Poll
MP3
~100 kbps or less
[ 10 ] (2.1%)
~130 kbps
[ 32 ] (6.7%)
~145 kbps
[ 12 ] (2.5%)
~160 kbps
[ 28 ] (5.8%)
~180 kbps
[ 45 ] (9.4%)
~200 kbps
[ 66 ] (13.8%)
~225 kbps
[ 38 ] (7.9%)
~260 kbps
[ 60 ] (12.5%)
320 kbps
[ 62 ] (12.9%)
I don't encode to MP3
[ 127 ] (26.5%)
Total Members Voted: 520
Topic: What bitrate do you use? (2011) (Read 79107 times) previous topic - next topic
It was a long time since poll like this. It will be interesting to see what bitrates people use in 2011.
Please, move this topic to the poll section.
Ogg Vorbis, q5.0 (LancerMod SSE3).
Music washes away from the soul the dust of everyday life.
I would rather target a quality than a specific bitrate.
hm.. I answered ~180 for MP3 because that the average of a few albums I just selected.
But I agree with Nick, since I just use -V2.
The biggest change since the last poll I participated in is that storage is so cheap now that I really don't need to care about bitrate.
The complicated thing is that if options would be target bitrate then I should mention ALL of settings like VBR/ABR/CBR and even 2-pass ABR/VBR. Plus it would make the poll unreadable with all settings.
If I go only for -Vx then it's limitation for not LAME users http://www.hydrogenaudio.org/forums/index....st&p=640471
So the decision was to go as generic as possible. No settings.
BTW some quality labels are really funny like  "deaf, radio, insane.... braindead?". How about  "superman, batman, wolverine, ironman and  wonder woman"
Where's guru and the 2011 ripping/encoding general poll?
WavPack 5.7.0 -b384hx6cmv / qaac64 2.80 -V 100
ogg vorbis @ q5 (~160kbps). i've never bothered with listening tests (too lazy) so i had a search around and this seemed to be a popular choice of codec/setting and i just went with it.
I was using Vorbis at q 4 previously but found several tracks in my own library with obvious artifacts (mainly but not only metal tracks), so I did some ABX tests and concluded that q 5 is safe.
MP3 requires too much bitrate to be transparent, so I'm not using it anymore.
Opus 96 kb/s (Android) / Vorbis -q5 (PC) / WavPack -hhx6m (Archive)
I was encoding @mpc-q5 till 2006,switched to oggV till 2009 @q5,and 2010 i just go lossless couse hd are so cheap
AAC (Nero or QuickTime) at VBR around 130 kbps.
Quality is really strong to my taste and for portable use. There are some minor annoyance from time to time, but I easily forgive them. I have everything in lossless formats at home.
(thanks for this poll too)
I rip only to FLAC so bitrate is pointless to argue about there.
When I'm transferring to a DAP, I transcode to ogg vorbis at -q2 (~96Kbps)
If I'm transferring to a DAP that doesn't support ogg vorbis (of which I own none), then I transcode to mp3 using lame -V2 (~196Kbps)..
To me vorbis loses most annoying artifacts at -q2 (~96Kbps), and becomes transparent at -q5 (~160Kbps).
To me mp3 loses most annoying artifacts at -V2 (~196Kbps), and becomes transparent at -V0 (~256Kbps).
aoTuV Beta6.02 @ q5 still sound transparent in my own opinion for the given bit rate and file size.
I use NeroEnc -q 0.45 when I need lossy files, which has a bit of a range depending on the audio.
Vorbis @ q6 here.
Non-losslessly speaking, still using Musepack --standard here, SV7 due to slow adoption of SV8 decoders (W*cough*nAmp).
Why Musepack: still appears have the fastest decode speed of lossy formats according to my tests using foo_bench.dll; psy-model/VBR appears to perform well (mpcbits.exe showed bitrates at --standard between 3kbps to over 1000kbps); APE tags; and the comfort of using a format less known for artist exploitation (translation = screw the leechers  ).
In terms of lossless, I use FLAC so bitrates are, as said "pointless
In terms of lossy, I still use the ancient MP3. And even though most people (here) are using VBR, I'm still using CBR, 320kbps though small quantities of my library are encoded in LAME VBR V0 and V2
sin(α) = v sound/v object = Mach No.
I have start to encode in Nero AAC q 0.45 (~150 kbps) after I started to hear differences between Lossless (ALAC) and AAC 128
One good song where I really can hear difference is Red Hot Chili Peppers - Californication, in the AAC 128 encode there is sounds that is missing, but in q 0.45 it is (for me) fully transparent.
foo_abx 1.3.4 report
foobar2000 v1.1.2
2011/03/05 20:37:23
File A: C:\Red Hot Chili Peppers\Californication\06 Californication.m4a
File B: C:\Red Hot Chili Peppers\06 Californication.m4a
20:37:23 : Test started.
20:37:56 : 01/01  50.0%
20:38:31 : 02/02  25.0%
20:39:21 : 03/03  12.5%
20:40:02 : 04/04  6.3%
20:40:40 : 04/05  18.8%
20:41:22 : 05/06  10.9%
20:42:06 : 06/07  6.3%
20:43:09 : 07/08  3.5%
20:43:35 : 08/09  2.0%
20:44:17 : 09/10  1.1%
20:44:45 : 10/11  0.6%
20:45:41 : 11/12  0.3%
20:46:04 : 12/13  0.2%
20:46:25 : 13/14  0.1%
20:46:54 : 14/15  0.0%
20:47:09 : 15/16  0.0%
20:47:39 : 16/17  0.0%
20:47:57 : 17/18  0.0%
20:48:27 : 18/19  0.0%
20:48:45 : 19/20  0.0%
20:49:18 : 20/21  0.0%
20:49:32 : 21/22  0.0%
20:49:54 : 22/23  0.0%
20:50:12 : 23/24  0.0%
20:50:35 : 24/25  0.0%
20:51:07 : 25/26  0.0%
20:51:16 : Test finished.
Total: 25/26 (0.0%)
256 kbps Apple AAC bought iTunes music
Lame V3 (Voted ~180 kbps).
I used V5 for the longest.  But even phones today come with 16GB standard.  It's not such a big deal anymore.  My library grew a couple of gigs.  *shrug*
I use FLAC or WavPack for ripping, but if I need lossy, I'll use LAME V2. If I need really lossy, I'll use Nero AAC -q 0.3.
Since large storage is cheap I just rip to Wavpack with switch -hx.
For my Rockboxed portable I use lame 3.98.4 -V4
64 kbps mono MP3
okay...
For lossy neroaacenc -q0.55.. Occassionally mp3 -v0. Voted ~260/~220
My lossy compression of choice is Ogg (AuToV whichever's-latest) at q6, or ~192kbps (so i selected ~200, as the results usually shoot high of 200).  These days I've gotten my EAC set to rip straight to FLAC (compression level -6, which is the max anyone should bother using IMHO), then I make my lossy copy with oggdropxd (still q6).
