Topic: MAREO 3.0 Released! (Read 63760 times) previous topic - next topic
  • kwanbis
  • Developer (Donating)
MAREO 3.0 Released!
Reply #200
I'm not sure about EAC myself, because I use PlexTools. With PTPXL it is possible to pass both track- and albumartist.
can you tell me how? i would like to add it as an example on the documentation.
RC3 looks good.  I've run it through several tests, no bugs to report.  It's doing everything I want.
good to hear.
Side Note, is anyone user of BLOG:CMS? I have moved MAREOs home page to it, so i can concentrate on writing the manual, but i want to change the look of the page.
  • kindofblue
MAREO 3.0 Released!
Reply #201
@GHammer: Thanks for your reply on fb2k 0.9. I get exactly the same thing.
@Kwanbis: Would you mind posting your setup for foobar 0.9?
thanks
kindofblue
edit: I think the MAREO download link should indicate the version number or something, just for clarity's sake. Thanks again.
  • Last Edit: 10 May, 2006, 10:58:00 PM by kindofblue
WavPack 4.31 / LAME 3.98 alpha 3 -V9 -vbr-new
  • kwanbis
MAREO 3.0 Released!
Reply #202
i just did whats on the help.
  • kindofblue
MAREO 3.0 Released!
Reply #203
Huh. Well, I'm stumped then.
Here's my test config:
; WavPack: excelent lossless encoder, with hybrid option: [url=http://www.wavpack.com/]http://www.wavpack.com/[/url]
 EXECUTEIF = TRUE
 FINALPATH = C:\Documents\Refuse\_transfer6\Batchenc\Audio samples\Music\
 FINALNAME = <trackpadded>. <title> - <artist>
 EXTENSION = wv
 ENCODEREXE = C:\Documents\Refuse\_transfer6\Batchenc\wavpack.exe
 PARAMETERS = -m -i -q "<source>" "<DESTTMP>"
 RENAME = FALSE
; MP3 LAME: best MP3 encoder: [url=http://www.rarewares.org/mp3.html]http://www.rarewares.org/mp3.html[/url]
EXECUTEIF = TRUE
EXTENSION = mp3
ENCODEREXE = C:\Documents\Refuse\_transfer6\Batchenc\lame398a4.exe
PARAMETERS = -V5 --vbr-new --ignore-tag-errors --ta "<artist>" --tl "<album>" --tt "<title>" --tn "<track>" --ty "<year>" --tg "<genre>" "<source>" "<DESTTMP>"
RENAME = TRUE
Temp wav file is saved in <finalpath>
  • kwanbis
MAREO 3.0 Released!
Reply #204
why don't you just run MAREO first from the command line, to see if it works?
MAREO 3.0 Released!
Reply #205
Well, I just added one varible in the command Line Arguments field. I added the argument "%D". Now the configuration looks like this: mareo.ini %S %O "%A" "%C" "%T" "%N" %Y "%G" "%D". In MAREO I just created the Placeholder <1> as it's representative.
I could also add "%M" for the comment field in PlexTools, but I don't need it.
Here a list of all the arguments:
If the program asks for an inputfile you should enter %S.
If the program asks for an outputfile you should enter %O.
For Tag-information we use the same rules as for Filename Construction:
%N: Track Number
%T: Track Title
%A: Track Artist
%C: Album Title
%D: Album Artist
%M: Comments
%G: Genre
%Y: Year
  • kindofblue
MAREO 3.0 Released!
Reply #206
Ok, just tried it... Commandline works, files are encoded and tagged. Could be a foobar issue then. Thanks.
MAREO 3.0 Released!
