Topic: m-TAGS component (foo_tags) (Read 174699 times) previous topic - next topic
Re: m-TAGS component (foo_tags)
Reply #350
I use this component for backup purposes only between two disks.
But i thing there is a problem when m-tags files already exists in folders because it seams that it can't overwrite ( although i have check it to do so ) the old files with the updated tags.
So i have to delete the old files and create new every time i want to make a backup.
Also when i have lyrics in a tag m-tags only writes a dot (.) . Is this normal.
Anyway thanks for this great plugin and i hope in future development.
Reply #351
I want to use this component for backup purposes only between two disks.
sorry i made a mistake in the first line
Reply #352
I had no issues with m-tags this far though today I noticed it was somewhat broken. While it still displays tracks perfectly fine it only shows about a third of all indexed files when I have the filter on artists rather than year, album title or genre. Is there any way to resolve this issue without having to re-add every single !.tags file?
Artist: https://i.imgur.com/6FBMkvT.png
Album title: https://i.imgur.com/G8peV0Q.png
Year: https://i.imgur.com/YCs77pt.png
Reply #353
Never mind. Just had to remove the Artist tab and add it and it was back to normal.
Reply #354
Thanks @luigimercurio, m-TAGS seems to be exactly what I needed to make compilations with individual tagging and cover without the burden of having duplicate files.
But how do I export these virtual albums?
File Operations > Copy to... only copies the !.tags and !.tags.front.bin files. So I use Convert to create the new files with applied tagging. Apart from the occasional "Could not attach image/File in use" bug this works as expected and seems a good choice in case of FLAC to FLAC or FLAC to lossy. But I want to avoid transcoding from lossy origin files, so how would I do that?
Reply #355
How can I set up saving music files in a folder without using file Explorer? It's terribly inconvenient to scroll through all the subfolders until you get to the right one
Reply #356
More questions how to create a file not unix and Windows?How do I create my own tag? How do I add it to filters so that the database is indexed by m-tags?
Reply #357
I love this plugin, but I have found a bug related to how album art is displayed: In a generated m-tags file, the 'Properties > Artwork' panel will show attached album artwork for every song except the first song. As soon as I go to play the first song, the album art seemingly disappears. I have confirmed this behavior by adding a blank tag to the beginning of a .tags file, and the same behavior occurs. What is even even more bizarre is if I create a duplicate tag entry with the same '@' reference as the first song in the .tag file, it also fails to display the album art when played. I have illustrated a few examples below:
In this example, both 02.mp3 and 03.mp3 display the album art while playing, but 01.mp3 fails to display it.
      "@" : "01.mp3",
      "@" : "02.mp3",
      "@" : "03.mp3",
In this example, only 02.mp3 would display the album art.
      "@" : "01.mp3",
      "@" : "02.mp3",
      "@" : "01.mp3",
So far, the below example is the only solution I can find -- adding a blank tag to the beginning of the file. This allows all 3 songs to display properly.
      "@" : "01.mp3",
      "@" : "02.mp3",
      "@" : "03.mp3",
I'm unsure if this is a quirk of a newer version of foobar, but trying the same setup on a fresh copy of foobar2000 yields the same result. Has anyone else observed this behavior, and is there some way to change it?
Reply #358
I'm using this great component for several things. One of them involves a folder with many media files in it. So I end up with a single !.tags file containing all relevant information. So far so good.
My question is: how do I doo when I want to add media files to that same folder? I wish there was a way to add these new media files to the already existing !.tags file, without having to delete it and rescan everything all over again. Any suggestions ?
Reply #359
I figured out the solution to my issue. This seems to be a bug in m-tags itself, as it will not query the album art for any file ending in a known file extension if it is the first track in the .tags file, or in a .tags files that contains only one track. My fix was to change the referenced file extension to the URL encoding reference format (e.g. test.mp3 becomes test.%6D%70%33). This has fixed album art appearing for all of my radio stream URLs that ended in a file format, mostly .ogg, .aac, and .mp3.
For anyone else lurking who has encountered this issue, I have pasted the URL encoded extensions below:
.aac = %61%61%63
.ogg = %6F%67%67
.mp3 = %6D%70%33
Reply #360
Good to know! As for my issue, @luigimercurio hasn't been active since 2018 :( Has anybody taken over on this project, or can somebody do it ?...
My question is: how do I do when I want to add media files to that same folder? I wish there was a way to add these new media files to the already existing !.tags file, without having to delete it and rescan everything all over again. Any suggestions ?
Reply #361
Hi, can i suggest to update the component to use the option that foobar 2000 has that is the preserve file atributes?
thanks.
Reply #362
Hi.
Please help :).
I installed this plugin on my Foobar2K but I don't know how to use it.
I want to use the plugin to search for the currently playing song on the online radio, because by default foobar2k does not work correctly, when requesting the variables %title% and %artist%, in the case of the "Run Service" function.
Variables from Foobar2K return to the "Run Service" function, unfortunately only the name of the online radio. Not the title + artist of a song just played from online radio.
That's why I wanted to use the m-TAGS plugin.
Code (service to search the song title in a web-browser, on YouTube):
https://www.youtube.com/results?search_query=$replace(%artist%+-+%title%,' ','+','&','%26','$','%24','@','%40','#','%23')
Screenshots:
THANKS !
Reply #365
Hey!
Any possible chance to upgrade m-tags plug-in for foobar x64?
Reply #366
https://hydrogenaud.io/index.php?topic=117737.0
I installed the foo_dyndec plugin.
And it works now 👍.
@s3n0:  it is no longer necessary to use foo_dyndec or the "d" prefix on search tags to search dynamic radio stream metadata if you are using the latest foo_run plugin version (0.4.5) for the search.  Florian updated foo_run in September of last year to make dynamic searches possible as-is, in both 64-bit and 32-bit versions.
Go ahead and remove foo_dyndec, update foo_run, then just delete the leading "d" in all your search terms and you'll get results from streams just fine!
Reply #367
Is there a way to set up an individual autoplaylist so that it only monitors for m-TAGS (!.tags) files that are in a folder?
I am looking to use m-TAGS on a folder that will peroiodically have audio files added to it, and when those files are added I will be creating m-TAGS files for them.
So it would be nice if the playlist for those m-TAGS files reflected the newly added files automatically.
In my set up the options for creating autoplaylist are through fb2k's Album List and etip's Playlist Organizer.
Or is adding the m-TAGS files manually to a playlist the way to do it?
Perhaps I am overlooking something that is obvious.
Reply #368
I figured it out. With m-TAGS I needed to create the tags in a separate folder, and then configure the foobar2000 Library to monitor that folder.
And in the Album List export those folder(s} having the m-TAGS files in them to an autoplaylist.
Sorry for the false alarm!
On edit:
Still, it would be nice to have the m-TAGS files in the same folder as the audio files and be able to create an autoplaylist from just the m-TAGS files.
