Topic: FLAC command line options to convert stereo to mono (Read 4936 times) previous topic - next topic
I ripped The Beatles in Mono to FLAC.  Even though the tracks are "mono," they're actually stereo, with each channel being identical.  Is there some flac command line magic I can do to knock them down to one channel without having to re-rip everything?  Seems a waste of space to have "mono" tracks at twice the size they need to be.
You can't do that with the FLAC command line tool (as it only does lossless operations), you'll have to use something like SoX or another tool. This is intended behaviour.
There will be no difference in file size between mono and dual-mono FLAC files.
Why would there be no difference?  Shouldn't a mono file only have one channel in it, vs the two in there now?
I would never have suspected that but sure enough.  Same mono file converted to "stereo":
1-channel: 18.6 MB (19 520 182 bytes)
2-channel: 18.6 MB (19 532 503 bytes)
FLAC is pretty clever. If you're using the default compression level (5) or higher, it will detect that left and right are identical, and save space by only compressing a single channel of audio. (It can also do this at some of the lower compression levels, but not all of them. You might get a smaller file at level 2 than at level 3, for example.)
Gotcha!  Thanks for the info.
Why not? Stereo decorrelation is perhaps the easiest way to losslessly compress a file.
You may find that the Beatles material is actually 99-point-something percent mono, being identical channels when mastered at 24/96 or whatever, but then made different due to dither added during conversion to consumer formats.
There was some discussion of this previously in these threads:
http://www.hydrogenaud.io/forums/index.php?showtopic=77630
http://www.hydrogenaud.io/forums/index.php?showtopic=107566
