As promised here are the ini and log files:
mareo.ini
; MAREO - (M)ultiple (A)pplications ®unner for (E)AC and (O)thers.
; Literal From Replacing Value
; @source@ Parameter # 2 FULL temporal Source File Name
; @dest@ Parameter # 3 FULL temporal Destination File Name
; @artist@ Parameter # 4 CD Artist Name
; @album@ Parameter # 5 CD Name
; @title@ Parameter # 6 Track (Song) Name
; @track@ Parameter # 7 Track (song) Number
; @year@ Parameter # 8 Year of the CD release
; @genre@ Parameter # 9 CD's Music Genre
; @1@ .. @nn@ Parameter # 10+ User Definenable
; @ownpath@ MAREO finds out the full path to MAREO, without the the ending backslash
; @newext@ MAREO finds out the file extension without the dot (ex: MP3)
; DOES MAREO NEEDS TO LOG TO THE SCREEN?
LogToScreen = TRUE
; DOES MAREO NEEDS TO LOG TO A TXT FILE?
LogToFile = TRUE
; DOES MAREO DELETES THE WAV FILE AFTER ENCODING (TRUE) OR THE CD RIPPER DOES (FALSE)?
DeleteWavFile = FALSE
; WavPack: excelent lossless encoder, with hybrid option: [url=http://www.rarewares.org/lossless.html]http://www.rarewares.org/lossless.html[/url]
ONLYIFLAST = FALSE
ENCODER = D:\Codecs\wavpack.exe
PARAMETERS = -hmy -w "ARTIST=@artist@" -w "TITLE=@title@" -w "ALBUM=@album@" -w "YEAR=@year@" -w "TRACK=@track@" -w "GENRE=@genre@" -w "ENCODEDBY=WavPack 4.31 [-hm]" -w "RIPPEDBY=EAC [secure mode]" "@source@" "@dest@"
RENAME = TRUE
PATH = C:\Music\@artist@\@year@ - @album@\
FILENAME = @track@ - @title@
EXTENSION = wv
; WVGAIN: Album Mode: used to "normalize" WavPack files: [url=http://www.wavpack.com]http://www.wavpack.com[/url]
ONLYIFLAST = TRUE
ENCODER = D:\Codecs\wvgain.exe
PARAMETERS = -a "C:\Music\@artist@\@year@ - @album@\*.wv"
RENAME = FALSE
PATH = NONE
FILENAME = NONE
EXTENSION = NONE
; WAVEGAIN: Album Mode: used to "normalize" files: [url=http://www.rarewares.org/others.html]http://www.rarewares.org/others.html[/url]
ONLYIFLAST = TRUE
ENCODER = D:\Codecs\wavegain.exe
PARAMETERS = --album --apply --noclip "C:\Music\WAV\@artist@\@year@ - @album@\*.wav"
RENAME = FALSE
PATH = NONE
FILENAME = NONE
EXTENSION = NONE
; OGG VORBIS: excelent and patent free encoder: [url=http://www.vorbis.com/]http://www.vorbis.com/[/url]
; RECOMMENDED VERSION: AoTuV 4.51b: [url=http://www.geocities.jp/aoyoume/aotuv/]http://www.geocities.jp/aoyoume/aotuv/[/url]
ONLYIFLAST = TRUE
ENCODER = D:\Codecs\oggenc.exe
PARAMETERS = -q 4 "C:\Music\WAV\@artist@\@year@ - @album@\*.wav"
RENAME = FALSE
PATH = NONE
FILENAME = NONE
EXTENSION = NONE
; EOF
mareo.log
MAREO - Multiple Applications Runner for EAC and Others - GPL Licensed
3.1 - Copyright 2003-2006 by Kwanbis - [url=http://www.webearce.com.ar/]http://www.webearce.com.ar/[/url]
