Topic: % and * during Lame Encoding (Read 2927 times) previous topic - next topic
I use --alt-present-standard with LAME 3.90.3 and Exact Audio Copy.
After EAC rips the track and opens the command prompt I can see each bitrate.  Can anyone tell me what the information here actually means?  I tried to do a search on but it wouldn't let me due to the less than three character limit.
For instance
320 [2321] %%%%%%%%********
What do the numbers in the bracket and the % and * mean?  Every track I have encoded on various albums contains both, but on one track from Led Zeppelin one I only saw %'s.
Thanks in advance.
Search the forum for your answer.
Yes thank you.  I actually cannot search on the '%' and '*' characters due to a minimum three character limit in searches.  I'll try elsewhere.
Try the words LAME and histogram.
Ignore Steve here... he's being a jerk.
the % means L/R (stereo) frame, while the * denotes a M/S (mid-side stereo) frame. These only show up when using Joint Stereo.
320 [2321] means 2321 frames (1 frame = 1/75 sec.) encoded at 320kbps.
Different frames are encoded at different bitrates when using VBR modes ; very hard to encode frames are encoded at 320kbps to achieve good quality.
[span style='font-size:8pt;line-height:100%']Anyone correct me if I'm wrong.[/span]
It's in the FAQ, two positions left to the "search" button.
