Topic: EAC file creation errors. (Read 1769 times) previous topic - next topic
I am not sure what the problem is. I've included the log. Any help will be appreciated. Thank you.
Exact Audio Copy V1.0 beta 3 from 29. August 2011
EAC extraction logfile from 28. December 2012, 15:06
Oktober / Projekt Building
Used drive  : HL-DT-STDVD-RAM GH22LS30  Adapter: 0  ID: 0
Read mode              : Secure
Utilize accurate stream : Yes
Defeat audio cache      : Yes
Make use of C2 pointers : No
Read offset correction                      : 102
Overread into Lead-In and Lead-Out          : Yes
Delete leading and trailing silent blocks  : No
Null samples used in CRC calculations      : Yes
Used interface                              : Native Win32 interface for Win NT & 2000
Gap handling                                : Appended to previous track
Used output format              : User Defined Encoder
Selected bitrate                : 768 kBit/s
Quality                        : High
Add ID3 tag                    : No
Command line compressor        : C:\Program Files (x86)\Exact Audio Copy\FLAC\FLAC.EXE
Additional command line options : -6 -V -T "ARTIST=%artist%" -T "TITLE=%title%" -T "ALBUM=%albumtitle%" -T "DATE=%year%" -T "TRACKNUMBER=%tracknr%" -T "GENRE=%genre%" -T "COMMENT=%comment%" -T "BAND=%albuminterpret%" -T "ALBUMARTIST=%albuminterpret%" -T "COMPOSER=%composer%" %haslyrics%--tag-from-file=LYRICS="%lyricsfile%"%haslyrics% -T "DISCNUMBER=%cdnumber%" -T "TOTALDISCS=%totalcds%" -T "TOTALTRACKS=%numtracks%" %hascover%--picture="%coverfile%"%hascover% %source% -o %dest%
TOC of the extracted CD
    Track |  Start  |  Length  | Start sector | End sector
        1  |  0:00.00 |  2:58.14 |        0    |    13363
        2  |  2:58.14 |  3:55.12 |    13364    |    31000
        3  |  6:53.26 |  3:24.39 |    31001    |    46339
        4  | 10:17.65 |  3:30.49 |    46340    |    62138
        5  | 13:48.39 |  3:53.17 |    62139    |    79630
        6  | 17:41.56 |  3:46.10 |    79631    |    96590
        7  | 21:27.66 |  3:23.31 |    96591    |  111846
        8  | 24:51.22 |  4:03.05 |    111847    |  130076
        9  | 28:54.27 |  4:07.61 |    130077    |  148662
      10  | 33:02.13 |  2:39.01 |    148663    |  160588
      11  | 35:41.14 |  3:40.70 |    160589    |  177158
      12  | 39:22.09 |  3:08.25 |    177159    |  191283
      13  | 42:30.34 |  3:23.09 |    191284    |  206517
      14  | 45:53.43 |  3:20.64 |    206518    |  221581
      15  | 49:14.32 |  4:18.13 |    221582    |  240944
      16  | 53:32.45 |  4:51.42 |    240945    |  262811
Track  1
    Filename D:\Rip\Music\Oktober - 01 - In The Building (Front Entrance) .wav
    Pre-gap length  0:00:02.00
    Copy aborted
Track  2
    Filename D:\Rip\Music\Oktober - 02 - NYC.wav
    Peak level 92.1 %
    Extraction speed 1.6 X
    Track quality 100.0 %
    Copy CRC D28F589B
    Track not present in AccurateRip database
    Copy OK
Track  3
    Filename D:\Rip\Music\Oktober - 03 - Beefeater.wav
    Peak level 92.1 %
    Extraction speed 1.5 X
    Track quality 99.9 %
    Copy CRC 0E715832
    Copy OK
Track  4
    Filename D:\Rip\Music\Oktober - 04 - Four Korners.wav
    Peak level 96.6 %
    Extraction speed 1.9 X
    Copy CRC 3FBC9B17
    Copy OK
Track  5
    Filename D:\Rip\Music\Oktober - 05 - Stay In Line.wav
    Peak level 96.6 %
    Extraction speed 2.1 X
    Copy CRC 33AA339B
    Copy OK
Track  6
    Filename D:\Rip\Music\Oktober - 06 - Digamelo.wav
    Peak level 96.6 %
    Extraction speed 2.2 X
    Copy CRC F393E056
    Copy OK
Track  7
    Filename D:\Rip\Music\Oktober - 07 - Dont Want Hell .wav
    Copy aborted
Track  8
    Filename D:\Rip\Music\Oktober - 08 - Frostbitten.wav
    Peak level 85.3 %
    Extraction speed 2.5 X
    Copy CRC BDF6FD34
    Copy OK
Track  9
    Filename D:\Rip\Music\Oktober - 09 - On My Mind .wav
    Copy aborted
Track 10
    Filename D:\Rip\Music\Oktober - 10 - Letter Zero .wav
    Copy aborted
Track 11
    Filename D:\Rip\Music\Oktober - 11 - Sounds Like Drama .wav
    Copy aborted
Track 12
    Filename D:\Rip\Music\Oktober - 12 - Reset The Game.wav
    Peak level 98.1 %
    Extraction speed 2.6 X
    Copy CRC 7D4EEACC
    Copy OK
Track 13
    Filename D:\Rip\Music\Oktober - 13 - Hell To Pay .wav
    Copy aborted
Track 14
    Filename D:\Rip\Music\Oktober - 14 - None Wanna Die.wav
    Peak level 96.6 %
    Copy CRC 4E2A9C03
    Copy OK
Track 15
    Filename D:\Rip\Music\Oktober - 15 - Murder Me In My Sleep .wav
    Copy aborted
Track 16
    Filename D:\Rip\Music\Oktober - 16 - In Your Eye (Back Exit).wav
    Peak level 96.6 %
    Extraction speed 3.6 X
    Copy CRC 8675A6F8
    Copy OK
 9 track(s) not present in the AccurateRip database
 7 track(s) not fully ripped for AccurateRip lookup
No tracks could be verified as accurate
No errors occurred
End of status report
cheers,
kmplsv
"idleness is the holiday of fools."
Nevermind, problem solved. I had a lot of accidental spaces at the end of some of the track names and it was causing the issue.
cheers,
kmplsv
