Topic: Twitter Post (Read 60716 times) previous topic - next topic
Twitter Post
2011/06/24
I released new version "foo_twitter_post v3.1.1".
Change Log
  • Fixed: Link function of j.mp is disabled.
  • Changed: The setting was reflected at once (Automatic Post Settings is excluded).
  • Changed: The preference page is changed old version (For the division of the crash).
Download here
2010/06/25
I released new version "foo_twitter_post v3.0.1".
Change Log
  • Changed: Corresponded to OAuth(xAuth).
  • Fixed: Foobar2000 crash when executing keyboard shortcut to Twitter Post when you have not played the song.
  • Fixed: Foobar2000 might crash when using "With comment".
  • Fixed: When the compiled link format was empty, URL by j.mp was not shortened.
  • Updated: Rebuild with latest SDK.
(Note 1) Previous versions of foo_twitter_post will be disabled after 2010/08/31 because Twitter changes specifications. Please see here for details. Please update previous version to this version when you use foo_twitter_post after 2010/08/31.
(Note 2) The Twitter password is reset, and please authenticate in preferences page when updating it from the version before foo_twitter_post v2.0.1 to this version.
Download here
2009/05/15
I released new version "foo_twitter_post v1.5.2".
Change Log
  • Change the Google link from TinyURL to bit.ly.
  • Add the manual post function from the menu.
  • Change the composition of preferences page.
Download here
2009/04/24
I released new version "foo_twitter_post v1.4.1".
Change Log
  • Allows you to post manually.
  • Changes strings "Add the link of Google to the end of post format" to "Add Google link at end of post" in preferences page.
Download here
2009/04/22
I released new version "foo_twitter_post v1.3.1".
Change Log
  • You can insert the music retrieval link to Google in the tail of post message.
  • Fixed bug that when interval is 1 in the random mode, it is may not to be posted.
Download here
2009/04/21
I released new version "foo_twitter_post v1.2.1".
Change Log
  • Allow you to use "Reset Page" button in preferences page.
  • Allow you to use "Help" button in preferences page.
Download here
2009/04/20
I released new version "foo_twitter_post v1.1.1".
Change Log
  * Allow you to set post message by Title Formatting.
The default format is below.
Now Playing: TITLE - ARTIST - [ALBUM #TRACKNUMBER]
Download here
For settings, see Preferences -> Tools -> Twitter Post.
2009/04/18
I have released new component.
Introduction
This component post now playing track information to Twitter.
The format is below.
    Now Playing : TITLE / ARTIST
    * This component post basically at intervals of 1 track. However, it is possible to post at intervals between 1 to 1000 tracks in consideration of being disliked.
    * Allows you to set timing to post.
Download here
Twitter Post
Nice work would be cool if you could format the text output to twitter using title formatting.
Thanks for this
Twitter Post
It would be cool if it could also add links to say a last.fm page or sounclound page.
Twitter Post
YAY!    I'd rather tweet music than any inane comment!
Twitter Post
boomtopper san
EdgedInBlue san
You came to be able to use Title Formatting by the latest version.
Please enjoy it and thank you for replies.
Twitter Post
Thanks for the update Kitahei.
One other thing that would be useful is if the reset page button on the preference worked.
Twitter Post
Thanks for the update Kitahei...lovely.
Twitter Post
The client name was updated from "from web" to "from foo_twitter_post" by Twitter API Support Team.
You don't have to update the component.
Twitter Post
boomtopper san
This version works the reset page button and help button on the preference page.
Twitter Post
Thank you so much for your excellent work on this and for sorting this out
Twitter Post
Change Log
Download here
I want you to confirm whether to operate correctly in the site in the foreign country the music retrieval link to Google.
The problem was not in Japanese.
Twitter Post
Wow you have been busy! I can confirm that that google link does work. There is only one small thing thats not quite right but it is minor. On the preferece page for the english version the text next to the check box says "Add link of Google to end of of post format" it should perhaps be "Add Google link at end of post"?
Top notch work this new feature is great it now makes it easier for people to find out what the track i'm listeninig to sounds like now
Twitter Post
Thank you for confirming that goole link does work.
And, today, new version 1.4.1 has released.
Please try.
Twitter Post
Twitter Post
I released new version "foo_twitter_post v1.6.1".
Change Log
  • Allows you to set a free link instead of google link.
  • The default link is searching by google at "%title% %artist% YouTube".
  • Switch default link function to on.
  • Add the default post format to "#music"
Download here
Twitter Post
中国ではTwitterがブロックされたので、使えないようになりました、プロクシのことお願いします~
As Twitter is blocked in China, a proxy setting is really heavilly needed. can you add this setting to the plugin or let us set own APIs?
That will be a GREAT help!
Twitter Post
Hi Kitahei san,
I posted that feature request already to Twitter. Can you add an option which collects the nowplaying info and sends in a bulk mode, i.e. "Every <n> tracks OR Every <n> minutes"...
Also I have a question.
Let's say I've set the slider to "10" and "Random" is checked. Does that mean, your plugin sends every 1-10th track (and randomizes after any sending)?
Thank you!
Twitter Post
I released new version "foo_twitter_post v1.7.1".
Change Log
  • Add function of comment post
  • Delete function "Play and post to Twitter"
  • Change URL shorten service bit.ly to j.mp
  • Change default post format
  • Change default link format
Download here
Twitter Post
????Twitter??????????????????????????????????????
I am sorry for the reply's slowing.
As for the proxy, it is not scheduled to mount at present. I am sorry.
Twitter Post
Hi Squeller san
Thanks for message.
Hi Kitahei san,
I'm sorry English cannot be understood.  What is "bulk mode"?
Please explain a little more in detail.
This means sending at a probability of 1/10.
The possibility that the first track is sent is 1/10.
The second track is also the same 1/10.
Twitter Post
@kitahei:
Is there any way to change twitter API URL?
since twitter.com is blocked here, I'd like to switch to a twitter api proxy, such as nest.onedd.net/api
Thanks in advance.
Twitter Post
Kitahei san, thanks for you reply and explanation.
I meant an option which makes your plugin only post every <n> tracks. Collect all <n> tracks and post them all at one moment, one by one.
Example, let's say the option is set to 4:
play track 1 - Don't post, but remember the track
play track 2 - Don't post, but remember the track
play track 3 - Don't post, but remember the track
play track 4 - Now send 4 twitter posts, starting from 1 to 4.
Twitter Post
Bug with the comment function: It converts special characters like "♫" to "?".
Twitter Post
I released new version "foo_twitter_post v1.8.1".
Change Log
  • Added proxy connection function.
  • Added post function from the Now Playing context menu.
  • The comment window has displayed at the center of the foobar2000 screen.
Download here
