Topic: foo_vis_projectM (Read 30520 times) previous topic - next topic
Re: foo_vis_projectM
This is a really nice plugin, but somehow the mentioned shortkeys under the github page not working in foobar2000.
Right clicking changes the current visualization and it seems only some of the Shift + <key> shortcuts are working too.
K33pSm1l1ng
The only thing implemented is right mouse button click - switch to next preset.
Thank you for porting this. It works great and looks amazing at 4k. I do have one suggestion if at all possible: to add a hotkey to lock the current visualization. What happens is, I will see a really nice one but then it changes automatically to something not as nice. So a lock feature would be fantastic and greatly appreciated.
It works well here.
Is there a way to transfer my old presets from Schpeck/Winamp Milkdrop to this new ProjectM? How can you access the ProjectM settings etc? Where are the ProjectM presets stored?
It works well here.
Hi darkflame23 !
Good to read this)
Presets are stored here: "C:\Users\<user>\Application Data\foobar2000\user-components\foo_vis_projectM\presets".
I don't know about presets compatibility (are old presets working with current version or not).
Reply #30
Hi vladim1r !) Thanks for feedback!
I'll take this into account when I'll make a new version.
Is there any way to increase the sensitivity of the visualizations? I end up with a lot of visualizations that seem to be unaffected by the music at all, or have only a very small effect. Static single-color screens, very small squiggles in the very center of the screen, etc. Many of visuals are very nice, but have very little difference between Pause and Play... :(
Reply #35
iridescentaudio, GM_Prod
You can always check official build.
https://store.steampowered.com/app/1358800/projectM_Music_Visualizer/
The last time I tried this it also didn't work, however, after trying it again yesterday an update was downloaded, which included the Microsoft C++ Redistributable. Now it works! So that's progress.
I've since restarted my system and also downloaded a fresh portable copy of the latest foobar2000 for testing, installing only this component. I was optimistic that it would work, but unfortunately it still isn't working. It isn't essential that I use projectM within foobar2000 since it'll pick up sound from foobar2000 either way, but it would be nice to cut out the Steam middleman.
Reply #36
C++ runtime is 100% not a reason.
Reply #37
IS THERE A FIX FOR MY PROBLEM? It's been two weeks since I've posted a report.
EDIT: If no, how do I install the Steam version in foobar2000?
Reply #38
Hi
Is it use the ancient MilkDrop visualiser or using the latest avaliable one the MilkDrop 2.25c?
Regards
szabi
Reply #39
Just released a new version 0.0.2.
Built from latest projectM source tree.
https://github.com/projectM-visualizer/projectm
Some options added (press right mouse button to show menu).
All presets & textures from "Cream of the Crop" database added (9,795 Milkdrop presets).
https://thefulldomeblog.com/2020/02/21/nestdrop-presets-collection-cream-of-the-crop/
Database is ~120 Mb in size.
Project now uses C-API and moved to separate github repository.
https://github.com/djdron/foo_vis_projectM
Grab it here.
Or just update it inside foobar2000.
Reply #41
You have a context menu bug where you can't access any stand fb2k element commands when layout editing mode is enabled. This means once you've added it, it's impossible to remove from a layout without uninstalling the component...
You need to add code something like this to your OnContextMenu...
if (m_callback->is_edit_mode_enabled()) {
SetMsgHandled(FALSE);
return;
Reply #42
marc2k3
Thank you for hint.
Also I found another bug - context menu is not visible in full screen mode on one of my computers.
Reply #43
Updated to version 0.0.3
Fixed context menu in layout editing mode.
Fixed crash when switching presets with multiple projectM instances.
Fixed OpenGL objects leaks.
Reply #44
Hello,
on my installations (Windows 7 and 10 PC) projectM not available from "Visualization" submenu section in "Live Editing" mode with a right-click.
Neither in "Preferences" under ColumnsUI -> Layout -> Insert Panel -> Visualisations.
Only under View -> Visualizations in the menu bar it is selectable as an additional window.
Reply #45
Because Columns UI is not supported.
It's discussed in this topic, vote for support on CUI github)
Reply #46
Oh, I must have missed that probably because of my temporary lack of understanding of the abbreviations CUI & DUI.
Is there support for CUI planned for it or is it out of your responsibility/control?
Sorry, I don't understand everything as English is not my first language.
Reply #47
It's not planned, I hope developers of CUI will just add support to insert standard UI elements.
Reply #48
Without support for CUI, it is basically difficult to get more users, of course, the developer is not obliged to support it...
Reply #49
Is there any stats how many foobar2000 users use Columns UI?
I even didn't heard about it while someone reported that projectM plugin not works with it.
