0.6.0.006 released. Lots of little changes that you can see and use. Lots of big changes behind the scenes that make it easer to update the plugin.
http://gelaed.com/resources/cplusplus/foo_shizzle.zip
[0.6.0.006]
Changed:
Major changes "under the hood"
Changed:
New layout for the config window.
Fixed: No more annoying "please close search/config window" popups
Added: results list font is now selectable
Added: Search Window context menu
Added: "Remove from database" to context menu
Added: "Activate search window" button
Changed:
Preferences are now saved as soon as they are changed, rather than when
the config window is destroyed. To apply the new settings to the search
window, click the refresh button, or close and re-open the window.
Added: search window now has a refresh button
Fixed: slightly less flicker on resizing
Changed:
Resized search window buttons.
Added: Text in quotation marks (in both the "search in" and the "search for"
fields) is now considered to be a single token. Now it's possible to
search in "recording engineer" for "Ibbetson, Adrian", as opposed to
searching "recording" and "engineer" for "Ibbetson," and/or "Adrian".
Added: Remember window placement option.
Added: "Display results as paths when searching in paths" option
Fixed: Searching for "file://" in paths no longer returns all database entries
Fixed: Minor tabbing glitch in search window
Changed:
Context menu has more friendly behavior now.
