foobar2000 1.3.9 beta discussion
Reply #14 – 2015-09-15 08:55:07
In v1.3.9b2 the "Cursor follows playback" highlights the current playing track, but the highlighted track is on top or bottom in the playlist view when using random/shuffle playback. Before, in v1.3.8 the highlighted track was always in the middle of the playlist view when using random/shuffle playback. 1.3.8 wasn't always in the middle, was in much more occasions in the middle, 1.3.9 is almost always on top or bottom and sometimes in the middle, not sure it's an issue though. Well, it's not really an issue. It's just unexpected behavior, as I'm used to current playing track to be highlighted in the middle of the playlist view. Maybe the new behavior for the playlist view is unintentional? We'll see in the next beta... It was a side effect of another change: don't scroll the focused item to the middle of playlist when using cursor keys to walk playlist. It's been resolved in beta 3: explicitly highlighting the now playing item centers the playlist again.What's the difference from beta and stable, is it worth it to just use BETA? that was the first thing I Installed but due to me believing it didn't recognize my audio driver, I uninstalled it. and If I were to choose to upgrade to beta how should I do it without losing components or anything?Sorry if this doesn't belong here. Unless one of the fixes mentioned in the change log is relevant to you, you're probably better off using stable. Just install the desired version over your existing installation - without uninstalling - and all your settings and components will remain there.
