Topic: Burning Offset Corrected (Read 26648 times) previous topic - next topic
Howdy,
I am looking at burning software that will burn "offset" corrected.
Basically I have been ripping with the writing offset added onto the read offset, so when I burn I get a proper copy with offsets set.
This is now an issue as I have a new burner with diffrent write offsets
What I want to do now, is to have all my cd's read offset corrected without the write offset added, so that the original rips are 100% corrected.
Now what I need is a program, that when I burn, I can enter the write "offset" somewhere in the program so that it burns with 100%  corrected offsets.
I am using my Plextor PX-712A.
I know EAC can burn "offset" corrected, but it's a horribile program to work with when it comes to burning discs.
Can NERO write offset corrected? If not what other programs are there?
Cheers and Thanks,
Burgerings
P.S Please don't tell me, not to worry about offsets, i want to!
To date, I know of no other program able to support write offsets. A year ago someone asked Jörg Schilling whether this could be implemented in the CDRTools suite:
>From: "David Williams" <david_h_williams@hotmail.com>
>First of all, I would like extend my profound thanks to Mr. Schilling for
>creating, and making freely available, a simply outstanding program.
>My question is in regards to possible future development, and if the ability
>to set read and write offsets is planned.  If it is not, I would like to go
>on record as being one user who would be very interested in these features.
This is a question you need to ask Heiko...
Jörg
EMail:joerg@schily.isdn.cs.tu-berlin.de (home) Jörg Schilling D-13353 Berlin
       js@cs.tu-berlin.de  (uni)  If you don't have iso-8859-1
       schilling@fokus.fraunhofer.de   (work) chars I am J"org Schilling
URL:  http://www.fokus.fraunhofer.de/usr/schilling ftp://ftp.berlios.de/pub/schily
... but so far there has been no further comment on the possibility of adding this feature. If you are among those interested, feel free to write Jörg and express your opinion (just remember to also thank him for his work, and above all be polite!).
    - M.
Edit: Forgot to close the quote.
Howdy,
MMM, Thats no good...
I wonder if the developer of Burrrn would be interested in implimenting write offset correction? Or any other developer of software...
IWhat do people do to get around this?
Cheers
Howdy,
Cheers
[{POST_SNAPBACK}][/a]
The next version of Burrrn will have it:
[a href="http://www.hydrogenaudio.org/forums/index.php?showtopic=21087&view=findpost&p=223432]http://www.hydrogenaudio.org/forums/index....ndpost&p=223432[/url]
WARNING:  Changing of advanced parameters might degrade sound quality.  Modify them only if you are expirienced in audio compression!
No, Nero does not.
PlexTools burns 0± offset, IIRC.
It seems like there was at least one more but my mind is cloudy.
All Plextors that I know of use -30 Write Offset, if you were using a Plextor before.
It's really better not to use combined offset for archiving, as it appears you've seen.
tec
WOW! That will be GREAT when Burrn support write offsets...Can't wait..
is there an ETA?
Burgerings
PlexToolsPro applies both the read and the write offsets automatically, at least with Premium and PX-712.
Hi, I have the Plextor 712A as well.  This drive has a +ve read offset of +30 and a -ve write offset of -30. So, the combined offset is 0. Thus, if you read and write not using any offsets at all, then your clone will be exactly the same offset as the original.
But, if you want to store un-offseted rips, then you will need to set EAC to +30 and apply -30 to your writer.
Hope this helps.
Ah, you mean your writer has a read and write offset of both -30 samples and a read and write offset correction of both +30 samples. EAC is inconsistent in using the correction/actual values. Look in this post of mine.
I wonder if it's normal (or necessary ?) that a writer's write offset is the same like its read offset. I haven't seen mentioned different offsets so far.
I know that I know nothing. But how can I then know that ?
Any more news on Burrn Supporting this much needed feature?
Burgerings
Hi!
I found a little command line tool, which is able to modify an offset of a wav file on the hard disk. If a burner doesn't support write offset, we can modify the offset before burning. Name: Fix Wav Offset. Link:
http://www.lameb.fsnet.co.uk/
It's included in the Lameb distribution file. It requires Perl for Windows.
Has anybody any experiences with this tool?
Anyone know of any programs lately that allow you to set the write offset
Cheers
Cheers
EAC + CDRDAO package ("Writer" tab of the "Drive Options..."):
[a href="http://www.exactaudiocopy.de/eac6.html]http://www.exactaudiocopy.de/eac6.html[/url]
WavPack 5.7.0 -b384hx6cmv / qaac64 2.80 -V 100
Cheers
[a href="index.php?act=findpost&pid=353062"][{POST_SNAPBACK}][/a]
Yes, I know this..I want a simple program like Burrn or BurnAtOnce to be able to do it..EAC is hard to use..Have a read of this thread
To make things clear, setting a write offset can be implemented in two ways:
1. By over-writing given number of samples to lead-in or lead-out
2. By shifting audio data by a number of samples before burning (so you lose some samples at the beginning or end of the disc)
Unfortunately EAC (+CDRDAO) does the 2nd thing, so it's only a half-solution which you can do by hand in any decent audio editor. Some versions ago it supported over-writing on some Teac drives, but AFAIK it is disabled in the newer versions.
More details in this topic.
Write offset correction is about shifting the audio data burned to disc, and over-writing is just an added element to this. Also you can't over-write into the lead-out without shifting the audio data...
[a href="index.php?act=findpost&pid=353158"][{POST_SNAPBACK}][/a]
EAC's internal writing routines has over-writing into the lead-out enabled for : Teac 56-600, 56-400 and 58. When using cdrdao as writing engine in EAC, then over-writing isn't possible...
Howdy,
Cheers
[a href="index.php?act=findpost&pid=226631"][{POST_SNAPBACK}][/a]
I do have 1.14 b2 and don't know where to adjust the write offset
would you help me
Gambit has offset corrected writing on his todo list for Burrrn v1.14 Final.
WAV Tools can offset WAVs so you can burn with whatever you want.
are there to this moment other programs exept eac which do write with offset correction
