Topic: MP4 (MPEG-4) player, MP4 AAC audio WinAmp plugin and MP4crea (Read 23726 times) previous topic - next topic
Menno, in collaboration with MPEG4IP-project, has created MP4 player capable of playing MPEG-4 compatible audio&video streams. It's currently the most compatible ISO MPEG-4 audio&video player. Menno has also released WinAmp plugin capable of playing MP4 AAC audio streams. Winamp plugin will play audio part of compatible MP4 audio&video streams or pure MP4 audio streams.
MP4Creator creates ISO MPEG-4 (MP4) streams from (AAC) and/or video (MP4V,DIVX) compliant streams.
Command line Win32 MPEG-4 audio&video player:
http://www.psytel-research.co.yu/downloads/mp4player.zip
MP4 AAC audio WinAmp plugin:
http://www.psytel-research.co.yu/downloads/in_mp4.zip
WinAmp plugin's supported audio AAC profiles are: AAC LC, AAC Main and AAC LTP.
It won't play AAC SSR, AAC LD, ER AAC (LD), CELP or TwinVQ.
Source code for WinAmp plugin can be found at http://www.audiocoding.com CVS.
Source code for MP4Player can be found at http://www.mpeg4ip.net/
Some MP4 audio test streams:
http://www.psytel-research.co.yu/showcase.htm
Some MP4 streams:
http://www.envivio.com/solutions/etv/content/quality.jsp
http://www.mpeg-4player.com/downloads/videos/
To create your own ISO MPEG-4 (MP4) streams, use MP4creator. MP4creator is part of the open source MPEG4IP package
(http://www.mpeg4ip.net/)
It can:
    Juha Laaksonheimo
    Somebody should make a GUI for MP4Player.
    Source code here: http://www.mpeg4ip.net/
    Juha Laaksonheimo
    mp4creator can even create mp4 files out of MPEG 2 AAC files :confused:
    Yes it can. Here are some of the MPEG-2 and MPEG-4 audio profiles explained:
    MPEG-2 AAC LC
    MPEG-2 AAC Main = LC + Backward Prediction
    MPEG-4 AAC LC = MPEG-2 AAC LC
    MPEG-4 AAC Main = MPEG-2 AAC Main + PNS (optional)
    MPEG-4 AAC LTP = MPEG-4 AAC LC + LTP + PNS (optional)
    LC=Low Complexity
    LTP=Long Term Prediction
    PNS=Perceptual Noise Substitution (for very low bitrates)
    MP4Creator can also combine aac and MPEG4-video like DivX4 or XviD (http://www.videocoding.de/) to ISO MP4 stream..
    Juha Laaksonheimo
    I am more confused then a jackrabbit stuck in a snowstorm :confused:
    you see, I don't follow AAC, so the most I know about it, is that it exsists and it sounds pretty damn good.
    now I see this news post and, cool, mp4 is out (which i have known was in the works for a while) but there is all this talk about AAC this and MP4 AAC that.
    What the heck is going on?  I though MP4 and AAC were two seperate things :confused:
    (((10 bucks says Somebody answers my question )))
    MP4 is actually a name for the file format, MPEG-4 File Format (M4FF)
    MPEG-4 file format is designed to be container for audio, visual and systems part of MPEG-4 standard, which means that you can:
    1. Put audio tracks in .mp4 file
    2. Put video tracks in .mp4 file
    3. Put still image tracks in .mp4 file (JPEG2000/MPEG-4 WTC)
    4. Put BIFS/MPEG-4 systems information
    Audio object types supported are MPEG-4 audio object types:
    AAC (Main, LC, SSR, Error Resilient, Low Delay, Scalable...), TwinVQ (VQF), CELP (Speech Codec), Synthetic Audio (similar to midi/wavetable) and even PCM data - you can put as many audio objet tracks as you want...
    Video Object types are MPEG-4 profiles (Simple, Advanced Simple, Scalable, etc...)
    So, MP4 is more general than AAC...
