Topic: Looking for help (Read 2361 times) previous topic - next topic
Looking for help
Hello everybody, recently I signed up for an account in the forum, read some articles, believe can solve the puzzles here, hoping to get some help. I want to code for foobar2000, but I tried for so long was not able to run a successful example, can not be started, anybody can give me some advice  on where to find information on getting started, or even a small example can run in vs2015 . Thanks again.
Re: Looking for help
There is an example component bundled with the SDK- foobar2000\foo_sample\foo_sample.sln
You need to download WTL and extract it somewhere. In the solution explorer, right click foo_sample project>Properties>VC++ Directories>Include directories. Add the include folder from inside the wtl folder like this...
Repeat the above steps for the foobar2000_ATL_helpers project. You can get WTL here...
https://sourceforge.net/projects/wtl/
To compile make sure you set the active config to Release|x86 or Debug|x86 (it defaults to x64 on a 64bit system which won't work).
marc2003, thank you, I downloaded the file, try testing ^-^
Hello everyone,  how to solve this error, thanks!
Look at the last sentence of my original post concerning the Active config. You do this by selecting the root in the Solution explorer and then opening the Properties panel. By default it's collapsed on the top right of the layout. This is a different solution but you get the idea...
marc2003, thanks again. Now everything is running correctly, Here is a screenshot:
I can confirm this works as well. Topic should be linked and/or stickied somewhere.
