Topic: WSH Panel Mod script discussion/help (Read 1421239 times) previous topic - next topic
Reply #4350
@marc2003
There a trick to use custom backgrounds for newest menu button sample?
Reply #4352
would it be possible to make it so you can change the artist field mapping with the thumbs script? i keep featured artists in the artist tag so using %album artist% for this would be great.
thanks alot for the scripts either way
Reply #4353
the script should have that feature but i've missed it out. right click the panel>configure. replace
var panel = new _.panel("Thumbs", ["metadb", "custom_background"]);
with
var panel = new _.panel("Thumbs", ["metadb", "custom_background", "remap"]);
Reply #4354
Now I'm using Br3tt's foo_Razor Skin after some modification.
There is a toggle script which changes the panel size according "Toggle" state.
I figured out that the panel color can be changed by 'var COLOR_BTNFACE'.
I want to make the color of this panel change between two colors according to the panel size.
For example, for the width=390 : Black, for the width=1 : White.
I'd like to know if this is possible and where I have to change.
Thank you for reading and helping.
var COLOR_BTNFACE = 15;
var toggle = window.GetProperty("toggle", false);
var ww = 0, wh = 0;
//var COLOR_BTNFACE = 15;
var g_syscolor = 0;
function get_colors() {
g_syscolor = utils.GetSysColor(COLOR_BTNFACE);
get_colors();
// START
function on_size() {
ww = window.Width;
wh = window.Height;
if(toggle) {
window.MinWidth = 390;
window.MaxWidth = 390;
} else {
window.MinWidth = 1;
window.MaxWidth = 1;
window.MinHeight = 4;
window.MaxHeight = 4;
function on_paint(gr) {
gr.FillSolidRect(0, 0, ww, wh, g_syscolor);
toggle = !toggle;
window.SetProperty("toggle", toggle);
if(toggle) {
} else {
function on_colors_changed() {
get_colors();
window.Repaint();
function on_notify_data(name, info) {
switch(name) {
case "left_pane":
toggle = !toggle;
if(toggle) {
} else {
break;
function on_mouse_rbtn_up(x, y) {
return true;
Reply #4355
I'm modifying a display panel and I was wondering if anyone can help me find the proper tags to display encoding (lossless), bitspersampe (IE 16 /24).
I'm using commands like:
Info.prototype.setBitrate = function() {
   this.Bitrate = fb.TitleFormat("%bitrate%").Eval();
Tags like "bitrate", "samplerate" and "codec" display fine.  But "encoding" and "bitspersample" do not. Are there other official terms for these tags?
Reply #4357
Thanks. But to answer my own question, I figured it out:
this.Bitrate = fb.TitleFormat("$info(bitspersample)").Eval();
You'd think it would be "%bitspersample%", but no...it couldn't be THAT easy.  Same thing applies to encoding. (Although oddly, encoding displays as lower case only)
Reply #4358
Is there a way to force a font to display uppercase only? IE: Getting "lossless" to display as "LOSSLESS".
Reply #4359
Never mind.  To get upper, you would go: $upper($info(encoding))
Reply #4360
@marc2003
How painful would it be to parse embedded images with the thumbs script? Noticed Falstaff's CoverFlow displays them and was wondering if this could as well.
Reply #4361
i've not tested it because i can't be bothered to embed any art but this should work. open thumbs.js in a decent text editor and find this...
this.images = _.map(this.files, _.img);
insert this directly after it...
var tmp = utils.GetAlbumArtEmbedded(panel.metadb.RawPath, 4); //4 assumes you want the artist image
if (tmp) {
    this.files.unshift(panel.metadb.Path);
    this.images.unshift(tmp);
unshift puts the embedded image first. if you want it last, use push instead.
Reply #4362
Hi, i'm getting this error when trying to import library with lastfm playcount sync
Last.fm Playcount Sync: {"error":26,"message":"API Key Suspended - This application is not allowed to make requests to the web services"}
any help?
Reply #4363
where to begin....
that api key is no longer valid.
last.fm are not allowing anyone to register for a new api key.
even if you did have an api key, the import doesn't even work any more
Reply #4364
Hi marc2003, how do I set the background colour in the rating panel? I can't figure it out. Thanks!
Reply #4365
i did add "custom_background" as an option but i forgot to include this function which is needed for it to work.
    return panel.rbtn_up(x, y);
just paste it at the end inside the panel.
Reply #4366
Do you have a legend for this?
EG: cycle through all types embedded if that is enabled.
Mainly interested in cover & artist but not sure what the key for each is.
Reply #4367
check flags.txt inside the docs folder. but if you just want the front, it's 0.
Reply #4368
Can it be variable? If (any) present = display.
Reply #4369
do you really think the answer to that question could be no?
Reply #4370
Sorry, man. Just asking. Not sure where to look for an example that allows it go both ways.
EG: two panels > one displays embedded (say cover) > one uses embedded artist image without conflicting
edit: clarified example
Reply #4371
just use an artwork panel?? check file>preferences>advanced>display>album art>embedded vs external.
Reply #4372
Yeah, I could do that. I like how your script centers the image is all. Mostly it was just curiosity if it could done as a fallback method if encountered.
edit: Just because.
Reply #4373
you can modify the album art script so it has borders around the edge. replace
    panel.size();
    albumart.w = panel.w;
    albumart.h = panel.h;
with
    panel.size();
    albumart.x = albumart.y = 20;
    albumart.w = panel.w - 40;
    albumart.h = panel.h - 40;
Reply #4374
where to begin....
I see. Anyway any chance to get this script working again?
//show if a track is loved
$ifequal(%LASTFM_LOVED_DB%,1,♥,)
