Topic: Speexenc crushing (Read 13847 times) previous topic - next topic
  • Anakunda
Speexenc crushing
Greetings,
need convert some audio files to SPX. Used the free binaries from speex.org, particulary speexenc.exe 1.2b3.
I use this string for fb2k converter:
--vbr --quality 8 - %d
I believe there's nothing bad on it.
But suddenly conversin crashes. Error report here:
1 out of 1 tracks converted with major problems.
Source: "E:\xfer\01 - Jambory.mp3"
  An error occurred while writing to file (The encoder has terminated prematurely with code -1073741819 (0xC0000005); please re-check parameters) : "C:\Users\Anakunda\AppData\Local\Temp\01 - Jambory.spx"
Additional information:
Encoder stream format: 44100Hz / 2ch / 16bps
Command line: "D:\media\speex\speexenc.exe" --vbr --quality 8 - "01 - Jambory.spx"
Working folder: C:\Users\Anakunda\AppData\Local\Temp\
  Conversion failed: The encoder has terminated prematurely with code -1073741819 (0xC0000005); please re-check parameters
speexenc does start, at least to print commandline help, just no conversion
Using Win7/x64
  • Last Edit: 29 September, 2010, 06:42:35 AM by Anakunda
  • ojdo
Speexenc crushing
When I read the manual I see the options begining with a single hyphen "-vbr", not "--vbr". And -quality 8 is not necessary as it is the default value.
Edit: removed wrong suggestion
  • Last Edit: 29 September, 2010, 07:13:21 AM by ojdo
  • Anakunda
Speexenc crushing
Hey thanks!
you were quite rite with the switches.
Now using %s does make work !
A side question, how do I force foobar2000 to use pipe instead file I/O ?
  • Yirkha
  • FB2K Moderator
Speexenc crushing
fb2k uses pipe unless you specify %s, then it uses a temporary .wav file.
The reason for crashing when using pipe input (-) might be that fb2k AFAIK uses 0xFFFFFFFF as file length in the dummy WAVE header in piped data.
  • Speech
Speexenc crushing
I'm trying to convert audio files with speexenc.exe. Its basic syntax is extremely simply:
speexenc.exe inputfilename.wav outputfilename.spx
However, when I define a conversion preset, I see that you can only define the output file name (%d); you can't define the input file name.
I would get the following error with the option %d:
Source: "D:\My documents\test.wav"
  An error occurred while writing to file (The encoder has terminated prematurely with code 1 (0x00000001); please re-check parameters) : "D:\My documents\test.spx"
  Encoder stream format: 16000Hz / 1ch / 24bps
  Command line: "C:\Program Files (x86)\foobar2000\speexenc.exe" "test.spx"
  Working folder: D:\My documents\
  Conversion failed: The encoder has terminated prematurely with code 1 (0x00000001); please re-check parameters
I would get the following error with the option %s %d:
  An error occurred while finalizing the encoding process (Object not found) : "D:\My documents\test.spx"
  Conversion failed: Object not found
This would be extremely basic, but I didn't find any information in the manual: where is the input file with default parameters like these ("-S --noreplaygain -V 2 - %d")?  Or, how do you define where the input file would be placed in the command line?
  • klonuo
Speexenc crushing
It's in last dash, as pipe which speexenc does not understand so you have to use temp file %s
It's in Destination section in converter
edit: Destination section is for output file of course. For input file you don't have to worry about it (foobar uses %temp% folder)
  • Last Edit: 07 June, 2011, 08:36:40 PM by klonuo
  • Speech
Speexenc crushing
Thank you for your answer, but it's not clear for me: what would you put in the "parameters" field then? "%s %d" or "%d" don't work.
  • klonuo
Speexenc crushing
%s is temporary input file
%d is destination file
for speexenc, you should use both, as it does not accept piping from foobar
  • lvqcl
  • Developer
Speexenc crushing
"%s %d" should work.
But sometimes foobar2000 cannot recognize speex files, don't know why.
Also, only 8 and 16-bit WAV files are supported. Set "Highest BPS mode supported" to 16.
  • Last Edit: 07 June, 2011, 08:47:51 PM by lvqcl
  • Speech
Speexenc crushing
Thanks again, but what you say doesn't seem to work (see the output window I posted before).
Here are two screen captures; is there anything wrong with these?
  • klonuo
Speexenc crushing
If "source track folder" isn't read only medium, then I don't see what could be wrong
edit: OK, lvqcl posted more probable problem
  • Last Edit: 07 June, 2011, 08:57:06 PM by klonuo
  • Speech
Speexenc crushing
No, just My documents on the hard disk. Does it work for you? If not, I think this should be considered as a bug.
  • lvqcl
  • Developer
Speexenc crushing
In case you didn't mention: I edited my previous post and added to it:
  • lvqcl
  • Developer
Speexenc crushing
and make sure you don't have foo_input_celt installed.
  • Speech
Speexenc crushing
Yes! Setting the Highest BPS mode supported to 16 solved the problem (and I don't have foo_input_celt).  Thank you both for your help.
