Topic: Speexenc crushing (Read 18376 times) previous topic - next topic
Speexenc crushing
Greetings,
need convert some audio files to SPX. Used the free binaries from speex.org, particulary speexenc.exe 1.2b3.
I use this string for fb2k converter:
--vbr --quality 8 - %d
I believe there's nothing bad on it.
But suddenly conversin crashes. Error report here:
1 out of 1 tracks converted with major problems.
Source: "E:\xfer\01 - Jambory.mp3"
  An error occurred while writing to file (The encoder has terminated prematurely with code -1073741819 (0xC0000005); please re-check parameters) : "C:\Users\Anakunda\AppData\Local\Temp\01 - Jambory.spx"
Additional information:
Encoder stream format: 44100Hz / 2ch / 16bps
Command line: "D:\media\speex\speexenc.exe" --vbr --quality 8 - "01 - Jambory.spx"
Working folder: C:\Users\Anakunda\AppData\Local\Temp\
  Conversion failed: The encoder has terminated prematurely with code -1073741819 (0xC0000005); please re-check parameters
speexenc does start, at least to print commandline help, just no conversion
Using Win7/x64
Speexenc crushing
When I read the manual I see the options begining with a single hyphen "-vbr", not "--vbr". And -quality 8 is not necessary as it is the default value.
Edit: removed wrong suggestion
Speexenc crushing
Hey thanks!
you were quite rite with the switches.
Now using %s does make work !
A side question, how do I force foobar2000 to use pipe instead file I/O ?
Speexenc crushing
fb2k uses pipe unless you specify %s, then it uses a temporary .wav file.
The reason for crashing when using pipe input (-) might be that fb2k AFAIK uses 0xFFFFFFFF as file length in the dummy WAVE header in piped data.
Speexenc crushing
I'm trying to convert audio files with speexenc.exe. Its basic syntax is extremely simply:
speexenc.exe inputfilename.wav outputfilename.spx
However, when I define a conversion preset, I see that you can only define the output file name (%d); you can't define the input file name.
I would get the following error with the option %d:
Source: "D:\My documents\test.wav"
  An error occurred while writing to file (The encoder has terminated prematurely with code 1 (0x00000001); please re-check parameters) : "D:\My documents\test.spx"
  Encoder stream format: 16000Hz / 1ch / 24bps
  Command line: "C:\Program Files (x86)\foobar2000\speexenc.exe" "test.spx"
  Working folder: D:\My documents\
  Conversion failed: The encoder has terminated prematurely with code 1 (0x00000001); please re-check parameters
I would get the following error with the option %s %d:
  An error occurred while finalizing the encoding process (Object not found) : "D:\My documents\test.spx"
  Conversion failed: Object not found
This would be extremely basic, but I didn't find any information in the manual: where is the input file with default parameters like these ("-S --noreplaygain -V 2 - %d")?  Or, how do you define where the input file would be placed in the command line?
Speexenc crushing
It's in last dash, as pipe which speexenc does not understand so you have to use temp file %s
It's in Destination section in converter
edit: Destination section is for output file of course. For input file you don't have to worry about it (foobar uses %temp% folder)
Speexenc crushing
Thank you for your answer, but it's not clear for me: what would you put in the "parameters" field then? "%s %d" or "%d" don't work.
Speexenc crushing
%s is temporary input file
%d is destination file
for speexenc, you should use both, as it does not accept piping from foobar
Speexenc crushing
"%s %d" should work.
But sometimes foobar2000 cannot recognize speex files, don't know why.
Also, only 8 and 16-bit WAV files are supported. Set "Highest BPS mode supported" to 16.
Speexenc crushing
Thanks again, but what you say doesn't seem to work (see the output window I posted before).
Here are two screen captures; is there anything wrong with these?
Speexenc crushing
If "source track folder" isn't read only medium, then I don't see what could be wrong
edit: OK, lvqcl posted more probable problem
Speexenc crushing
No, just My documents on the hard disk. Does it work for you? If not, I think this should be considered as a bug.
Speexenc crushing
In case you didn't mention: I edited my previous post and added to it:
Speexenc crushing
and make sure you don't have foo_input_celt installed.
Speexenc crushing
Yes! Setting the Highest BPS mode supported to 16 solved the problem (and I don't have foo_input_celt).  Thank you both for your help.
