Topic: foo_vis_projectM (Read 30523 times) previous topic - next topic
Re: foo_vis_projectM
Reply #52
I've been using foobar2000 for 10+ years and always with ColumnsUI.
Reply #53
Updated to version 0.0.3
Fixed context menu in layout editing mode.
Fixed crash when switching presets with multiple projectM instances.
Fixed OpenGL objects leaks.
Can you please re-implement a shortcut to skip the current visual? right mouse button click - switch to next preset no longer works in fullscreen mode 0.0.3
Other ideas for 0.0.4:
  • View current visual name
  • Ban/Delete current visual
Reply #54
0.0.4 is out.
Presets & Textures folders (9K files) moved to data.zip.
Resizing events processing optimization.
Reply #55
You mean context menu is not appeared in full screen mode?
Or Next Preset option not works?
Reply #57
Version 0.0.5 is out.
Popup menu in fullscreen mode fixed.
Reply #58
Just thought I'd mention that the Github link in the OP 404s. Apparently the repo name was changed so the working link seems to be this. I think users with dev status have the permissions to update old OPs but could be wrong.
Reply #59
Coreda Thanks, fixed.
Reply #61
64 bit compatibility added
Reply #62
I love that someone is still developing a Milkdrop based app, but what I'm missing from Milkdrop are all the configuration settings, and the ability to manage your own presets. Are these functions likely to be added to ProjectM in future?
Reply #63
darkflame23
I recommend to use official projectM on Steam.
Edit presets, etc.
Then place them inside C:\Users\<your user>\AppData\Roaming\foobar2000-v2\user-components\foo_vis_projectM\data.zip
This plugin supports presets only inside zip archive (because foobar2000 unpacking time of ~10K files when installing plugin was too long).
Reply #66
Thanks. I gave it a try, some presets work but some don't (a lot of the really cool ones by Martin/Nitorami). I think I'm gonna stick with Shpeck and the old Milkdrop until the ProjectM component becomes a bit more mature. I really miss all the quality settings too, you could really adjust things to your own system/graphics card.
Reply #67
darkflame23
Also could you send bug reports if something rendered not correctly? To their github.
Reply #68
Nah, Milkdrop still works flawlessly under Schpeck, so I'm afraid I don't have the time to do unpaid beta testing for ProjectM. I'll come back to it when it has the full functionality that Milkdrop has, they need to aspire to that, IMO.
Reply #69
Hello. Are there any plans to further update this component?
It seems to lack features that standalone projectM can do through keyboard commands (show preset name/stats). I love the visualizations and this component seems to run smoothly and seamlessly but I'd like to be able to choose specific presets (which if I'm not mistaken, isn't possible at the moment) and if possible, to have a list of all presets on the options menu that'd let you block some presets or mark some as favourites. That's my suggestion. Thanks for the component!
Reply #70
I even didn't heard about it while someone reported that projectM plugin not works with it.
I wondered why it didn't show up when trying to add a panel! lol
foobar2000  x64
Reply #71
Is there any way for this visualizer to start in fullscreen without needing to toggle it manually every time?
Reply #72
Incredible job, nostalgia for Winamp hit me hard man, thank you so much for porting the plugin to foobar2000! I'd say the experience is even better as foobar2000 has Windows theme support meaning I can dock side to side with another.
Reply #73
Would be better to do a complete port of Milkdrop to DX11/Vulkan/OGL4.
Such ports for OGLESv2/GL4 already exist. 64bit is another matter entirely, since the script parser VM would need to be completely rewritten. It extensively uses x86 assembly in the JIT and that would need to be completely regutted.
Reply #74
First of all: Great job making this for the 64 bit version! Unfortunately I prefer Milkdrop 2 by a mile over Milkdrop so I have to keep using the 32 bit version of foobar2000 with Shpeck.
Any chance you can make your component work with Milkdrop 2 presets?