Developed with Borland Delphi (info @ [url=http://borland.com/delphi/)]http://borland.com/delphi/)[/url]
*** Received Command Line ***
"C:\Appl\EAC\MAREO\mareo.exe" mareo.ini "C:\Music\WAV\Living Colour\1991 - Biscuits\0tmp2(207.wav" "C:\Music\WAV\Living Colour\1991 - Biscuits\0tmp2(207.wv" "Living Colour" "Biscuits" "Money Talks" "06" "1991" "Rock"
*** Parsed Parameters ***
IniFileName (%1) = mareo.ini
@source@ (%2) = C:\Music\WAV\Living Colour\1991 - Biscuits\0tmp2(207.wav
@dest@ (%3) = C:\Music\WAV\Living Colour\1991 - Biscuits\0tmp2(207.wv
@artist@ (%4) = Living Colour
@album@ (%5) = Biscuits
@title@ (%6) = Money Talks
@track@ (%7) = 06
@year@ (%8) = 1991
@genre@ (%9) = Rock
*** INI Parameters ***
LogToScreen = TRUE
LogToFile = TRUE
*** PROCESSING ENCODER ORDER # 1 ***
Run Only If Last = FALSE
NEW Extension = wv
TEMPORAL Full Name = C:\Music\WAV\Living Colour\1991 - Biscuits\0tmp2(207.wv
TEMPORAL Path Only = C:\Music\WAV\Living Colour\1991 - Biscuits
TEMPORAL Name Only = 0tmp2(207
RENAME Final File = TRUE
FINAL Full Name = C:\Music\Living Colour\1991 - Biscuits\06 - Money Talks.wv
FINAL Path Only = C:\Music\Living Colour\1991 - Biscuits
FINAL Name Only = 06 - Money Talks
EXECUTING: D:\Codecs\wavpack.exe -hmy -w "ARTIST=Living Colour" -w "TITLE=Money Talks" -w "ALBUM=Biscuits" -w "YEAR=1991" -w "TRACK=06" -w "GENRE=Rock" -w "ENCODEDBY=WavPack 4.31 [-hm]" -w "RIPPEDBY=EAC [secure mode]" "C:\Music\WAV\Living Colour\1991 - Biscuits\0tmp2(207.wav" "C:\Music\WAV\Living Colour\1991 - Biscuits\0tmp2(207.wv" ... EXECUTION SUCCESS!!
DIRECTORY "C:\Music\Living Colour\1991 - Biscuits" allready exists.
RENAMING: C:\Music\WAV\Living Colour\1991 - Biscuits\0tmp2(207.wv => C:\Music\Living Colour\1991 - Biscuits\06 - Money Talks.wv ... SUCCESS!!
*** PROCESSING ENCODER ORDER # 2 ***
Run Only If Last = TRUE
NEW Extension = NONE
TEMPORAL Full Name = C:\Music\WAV\Living Colour\1991 - Biscuits\0tmp2(207.NONE
RENAME Final File = FALSE
FINAL Full Name = NONE\NONE.NONE
FINAL Path Only = NONE
FINAL Name Only = NONE
OnlyIfLast Is TRUE, and track number is 06, executing.
DELETING: C:\Appl\EAC\MAREO\mareoLAST.ini ... **ERROR**
EXECUTING: D:\Codecs\wvgain.exe -a "C:\Music\Living Colour\1991 - Biscuits\*.wv" ... EXECUTION SUCCESS!!
Rename is FALSE, NO need to rename.
*** PROCESSING ENCODER ORDER # 3 ***
EXECUTING: D:\Codecs\wavegain.exe --album --apply --noclip "C:\Music\WAV\Living Colour\1991 - Biscuits\*.wav" ... EXECUTION SUCCESS!!
*** PROCESSING ENCODER ORDER # 4 ***
EXECUTING: D:\Codecs\oggenc.exe -q 4 "C:\Music\WAV\Living Colour\1991 - Biscuits\*.wav" ... EXECUTION **ERROR**
~~~ Encoder Orders Ends ~~~
Del