Reply #207
Forgot to add:
;  <PLACEHOLDER>		   VALUE
;  <SOURCE> Temporal source FULL file name, command line arameter #2 passed by the ripper to MAREO
;  <DESTTMP>   Temporal destination FULL file name, command line arameter #3 passed by the ripper to MAREO
;  <ARTIST> CD Artist Name, command line arameter #4 passed by the ripper to MAREO
;  <ALBUM> CD Name, command line arameter #5 passed by the ripper to MAREO
;  <TITLE> Track (song) Name, command line arameter #6 passed by the ripper to MAREO
;  <TRACK> Track (song) Number, command line arameter #7 passed by the ripper to MAREO
;  <TRACKPADDED>   <TRACK> padded with PaddingZeros.
;  <YEAR>   Year of the CD release, command line arameter #8 passed by the ripper to MAREO
;  <GENRE> CD's Music Genre, command line arameter #9 passed by the ripper to MAREO
;  <ALBUM ARTIST>   <1> As placeholder
EXECUTEIF = TRUE
FINALPATH = J:\Music\Lossless\<GENRE>\<1>\<ALBUM>\
FINALNAME = <TRACKPADDED>. <ARTIST> - <TITLE>
EXTENSION = wv
ENCODEREXE = J:\Music\MAREO\wavpack.exe
PARAMETERS = -hxm -w "ARTIST=<artist>" -w "TITLE=<TITLE>" -w "ALBUM=<ALBUM>" -w "YEAR=<YEAR>" -w "TRACK=<TRACK>" -w "GENRE=<GENRE>" -w "ALBUM ARTIST=<1>" -w "ENCODEDBY=WavPack 4.31 [-hxm]" -w "RIPPEDBY=PlexTools Professional XL V3.09" "<SOURCE>" "<DESTTMP>"
RENAME = TRUE
; WvGain
EXECUTEIF = LASTTRACK
FINALPATH = NONE
FINALNAME = NONE
EXTENSION = NONE
ENCODEREXE = J:\Music\MAREO\wvgain.exe
PARAMETERS = -a <FINALPATHSHORT>\*.wv
RENAME = FALSE
; WAVEGAIN: Track Mode: used to "normalize" files: [url=http://www.rarewares.org/others.html]http://www.rarewares.org/others.html[/url]
EXECUTEIF = TRUE
FINALPATH = NONE
FINALNAME = NONE
EXTENSION = NONE
ENCODEREXE = J:\Music\MAREO\wavegain.exe
PARAMETERS = --radio --apply --noclip --limiter "<SOURCE>"
RENAME = FALSE
EXECUTEIF = TRUE
FINALPATH = J:\Music\Lossy\<GENRE>\<1>\<ALBUM>\
EXTENSION = mp3
ENCODEREXE = J:\Music\MAREO\lame.exe
PARAMETERS = -V5 -q0 --vbr-new --ignore-tag-errors --add-id3v2 --noreplaygain --ta "<ARTIST>" --tl "<ALBUM>" --tt "<TITLE>" --tn "<TRACK>" --ty "<YEAR>" --tg "<GENRE>" --tc "<1>" "<SOURCE>" "<DESTTMP>"
RENAME = TRUE
; EOF
With WavPack there is no problem in creating a Field called "ALBUM ARTIST" (-w "ALBUM ARTIST=<1>"). But I can't figure out how to do the same with LAME! There are no addiotional field options (I think). So I had to use --tc (The COMMENTS field) as the future ALBUM ARTIST field!
[Edit: Shortened the .ini file & put it into a codebox]
  • Last Edit: 11 May, 2006, 04:56:02 AM by Realityfreak
  • kwanbis
MAREO 3.0 Released!
Reply #208
thanks for the info. One only thing. Don't need to paste the whole INI file, just relevant parts.
MAREO 3.0 Released!
Reply #209
Yes... Indeed, it is kind of long, sorry for that!
I was in a hurry this morning and couldn't pick out the important parts!
(There is still one thing bugging me... I can't get wvgain in album mode to work, no matter what settings I try! So if anybody should know how to set it up, please tell me)
  • Last Edit: 11 May, 2006, 04:52:19 AM by Realityfreak
  • sh1leshk4
MAREO 3.0 Released!
