Topic: WSH Panel Mod script discussion/help (Read 1414036 times) previous topic - next topic
Reply #4325
foobar goes unresponsive making it unusable. it's because it's a thin client pc with a single core VIA cpu @ 1000MHz and my music is on microSDXC card inside a sansa clip+ mp3 player which has really slow read/write speeds. EsPlaylist in library mode works fine on the same setup but i guess that's because it can run at a lower priority. we have no such control with WSH panel and it will use all the resources it can.
Reply #4326
normal with this kind of config ...  try on a true PC with a HDD
Reply #4327
Could it be made to use default stub image instead of the generated no art/image found it uses now?
Reply #4329
Sorry... I have about ten different portable installs for testing right now and, of course, I opened the one that wasn't set.
Reply #4331
JS Smooth Browser 1st beta available for those interrested by:
always interested in your work!
the WSH panel v.156+ is difficult to find and probably a reason for other errors people have posted.
Fantastic response time - I'm using FB over network with 14K+ albums and it works great! I'm guessing prefs will improve later after beta? It would be nice to change label font size and fields displayed.
One issue - the cover display does not seem to take Foobar preferences?
Many of my covers are displaying wrong (back or other images instead of cover.*)
Also not sure if WSH limitation - but if I select an album, it would be nice if other components (like your jsplaylist) follow selection? (and also vice versa - smooth browser can follow selection)
Reply #4332
covers are those set in foobar200 preferences, so it should work as all other foobar2000 panels that uses cover art. Check your settings and if you are sure there is a problem, report it here please, i'll check it
Reply #4333
yes, I'm sure - notice SB versus your correct jsplaylist display:
also - different issue - any idea why that green "83" appears in your jsplaylist at the upper right corner?
Reply #4334
@mjm716
ok, i think i know why front cover is bad in some case. it's due to the cache engine and because you have multiple images in the album folder (right ?), and the script look for front.* or cover.* pattern name only ...
if not found, it take the first image found in the folder (*.*)
if your front cover is named differently than front.* or cover.*, seek for this line in the script:
var cover_img = "*front*.*-*cover*.*-*.*".split("-");
and change the pattern according to yours, for example, if your front covers are named "folder.jpg", remplace the line with:
var cover_img = "*folder*.*-*cover*.*-*.*".split("-");
HTH
Reply #4335
@Falstaff
Is the follow playlist option working as intended? It's doing some really weird things like not selecting items in the playlist and a double click on anything seems to trigger the first item it encounters. No matter what. I placed it in a tab and Facets in another. Facets, in Playlist mode, does pretty much what I'd expect it to. Not sure if this is what you intended or not. Some clarification please.
Reply #4336
thanks - all my front covers are cover.*
I changed it to: var cover_img = "cover.*"
and deleted the cache.
Looking forward to future versions - great work!
PS: also updated by jsplaylist script to 1.32 and the green "83" disappeared.
Reply #4337
@Falstaff
if you're talking about JSSBrowser, this panel do not follow anything. a double click on an item send its content to Library selection playlist and play the 1st track of this item. a single click just send the content to the playlist (not that CTRL key allow you to Add the item contents (tracks) to the Library selection playlist, without clearing it.
i hope that explain you things. if you encounter another behaviour, please, tell me, it's maybe a bug. Thanx
Reply #4338
Updating from 1.5.6 to 1.5.10 - every panel says 'crashed' and this popup appears:
WSH Panel Mod (Damask Art Panel): Microsoft JScript runtime error:
Object doesn't support this property or method
File: <main>
Line: 2006, Col: 14
<source text only available at compile time>
Is there a fix?
Reply #4340
@Falstaff, since i saw someone on your DA page not having the right component version, here's a way you can detect if it has the required features...
if (!("GetLibraryItems" in fb))
    fb.ShowPopupMessage("This script requires WSH panel mod v1.5.9 or higher.\n\nhttps://www.hydrogenaud.io/forums/index.php?showtopic=108811");
Reply #4342
if you mean that code snippet then yes.
if you mean have i tested your script on a proper pc? no. i won't have my own pc running until wednesday.
Reply #4344
if you're talking about JSSBrowser, this panel do not follow anything. [...]
So...are there plans for it to follow whatever playlist is active? I'm curious why it would be an option otherwise.
Reply #4345
as said, this is an earlier beta, all features aren't implemented yet, so, it could be added later, i can't tell yet. for now it is a library browser, simple, nothing more
Reply #4346
I have this in Tag ''Similar'' in mp3:
''Howard Hewett,Keith Washington,Jeffrey Osborne,Miki Howard,Freddie Jackson,Gerald Levert,Lalah Hathaway,Phil Perry,Chanté Moore,Anita Baker,Eric Benét,Atlantic Starr,Mint Condition,Johnny Gill,Regina Belle,Stephanie Mills,Kem,Karyn White,Angela Winbush,L.T.D.,LeVert,Kindred The Family Soul,Frank Mccomb,Rachelle Ferrell,Najee,Boney James,The Whispers,Peabo Bryson,After 7,Carl Thomas,Gerald Albright,Patti LaBelle,Troop,Al B. Sure!,Kenny Lattimore,Patti Austin,George Howard,Tevin Campbell,Rahsaan Patterson,Norman Brown,Jaheim,Jonathan Butler,Dave Hollister,Kirk Whalum,Teena Marie,Pieces Of A Dream,Silk,Hil St. Soul,Walter Beasley,Ledisi ''
How can i add all files from ''Similar'' in Autoplaylist:
I try this:
fb.CreateAutoPlaylist(fb.PlaylistCount, "Tag", "%artist% HAS " + similar.split('/'));
But this adds only one random artist, i need to add all artists from Tag.
Reply #4347
since listenbrainz updated their site to https, my previous script no longer works. an updated version is available here
https://github.com/19379/wsh_marc2003/releases
it's now part of my main package of scripts and has a button/menu instead of settings inside the script.
Reply #4348
@mire777, try something like...
var similar = "Howard Hewett,Keith Washington,Jeffrey Osborne,Miki Howard,Freddie Jackson,Gerald Levert,Lalah Hathaway,Phil Perry,Chanté Moore,Anita Baker,Eric Benét,Atlantic Starr,Mint Condition,Johnny Gill,Regina Belle,Stephanie Mills,Kem,Karyn White,Angela Winbush,L.T.D.,LeVert,Kindred The Family Soul,Frank Mccomb,Rachelle Ferrell,Najee,Boney James,The Whispers,Peabo Bryson,After 7,Carl Thomas,Gerald Albright,Patti LaBelle,Troop,Al B. Sure!,Kenny Lattimore,Patti Austin,George Howard,Tevin Campbell,Rahsaan Patterson,Norman Brown,Jaheim,Jonathan Butler,Dave Hollister,Kirk Whalum,Teena Marie,Pieces Of A Dream,Silk,Hil St. Soul,Walter Beasley,Ledisi";
var arr = similar.split(",");
var query = "";
for (var i = 0; i < arr.length; i++) {
    query += "artist HAS " + arr[i];
    if (i < arr.length - 1)
        query += " OR ";
i've not tested fb.CreateAutoPlaylist to see how long the query strings can be.
Reply #4349
Thanks, it works
var arr = similar.split("/");
var query = "";
        query += " OR ";
function del()
fb.ActivePlaylist = (GetPlaylistID("Genre"));
var PL_NM = (GetPlaylistID("Genre"));
if (fb.ActivePlaylist == PL_NM) { fb.RemovePlaylist(PL_NM)}
del();
fb.CreateAutoPlaylist(fb.PlaylistCount, "Genre", query);
                set_focus();
                fb.Play();
