Topic: foo_lnk (Read 3184 times) previous topic - next topic
foo_lnk
Hello. Foosion (which is not on this forum already 4 months) or someone other, make please:
  • adding all duplicates shell link (file .lnk) at draging in playlist;
  • adding name shell link (.lnk) (not the name of the target object) in column "file name" in playlist.
Source code foo_lnk 1.3.1 here.
Re: foo_lnk
Maybe Who help contribute changes in foo_lnk v1.3.1  by the requested features?
Re: foo_lnk
I'll have a go at it.
Re: foo_lnk
I don't understand the requirement. foo_lnk does no filtering.
foo_lnk only resolves the *.LNK file and presents the resulting file path to foobar2000. It can not manipulate meta data.
Re: foo_lnk
Foo_lnk not add all duplicates *.lnk files.
Names *.lnk files it meta dates? You can teach foo_lnk manipulate this?
Re: foo_lnk
And can whether foo_lnk presents paths themselves *.lnk files?
Re: foo_lnk
Hi. Pqyt?
Re: foo_lnk
I don't know how to answer your question because it does not make sense.
The plugin simply translates an *.LNK to its target. Why would you want to keep a reference to the source *.LNK of a file in a playlist?
Re: foo_lnk
@pqyt
Shell Link Resolver (foo_lnk) 64bit compatible:
Where do i download this from?
SHURE SRH1840, SENNHEISER HD660S2, SENNHEISER HD 490 PRO, DT 1990 PRO, HiFiMAN Edition XS, Bowers & Wilkins P7, FiiO FT5, 水月雨 (MOONDROP) 空鳴 - VOID, Nakamichi Elite FIVE ANC, SONY WH-ULT900N (ULT WEAR) (made a Upgrade/Balanced Cable by myself)
Re: foo_lnk
I haven't found the time to package it yet.
Re: foo_lnk
@pqyt
Thanks. :)
Re: foo_lnk
Hello. Apologize for absence. You about playli*.fpl?