Reply #210
Guys, you could use the codebox tag for those lengthy .ini or .log file.
This is a codebox tag.
Code boxes will show a scroll bar when the text length exceeds its dimension.
It's better suited for long texts than a simple code tag.
This is a code tag.
Anyway, kwanbis, I could help you design a site for MAREO if that's fine with you. =)
Oh, and I also 'lost' that copy of 2.1.2; it's in my PC that's currently under repair. =/
Currently using my laptop.
  • start78
MAREO 3.0 Released!
Reply #211
Why don't you create mp3s with id3v1-tags and ape2-tags? The first for porty use and the second kind for flexible tagging.
ini-sample:
; MP3 LAME with APEv2 TAGS (requires wapet.exe)
EXECUTEIF = TRUE
FINALPATH = <MYMUSIC>\<artist>\[<year>] <album>\
FINALNAME = <artist> - <track> - <title>
EXTENSION = mp3
ENCODEREXE = wapet.exe
PARAMETERS = "<DESTTMP>" -t "Artist=<artist>" -t "Album=<album>" -t "Title=<title>" -t "Track=<TRACKPADDED>" -t "Year=<year>" -t "Genre=<genre>" -t "Totaltracks=<1>"  -t "Album Artist=<2>" lame.exe -V4 --vbr-new --id3v1-only --ignore-tag-errors --ta "<artist>" --tl "<album>" --tt "<title>" --tn "<TRACKPADDED>" --ty "<year>" --tg "<genre>" "<source>" "<DESTTMP>"
RENAME = FALSE
For this sample, you should pass number of total tracks first and album artist second. Both after the usual parameters, of course! And wapet.exe and lame.exe should be in the same folder as mareo.exe, because wapet.exe gets confused otherwise!
I would leave id3v2-tags if you don't need them for some reason. AFAIK using both ape- and id3v2-tags is not recommended...
The totaltracks-field can be very handy (for example for some columns ui-presets in foobar2k).
  • Last Edit: 11 May, 2006, 05:15:49 AM by start78
  • GHammer
MAREO 3.0 Released!
Reply #212
I fear I am suffering from terminal denseness. How can I use any of the 'CLEAN' parameters?
first, the clean parameters are <XXXclean>, and not <cleanXXX>.
second, why would you use them if you don't need them? you are not required, and infact probably shouldn't be using it.
Oh, I missed that in the ini included.
;  <1> .. <N>              Any parameter passed by the ripper to MAREO, after the genre.
;  <CLEANARTIST>           (filename friendly) CD Artist Name
;  <CLEANALBUM>            (filename friendly) CD Name
;  <CLEANTITLE>            (filename friendly) Track (Song) Name
;  <CLEANTRACK>            (filename friendly) Track (song) Number
;  <CLEANYEAR>             (filename friendly) Year of the CD release
;  <CLEANGENRE>            (filename friendly) CD's Music Genre
;  <OWNPATH>               the full path to MAREO, without the the ending backslash, example: c:\encoders
I am unable to use MAREO with foobar 0.9.x
It is called and a process is created but a window never opens and I must kill MAREO from task manager.
No log is left behind.
fb2k 0.9 its a little problematic, as it hiddes the application it's calling. But MAREO should be working behind. Mine is working perfectly. Why don't you try to run it first from a command prompt, and see if it runs ok?
Runs fine from command line, fb 0.8.3, eac.
Doesn't run from fb 0.9x, though it does get loaded.
  • GHammer
MAREO 3.0 Released!
Reply #213
Ok got that all figured out now. I just found out that mp3gain can't be run on a directory with spaces even putting the directory in ""?  I wanted to do mp3gain in album mode and can't get it to run on a directory with spaces. Anyone using mp3gain that could enlighten me?
Actually, it does work if the directory is enclosed in double quotes.
