Topic: Twitter Post (Read 60053 times) previous topic - next topic
Twitter Post
????Twitter??????????????????????????????????????
As Twitter is blocked in China, a proxy setting is really heavilly needed. can you add this setting to the plugin or let us set own APIs?
That will be a GREAT help!
I released new version "foo_twitter_post v1.8.1".
This version enable to set proxy.
Check this version.
Download here
Twitter Post
@kitahei:
Is there any way to change twitter API URL?
since twitter.com is blocked here, I'd like to switch to a twitter api proxy, such as nest.onedd.net/api
Thanks in advance.
Check this version.
Download here
Twitter Post
ええ~ 出来た~!
Viaプロクシサーバはちょっと遅い。でも、ホントに助かったよ。ありがとう。
Fantastic it works!
Although it is much slower to send tweets via proxy, it is better than blocked so it really helps so... Thank you!
Moderation:Removed unnecessary full quote of the preceding post.
Twitter Post
How about autopost on album change?
I think it would be a great options..
IMO, autopost on every track change is very annoying even with intervals .
Twitter Post
Would it be possible to get a recompile of this with the latest foobar sdk? As it doesn't work with foobar 1.0
Twitter Post
Reply #30
Great! Just downloaded.
Twitter Post
love this plugin, but i don't see the twitter post option in the tray icon.??
Twitter Post
I don't get any submenu in the context menu either, even though it's set up to be there...
Twitter Post
Reply #33
It's under Playback in foobar 1.0
Twitter Post
Reply #34
2010/02/21
I released new version "foo_twitter_post v2.0.1".
Note
  • Foobar2000 v1.0 series is needed since this version.
  • The Twitter password is reset, and please set the password in preferences page again when updating it from the version before foo_twitter_post v1.8.1 to this version.
Change Log
  • Rebuild with latest SDK.
  • Changed: OK/Cancel/Apply button in preferences page was enabled.
  • Fixed: The "Post to Twitter" menu was displayed from the Now Playing context menu.
  • Changed: The preservation method of the Twitter password was changed.
  • Changed: The Automatic Post Settings group was made to contain the Other Settings group (preferences page).
Download here
Twitter Post
Reply #35
Sorry. Autopost on album change  is impossible.
Twitter Post
Reply #39
Thanks for the component.
While using the plugin I get the error message on the console
j.mp Error Code : 201
j.mp Error Message : Missing parameter longUrl
For the message I use this code:
[%meta genre%-]Tip des Tages: $if([%album artist%],$cut(%album artist%,38))$if([%album%], - "$cut(%album%,38)")$if(%date%, $char(91)%date%$char(93),) $if(%DISCOGS_LABEL%,$char(91)$cut(%DISCOGS_LABEL%[ %DISCOGS_Catalog%],38)$char(93),[%publisher%])
And for the URL I use:
$if(%DISCOGS_RELEASE_ID%,'http://www.discogs.com/release/'%DISCOGS_RELEASE_ID%,)
The post is posted but not the link. What am I doing wrong?
Regards,
Chris
Twitter Post
Reply #41
The component is really crash happy (using v.2.0.1 on foobar 1.0.3) and posting without comment doesn't work at all.
Twitter Post
Reply #43
kitahei I hope you managed to make the crashes go away. Right now foobar2000 considers this to be crashware if you run the troubleshooter.
Twitter Post
Reply #44
Tried the new version and it doesn't post to twitter. It gives this in the console each time I try and use it.
Twitter Post: Unauthentication.
I've made sure under the preferences that it succeeds with my login details.
Twitter Post
Reply #45
I had the same issue.
Delete the auth and enter again.
Hope it works, did for me.
Twitter Post
Reply #46
Please try following.
  • Authentication is made to succeed.
  • OK/Apply button down in preferences page - important
  • Play next track - important
  • Post to Twitter
Twitter Post
Reply #47
  • Post to Twitter
Twitter Post
Reply #48
V2.0.1 has the possibility of crashing and please make it to crashware.
I will have fixed the bugs of the crash in v3.0.1.
Twitter Post
Reply #49
Works now many thanks!