    What type of AAC object is created by the aacenc encoder?
    aacenc could create LC, Main and LTP profiles (although Main is buggy at the moment)
    Yes, Ivan also said to me that he recommends the use of LC-profile with MP4 streams, because it's the only profile supported by hardware devices (at least at the moment).
    Of course multi-channel audio is also possible.
    Juha Laaksonheimo
    What about Ogg? Can we mux divx/ogg with this thingie?
    It could be possible in principle to mux Vorbis stream into mp4 container format, but then it wouldn't be anymore ISO compatible MP4-stream, and it would need specific support.
    I'm not 100% sure though if it would be possible or not.
    Juha Laaksonheimo
    When you use aacenc -normal to encode a file, what kind of profile does that use? I don't know enough to select any of the other switches.
    -normal uses LC-profile. Encoder displays "(AAC Profile: Low Complexity)".
    If you add -profile 1 switch, you'll see the encoder says "(AAC Profile: Main)"
    If you use -profile 2 instead, you'll see it uses LTP.
    Juha Laaksonheimo
    I believe LC is defaulted on all VBR presets.
    The only way to override would be using -profile 1 (Main) or -profile 2 (LTP)
    Edit: Damn! JohnV was faster than me
    I will try muxing a divx with an oggvorbis file and i'll get back to you.
    I hope it will work.
    Hmmmm ..... now for those amongst us that are a bit slower, like i am  ..... if the powerdivx.com team ( means BlackSun  ) decided to have MPEG4 support for PowerDivX player ..... what about the licensing issue ?
    I thought MPEG4 is a proprietary format ? Did i miss something ??
    Well, MPEG-4 file format is patented, too - Apple holds patents for the file format. However, as I see - they (Apple) offer their MPEG-4 streaming server as opensource package, so I am not sure what kind of licensing they wish to apply there...
    Will/does MPEG4 have an official tagging system (Maybe Quicktime system)?
    It would be great, to avoid the messy problems we have with ID3v1/2
    Well, since the MPEG4 file format is the QuickTime file format, I would assume that they're going to do a complete QuickTime implementation, including the metadata features.  But that's just a guess.
    Right, did anybody try this?
    I tried creating a stream from a divx video i have encoded.
    The command line was:
    mp4creator.exe -create=hayes.divx -verbose test.mp4
    It did not produce any errors. However the output file was 1.939 bytes big and i couldnt play it in the player ofcourse.
    The divx file was 23mb and was encoded using 2-pass encoding.
    Tried the same but with an MP3 file and everything worked fine.
    Any feedback?
    Hm...
    I tried putting .avi instead of .divx and i got this error:
    Write: type ftyp
    Write:  majorBrand = isom
    Write:  minorVersion = 0 (0x00000000)
    Write: Write: finished ftyp
    mp4creator.exe: can't open ev.avi: avilib - Error reading from AVI file - No such file or directory
    the .avi was there though.... do we need something like a raw divx stream? how could we do that?
    Maybe HEX-editing the AVI file...
    Perhaps you could give a hand on this one? I am not really familiar with Hexedit....
    everwicked: I got the same problem as you when trying to use an avi file.
    The project forum had some info on this: http://sourceforge.net/forum/forum.php?forum_id=122286
    For those who have been generating Divx/MP3 AVI files with tools such as VirtualDub, you can now easily convert those to MP4 files with version 0.9 of MPEG4IP.
    Here's how:
    $ mp4creator -c mydivx.avi -H -O mydivx.mp4
    The -H option adds the hint tracks so the file can be streamed.
    The -O option optimizes the data layout for maximum server performance. It also allows HTTP streaming of the mp4 file.
    I tried the above suggestion but to no avail. Maybe it works using the Linux version :confused:
    BTW What version # is this?
    Just tried it with a muxed video instead of trying muxing too.
    Gave different error:
    D:My Documentsmp4creator>mp4creator.exe -c ev.avi -H -O mydivx.mp4
    Write: type ftyp
    mp4creator.exe: can't open Isaac Hayes - Shaft.avi: avilib - Error reading from
    Now it find the AVI but can't read?
    Somebody debug us