PARAMETERS = /p /k /r /d 1.0 /s s "<DESTTMPFULLNAME>"
EXECUTING: D:\Encoders\mp3gain.exe /p /k /r /d 1.0 /s s "D:\Transcode\AC_DC\Highway to Hell\AC_DC - 02 - Girls Got Rhythm.mp3"
Or from a command line:
D:\>mp3gain.exe /p /k /r /d 1.0 /s s "D:\Transcode\AC_DC\Highway to Hell\AC_DC - 02 - Girls Got Rhythm.mp3"
No changes to D:\Transcode\AC_DC\Highway to Hell\AC_DC - 02 - Girls Got Rhythm.mp3 are necessary
  • kwanbis
MAREO 3.0 Released!
Reply #214
i'm using 0.9.2 beta 2
you mean wavegain in album mode? what are you doing?
but you are running in track mode, not album mode ... track mode works fine ... album mode not ... so i created the <FINALPATHSHORT> placeholder, which works.
i actually decided on using blog:cms, cause my main problem is that i don't want to edit html, and blog:cms uses a very good word-processor-like editor ... but i can use some help with the template/skin of blog:cms if you feel like.
MAREO 3.0 Released!
Reply #215
No, I mean wvgain for WavPack.
What I'm doing? That's exactly it... I can't figure it out!
  • kwanbis
MAREO 3.0 Released!
Reply #216
should be the same as mp3gain in album mode, send me a link to wvgain.exe
MAREO 3.0 Released!
Reply #217
Problem has been solved... (Thanks to madxcream)
The wvgain.exe file is included in the WavPack directory from www.wavpack.com [ http://www.wavpack.com/wavpack-4.31.zip ]
I simply forgot to add some quotes! (Small object, big importance!)
The setup would be:
; WvGain
FINALPATH = NONE
FINALNAME = NONE
EXTENSION = NONE
PARAMETERS = -a "J:\Music\Lossless\<GENRE>\<1>\<ALBUM>\*.wv"
RENAME = FALSE
  • Last Edit: 11 May, 2006, 03:12:14 PM by Realityfreak
  • madxcream
MAREO 3.0 Released!
Reply #218
Question, For me I use LASTTRACK because Plextools cannot pass the # of tracks at the moment, so I was wondering if you can use the variable LASTTRACK to pass as a field to the encoders for tagging?
  • Last Edit: 11 May, 2006, 03:26:20 PM by madxcream
  • kwanbis
MAREO 3.0 Released!
Reply #219
good idea ... i would implement it ... give me some minutes.
  • madxcream
MAREO 3.0 Released!
Reply #220
ini-sample:
EXECUTEIF = TRUE
EXTENSION = mp3
RENAME = FALSE
When I add the ape 2 tag, the id3v1 tag doesn't show anymore in winamp or WMP. Foobar sees the ape tag though. I thought maybe it was a wapet execution problem so I try adding the ape tag using Tag.exe to a mp3 that had just id3v1 tag and same thing happens. Not sure why it's not keeping both.
  • start78
MAREO 3.0 Released!
Reply #221
I tested some files in winamp and saw all id3v1 infos in the file info window, so it seems to recognize the id3v1 tags (winamp 2.51 here). Not shure what wmp does....
  • Last Edit: 12 May, 2006, 03:58:05 AM by start78
  • kwanbis
MAREO 3.0 Released!
Reply #222
ok, been implemented.
Now, when MAREO starts, it tries to read the mareoLAST.INI, and if found, it assigns the value to the [LASTTRACK] placeholder.
Also, i have changed the <> to [] cause it was messing arround with HTML code.
  • Last Edit: 12 May, 2006, 01:40:49 PM by kwanbis
  • madxcream
MAREO 3.0 Released!
Reply #223
Thank You!
  • sidewalking
MAREO 3.0 Released!
Reply #224
My bad - a search pulled this older topic up first.  Editing to post in (more) appropriate MAREO 4.0 thread here.
  • Last Edit: 12 June, 2006, 05:13:34 PM by sidewalking
