quickly support the new tag data and correctly write this information to the library on the iPod.
What I find ironic is that Winamp will still not be able to support gapless playback natively.  I also doubt that Winamp will be doing any scanning for gaps in tracks like iTunes does.
Though I hope I'm wrong!
EDIT: Italics added, "gaps in" added for clarity
Reply #219
Winamp has supported gapless playback natively since 5.2
Reply #220
Winamp has had native gapless support for quite a while now. It is based on the same MP3info header all serious gapless implementations (i.e. not the crossfade crap) use. It does of course only work on LAME MP3's.
Check this thread. I'm not quite sure what to make of it but it appears they do some sort of scan...
Edit: Ah, I'm sure benski can enlighten us...
Reply #221
That scan is for songs already on your iPod before the upgrade.  There is no iTunes-style "guessing" scan.  We hope that Winamp users are sane enough to have been using LAME to encode their MP3s.
Reply #222
Thanks. It makes sense, especially since since the method of the 'iTunes scan' is still a huge black box as far as I know.
Reply #224
I think I may have good news for those of you who haven't been able to get the promised gapless audio playback on your iPod after installing iTunes 7 and letting it go through your songs to determine gapless playback. After iTunes kept kicking my iPod off I was at a loss about what to do next. I am happy to say I got it to work today. It's a bit of a dirty way to do it, but it works!  I found this post on ipodwizard.net by Kaneda:
1. iTunes seems to say that your iPod is up to date, if there isn't an update file on your computer. I.e., it won't actually check on the internet. However, it also seems it will check for iPod updates when it checks for iTunes updates, so try to click Help/Check for Updates in the menu. Then iTunes should tell you there's an update for you iPod - download and continue...
2. Seems that iTunes somehow fails to connect to the iPod in some cases, when doing an update - like it "forgets" it's actually there. The iPod will go the menu screen (or Charging display), iTunes will keep saying "updating iPod", and after a while it will give an error 1417 or 1418, depending on whether you chose Update or Restore. What worked for me: Click Update, then when the "indeterminate progress bar" starts in iTunes, pull out the iPod from the dock and put it back in. After that forceful re-recognition of the iPod, the update started (took only 5 seconds or so to complete). Everything works. But do this at your own risk - if the iPod has actually started updating when you pull out, there's a chance you'll be in big trouble
It took my iPod a bit longer to update, but once I did, I selected "The Who Sell Out" for gapless playback and it works seamlessly. The only problem I've had is that even though iTunes spent a good hour scanning all 10K+ of my songs, it didn't turn on the feature for any of my albums. However, if I manually select an album on my iPod, it will update it and it will play gapless. This is a major PITA given the amount of songs I have, but at least many of my albums will play right!
I hope everyone has as good of luck with this I did!
